  3. Arduino mini pro 3.3 battery optimization code
23 Posts 6 Posters 5.0k Views 5 Watching
  • T
    Tommas
    wrote on last edited by Tommas
    Dear All!
    I would like to use the Arduino Mini Pro 3.3 8Mhz (aTMega328) with 2xAA battery. I have read that it useful to put it in powerdown/sleep mode.
    Could you help me what code/sketch should I use. I copied to here my beta sketch(It works, but it doesnt have the powerdown function)
    If someone has any other suggestion related to the code, please write it!
     * Version 1.0: Henrik EKblad
    #define MY_NODE_ID 6
    // Enable debug prints
    //#define MY_RS485
    /* Sketch with Si7021 and battery monitoring.
    by m26872, 20151109
    #include <Wire.h>
    #include <SI7021.h>
    #include <RunningAverage.h>
    #include <BH1750.h> //BH1750
    #define DEBUG
    #ifdef DEBUG
    #define DEBUG_SERIAL(x) Serial.begin(x)
    #define DEBUG_PRINT(x) Serial.print(x)
    #else
    #define MOTION_DIGITAL_INPUT_SENSOR 3 //MOTION
    #define NODE_ID 6             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    #define CHILD_ID_LIGHT 2 //BH1750
    #define CHILD_ID_MOTION 3 /*MOTION*/
    //BATTERY
    uint32_t SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
    //#define SLEEP_TIME 15000 // 15s for DEBUG
    #define SLEEP_TIME 10000   // 5 min
    //#define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
    #define FORCE_TRANSMIT_CYCLE 1  // 5min*12=1/hour, 5min*36=1/3hour
    //#define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
    //#define VMIN 1900
    //#define VMAX 3300
    #define HUMI_TRANSMIT_THRESHOLD 3.0  // THRESHOLD tells how much the value should have changed since last time it was transmitted.
    #define TEMP_TRANSMIT_THRESHOLD 0.5
    #define AVERAGES 2
    //int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
    int measureCount = 0;
    float lastTemperature = -100;
    int lastHumidity = -100;
    uint16_t lastlux; //BH1750
    RunningAverage raHum(AVERAGES);
    SI7021 humiditySensor;
    BH1750 lightSensor;
    //MySensor gw;
    MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP); // Initialize temperature message
    MyMessage msgHum(CHILD_ID_HUM,V_HUM);
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); //BH1750
    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED); //MOTION
    void presentation(){
    sendSketchInfo("Node 6, Temp,Hum,Light,Motion", "1.1");
      present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); //BH1750
      present(CHILD_ID_MOTION, S_MOTION); /*MOTION*/
    //BATTERY
    sendSketchInfo("Battery Meter", "1.0");
      //BATTERY
        analogReference(INTERNAL1V1);
    #else
        analogReference(INTERNAL);
    //BATTERY
      DEBUG_SERIAL(115200);
      DEBUG_PRINTLN("Serial started");
      //DEBUG_PRINT("Voltage: ");
      //DEBUG_PRINT(readVcc());
      //DEBUG_PRINTLN(" mV");
      delay(500);
      DEBUG_PRINT("Internal temp: ");
      DEBUG_PRINT(GetInternalTemp()); // Probably not calibrated. Just to print something.
      DEBUG_PRINTLN(" *C");
      delay(500); // Allow time for radio if power useed as reset
      //begin(NULL,NODE_ID);
      //DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
      raHum.clear();
      lightSensor.begin(); //BH1750
      /* MOTION */
      pinMode(MOTION_DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
      DEBUG_PRINTLN("Loop started");
      measureCount ++;
      bool forceTransmit = true;
      //if (measureCount > FORCE_TRANSMIT_CYCLE) {
      //forceTransmit = true;
      sleep(SLEEP_TIME);
      //BATTERY
    // get the battery Voltage
    #ifdef MY_DEBUG
        Serial.println(sensorValue);
    #ifdef MY_DEBUG
        float batteryV  = sensorValue * 0.003363075;
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
            // Power up radio after sleep
            oldBatteryPcnt = batteryPcnt;
      //BATTERY
      //BH1750
        uint16_t lux = lightSensor.readLightLevel();// Get Lux value
        Serial.println(lux);
        DEBUG_PRINT("LUX: ");DEBUG_PRINTLN(lux);
        if (lux != lastlux) {
            send(msgLight.set(lux));
            lastlux = lux; }
      //BH1750
      /* MOTION */
      // Read digital motion value
      bool tripped = digitalRead(MOTION_DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
      DEBUG_PRINTLN("Loop ended");
     * * Sends temperature and humidity from Si7021 sensor
     * Parameters
     * - force : Forces transmission of a value (even if it's the same as previous measurement)
    void sendTempHumidityMeasurements(bool force) {
      bool tx = force;
      DEBUG_PRINTLN("Send TEMP and HUM started");
      si7021_env data = humiditySensor.getHumidityAndTemperature();
      float temperature = data.celsiusHundredths / 100.0;
      DEBUG_PRINT("T: ");DEBUG_PRINTLN(temperature);
      float diffTemp = abs(lastTemperature - temperature);
      DEBUG_PRINT(F("TempDiff :"));DEBUG_PRINTLN(diffTemp);
      //if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
      //lastTemperature = temperature;
      //measureCount = 0;
      DEBUG_PRINTLN("T sent!");
      int humidity = data.humidityPercent;
      DEBUG_PRINT("H: ");DEBUG_PRINTLN(humidity);
      raHum.addValue(humidity);
      humidity = raHum.getAverage();  // MA sample imply reasonable fast sample frequency
      float diffHum = abs(lastHumidity - humidity);
      DEBUG_PRINT(F("HumDiff  :"));DEBUG_PRINTLN(diffHum);
      //if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
      //lastHumidity = humidity;
      //measureCount = 0;
      DEBUG_PRINTLN("H sent!");
    Thank you in advance!!
    gohanG sundberg84S T 4 Replies Last reply
    • T Tommas
      Dear All!
      //#define MY_RS485
      by m26872, 20151109
      #include <Wire.h>
      #include <SI7021.h>
      #define DEBUG
      #ifdef DEBUG
      #else
      //BATTERY
      //#define VMIN 1900
      //#define VMAX 3300
      #define AVERAGES 2
      BH1750 lightSensor;
      //MySensor gw;
      //BATTERY
        //BATTERY
      #else
      //BATTERY
        delay(500);
        raHum.clear();
        /* MOTION */
        measureCount ++;
        sleep(SLEEP_TIME);
        //BATTERY
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
        //BATTERY
        //BH1750
              lastlux = lux; }
        //BH1750
        /* MOTION */
       * Parameters
        bool tx = force;
        //measureCount = 0;
        //measureCount = 0;
      wrote on last edited by gohan
      @tommas said in Arduino mini pro 3.3 battery optimization code:
      sleep(SLEEP_TIME);
      That is the power down command, usually it is put at the end of loop
      T 1 Reply Last reply
      • T Tommas
        Dear All!
        //#define MY_RS485
        by m26872, 20151109
        #include <Wire.h>
        #include <SI7021.h>
        #define DEBUG
        #ifdef DEBUG
        #else
        //BATTERY
        //#define VMIN 1900
        //#define VMAX 3300
        #define AVERAGES 2
        BH1750 lightSensor;
        //MySensor gw;
        //BATTERY
          //BATTERY
        #else
        //BATTERY
          delay(500);
          raHum.clear();
          /* MOTION */
          measureCount ++;
          sleep(SLEEP_TIME);
          //BATTERY
        #ifdef MY_DEBUG
        #ifdef MY_DEBUG
          //BATTERY
          //BH1750
                lastlux = lux; }
          //BH1750
          /* MOTION */
         * Parameters
          bool tx = force;
          //measureCount = 0;
          //measureCount = 0;
        @tommas - have a look at the build section: https://www.mysensors.org/build/battery
        • sundberg84S sundberg84
          Tommas
          @sundberg84
          Oh ok. I have put this in the code, so it is OK, i think. I thought that SLEEP_TIME isnt equal to powerdown, but it seems that i misunderstood.
          I use your easypcb board Sundberg.... Is your battery measurement code better than this standard mysensors one?
          Thank You again!
            sleep(SLEEP_TIME);
            Tommas
            @gohan
            Dear Gohan!
            Thank you! I thought that it isnt equal with this: https://www.mysensors.org/download/sensor_api_20#sleeping ....
            But perhaps I misunderstood something because you says that it is the same sleep mode...
              SLEEP_TIME is defined as the amount of time the node will sleep, but it is the function sleep() that actually puts the node into low power mode and that usually is at the end of loop
              • T Tommas
                @sundberg84
                Thank You again!
                @tommas - "my" batterycode is due to a booster and a voltage divider. Its not possible to compare this to @Yveaux Vcc library which uses the internal vcc to measure battery level. This is not possible to use since you boost your VCC on the arduino. I think my code works great though for a voltage divider setup.
                G 1 Reply Last reply
                • T
                  Tommas
                  Hi All!
                  Im near to get it work:) .
                  Someone could write an example openhab2 thing and item for Battery Voltage handling?
                  Thank you!
                    G
                    G
                    ghiglie
                    @sundberg84 said in Arduino mini pro 3.3 battery optimization code:
                    Sorry, I'm revisiting a temp/hum sensor running on battery, I lost my code so I'm back to work with this (and signing/encryption, doh!)
                    I think I have something similar to yours- I'm boosting the arduino and DHT voltage to 3,3v, while the antenna is directly connected. I have a voltage divider where I get the Voltage measure. Can I borrow directly your code, you think?
                    atmega328p serial killer
                    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                    • G ghiglie
                      @ghiglie - you can, as long as you have the same divider... (which is the standard divider found @ mysensors website.)
                      // BATTERY MEASURER
                      // VOLTAGE DIVIDER SETUP
                      #define VBAT_PER_BITS 0.003363075
                      If not you need to recalculate,
                      • T Tommas
                        Dear All!
                        //#define MY_RS485
                        by m26872, 20151109
                        #include <Wire.h>
                        #include <SI7021.h>
                        #define DEBUG
                        #ifdef DEBUG
                        #else
                        //BATTERY
                        //#define VMIN 1900
                        //#define VMAX 3300
                        #define AVERAGES 2
                        BH1750 lightSensor;
                        //MySensor gw;
                        //BATTERY
                          //BATTERY
                        #else
                        //BATTERY
                          delay(500);
                          raHum.clear();
                          /* MOTION */
                          measureCount ++;
                          sleep(SLEEP_TIME);
                          //BATTERY
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                          //BATTERY
                          //BH1750
                                lastlux = lux; }
                          //BH1750
                          /* MOTION */
                         * Parameters
                          bool tx = force;
                          //measureCount = 0;
                          //measureCount = 0;
                        Tommas
                        @tommas
                        Dear All!
                        Can I use 2xAA 1.6V NiZn battery for 3.3V arduino mini pro?
                        NeverDieN gohanG 2 Replies Last reply
                        • T Tommas
                          @tommas
                          Dear All!
                          NeverDieN
                          NeverDieN
                          @tommas
                          Dear All!
                          Accoding to wikipedia, at 100% SOC each cell would deliver 1.85V, which is a smidge too high if running the pro mini with its voltage regulator removed. Well, actually, the pro mini would tolerate it, just maybe not the radio.
                          • T Tommas
                            @tommas
                            Dear All!
                            @tommas get some LiFePo4 AA and you can use a single cell
                            • NeverDieN NeverDie
                              @tommas
                              Dear All!
                              Tommas
                              Dear @neverdie ,
                              Ok, so I wont use these batteries.
                              • T Tommas
                                Dear All!
                                //#define MY_RS485
                                by m26872, 20151109
                                #include <Wire.h>
                                #include <SI7021.h>
                                #define DEBUG
                                #ifdef DEBUG
                                #else
                                //BATTERY
                                //#define VMIN 1900
                                //#define VMAX 3300
                                #define AVERAGES 2
                                BH1750 lightSensor;
                                //MySensor gw;
                                //BATTERY
                                  //BATTERY
                                #else
                                //BATTERY
                                  delay(500);
                                  raHum.clear();
                                  /* MOTION */
                                  measureCount ++;
                                  sleep(SLEEP_TIME);
                                  //BATTERY
                                #ifdef MY_DEBUG
                                #ifdef MY_DEBUG
                                  //BATTERY
                                  //BH1750
                                        lastlux = lux; }
                                  //BH1750
                                  /* MOTION */
                                 * Parameters
                                  bool tx = force;
                                  //measureCount = 0;
                                  //measureCount = 0;
                                Tommas
                                @tommas
                                I did a new code, and it seems that it is do the job.
                                My goal was, that I only send the battery voltage (percent) when:
                                At least one of sensor value transmission occured + The battery report time is elapsed.
                                What do you think about my code? IT IS NOT ONLY MY CODE and it is not clear yet Thank for @gohan , @sundberg84 and mysensors for the base.
                                //#define MY_RS485
                                #include <Wire.h>
                                #include <SI7021.h>
                                #include <Math.h>
                                #define DEBUG
                                #ifdef DEBUG
                                #else
                                #define CHILD_ID_VBAT 254
                                /*BATTERY*/
                                // BATTERY MEASURER
                                #define VMIN 2.1                                  //  Vmin (radio Min Volt)=1.9V (564v)
                                #define VMAX 3.1                                  //  Vmax = (2xAA bat)=3.0V (892v)
                                int batteryPcnt = 0;                              // Calc value for battery %
                                int battAveragePcnt;
                                int battSumPcnt = 0;
                                float VbatAverage=0;
                                float VbatSum=0;
                                /*BATTERY*/
                                //#define SLEEP_TIME 180000   // 3 min
                                //#define FORCE_TRANSMIT_CYCLE 10  // SLEEP_TIME*FORCE_TRANSMIT_CYCLE=Mindenképp küldi az értéket (Temp+HUM), különben akkor ha HUMI_TRANSMIT_THRESHOLD vagy TEMP_TRANSMIT_THRESHOLD igaz,
                                //#define BATT_MEASURE_CYCLE 10   // SLEEP_TIME/1000*BATTERY_Measure_CYCLE=Ennyi időnként Veszünk mintát (BATTERY)
                                //#define BATT_REPORT_CYCLE 15   // SLEEP_TIME/1000*BATTERY_REPORT_CYCLE=Ennyi időnként küldi az értéket (BATTERY)
                                #define SLEEP_TIME 300000   // 15sec
                                #define FORCE_TRANSMIT_CYCLE 24  // 30sec SLEEP_TIME*FORCE_TRANSMIT_CYCLE=Mindenképp küldi az értéket (Temp+HUM), különben akkor ha HUMI_TRANSMIT_THRESHOLD vagy TEMP_TRANSMIT_THRESHOLD igaz,
                                #define BATT_MEASURE_CYCLE 2   // Hányszor vegyünk mintát a küldés előtt
                                #define BATT_REPORT_CYCLE 60     // SLEEP_TIME/1000*BATTERY_REPORT_CYCLE*2=Ennyi időnként küldi az értéket (BATTERY)
                                #define LUX_TRANSMIT_THRESHOLD 10
                                #define AVERAGES 2
                                int battreportCount=-2;
                                int lastLux = 0; //BH1750
                                boolean transmission_occured = false;
                                BH1750 lightSensor;
                                //MySensor gw;
                                MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE); //BH1750
                                sendSketchInfo("Node 6, Temp,Hum,Light", "1.1");
                                  present(CHILD_ID_VBAT, S_MULTIMETER); //BH1750
                                  raHum.clear();
                                  /*BATTERY*/
                                  // BATTERY MEASURER
                                  //Set internal ref to internal to be able to measure bat 0-1v
                                  //Make sure this fits other sensors using analogRead()!
                                  //If you have a sensor reporting 0-5v you need to change analogReference() before reading that sensor.
                                  //DEFAULT: the default analog reference of 5 volts (on 5V Arduino boards) or 3.3 volts (on 3.3V Arduino boards)
                                  //INTERNAL: an built-in reference, equal to 1.1 volts on the ATmega168 or ATmega328 and 2.56 volts on the ATmega8 (not available on the Arduino Mega)
                                  //EXTERNAL: the voltage applied to the AREF pin (0 to 5V only) is used as the reference.
                                  //Battery inital calc
                                  Serial.print("With Battery VMax (100%) = "); Serial.print(VMAX); Serial.print("volts and Vmin (0%) = "); Serial.print(VMIN); Serial.println(" volts");
                                  Serial.print("Battert Percent 25%/50%/75% should be: "); Serial.print(((VMAX - VMIN) / 4) + VMIN); Serial.print("/"); Serial.print(((VMAX - VMIN) / 2) + VMIN); Serial.print("/"); Serial.println(VMAX - ((VMAX - VMIN) / 4));
                                  delay(500);
                                  delay(50);
                                  float Vbat  = sensorValue * VBAT_PER_BITS;
                                  int batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN)) * 100.);
                                  Serial.print("Current battery are measured to (please confirm!): "); Serial.print(batteryPcnt); Serial.print(" % - Or "); Serial.print(Vbat); Serial.println(" Volts");
                                  /*BATTERY*/
                                  boolean forceTransmit = false;
                                  battreportCount ++;
                                  measureCount ++;
                                  if (measureCount == FORCE_TRANSMIT_CYCLE) {
                                  measureCount = 0;
                                  sendLightMeasurements(forceTransmit);
                                  Serial.print("battreportCount");Serial.println(battreportCount);
                                    /*BATTERY*/
                                    // BATTERY MEASURER
                                    if(((transmission_occured) && (battreportCount>=BATT_REPORT_CYCLE)) || (battreportCount == -1)){
                                            Serial.print("----BATTERY SEND/Measure CYCLE---- ");
                                            MeasureBattery();
                                            send(msgVBat.set(VbatAverage, 3));
                                            sendBatteryLevel(battAveragePcnt);
                                            Serial.print("Battery Average (Send): "); Serial.print(battAveragePcnt); Serial.println(" %");
                                            Serial.print("Battery Average Voltage (Send): "); Serial.print(VbatAverage); Serial.println(" V");
                                            battreportCount=0;
                                            battAveragePcnt=0;
                                            VbatAverage=0;
                                            VbatSum=0;
                                            battSumPcnt=0;
                                            measureCount=0;
                                  /*BATTERY*/
                                  sleep(SLEEP_TIME);
                                 * Parameters
                                  bool tx = force;
                                    DEBUG_PRINTLN("TEMP sent!");
                                    transmission_occured = true;
                                    DEBUG_PRINTLN("HUM sent!");
                                //BH1750
                                void sendLightMeasurements(bool force){
                                    bool tx = force;
                                    int lux = lightSensor.readLightLevel();// Get Lux value
                                    float diffLux = abs(lastLux - lux);
                                    //Serial.println(lux);
                                    DEBUG_PRINT("LuxDiff: ");DEBUG_PRINTLN(diffLux);
                                    if (diffLux > LUX_TRANSMIT_THRESHOLD || tx) {
                                      lastLux = lux;
                                      DEBUG_PRINTLN("LUX sent!");
                                //BH1750
                                /*BATTERY*/
                                // BATTERY MEASURER
                                void MeasureBattery() //The battery calculations
                                 if (batteryPcnt > 100) {
                                     batteryPcnt = 100;
                                      for (int i = 1 ; i <= BATT_MEASURE_CYCLE; i++)
                                        delay(500);
                                        // Battery monitoring reading
                                        delay(500);
                                        // Calculate the battery in %
                                        Serial.print("I: ");Serial.println(i);
                                        Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.print(" %"); Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" Volts");
                                        battSumPcnt += batteryPcnt;
                                        Serial.print("battSumPcnt:::");Serial.println(battSumPcnt);
                                        battAveragePcnt = battSumPcnt / i;
                                        VbatSum += Vbat;
                                        VbatAverage = VbatSum / i;
                                        Serial.print("battAveragePcnt Calculated: ");Serial.println(battAveragePcnt);
                                /*BATTERY*/
                                • T Tommas
                                  @tommas
                                  //#define MY_RS485
                                  #include <Wire.h>
                                  #include <SI7021.h>
                                  #include <Math.h>
                                  #define DEBUG
                                  #ifdef DEBUG
                                  #else
                                  /*BATTERY*/
                                  // BATTERY MEASURER
                                  float VbatSum=0;
                                  /*BATTERY*/
                                  #define AVERAGES 2
                                  BH1750 lightSensor;
                                  //MySensor gw;
                                    raHum.clear();
                                    /*BATTERY*/
                                    // BATTERY MEASURER
                                    delay(500);
                                    delay(50);
                                    /*BATTERY*/
                                    battreportCount ++;
                                    measureCount ++;
                                    measureCount = 0;
                                      /*BATTERY*/
                                      // BATTERY MEASURER
                                              MeasureBattery();
                                              battreportCount=0;
                                              battAveragePcnt=0;
                                              VbatAverage=0;
                                              VbatSum=0;
                                              battSumPcnt=0;
                                              measureCount=0;
                                    /*BATTERY*/
                                    sleep(SLEEP_TIME);
                                   * Parameters
                                    bool tx = force;
                                  //BH1750
                                      bool tx = force;
                                        lastLux = lux;
                                  //BH1750
                                  /*BATTERY*/
                                  // BATTERY MEASURER
                                       batteryPcnt = 100;
                                          delay(500);
                                          delay(500);
                                          VbatSum += Vbat;
                                  /*BATTERY*/
                                  Tommas
                                  @tommas
                                  Should I use any other sleep "code"? How I know that the nrf24L01 go to sleep?
                                  gohanG 1 Reply Last reply
                                    Tommas
                                    @gohan said in Arduino mini pro 3.3 battery optimization code:
                                    LiFePo4 AA
                                    THank You! I will try!
                                    • T Tommas
                                      @tommas
                                      @tommas
                                      If you measure current while the node is sleeping, if it is in the range 6 to 20 uA you are good
                                        Tommas
                                        loop
                                        What kind of sleep is it? There are parameters out there. ADC_OFF and some and some... Is this sleep turn off adc?
                                          Just use the sleep () function, that's it
