  3. Garage door status sensors ideas
doorgaragesensor
27 Posts 11 Posters 8.8k Views 8 Watching
  • I iahim67
    Hi, maybe you can use the reed switch in a different way, I mean do not use it like contact closed or contact opened as this would cause you overshoot issues.
    When the magnet attached to the door slides in front of the reed switch, then you'll have the reed switch closed for a short time at least, most likely, you can test that. You can use the reed just like you would use a motion detector.
    I mean connect the reed to pin 3 - interrupt - and put this at the end of your code, so when an interrupt occurs you will know the door has moved (and you can keep track of movement of course so you would know if the door is open or close) ... just an idea ... :
    sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    @iahim67 That is a creative option.
    • Tim Nagy183T Offline
      Tim Nagy183
      Couldn't you just use a proximity sensor mounted to the ceiling. That way you can see if the door is up, or if something is parked there, or if the door is down with nothing parked there - all based on the measured distance.
        Remember that if you have a battery powered node, try to find normally closed reed switches as they will not drain battery as the magnet will keep the reed switch open.
        • I Offline
          I Offline
          iahim67
          @dbemowsk Thank you :smile:
          To be a bit more creative I think, @McQueen you can use the interrupt as RISING at the end of your code like this:
          sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), RISING, SLEEP_TIME);
          The goal is to set a flag in your main loop every time you get an interrupt and then put this flag in the EEPROM, use the Relay Actuator sketch example again to see how to do that:
                  // Store state in eeprom
          And read the flag from the EEPROM like this:
          This way you'll know the status of your door. This only works however is during the magnet slide you get just one interrupt trigger, that you can check for yourself, use Arduino itself to print out how many times you get interrupted while closing the door or opening the door. Hope it helps ...
          gohanG 1 Reply Last reply
          • I Offline
            I Offline
            iahim67
            If you get interrupted by the magnet several times during closing or opening the door then you can eventually debounce ...
            • I iahim67
              @iahim67 that's a little overkill, just do debounce and you should be fine. Even if you get multiple interrupts, what would it be the problem? It will just report door open or closed a few times.
              • I Offline
                I Offline
                iahim67
                That's right @gohan , if you place the "door closed"reed near the floor then only first interrupt should matter, first interrupt should tell you the door is closed. Same for a second reed placed high - the "door open" reed, that would tell you the door is open when interrupted the first time. @McQueen, could be close to you needs ...
