  3. 5v cable
5v cable
8 Posts 5 Posters 2.4k Views 4 Watching
  • D
    D
    Dragon
    Have a panel with a Nextion 3.2" screen and a Wemos D1. I need about 5m cable to feed this with 5v. Would it work with an network cable or phone cable or would this be too thin?
    • D Dragon
      @dragon according to https://nextion.itead.cc/resources/datasheets/nx4024k032_011/ the screen uses 85mA at full power. According to the same page, the minimum voltage is 4.75V.
      From http://oberoninc.com/images/WebDocs/Partner_Resources/IEEE 802_3af PoE document.pdf I found this:
      Typical Cat5e UTP has a 10ohm/100m conductor resistance
      So 5m of cat5e utp network cable would have 0.5 ohm resistance one-way, so 1 ohm there and back.
      The voltage drop for 85mA through a 1 ohm cable is 1 * 0.085 = 0.085V.
      So if you feed 5V to the cable, 0.085V will be lost in the cable and 4.915V will be available to the screen. This is more than the minimum required for the screen, so the cable will work.
      If the wemos needs to be powered through the cable as well, you'll need to add the power usage for the wemos to the calculations above.
      sundberg84S B 2 Replies Last reply
        @mfalkvidd that is what I call a great answer.
        • sundberg84S sundberg84
          Thanks @sundberg84 :)
            B
            B
            boozz
            @mfalkvidd
            and a simple 'trick' to allow higher currents if necessary:
            A network cable has 8 leads in it. Any spare pair of leads not used for something else (e.g. data....) can be used to increase the current strength of the 5V and return (GND) line.
            ben999B 1 Reply Last reply
            • B boozz
              @mfalkvidd
              ben999B
              ben999B
              ben999
              @boozz
              :scream: doubling cable = doubling resistance = doubling voltage drop
              :rolling_on_the_floor_laughing: sorry
              don't throw stones at me, it's only a joke :raised_hand_with_fingers_splayed:
              • D
                D
                Dragon
                Thanks!👍
                • ben999B ben999
                  @boozz
                  @ben999 doubling cable = doubling conductance. So you're almost right ;-)
