  3. Home Assistant
  4. Problem with sketch IRSender/Receiver (A/C control)
6 Posts 3 Posters 1.8k Views 3 Watching
  • luglioL
    luglioL
    luglio
    wrote on last edited by luglio
    Hello everyone,
    I'm trying to control with HA my A / C just to turn on and off. For this I am using the sketch of mysensors about IRSender / Receiver.
    I'm starting in this wonderful world, but I've been stuck with this error for several days: Not a valid message: value must be either 0 or 1 for dictionary value @ data ['payload']
    I show you an image where it is collected:
      - on the screen top left, mysgwd
      - on the screen at the top right, IDE Arduino
      - on the screen below to the left, HA log
      - on the screen below to the right, serial monitor
    The code is exactly the same as the sketch. I hope to receive your advice and be able to realize this objective.
    Greetings and thank you!
    YveauxY martinhjelmareM 2 Replies Last reply
    • luglioL luglio
      Hello everyone,
      YveauxY
      YveauxY
      @luglio judging from your screenshot you seem to be using home assistant?
      If correct, then I'll move this topic to the home assistant subtopic.
      • luglioL
        luglioL
        luglio
        Yes it is, you can move it to the home assistant subtopic
        YveauxY 1 Reply Last reply
        • luglioL luglio
          YveauxY
          YveauxY
          @luglio done
          • luglioL luglio
            Hello everyone,
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @luglio
            V_IR_RECORD isn't yet supported by home assistant.
            luglioL 1 Reply Last reply
              @luglio
              luglioL
              luglioL
              luglio
              @martinhjelmare Oh it's true, I've tried it with V_IR_SEND and it worked. Thank you.
