  3. Pin Change Interrupts debounce
16 Posts 3 Posters 3.8k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    MY GW is flooded with messages as I am using pin change interrupt.
    How do I debounce it please? sleep() does not work
    ISR (PCINT0_vect)
     // handle pin change interrupt for D8 to D13 here
     }  // end of PCINT0_vect
    ISR (PCINT1_vect)
     // handle pin change interrupt for A0 to A5 here
     }  // end of PCINT1_vect
    ISR (PCINT2_vect)
     // handle pin change interrupt for D0 to D7 here
     }  // end of PCINT2_vect
    void setup ()
      // pin change interrupt (example for D9)
      PCMSK0 |= bit (PCINT1);  // want pin 9
      PCIFR  |= bit (PCIF0);   // clear any outstanding interrupts
      PCICR  |= bit (PCIE0);   // enable pin change interrupts for D8 to D13
    • alexsh1A alexsh1
      ISR (PCINT0_vect)
      ISR (PCINT1_vect)
      ISR (PCINT2_vect)
      void setup ()
      @alexsh1 debounce must be done in the loop. The ISRs must execte quickly, so no debouncing can be done there.
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @mfalkvidd Ok, thank you. How exactly do I do that? I cannot use sleep() to debounce as it will be interrupted.
        • alexsh1A alexsh1
          @alexsh1 how to do it would depend entirely on how the node is supposed to function. Could you describe what triggers the interrups and how you would like them to be handled?
          • alexsh1A
            alexsh1A
            alexsh1
            This is the most of the loop function I have apart from sleep.
             if (IRQHigh) {
                send(msg.set("1"));
                IRQHigh = false;
            • alexsh1A alexsh1
               if (IRQHigh) {
                  send(msg.set("1"));
                  IRQHigh = false;
              @alexsh1 how about adding global variables for all interrups like this
              volatile unsigned long lastInterruptD1 = 0;
              volatile unsigned long lastInterruptD2 = 0;
              and inside the ISRs set the corresponding variable to millis() like this
              lastInterruptD1 = millis();
              and in loop have a series of
              if(lastInterruptD1 != 0 && millis()-lastInterruptD1 > DEBOUNCE_MS){
                // Do whatever the interrupt does here
              You could use an array instead of individual variables to make the code cleaner, especially if you want to cover a lot of pins. Which board/Arduino are you using?
                alexsh1A
                alexsh1A
                alexsh1
                @mfalkvidd it is a custom made board using atmega328p-au with sensebender bootloader running at 8Mhz and 3.3V.
                I'll try the above, however, does millis() work while sleeping?
                • alexsh1A alexsh1
                  @alexsh1 it will return the last value, but it will not increment. That's one of the reasons ISRs should exit quickly.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @mfalkvidd
                    Want to share what I found in case others have a similar issue.
                    const unsigned long debounceTime = 50;
                    volatile bool ir_selector_pressed = false;
                    ISR (PCINT2_vect) { // handle pin change interrupt for D0 to D7 here
                      static unsigned long previousStateChangeMillis = 0;
                      static bool previousPinState = HIGH;
                      bool pinState = digitalRead(SELECTOR_BTN);
                      if (pinState != previousPinState) { // ignore pin changes of pins other than SELECTOR_BTN
                        if (pinState == LOW) { // only falling events
                          if ((millis() - previousStateChangeMillis) > debounceTime) { // debounce
                            ir_selector_pressed = true;
                        previousPinState = pinState;
                        previousStateChangeMillis = millis();
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Another way to debounce is to stop interrupts in loop, sleep for say 20 seconds and then resume interrupts.
                      YveauxY 1 Reply Last reply
                      • alexsh1A alexsh1
                        YveauxY
                        YveauxY
                        @alexsh1 this is in general a bad idea, as it will also stop eg reception of serial data and incoming packages (when using message queuing).
                        • YveauxY Yveaux
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @yveaux you mean stopping interrupts?
                          • alexsh1A alexsh1
                            YveauxY
                            YveauxY
                            @alexsh1 yup
                            • YveauxY Yveaux
                              @alexsh1 yup
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @yveaux What is the best way to do it please?
                              • alexsh1A alexsh1
                                YveauxY
                                YveauxY
                                @alexsh1 The easiest way would probably use a debounce-library.
                                These normally aren't using interrupts, but you have to question yourself if you really need interrupts in your case.
                                I don't have any readymade, tested code which uses interrupts and debounces switches.
                                • YveauxY Yveaux
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @yveaux said in Pin Change Interrupts debounce:
                                  I'll look into that. Thank you
