  3. How to setup mqtt gateway not from predified constants?
5 Posts 3 Posters 1.2k Views 3 Watching
  • S Offline
    Stas Dovgodko
    I'm using esp sketch with web-configured mqtt options. How I can feed it to MS gateway?
      That would quite a challenge.... What did you had in mind?
      S 1 Reply Last reply
      • S Offline
        wrote on last edited by scalz
        @Stas-Dovgodko
        would that do the job ?
        #MY_MQTT_DEFINE_I_WANT_VARIABLE myMqttVariable
        then use the myMqttVariable in your sketch
          Stas Dovgodko
          wrote on last edited by Stas Dovgodko
          @gohan Yeah, just rewrote lib a lot of ) For now subscribe working but not publishing. This would be configurable (just like sonoff for example) gateway with wifi-portal (ap) and configurable wifi/mqtt options from web interface
          • S scalz
            @Stas-Dovgodko
            Stas Dovgodko
            @scalz No. But this in mysensor lib does :) :
            extern PubSubClient MQTTClient;
            extern WiFiClient wclient;
