  3. How connect arduino mega on Serial3 like USB
1 Posts 1 Posters 799 Views 2 Watching
  • W Offline
    W Offline
    Woodu
    Hello
    I need some help. Can someone tell me how to make connection on Serial3 in arduino mega?
    i use something like this:
    //#define MY_DEBUG
    #define MY_GATEWAY_SERIAL Serial3
    #define MY_SERIALDEVICE Serial3
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    #define MY_RS485_BAUD_RATE 115200
    // Enable this if RS485 is connected to a hardware serial port
    #define MY_RS485_HWSERIAL Serial3
    #include <OneWire.h>
    #define ONE_WIRE_BUS 7 // Pin where dallase sensor is connected
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1.1");
         present(i, S_TEMP);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
    But on serial i get this:
    055;;01;aea tru opee02550;0;182.2.0;5;;;1;emeraue Snsr025530;1;.1
    Not good :(
