  3. Combine a controller and a gateway in a raspberry pi
7 Posts 5 Posters 2.6k Views 6 Watching
  • M Offline
    M Offline
    McQueen
    Hi guys,
    I was wondering if it's possible to use a raspberry pi to be both a controller and a gateway at the same time. Specifically thinking of using hass.io as the controller.
    Has anyone tried this?
    Thanks.
      I read on the forum there should be a couple of users trying to get it working with Hass.io, but it is not ready yet
      • Alex BoykoA Offline
        Alex BoykoA Offline
        Alex Boyko
        This shield will help you
        gohanG 1 Reply Last reply
        • W Offline
          W Offline
          Wikibear
          I do this via Pimatic and Raspberry Pi 3
          • Alex BoykoA Alex Boyko
            @alex-boyko that's quite expensive when you can get away with just a couple of dollars
            • sburlotS Offline
              sburlotS Offline
              sburlot
              I use a Raspberry 3 that is a MySensors MQTT Gateway, a Domoticz Controller, a Mosquitto Broker and Node-Red. The Raspi has more power than needed. I even had InfluxDB+Grafana on this same Raspberry.
              The NRF24L01+ is connected directly to the pins. I have ordered a PCB to mount the NRF, but I haven't found the time to install it.
              The PCB:
              https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01
              • W Offline
                W Offline
                Wikibear
                BTW you can create an arduino gw and plugin via USB. I must do this 'cause I'm using Zwave.me gateway parallel and with stretch i get an error with both over GPIO.
                12.1k
