  3. Home Assistant
  4. Arduino USB gateway for relay with buttons
6 Posts 3 Posters 3.0k Views 2 Watching
    mredone
    Hello.
    This is my first post.
    I use HA since 0.3 version.
    All automations i have build on sonoffs.
    Now in new flat i want make all wired automation.
    Does anyone make a gateway on arduino Mega with relay and buttons connected to arduino?
    I search for gateway skatch that work with HA via USB.
    Maybe someone can help me?
    Regards
    • M mredone
      Hello.
      Regards
      Welcome to the MySensors community @mredone
      Here is an example sketch for relay with button. Wiring for relay and button is the same for Mega. Wiring for the radio is different, see https://www.mysensors.org/build/connect_radio for details.
        mredone
        This post is deleted!
          mredone
          wrote on last edited by mredone
          I have a sketch with 2 relays, with option save to eprom.
          But i have problem in Home Assistant.
          I see relay in dashboard but i can't change it state from dashboard.
          Home Assistant update state only when i change relay with button
          //#define MY_RADIO_NRF24
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Flash leds on rx/tx/err
          // #define MY_LEDS_BLINKING_FEATURE
          // Set blinking period
          // #define MY_DEFAULT_LED_BLINK_PERIOD 300
          // #define MY_WITH_LEDS_BLINKING_INVERSE
          // Enable inclusion mode
          #include <Bounce2.h>
          #define MY_REPEATER_FEATURE
          #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          #define RELAY_2  5
          #define RELAY_ON 0  // GPIO value to write to turn on attached relay
          #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
          #define BUTTON_PIN A1
          #define BUTTON2_PIN A2
          void before() {
              pinMode(pin, OUTPUT);
          Bounce debouncer = Bounce();
          Bounce debouncer2 = Bounce();
            delay(10000);
             // Setup the button.
            pinMode(BUTTON_PIN, INPUT_PULLUP);
            pinMode(BUTTON2_PIN, INPUT_PULLUP);
            // After setting up the button, setup debouncer.
            debouncer.attach(BUTTON_PIN);
            debouncer.interval(5);
            debouncer2.attach(BUTTON2_PIN);
            debouncer2.interval(5);
            //presentation();
              present(sensor, S_BINARY);
          MyMessage msg(1, V_STATUS);
          MyMessage msg2(2, V_STATUS);
            if (debouncer.update()) {
              // Get the update value.
              int value = debouncer.read();
              // Send in the new value.
              if(value == LOW){
                   saveState(1, !loadState(1));
                   digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
                   send(msg.set(loadState(1)));
            if (debouncer2.update()) {
                int value2 = debouncer2.read();
              if(value2 == LOW){
                   saveState(2, !loadState(2));
                   digitalWrite(RELAY_2, loadState(2)?RELAY_ON:RELAY_OFF);
                   send(msg2.set(loadState(2)));
            if (message.type==V_STATUS) {
               // Change relay state
               // Store state in eeprom
               // Write some debug info
               Serial.print(message.sensor);
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            You need to feedback the state change to home assistant by sending the new state from the receive function after the calls to digitalWrite and saveState.
              mredone
              Ehh.
              I need a little help.
              I have a problem with change relay to light in HA.
              And i use in HA optimistic: true. Without it i can't change status of relay.
              My knowledge about programming is to low.
