  3. Home Assistant
  4. Raspberry Pi gateway and controller in one
11 Posts 7 Posters 3.8k Views 8 Watching
  • J
    J
    JCH
    Has anyone successfully installed Home Assistant on a RPi and used the same pi as a Mysensors Gateway with a NRF module attached to the Pi?
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      This should be pretty easy. Install your Home Assistant, then follow the pi gateway instructions. Shouldn't have any issues with it conflicting.
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      SebexS 1 Reply Last reply
        Home Assistant or HASS.IO?
        • D
          D
          David Cabañero
          I haven't installed Home Assistant but I have openhab and the gateway running on the same raspberry pi.
          HA should't be any different.
            Normal HA is ok, the problem is hass.io
            • O
              O
              oneyb
              Yes, I have.
              This is how I configured things:
              https://github.com/oneyb/rpi-embed-dev/blob/master/install-mysensors-gateway-raspberry.yaml
              HTH
              • J
                J
                JCH
                Ok cool, thanks for the replys. I will give it a go and see how i get on
                • CrankyCoderC CrankyCoder
                  SebexS
                  SebexS
                  Sebex
                  @crankycoder Any advice on how? HA is running on my raspberry Pi and I can access it just fine. How can I make it a gateway as well? The first step is to log in to my raspberry but I can only log in via HA. Any advice?
                  gohanG 1 Reply Last reply
                  • O
                    O
                    oneyb
                    SSH will get you into your pi. If your pi has a wifi connection and ssh enabled, the following should work.
                    ssh pi@raspberrypi.local
                    • A
                      A
                      arden
                      ive got openhab and gateway so shouldn't be a problem with hass 0_1577584196725_IMG_20191226_024628.jpg
                      • SebexS Sebex
                        @sebex unless you have hass.io you should be able to SSH into the rpi
