  3. 6/8 Buttons battery remote node
53 Posts 7 Posters 11.0k Views 8 Watching
    I would like to make a 6 or 8 buttons remote control (to control some lights and scenes) with NRF24 or RFM69 and be a battery powered node. Is there a clever way to handle interrupts on all the pins besides the usual 2 and 3?
    • N Offline
      N Offline
      You can :
      • use another IC that is not so cheap about external interrupts (ex: nrf5)
      • connect each button to pin 3 through a diode so your board will wake up, then check each input pin to know which button is pressed
      • use pin change interrupt, it works but you need to write your own sleep method as it's not in the options of the MySensors sleep
      • use an extender ic (for example sx150x but there are cheaper and easier to solder options) or a touch ic (for example mpr121) and use their interrupt pin to wake up your board, then retrieve data through I2C
      gohanG 1 Reply Last reply
      • N Nca78
        You can :
        @nca78 said in 6/8 Buttons battery remote node:
        I had the same thought, I just wanted to ask for other viable options. How is the power usage of the mpr121?
        N 1 Reply Last reply
          N Offline
          N Offline
          @gohan said in 6/8 Buttons battery remote node:
          Somewhere around 20uA.
          • N Offline
            N Offline
            I wonder if this would do what Gohan has in mind?
            https://www.aliexpress.com/item/Button-Keypad-3x4-module/32530917534.html?spm=2114.10010108.0.0.2d82a4e4IC03UP&traffic_analysisId=recommend_2049_1_83259_iswiall&scm=1007.12908.83259.0&pvid=19937069-0349-4cc8-8b2a-ca440c3537da&tpp=1
            Looks as though it needs just one analog pin to read the voltage and thereby infer which button was pressed. With luck, maybe all the voltages would be high enough to trigger the interrupt.
            • N Offline
              N Offline
              Here it is notionally for 4 buttons:
              It's a voltage divider. Structured like this, it could trigger the IRQ pin when a button is pushed, and the analog pin could read the voltage to determine which button it was.
              • N Offline
                N Offline
                By clever resistor selection, you can even shave a few resistors off the design:
                • N NeverDie
                  @neverdie I know, it is similar to the arduino examples for the classic flat numeric keypad, the problem would be how to trigger the interrupt to wake the mcu.
                    N Offline
                    N Offline
                    What problem? You trigger on the rising edge.
                    The other benefit is that it consumes no power unless a button is pushed.
                      On analog pin?
                      • N Offline
                        N Offline
                        Well, on an arduino, you could wire it to both the IRQ pin and an analog pin (see above schematic). On an nRF52832, you'd need only one pin.
                        D 1 Reply Last reply
                          Would it still be able to trigger interrupt even with all those resistors?
                            N Offline
                            N Offline
                            Try it. I don't see a problem with it, but if it were a problem, you'd just reduce all the resistor values proportionately.
                            • N Offline
                              N Offline
                              The nice thing is that since you'd be measuring the voltage relative to the voltage powering your arduino/mcu, even if the battery voltage were to decrease, you'd still get the correct value for the button pressed.
                              • N NeverDie
                                @neverdie said in 6/8 Buttons battery remote node:
                                Slightly off topic question. On the nRF5's, can any pin act as an interrupt?
                                • D dbemowsk
                                  N Offline
                                  N Offline
                                  @dbemowsk said in 6/8 Buttons battery remote node:
                                  IIRC, any GPIO can. I can't think of any exceptions. So, notionally, you would wake from the interrupt pin, then change it to be an analog pin and read the voltage from that.
                                  • N NeverDie
                                    N Offline
                                    N Offline
                                    I made a custom PCB to test the concept:
                                      Tomorrow I'll try to bring out the arduino numeric keypad and an old sketch I used with it and see what I can do
                                        N Offline
                                        N Offline
                                        Cool! I didn't know there was an official Arduino keypad.
                                        Here's mine:
                                        • N Offline
                                          N Offline
                                          It works. Connecting the output wires to A0 and D3, and running this script:
                                          #include <avr/sleep.h>
                                          void wake ()
                                            // cancel sleep as a precaution
                                            sleep_disable();
                                            // precautionary while we do other stuff
                                            detachInterrupt (1);
                                          }  // end of wake
                                            pinMode(A0,INPUT);
                                            Serial.begin(115200);
                                            Serial.println("Starting...");
                                            Serial.flush();
                                            uint16_t voltage;
                                            set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                                            sleep_enable();
                                            // Do not interrupt before we go to sleep, or the
                                            // ISR will detach interrupts and we won't wake.
                                            noInterrupts ();
                                            // will be called when pin D2 goes low
                                            attachInterrupt (1, wake, RISING);  //pin D3
                                            EIFR = bit (INTF1);  // clear flag for interrupt 1
                                            // turn off brown-out enable in software
                                            // BODS must be set to one and BODSE must be set to zero within four clock cycles
                                            MCUCR = bit (BODS) | bit (BODSE);
                                            // The BODS bit is automatically cleared after three clock cycles
                                            MCUCR = bit (BODS);
                                            // We are guaranteed that the sleep_cpu call will be done
                                            // as the processor executes the next instruction after
                                            // interrupts are turned on.
                                            interrupts ();  // one cycle
                                            sleep_cpu ();   // one cycle
                                            delay(100);  //debounce the button
                                            voltage=analogRead(A0);
                                            if (voltage>0) {
                                              Serial.println(voltage);
                                              Serial.flush();
                                          on a 3.3v Arduino pro mini yields these values for each of the four buttons:
                                          Starting...
                                          1023
                                          930
                                          852
                                          787
                                          The pro mini sleeps until one of the buttons gets pressed, then it wakes up, reads the value, displays the value, and then goes back to sleep. :)
                                          12.2k
