  3. Domoticz TEXT sensor triggering
45 Posts 10 Posters 13.0k Views 10 Watching
  • SushukkaS
    SushukkaS
    Sushukka
    Here is the latest update:
    https://github.com/domoticz/domoticz/issues/2380
    At least got some response...do it yourself.
    Darn sad: a good, reliable and widely-used product, but the developers are just pricks or don't give shit. With better attitude this could be so much more and most likely there would be lots of more contributors helping with them.
      Agreed, that is bad but on the other side consider it is a feature not used much actually.
      Nca78N GertSandersG 2 Replies Last reply
        @gohan said in Domoticz TEXT sensor triggering:
        Well I don't use it at the moment, but only because it's a PITA with Domoticz...
          GertSandersG
          GertSandersG
          GertSanders
          @gohan I would love to have that feature so I can send updates to a LCD equipped sensor, without the "switch" hack.
          Polling is really inefficient, one should be able to send V_TEXT just like V_STATUS.
          alexsh1A 1 Reply Last reply
            Don't get me wrong, I understand, I was just considering that it a feature not needed by many people and it is still on the feature request list
            • alowhumA
              alowhumA
              alowhum
              #37
              I built a partial solution for this in the Aurora theme for Domoticz. With it you can just change the vText variable value in the interface.
              • Install Aurora
              • Go to Utility tab
              • click on the text value. It will change into an edit field. Click outside of it when you're done.
              The node still needs to poll Domoticz periodically to request the new value. But at least you can change the value easily this way.
              • SushukkaS
                SushukkaS
                Sushukka
                YEEEEEEESSSSHHH!!! This is now implemented in Domoticz!
                You can change the V_TEXT sensor value from Domoticz via JSON, Scripts and Blocky and the update will be sent directly to the node without any hacks!!! This is big update; you can pass lots of information, parameters etc directly to the nodes without extra steps. And @alowhum you don't need that poll anymore in the sketch. :) LCD screen updates, speech-to-text commands...now we just need bigger payload size for MySensors... :D
                • GertSandersG GertSanders
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @gertsanders said in Domoticz TEXT sensor triggering:
                  you ca do it now with the latest update
                  • alowhumA
                    alowhumA
                    alowhum
                    #40
                    What other things are bi-directional with Domoticz?
                    Fo example I'm looking to receive a setpoint value from Domoticz for a node that is an oven controller. Dresenting a s_hvac and then setting a new temperature in Domoticz, does that automatically get sent back to a node? Or is there a setpoint something?
                    gohanG K 2 Replies Last reply
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @alowhum
                      If I remember right, then domoticz sends the new temperature to the device, but only updates the gui when it receives a value from the node. So your node sketch have to reply the set command from your controller, with another set command, which sends the value back to your controller.
                      • alowhumA alowhum
                        @alowhum those kind of values should be sent automatically to the node if they are changed in domoticz
                        • alowhumA alowhum
                          K
                          K
                          kimot
                          @alowhum
                          bool MySensorsBase::WriteToHardware(const char *pdata, const unsigned char length)
                          	const tRBUF *pCmd = reinterpret_cast<const tRBUF *>(pdata);
                          	unsigned char packettype = pCmd->ICMND.packettype;
                          	unsigned char subtype = pCmd->ICMND.subtype;
                          	if (packettype == pTypeLighting2)
                          		//Light command
                          		int node_id = pCmd->LIGHTING2.id4;
                          		int child_sensor_id = pCmd->LIGHTING2.unitcode;
                          		if (_tMySensorNode *pNode = FindNode(node_id))
                          			_tMySensorChild *pChild = pNode->FindChild(child_sensor_id);
                          			if (!pChild)
                          				_log.Log(LOG_ERROR, "MySensors: Light command received for unknown node_id: %d, child_id: %d", node_id, child_sensor_id);
                          				return false;
                          			int light_command = pCmd->LIGHTING2.cmnd;
                          			if ((pCmd->LIGHTING2.cmnd == light2_sSetLevel) && (pCmd->LIGHTING2.level == 0))
                          				light_command = light2_sOff;
                          			else if ((pCmd->LIGHTING2.cmnd == light2_sSetLevel) && (pCmd->LIGHTING2.level == 255))
                          				light_command = light2_sOn;
                          			if ((light_command == light2_sOn) || (light_command == light2_sOff))
                          				std::string lState = (light_command == light2_sOn) ? "1" : "0";
                          				if (pChild->presType == S_LOCK)
                          					//Door lock/contact
                          					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_LOCK_STATUS, lState, pChild->useAck, pChild->ackTimeout);
                          				else if (pChild->presType == S_SCENE_CONTROLLER)
                          					//Scene Controller
                          					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, (light_command == light2_sOn) ? V_SCENE_ON : V_SCENE_OFF, lState, pChild->useAck, pChild->ackTimeout);
                          					//normal
                          					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STATUS, lState, pChild->useAck, pChild->ackTimeout);
                          			else if (light_command == light2_sSetLevel)
                          				float fvalue = (100.0f / 14.0f)*float(pCmd->LIGHTING2.level);
                          				if (fvalue > 100.0f)
                          					fvalue = 100.0f; //99 is fully on
                          				int svalue = round(fvalue);
                          				std::stringstream sstr;
                          				sstr << svalue;
                          				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_PERCENTAGE, sstr.str(), pChild->useAck, pChild->ackTimeout);
                          		else {
                          			_log.Log(LOG_ERROR, "MySensors: Light command received for unknown node_id: %d", node_id);
                          			return false;
                          	else if (packettype == pTypeLimitlessLights)
                          		//RGW/RGBW command
                          		_tLimitlessLights *pLed = (_tLimitlessLights *)pdata;
                          		//unsigned char ID1 = (unsigned char)((pLed->id & 0xFF000000) >> 24);
                          		//unsigned char ID2 = (unsigned char)((pLed->id & 0x00FF0000) >> 16);
                          		unsigned char ID3 = (unsigned char)((pLed->id & 0x0000FF00) >> 8);
                          		unsigned char ID4 = (unsigned char)pLed->id & 0x000000FF;
                          		int node_id = (ID3 << 8) | ID4;
                          		int child_sensor_id = pLed->dunit;
                          			if (!pChild)
                          				return false;
                          			bool bIsRGBW = (pNode->FindChildWithPresentationType(child_sensor_id, S_RGBW_LIGHT) != NULL);
                          			if (pLed->command == Limitless_SetRGBColour)
                          				int red, green, blue;
                          				float cHue = (360.0f / 255.0f)*float(pLed->value);//hue given was in range of 0-255
                          				int Brightness = 100;
                          				int dMax = round((255.0f / 100.0f)*float(Brightness));
                          				hue2rgb(cHue, red, green, blue, dMax);
                          				sstr << std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << red
                          					<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << green
                          					<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << blue;
                          				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, (bIsRGBW == true) ? V_RGBW : V_RGB, sstr.str(), pChild->useAck, pChild->ackTimeout);
                          			else if (pLed->command == Limitless_SetColorToWhite)
                          				int wWhite = round((255.0f / 100.0f)*float(Brightness));
                          				if (!bIsRGBW)
                          					sstr << std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << wWhite
                          						<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << wWhite;
                          					sstr << "#000000"
                          			else if (pLed->command == Limitless_SetBrightnessLevel)
                          				float fvalue = pLed->value;
                          				if (svalue > 100)
                          					svalue = 100;
                          				sstr << svalue;
                          			else if ((pLed->command == Limitless_LedOff) || (pLed->command == Limitless_LedOn))
                          				std::string lState = (pLed->command == Limitless_LedOn) ? "1" : "0";
                          			return false;
                          	else if (packettype == pTypeBlinds)
                          		//Blinds/Window command
                          		int node_id = pCmd->BLINDS1.id3;
                          		int child_sensor_id = pCmd->BLINDS1.unitcode;
                          			if (!pChild)
                          				return false;
                          			if (pCmd->BLINDS1.cmnd == blinds_sOpen)
                          				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_UP, "", pChild->useAck, pChild->ackTimeout);
                          			else if (pCmd->BLINDS1.cmnd == blinds_sClose)
                          				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_DOWN, "", pChild->useAck, pChild->ackTimeout);
                          			else if (pCmd->BLINDS1.cmnd == blinds_sStop)
                          				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STOP, "", pChild->useAck, pChild->ackTimeout);
                          		else {
                          			_log.Log(LOG_ERROR, "MySensors: Blinds/Window command received for unknown node_id: %d", node_id);
                          			return false;
                          	else if ((packettype == pTypeThermostat) && (subtype == sTypeThermSetpoint))
                          		//Set Point
                          		const _tThermostat *pMeter = reinterpret_cast<const _tThermostat *>(pCmd);
                          		int node_id = pMeter->id2;
                          		int child_sensor_id = pMeter->id3;
                          		_eSetType vtype_id = (_eSetType)pMeter->id4;
                          			if (!pChild)
                          				return false;
                          			char szTmp[10];
                          			sprintf(szTmp, "%.1f", pMeter->temp);
                          			return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, vtype_id, szTmp, pChild->useAck, pChild->ackTimeout);
                          		else {
                          			return false;
                          	else if (packettype == pTypeGeneralSwitch)
                          		//Used to store IR codes
                          		const _tGeneralSwitch *pSwitch= reinterpret_cast<const _tGeneralSwitch *>(pCmd);
                          		int node_id = pSwitch->unitcode;
                          		unsigned int ir_code = pSwitch->id;
                          			_tMySensorChild* pChild = pNode->FindChildByValueType(V_IR_RECEIVE);
                          			if (pChild)
                          				sstr << ir_code;
                          				return SendNodeSetCommand(node_id, pChild->childID, MT_Set, V_IR_SEND, sstr.str(), pChild->useAck, pChild->ackTimeout);
                          		else {
                          			return false;
                          		_log.Log(LOG_ERROR, "MySensors: Unknown action received");
                          		return false;
                          	return true;
                          • alowhumA
                            alowhumA
                            alowhum
                            @kimot : Thanks! If I'm reading that domoticz code correctly:
                            • All kinds of switches, including percentage and V_IR_RECEIVE
                            • "sTypeThermSetpoint"
                            • Hmm, I don't see the V_text update in that code
                            @tbowmo : I had discovered that by experimenting, good to see it confirmed by you too.
                            K 1 Reply Last reply
                            • alowhumA alowhum
                              K
                              K
                              kimot
                              @alowhum
                              There are some changes in V_TEXT type in latest builds.
                              Read this:
                              https://forum.mysensors.org/topic/9340/domoticz-v_text-sensor-now-bidirectional
