  3. Node unable to get ID from gateway. [2.2.0]
17 Posts 4 Posters 4.4k Views 5 Watching
  • Suresh MaliS
    Suresh MaliS
    Suresh Mali
    wrote on last edited by Suresh Mali
    I updated the gateway to 2.2.0. I have one sensor on 2.1.1 which able to communicate fine with my gateway. I tried testing a node on 2.2.0. I flash the MockMySensor sketch, but its not able to get a node ID from gateway. I also cleared EEPROM and replashed , tied to assign ID to node but did not help. The ID:4 we see in the gateway log is my node running on 2.1.1. Need help in understanding what could be the issue/fix. Thanks
    Logs from Node:
    6 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
    25 TSM:INIT
    26 TSF:WUR:MS=0
    33 TSM:INIT:TSP OK
    35 !TSF:SID:FAIL,ID=0
    37 TSM:FAIL:CNT=1
    38 TSM:FAIL:DIS
    40 TSF:TDI:TSL
    10042 TSM:FAIL:RE-INIT
    10044 TSM:INIT
    10051 TSM:INIT:TSP OK
    10053 !TSF:SID:FAIL,ID=0
    10055 TSM:FAIL:CNT=2
    10057 TSM:FAIL:DIS
    10059 TSF:TDI:TSL
    Logs from Gateway:
    Mar  6 15:51:47 myhome mysgw: GWT:RFC:C=0,MSG=0;0;3;0;18;PING
    Mar  6 15:51:57 myhome mysgw: GWT:RFC:C=0,MSG=0;0;3;0;18;PING
    Mar  6 15:52:06 myhome mysgw: TSF:MSG:READ,4-4-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Mar  6 15:52:06 myhome mysgw: TSF:MSG:BC
    Mar  6 15:52:06 myhome mysgw: TSF:MSG:FPAR REQ,ID=4
    Mar  6 15:52:06 myhome mysgw: TSF:PNG:SEND,TO=0
    Mar  6 15:52:06 myhome mysgw: TSF:CKU:OK
    Mar  6 15:52:06 myhome mysgw: TSF:MSG:GWL OK
    Mar  6 15:52:06 myhome mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    Mar  6 15:52:07 myhome mysgw: GWT:RFC:C=0,MSG=0;0;3;0;18;PING
    Mar  6 15:52:10 myhome mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    Mar  6 15:52:10 myhome mysgw: TSF:MSG:PINGED,ID=4,HP=1
    Mar  6 15:52:10 myhome mysgw: !TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    rejoe2R Suresh MaliS 3 Replies Last reply
    • Suresh MaliS Suresh Mali
      Logs from Node:
      25 TSM:INIT
      26 TSF:WUR:MS=0
      33 TSM:INIT:TSP OK
      37 TSM:FAIL:CNT=1
      38 TSM:FAIL:DIS
      40 TSF:TDI:TSL
      10044 TSM:INIT
      10057 TSM:FAIL:DIS
      10059 TSF:TDI:TSL
      Logs from Gateway:
      rejoe2R
      rejoe2R
      rejoe2
      @suresh-mali said in Node unable to get ID from gateway. [2.2.0]:
      Did you use the standard arduino Clean-EEPROM-Sketch or the one that comes with MySensors? The first writes "00" in EEPROM, the later "FF".
      For analysing this kind of trouble also the https://www.mysensors.org/build/parser is a very valueable tool.
      Suresh MaliS 1 Reply Last reply
      • rejoe2R rejoe2
        Suresh MaliS
        Suresh MaliS
        Suresh Mali
        @rejoe2 I have used the Mockmysensor example sketch from Mysensors.
          Logs from Node:
          25 TSM:INIT
          26 TSF:WUR:MS=0
          33 TSM:INIT:TSP OK
          37 TSM:FAIL:CNT=1
          38 TSM:FAIL:DIS
          40 TSF:TDI:TSL
          10044 TSM:INIT
          10057 TSM:FAIL:DIS
          10059 TSF:TDI:TSL
          Logs from Gateway:
          rejoe2R
          rejoe2R
          rejoe2
          The question was: how did you do this? There are - as already mentionned - two sketches available, but only one works ;-) .
          • rejoe2R rejoe2
            Suresh MaliS
            Suresh MaliS
            Suresh Mali
            @rejoe2 oh, I am sorry. I use the sketch from EEPROM Lib in Arduino. Not from MySensors. I am doing it right?
            rejoe2R 1 Reply Last reply
              rejoe2R
              rejoe2R
              rejoe2
              @suresh-mali No, this is the one writing zero's. Use the one that comes with mysensors (or assign an ID manually in your sketch, this may lead directly to a working node).
              Suresh MaliS 2 Replies Last reply
              • rejoe2R rejoe2
                Suresh MaliS
                Suresh MaliS
                Suresh Mali
                @rejoe2 Will try that. I did tried assigning ID manually, but that did not work.
                • rejoe2R rejoe2
                  Suresh MaliS
                  Suresh MaliS
                  Suresh Mali
                  @rejoe2 I tried as suggested. Cleared EEPROM using the sketch from MySensors example folder, tried auto ID assignment and also predefined ID. None seems to work.
                  This is the log when no ID is assigned.
                  16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
                  25 TSM:INIT
                  26 TSF:WUR:MS=0
                  33 TSM:INIT:TSP OK
                  35 TSM:FPAR
                  37 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2046 !TSM:FPAR:NO REPLY
                  2049 TSM:FPAR
                  2051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4059 !TSM:FPAR:NO REPLY
                  4061 TSM:FPAR
                  4063 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  Log when Node is assigned ID:
                  25 TSM:INIT
                  26 TSF:WUR:MS=0
                  33 TSM:INIT:TSP OK
                  35 TSM:INIT:STATID=254
                  37 TSF:SID:OK,ID=254
                  39 TSM:FPAR
                  75 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2083 !TSM:FPAR:NO REPLY
                  2085 TSM:FPAR
                  2121 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4129 !TSM:FPAR:NO REPLY
                  4131 TSM:FPAR
                  4167 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  6175 !TSM:FPAR:NO REPLY
                  6177 TSM:FPAR
                  6213 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8221 !TSM:FPAR:FAIL
                  8222 TSM:FAIL:CNT=1
                  8224 TSM:FAIL:DIS
                  8226 TSF:TDI:TSL
                  Please advice if there anything that could help me understand the issue and fix it.
                  Thanks alot.
                  • rejoe2R
                    rejoe2R
                    rejoe2
                    !TSM:FPAR:FAIL
                    Seems like there is either a problem in the RF part (node could have a defect transmitter) or your controller is not accepting new nodes. This is partly controller specific, eg. in FHEM you have to set the GW to "inclusion mode" AND have to activate a feature called "autocreate".
                    • rejoe2R rejoe2
                      !TSM:FPAR:FAIL
                      Suresh MaliS
                      Suresh MaliS
                      Suresh Mali
                      @rejoe2 I have already tried 2 different RF modules, the known good ones. So RF can be ruled out. I am running it with Domoticz, usually I don't have to change any setting, on presentation the node is shown in Domoticz and I just add it to my UI. Also tried the option Allow discovery for 5 mins in Domoticz that did not work either. So kind of lost here as to what's happening.
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @suresh-mali So then last ideas could be the gw version: is it also 2.2.0?
                        What kind of RF are you using - if it's nRF24 and you are already using the recommended caacitor, the MySensors lib version really could make a difference. For other RF modules, you may have a look at recent changes (RFM69 new driver).
                        Beside that I'm also running out of ideas.
                        • rejoe2R rejoe2
                          Suresh MaliS
                          Suresh MaliS
                          Suresh Mali
                          @rejoe2 I am using 2.2.0 on both gateway and node. Using NRF24L01+ with Caps . Strangely one of my node running on 2.1.0 is able to communicate with the gateway. Let's hope Mods have some answers. Appreciate your efforts and time.
                            Logs from Node:
                            25 TSM:INIT
                            26 TSF:WUR:MS=0
                            33 TSM:INIT:TSP OK
                            37 TSM:FAIL:CNT=1
                            38 TSM:FAIL:DIS
                            40 TSF:TDI:TSL
                            10044 TSM:INIT
                            10057 TSM:FAIL:DIS
                            10059 TSF:TDI:TSL
                            Logs from Gateway:
                            Suresh MaliS
                            Suresh MaliS
                            Suresh Mali
                            Any Moderator or Admin here who can help me, please.
                              @suresh-mali I have moderator privileges. What do you need help with?
                                Suresh MaliS
                                Suresh MaliS
                                Suresh Mali
                                @mfalkvidd I have hit a dead end. The issue described in the thread is stii not resolved. Any advice on what can help figure out the issue would be helpful.
                                  @suresh-mali ah. Sorry, my moderator privileges did not include divine knowledge. I have no idea what could be the problem.
                                  • D
                                    D
                                    DirkB19
                                    Not sure if it is the same problem, but looking similar ?
                                    1. I upgrade my MQTT gateway to 2.2.0 (from 2.1.0), all working ok with my 2.1.0 sensor nodes
                                    2. I upgrade the first sensor node to 2.2.0, and I get TSM:INIT:TSP FAIL messages on the node.
                                    3. I downgrade the first sensor node back to 2.1.0 and it works again like a charm ...
                                    Did I miss something ? Is this a bug in 2.2.0 ? Do I need to change config ?
                                    Best regards,
                                    DirkB
