  3. [SOLVED] TSF:MSG:PVER,0!=2
4 Posts 2 Posters 1.4k Views 2 Watching
  • alowhumA Offline
    alowhumA Offline
    alowhum
    I'm getting a weird error. The forum only has one other thread about PVER, and that says "your radio might be broken". But
    • I tried three radios (one with capacitor), and all give the error.
    • Tried low and min power levels.
    • Also tried two sketches, and both give the error.
    • tried decoupling sensors and a button. No change.
    • I'm using it in a Nano Expansion board that gets 2A 12v power. I also tried powering it from just USB.
    Details:
    NRF24
    MySensors 2.2
    More debug data:
    0 MCO:BGN:INIT REPEATER,CP=RNNRA---,VER=2.2.0
    4 TSM:INIT
    4 TSF:WUR:MS=10000
    12 TSM:INIT:TSP OK
    13 TSM:INIT:STATID=40
    15 TSF:SID:OK,ID=40
    17 TSM:FPAR
    18 TSM:FPAR:STATP=0
    20 TSM:ID
    21 TSM:ID:OK
    22 TSM:UPL
    25 TSF:MSG:SEND,40-40-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    34 TSF:MSG:READ,0-0-40,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    39 !TSF:MSG:PVER,0!=2
    2032 TSM:UPL
    2034 TSF:MSG:SEND,40-40-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2042 TSF:MSG:READ,0-0-40,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2048 !TSF:MSG:PVER,0!=2
    4042 TSM:UPL
    4044 TSF:MSG:SEND,40-40-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4051 TSF:MSG:READ,0-0-40,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4057 !TSF:MSG:PVER,0!=2
    6052 TSM:UPL
    6054 TSF:MSG:SEND,40-40-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    6062 TSF:MSG:READ,0-0-40,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    6067 !TSF:MSG:PVER,0!=2
    8064 !TSM:UPL:FAIL
    8065 TSM:FPAR
    8067 TSM:FPAR:STATP=0
    8069 TSM:ID
    8070 TSM:ID:OK
    8071 TSM:UPL
    8074 TSF:MSG:SEND,40-40-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    8081 TSF:MSG:READ,0-0-40,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    8086 !TSF:MSG:PVER,0!=2```
      Could also be cheap Chinese crappy clones
      • alowhumA Offline
        alowhumA Offline
        alowhum
        I found the solution: clear the eeprom.
        I had used the nodes with the MY_SIGNING_SIMPLE_PASSWD feature. Apparently when you use security on a node, the security measures stay in place.
        • alowhumA Offline
          alowhumA Offline
          alowhum
          For anyone finding this: today I seemed to have the same issue, with cleared eeprom and with a test network made with two of the great red eByte radio modules.
          I read elsewhere on the forum it might be a memory issue.
