  3. Domoticz TEXT sensor triggering
45 Posts 10 Posters 13.0k Views 10 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @alowhum
    If I remember right, then domoticz sends the new temperature to the device, but only updates the gui when it receives a value from the node. So your node sketch have to reply the set command from your controller, with another set command, which sends the value back to your controller.
    • alowhumA alowhum
      What other things are bi-directional with Domoticz?
      Fo example I'm looking to receive a setpoint value from Domoticz for a node that is an oven controller. Dresenting a s_hvac and then setting a new temperature in Domoticz, does that automatically get sent back to a node? Or is there a setpoint something?
      @alowhum those kind of values should be sent automatically to the node if they are changed in domoticz
      • alowhumA alowhum
        K
        K
        kimot
        @alowhum
        bool MySensorsBase::WriteToHardware(const char *pdata, const unsigned char length)
        	const tRBUF *pCmd = reinterpret_cast<const tRBUF *>(pdata);
        	unsigned char packettype = pCmd->ICMND.packettype;
        	unsigned char subtype = pCmd->ICMND.subtype;
        	if (packettype == pTypeLighting2)
        		//Light command
        		int node_id = pCmd->LIGHTING2.id4;
        		int child_sensor_id = pCmd->LIGHTING2.unitcode;
        		if (_tMySensorNode *pNode = FindNode(node_id))
        			_tMySensorChild *pChild = pNode->FindChild(child_sensor_id);
        			if (!pChild)
        				_log.Log(LOG_ERROR, "MySensors: Light command received for unknown node_id: %d, child_id: %d", node_id, child_sensor_id);
        				return false;
        			int light_command = pCmd->LIGHTING2.cmnd;
        			if ((pCmd->LIGHTING2.cmnd == light2_sSetLevel) && (pCmd->LIGHTING2.level == 0))
        				light_command = light2_sOff;
        			else if ((pCmd->LIGHTING2.cmnd == light2_sSetLevel) && (pCmd->LIGHTING2.level == 255))
        				light_command = light2_sOn;
        			if ((light_command == light2_sOn) || (light_command == light2_sOff))
        				std::string lState = (light_command == light2_sOn) ? "1" : "0";
        				if (pChild->presType == S_LOCK)
        					//Door lock/contact
        					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_LOCK_STATUS, lState, pChild->useAck, pChild->ackTimeout);
        				else if (pChild->presType == S_SCENE_CONTROLLER)
        					//Scene Controller
        					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, (light_command == light2_sOn) ? V_SCENE_ON : V_SCENE_OFF, lState, pChild->useAck, pChild->ackTimeout);
        				else
        					//normal
        					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STATUS, lState, pChild->useAck, pChild->ackTimeout);
        			else if (light_command == light2_sSetLevel)
        				float fvalue = (100.0f / 14.0f)*float(pCmd->LIGHTING2.level);
        				if (fvalue > 100.0f)
        					fvalue = 100.0f; //99 is fully on
        				int svalue = round(fvalue);
        				std::stringstream sstr;
        				sstr << svalue;
        				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_PERCENTAGE, sstr.str(), pChild->useAck, pChild->ackTimeout);
        		else {
        			_log.Log(LOG_ERROR, "MySensors: Light command received for unknown node_id: %d", node_id);
        			return false;
        	else if (packettype == pTypeLimitlessLights)
        		//RGW/RGBW command
        		_tLimitlessLights *pLed = (_tLimitlessLights *)pdata;
        		//unsigned char ID1 = (unsigned char)((pLed->id & 0xFF000000) >> 24);
        		//unsigned char ID2 = (unsigned char)((pLed->id & 0x00FF0000) >> 16);
        		unsigned char ID3 = (unsigned char)((pLed->id & 0x0000FF00) >> 8);
        		unsigned char ID4 = (unsigned char)pLed->id & 0x000000FF;
        		int node_id = (ID3 << 8) | ID4;
        		int child_sensor_id = pLed->dunit;
        			if (!pChild)
        				return false;
        			bool bIsRGBW = (pNode->FindChildWithPresentationType(child_sensor_id, S_RGBW_LIGHT) != NULL);
        			if (pLed->command == Limitless_SetRGBColour)
        				int red, green, blue;
        				float cHue = (360.0f / 255.0f)*float(pLed->value);//hue given was in range of 0-255
        				int Brightness = 100;
        				int dMax = round((255.0f / 100.0f)*float(Brightness));
        				hue2rgb(cHue, red, green, blue, dMax);
        				sstr << std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << red
        					<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << green
        					<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << blue;
        				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, (bIsRGBW == true) ? V_RGBW : V_RGB, sstr.str(), pChild->useAck, pChild->ackTimeout);
        			else if (pLed->command == Limitless_SetColorToWhite)
        				int wWhite = round((255.0f / 100.0f)*float(Brightness));
        				if (!bIsRGBW)
        					sstr << std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << wWhite
        						<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << wWhite;
        				else
        					sstr << "#000000"
        			else if (pLed->command == Limitless_SetBrightnessLevel)
        				float fvalue = pLed->value;
        				if (svalue > 100)
        					svalue = 100;
        				sstr << svalue;
        			else if ((pLed->command == Limitless_LedOff) || (pLed->command == Limitless_LedOn))
        				std::string lState = (pLed->command == Limitless_LedOn) ? "1" : "0";
        		else
        			return false;
        	else if (packettype == pTypeBlinds)
        		//Blinds/Window command
        		int node_id = pCmd->BLINDS1.id3;
        		int child_sensor_id = pCmd->BLINDS1.unitcode;
        			if (!pChild)
        				return false;
        			if (pCmd->BLINDS1.cmnd == blinds_sOpen)
        				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_UP, "", pChild->useAck, pChild->ackTimeout);
        			else if (pCmd->BLINDS1.cmnd == blinds_sClose)
        				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_DOWN, "", pChild->useAck, pChild->ackTimeout);
        			else if (pCmd->BLINDS1.cmnd == blinds_sStop)
        				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STOP, "", pChild->useAck, pChild->ackTimeout);
        		else {
        			_log.Log(LOG_ERROR, "MySensors: Blinds/Window command received for unknown node_id: %d", node_id);
        			return false;
        	else if ((packettype == pTypeThermostat) && (subtype == sTypeThermSetpoint))
        		//Set Point
        		const _tThermostat *pMeter = reinterpret_cast<const _tThermostat *>(pCmd);
        		int node_id = pMeter->id2;
        		int child_sensor_id = pMeter->id3;
        		_eSetType vtype_id = (_eSetType)pMeter->id4;
        			if (!pChild)
        				return false;
        			char szTmp[10];
        			sprintf(szTmp, "%.1f", pMeter->temp);
        			return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, vtype_id, szTmp, pChild->useAck, pChild->ackTimeout);
        		else {
        			return false;
        	else if (packettype == pTypeGeneralSwitch)
        		//Used to store IR codes
        		const _tGeneralSwitch *pSwitch= reinterpret_cast<const _tGeneralSwitch *>(pCmd);
        		int node_id = pSwitch->unitcode;
        		unsigned int ir_code = pSwitch->id;
        			_tMySensorChild* pChild = pNode->FindChildByValueType(V_IR_RECEIVE);
        			if (pChild)
        				sstr << ir_code;
        				return SendNodeSetCommand(node_id, pChild->childID, MT_Set, V_IR_SEND, sstr.str(), pChild->useAck, pChild->ackTimeout);
        		else {
        			return false;
        	else
        		_log.Log(LOG_ERROR, "MySensors: Unknown action received");
        		return false;
        	return true;
        • alowhumA
          alowhumA
          alowhum
          @kimot : Thanks! If I'm reading that domoticz code correctly:
          • All kinds of switches, including percentage and V_IR_RECEIVE
          • "sTypeThermSetpoint"
          • Hmm, I don't see the V_text update in that code
          @tbowmo : I had discovered that by experimenting, good to see it confirmed by you too.
          K 1 Reply Last reply
          • alowhumA alowhum
            K
            K
            kimot
            @alowhum
            There are some changes in V_TEXT type in latest builds.
            Read this:
            https://forum.mysensors.org/topic/9340/domoticz-v_text-sensor-now-bidirectional
