Child X not present in node X
Dear All!
I dont know what might be the problem.
Openhab2 2.4.0
Mysensors 2.3.0 binding
All other nodes are OK except my NoDE 3. Previously it had been OK until I upgraded to openhab2 2.3 , but Im not sure that the upgrade the main problem.
Please give me suggestion what should i try to fix this issue.Message from gateway received: 3;1;1;0;0;5.2 2018-07-06 19:58:24.834 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 3 found in gateway 2018-07-06 19:58:24.834 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 not present in node 3 2018-07-06 19:58:24.845 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 3;2;1;0;1;69 2018-07-06 19:58:24.845 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 3 found in gateway 2018-07-06 19:58:24.845 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 3Thanks in advance,
Tamás -
I had exactly the same issue on Vera after upgrading my Gateway to 2.3.0.
After upgrading the Gateway I had to add each node back individually. Four of my nodes had manual Node_IDs assigned and one had auto Node_ID. As it happened I added Nodes 1 and 2 first which were manual and then added the auto node. It automatically assigned node 3 as the next available node.
I then added node 4 (manual) successfully but Node 3 would only add one of its child nodes.
The problem was that the auto node had added Child ids of 1 to 4. When I added the manual node 3, it correctly added child id 0 but could not add the second child as child 1 had already been allocated by the auto node.
I couldn't find any error messages to indicate the problem.
I eventually found this LUA code which showed all the devices with the node and child ids that had been assigned.
I deleted the auto node, changed the sketch to set the node manually and re-added it. Deleted node 3 and re-added and everything was fine.
I realise this was for a Vera system, but the real problem was the order of adding nodes and probably more importantly mixing nodes with manual and auto node assignments in the same mesh.
I will be using manual node assignment for all nodes going forward!
