  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 768.3k Views 27 Watching
  • NeverDieN
    NeverDieN
    #681
    Yup, I just now did a spark test on the old rods, and the result is conclusive: definitely aluminum. I should probably replace the z-axis rails as well.
    • NeverDieN
      NeverDieN
      #682
      Epilog: Definitely much less vibration in the CNC now that the x-axis rods have been replaced with steel rods. I've ordered y-axis and z-axis steel rods, so I plan to replace those as well. Hopefully doing so will damp the vibration even further.
      • NeverDieN
        NeverDieN
        #683
        I just now ran across z-axis tape, which may prove to be a God send for using any of the 6mil isolation routed PCB's that I might make on this PCB etcher. The problem I was having with such isolation routed boards was: no solder mask! So, soldering parts to the boards just wasn't working for me, and I had fallen back to producing boards with much larger isolation widths. However, it appears that with 3M's z-axis tape, I can just tape the SMD parts down onto the board, with no soldering required!
        Amazing! From my perspective, it's downright revolutionary:
        https://www.adafruit.com/product/1656
        YveauxY 1 Reply Last reply
        • NeverDieN NeverDie
          YveauxY
          YveauxY
          @neverdie Interesting stuff! I didn't know it existed.
          I saw a sparkfun youtube video in which they use it to tape down an ATMega TQFP instead of soldering it, but they keep it pressed down during the demo.
          So, do you think it can also be used to mount chips?
          NeverDieN 1 Reply Last reply
          • YveauxY Yveaux
            NeverDieN
            NeverDieN
            @yveaux said in CNC PCB milling:
            Yes! One of my favorite youtubers shows it being done at time index 1:00 on:
            https://www.youtube.com/watch?v=0uPZwMg5B3k
            • NeverDieN
              NeverDieN
              Anyone know whether it is possible to etch some or all of the silkscreen onto the PCB? I've tried some googling, and I haven't found any leads on how to do it using flatcam.
              E dbemowskD 2 Replies Last reply
                E
                E
                executivul
                @neverdie http://caram.cl/software/flatcam/tracing-the-silkscreen-with-flatcam/
                  dbemowskD
                  dbemowskD
                  @neverdie What about using toner transfer paper and ironing it on. Just print it reversed on a sheet, cut it out and iron it on. If you use a color laser you could do something other than black. Obviously you won't get white like a lot of fabs use, but I would think it would be good enough.
                  • E executivul
                    NeverDieN
                    NeverDieN
                    @executivul said in CNC PCB milling:
                    Have you tried it? i.e. Do you know if it works, or is it a blind reference?
                    dbemowskD E 2 Replies Last reply
                    • NeverDieN
                      NeverDieN
                      #690
                      Here's a very impressive looking demo of PCB etching:
                      https://www.youtube.com/watch?v=cwE3FqRb8Zg
                      I checked the machine specs, and it's a maximum of 11,000RPM on a brushless spindle . That's very encouraging.
                        dbemowskD
                        dbemowskD
                        @neverdie I never used it to do silkscreening, but years ago I made a few PCBs to try a sheet out. It worked okay. I had some gaps in some traces on some the boards. That may have been from me not cleaning the board well enough before doing the transfer.
                        • dbemowskD dbemowsk
                          NeverDieN
                          NeverDieN
                          @dbemowsk Since the etching has to work (else there will be no PCB), I'd rather keep it within that domain if possible. Wegstr's lettering (above) looks very nice.
                            E
                            E
                            executivul
                            @neverdie said in CNC PCB milling:
                            I've done it a few times, be careful though you don't cut your traces with the silkscreen :)
                            I use the tracing option all the time for custom cutouts when panelising boards, generate cutout paths in Altium and trace in Flatcam.
                            • NeverDieN
                              NeverDieN
                              #694
                              My Prusa i3 Mk3 still hasn't shipped due to production delays, and so I haven't been able to mount the new spindle yet on my PCB etching mill. Meanwhile, it looks as though the existing setup may just barely be good enough for etching pads for the atmega328p SMD. By using lots of rosin flux, it looks like I can solder to it without unresolvable solder bridges.
                              dbemowskD 1 Reply Last reply
                              • NeverDieN
                                NeverDieN
                                Also, I received a TMC2130 stepper driver, so I'll be auditioning that fairly soon:
                                Supposedly it is a bit more precise, and so that may help also. If it pans out, then I'll order TMC2130's for the Y and Z axis also.
                                  dbemowskD
                                  dbemowskD
                                  @neverdie Here is an interesting approach that might work, but it requires etching.
                                  https://www.youtube.com/watch?v=sNh0ubRcTYU
                                    NeverDieN
                                    NeverDieN
                                    @dbemowsk Using a laser is another way:
                                    https://www.youtube.com/watch?v=gm5P74vcB84
                                    • NeverDieN
                                      NeverDieN
                                      #698
                                      Good news! This guy has identified what may be the ultimate stepper motor driver for CNC:
                                      https://www.youtube.com/watch?v=p4ltHDpxrbI
                                      And he says that by pairing it with your own mosfets, you can send up to 20amps to your stepper motor. Taken altogether, this sounds like a really good setup to me. :)
                                      I assume that with this gear you can just tell the motor to go at maximum speed all the time and let it decide (through monitoring) what that speed should be. No more underperformance or endless tuning of parameters.
                                      • coddingtonbearC coddingtonbear
                                        @neverdie Congratulations on your purchase! I think you'll find having a real spindle will help a ton.
                                        If you haven't designed your own mount, you might want to check out the part I posted on Thingiverse the other day: https://www.thingiverse.com/thing:2817974 .
                                        NeverDieN
                                        NeverDieN
                                        @coddingtonbear said in CNC PCB milling:
                                        I'm finally able to print this. Is 20% infill OK, or does it need to be completely solid?
                                          dbemowskD
                                          dbemowskD
                                          @neverdie IMHO I wouldn't think you would need it completely solid. make sure your side walls are thick enough though. I would use 1mm or more for strength. That's just my opinion though.
