  3. Irrigation controller
12 Posts 5 Posters 2.6k Views 4 Watching
  • E Offline
    E Offline
    erik
    Hi!
    I am using the code at https://blog.m.nu/gastblogg-styrning-av-bevattning-balkonglador/ (swedish page) but can't seem to get it to work. The trick is, I have only one sensor.
    Which parts of the code needs to be altered?
    Pasted code:
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    256
    257
    258
    259
    260
    261
    262
    263
    264
    265
    266
    267
    268
    269
    270
    271
    272
    273
    274
    275
    276
    277
    278
    279
    280
    281
    282
    283
    284
    285
    286
    287
    288
    289
    290
    291
    292
    293
    294
    295
    296
    297
    298
    299
    300
    301
    302
    303
    304
    305
    306
    307
    308
    309
    310
    /* **SKETCH BEGINNING**
    * Version 1.0 - Henrik Ekblad
    //#define MY_DEBUG
    //Network
    #define MY_NODE_ID 8 // I have hardcoded the ID
    #define MY_PARENT_NODE_ID 0 // I have hardcoded the gateway
    #define MY_RADIO_NRF24 //What type of radio
    #define MY_RF24_PA_LEVEL RF24_PA_MAX //The radio is one with antenna so we must set this to max
    //Signing makes everything secure. Arduino must be prepared before according to mysensors.org
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    //Includes
    #include <SI7021.h>
    #include <RunningAverage.h>
    //Define Relay
    #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_3 5 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 3 // Total number of attached relays
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    #define RELEASE "1.4"
    //Define Moisture things
    #define AVERAGES 2 //we use 2 readings to smooth the readings
    #define STABILIZATION_TIME 1000 // Let the sensor stabilize before reading
    //Change direction on moisture could help with corrosion
    byte direction = 0;
    //Moisture sensor pins
    const int SENSOR_ANALOG_PINS[] = {A0, A1}; // Sensor1 is connected to these two pins.
    const int SENSOR_ANALOG_PINS2[] = {A2, A3}; // Sensor2 is connected to these two pins.
    // Child sensor ID's
    #define CHILD_ID_TEMP 5
    #define CHILD_ID_HUM 6
    #define CHILD_ID_MOISTURE 7
    #define CHILD_ID_MOISTURE2 8
    #define CHILD_ID_BUTTON 9
    #define CHILD_ID_BUTTON2 10
    // How many milli seconds between each measurement of temp and humidity
    #define MEASURE_INTERVAL 30000
    // FORCE_TRANSMIT_INTERVAL, the sensor is forced to report all values to the controller
    #define FORCE_TRANSMIT_INTERVAL 2000 // 20minutes
    // TRANSMIT_THRESHOLD tells how much the humidity/remperature should have changed since last time it was transmitted.
    #define HUMI_TRANSMIT_THRESHOLD 1.0
    #define TEMP_TRANSMIT_THRESHOLD 0.2
    #define round(x) ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
    #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
    SI7021 humiditySensor;
    RunningAverage raHum(AVERAGES);
    // Sensor messages, here I define different channels where the info is sent
    MyMessage msgMoist(CHILD_ID_MOISTURE, V_HUM);
    MyMessage msgMoist2(CHILD_ID_MOISTURE2, V_HUM);
    MyMessage msgButton(CHILD_ID_BUTTON, V_HUM);
    MyMessage msgButton2(CHILD_ID_BUTTON2, V_HUM);
    MyMessage msgR1(RELAY_1, V_STATUS);
    MyMessage msgR2(RELAY_2, V_STATUS);
    // Global settings
    const unsigned long tUpdateMoist = 3600000; // update interval for the moisture sensor1, 1hour
    const unsigned long tUpdateMoist2 = 3600000; //update interval for the moisture sensor2, 1hour
    unsigned long t1; //defining t1
    unsigned long t2; //defining t2
    int measureCount = 0; //defining measureCount
    boolean isMetric = true;
    boolean highfreq = true; //delete, is probably not needed
    boolean transmission_occured = false; //reset so it starts at false
    // Storage of old measurements, reset them all to 0
    float lastTemperature = -100;
    int lastHumidity = -100;
    int oldMoistureLevel = -1;
    int oldMoistureLevel2 = -1;
    int button = -1;
    int button2 = -1;
    void before()
    for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++)
    pinMode(pin, OUTPUT);
    Serial.begin(115200);
    humiditySensor.begin();
    isMetric = getControllerConfig().isMetric;
    Serial.print(F("isMetric: ")); Serial.println(isMetric);
    raHum.clear();
    t1=millis();
    t2=millis();
    //sendTempHumidityMeasurements(true);
    sendMoistureMeasurements();
    sendMoistureMeasurements2();
    delay(250);
    for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++)
    pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
    digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
    for (int j = 0; j < N_ELEMENTS(SENSOR_ANALOG_PINS2); j++)
    pinMode(SENSOR_ANALOG_PINS2[j], OUTPUT);
    digitalWrite(SENSOR_ANALOG_PINS2[j], LOW);
    sendSketchInfo("RelayTempHumMoist", "1.0");
    present(sensor, S_BINARY,"Relays");
    present(CHILD_ID_TEMP,S_TEMP,"Temperature");
    present(CHILD_ID_HUM,S_HUM,"Humidity");
    present(CHILD_ID_MOISTURE, S_HUM,"Moisture");
    present(CHILD_ID_MOISTURE2, S_HUM,"Moisture2");
    present(CHILD_ID_BUTTON, S_HUM,"Button");
    present(CHILD_ID_BUTTON2, S_HUM,"Button2");
    measureCount ++;
    bool forceTransmit = false;
    if (measureCount > FORCE_TRANSMIT_INTERVAL)
    forceTransmit = true;
    measureCount = 0;
    Serial.print(F("inne i loopen :"));
    if ((millis() - t1) > tUpdateMoist) sendMoistureMeasurements();
    if ((millis() - t2) > tUpdateMoist2) sendMoistureMeasurements2();
    void sendTempHumidityMeasurements(bool force)
    wait(MEASURE_INTERVAL);
    bool tx = force;
    si7021_env data = humiditySensor.getHumidityAndTemperature();
    raHum.addValue(data.humidityPercent);
    float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
    float diffHum = abs(lastHumidity - raHum.getAverage());
    Serial.print(F("TempDiff :"));Serial.println(diffTemp);
    Serial.print(F("HumDiff :"));Serial.println(diffHum);
    if (isnan(diffHum)) tx = true;
    if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
    if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
    if (tx)
    measureCount = 0;
    float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
    int humidity = data.humidityPercent;
    Serial.print("T: ");Serial.println(temperature);
    Serial.print("H: ");Serial.println(humidity);
    send(msgTemp.set(temperature,1));
    send(msgHum.set(humidity));
    lastTemperature = temperature;
    lastHumidity = humidity;
    transmission_occured = true;
    void sendMoistureMeasurements()
    pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP); // Power on the sensor
    analogRead(SENSOR_ANALOG_PINS[direction]);// Read once to let the ADC capacitor start charging
    sleep(STABILIZATION_TIME);
    int moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
    // Turn off the sensor to conserve battery and minimize corrosion
    pinMode(SENSOR_ANALOG_PINS[direction], OUTPUT);
    digitalWrite(SENSOR_ANALOG_PINS[direction], LOW);
    direction = (direction + 1) % 2; // Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
    // Always send moisture information so the controller sees that the node is alive
    // Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
    // See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
    if (oldMoistureLevel == -1)
    { // First reading, save value
    oldMoistureLevel = moistureLevel;
    if (button == 1)
    send(msgButton.set((moistureLevel + oldMoistureLevel + 0.5) / 2 / 10.23, 1));
    t1 = millis();
    Serial.print(F("inne i button :"));
    if (button == 0)
    send(msgMoist.set((moistureLevel + oldMoistureLevel + 0.5) / 2 / 10.23, 1));
    t1 = millis();
    button = 0;
    void sendMoistureMeasurements2()
    pinMode(SENSOR_ANALOG_PINS2[direction], INPUT_PULLUP); // Power on the sensor
    analogRead(SENSOR_ANALOG_PINS2[direction]);// Read once to let the ADC capacitor start charging
    int moistureLevel2 = (1023 - analogRead(SENSOR_ANALOG_PINS2[direction]));
    pinMode(SENSOR_ANALOG_PINS2[direction], OUTPUT);
    digitalWrite(SENSOR_ANALOG_PINS2[direction], LOW);
    if (oldMoistureLevel2 == -1)
    oldMoistureLevel2 = moistureLevel2;
    if (button2 == 1)
    send(msgButton2.set((moistureLevel2 + oldMoistureLevel2 + 0.5) / 2 / 10.23, 1));
    t2 = millis();
    Serial.print(F("inne i button2 :"));
    if (button2 == 0)
    send(msgMoist2.set((moistureLevel2 + oldMoistureLevel2 + 0.5) / 2 / 10.23, 1));
    t2 = millis();
    button2 = 0;
    // Here I can send messages to the node.
    if (message.type==V_STATUS)
    // Change relay state
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
    if (message.type==V_TRIPPED)
    button = 1;
    button2 = 1;
    **SKETCH END** */
    Thanks in advance.
    Cheers,
    Erik
    mfalkviddM A 2 Replies Last reply
    • E erik
      Hi!
      Pasted code:
      21
      22
      23
      24
      25
      26
      27
      28
      29
      30
      31
      32
      33
      34
      35
      36
      37
      38
      39
      40
      41
      42
      43
      44
      45
      46
      47
      48
      49
      50
      51
      52
      53
      54
      55
      56
      57
      58
      59
      60
      61
      62
      63
      64
      65
      66
      67
      68
      69
      70
      71
      72
      73
      74
      75
      76
      77
      78
      79
      80
      81
      82
      83
      84
      85
      86
      87
      88
      89
      90
      91
      92
      93
      94
      95
      96
      97
      98
      99
      100
      101
      102
      103
      104
      105
      106
      107
      108
      109
      110
      111
      112
      113
      114
      115
      116
      117
      118
      119
      120
      121
      122
      123
      124
      125
      126
      127
      128
      129
      130
      131
      132
      133
      134
      135
      136
      137
      138
      139
      140
      141
      142
      143
      144
      145
      146
      147
      148
      149
      150
      151
      152
      153
      154
      155
      156
      157
      158
      159
      160
      161
      162
      163
      164
      165
      166
      167
      168
      169
      170
      171
      172
      173
      174
      175
      176
      177
      178
      179
      180
      181
      182
      183
      184
      185
      186
      187
      188
      189
      190
      191
      192
      193
      194
      195
      196
      197
      198
      199
      200
      201
      202
      203
      204
      205
      206
      207
      208
      209
      210
      211
      212
      213
      214
      215
      216
      217
      218
      219
      220
      221
      222
      223
      224
      225
      226
      227
      228
      229
      230
      231
      232
      233
      234
      235
      236
      237
      238
      239
      240
      241
      242
      243
      244
      245
      246
      247
      248
      249
      250
      251
      252
      253
      254
      255
      256
      257
      258
      259
      260
      261
      262
      263
      264
      265
      266
      267
      268
      269
      270
      271
      272
      273
      274
      275
      276
      277
      278
      279
      280
      281
      282
      283
      284
      285
      286
      287
      288
      289
      290
      291
      292
      293
      294
      295
      296
      297
      298
      299
      300
      301
      302
      303
      304
      305
      306
      307
      308
      309
      310
      //#define MY_DEBUG
      //Network
      //Includes
      #include <SI7021.h>
      //Define Relay
      byte direction = 0;
      // Global settings
      int button = -1;
      int button2 = -1;
      void before()
      raHum.clear();
      t1=millis();
      t2=millis();
      delay(250);
      measureCount ++;
      measureCount = 0;
      bool tx = force;
      if (tx)
      measureCount = 0;
      if (button == 1)
      t1 = millis();
      if (button == 0)
      t1 = millis();
      button = 0;
      if (button2 == 1)
      t2 = millis();
      if (button2 == 0)
      t2 = millis();
      button2 = 0;
      button = 1;
      button2 = 1;
      **SKETCH END** */
      Thanks in advance.
      Cheers,
      Erik
      Welcome to the MySensors forum, @erik
      I think @Nicklas-Starkel wrote that blog post, tagging him so maybe he can assist.
      • E erik
        Hi!
        Pasted code:
        21
        22
        23
        24
        25
        26
        27
        28
        29
        30
        31
        32
        33
        34
        35
        36
        37
        38
        39
        40
        41
        42
        43
        44
        45
        46
        47
        48
        49
        50
        51
        52
        53
        54
        55
        56
        57
        58
        59
        60
        61
        62
        63
        64
        65
        66
        67
        68
        69
        70
        71
        72
        73
        74
        75
        76
        77
        78
        79
        80
        81
        82
        83
        84
        85
        86
        87
        88
        89
        90
        91
        92
        93
        94
        95
        96
        97
        98
        99
        100
        101
        102
        103
        104
        105
        106
        107
        108
        109
        110
        111
        112
        113
        114
        115
        116
        117
        118
        119
        120
        121
        122
        123
        124
        125
        126
        127
        128
        129
        130
        131
        132
        133
        134
        135
        136
        137
        138
        139
        140
        141
        142
        143
        144
        145
        146
        147
        148
        149
        150
        151
        152
        153
        154
        155
        156
        157
        158
        159
        160
        161
        162
        163
        164
        165
        166
        167
        168
        169
        170
        171
        172
        173
        174
        175
        176
        177
        178
        179
        180
        181
        182
        183
        184
        185
        186
        187
        188
        189
        190
        191
        192
        193
        194
        195
        196
        197
        198
        199
        200
        201
        202
        203
        204
        205
        206
        207
        208
        209
        210
        211
        212
        213
        214
        215
        216
        217
        218
        219
        220
        221
        222
        223
        224
        225
        226
        227
        228
        229
        230
        231
        232
        233
        234
        235
        236
        237
        238
        239
        240
        241
        242
        243
        244
        245
        246
        247
        248
        249
        250
        251
        252
        253
        254
        255
        256
        257
        258
        259
        260
        261
        262
        263
        264
        265
        266
        267
        268
        269
        270
        271
        272
        273
        274
        275
        276
        277
        278
        279
        280
        281
        282
        283
        284
        285
        286
        287
        288
        289
        290
        291
        292
        293
        294
        295
        296
        297
        298
        299
        300
        301
        302
        303
        304
        305
        306
        307
        308
        309
        310
        //#define MY_DEBUG
        //Network
        //Includes
        #include <SI7021.h>
        //Define Relay
        byte direction = 0;
        // Global settings
        int button = -1;
        int button2 = -1;
        void before()
        raHum.clear();
        t1=millis();
        t2=millis();
        delay(250);
        measureCount ++;
        measureCount = 0;
        bool tx = force;
        if (tx)
        measureCount = 0;
        if (button == 1)
        t1 = millis();
        if (button == 0)
        t1 = millis();
        button = 0;
        if (button2 == 1)
        t2 = millis();
        if (button2 == 0)
        t2 = millis();
        button2 = 0;
        button = 1;
        button2 = 1;
        **SKETCH END** */
        Thanks in advance.
        Cheers,
        Erik
        A Offline
        A Offline
        Anticimex
        @erik the sketch enables signing. As per the comment, that require the node to be personalized. Have you done that? And configured the gateway accordingly? If you don't want or don't plan to use signing, comment those flags.
        To the blogger (if he reads this): please be more clear on the implications of using security when posting online.
        E 1 Reply Last reply
        • A Anticimex
          E Offline
          E Offline
          erik
          @anticimex @mfalkvidd thanks for the replies.
          You mean line 41-43? I'm quite new to this, so even though I have bought and attached a wifi device I plan to start simple. A single sensor and water pump, no signing nor gateway. I do have a raspberry pi available, but haven't bought the required pi radio module from what I understand is required.
          A 1 Reply Last reply
          • E erik
            A Offline
            A Offline
            Anticimex
            @erik everything starting with "MY_SIGNING".
            Running a mysensors node without gateway? I don't think that is possible. The gateway is the interface to whateger controller you use/plan to use.
            • A Anticimex
              E Offline
              E Offline
              erik
              @anticimex gotcha. But the article says that if you want to run without a gateway, just skip the wifi part? Am I missing something here?
              • E erik
                A Offline
                A Offline
                Anticimex
                @erik I don't know. I am suspicious of the article since it shows a sketch that enables and enforces signing, but does not mention signing at all, so I don't know how many other assumptions are implicitly hidden in the article.
                As far as I know, a atmega328p device has no wifi capability, so it has to use one of the other radios (nrf24, rfm69, etc) to communicate its data to a receiver. That receiver is designated gateway.
                The only other way I can think of is running sensors directly on the gateway and have the gateway then communicate the sensor data using the gateway protocol in whatever transport the gateway has (which might be wifi).
                • alowhumA Offline
                  alowhumA Offline
                  alowhum
                  @erik said in Irrigation controller:
                  I don't know if it's useful to you, but here's my sketch. I use it to connect 6 analog capacitive sensors to one Arduino Nano, and also attach 6 LED's (or solenoid valves!) to 6 digital outputs.
                  So for example, if plant number 5 is thirsty (<30% moisture), then solenoid 5 will open to give it some water.
                   * This node can measure the moisture of 6 different plants. It uses the cheap 'capacitive analog
                   * moisture sensor' that you can get for about 3 dollars an Aliexpress or eBay. For example:
                   * https://www.aliexpress.com/item/Analog-Capacitive-Soil-Moisture-Sensor-V1-2-Corrosion-Resistant-Z09-Drop-ship/32858273308.html
                   * Each plant' moisture value can also be responded to individually, either by turning on an LED (wire that to the plan, and you can see which one is thirsty) or, if you want, per-plant automated irrigation by connecting a little solenoid..
                   * Todo: Allow the controller to set the threshold values for each plant individually. Unfortunately, Domoticz doesn't support this yet :-(
                  //#define MY_SIGNING_SIMPLE_PASSWD "changeme"           // Useful if your MySensors network is encrypted.
                  #define MY_SPLASH_SCREEN_DISABLED                       // saves a little memory.
                  //#define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE          // saves a little memory.
                  //#define MY_NODE_ID 60                                 // Optional. Sets fixed id with controller.
                  //#define MY_PARENT_NODE_ID 0                           // Optional. Sets fixed id for controller.
                  //#define MY_PARENT_NODE_IS_STATIC                      // Optional. Sets fixed id for controller.
                  #define MY_TRANSPORT_WAIT_READY_MS 10000                // try connecting to the gateway for 10 seconds. Otherwise just continue.
                  //#define MY_RADIO_NRF5_ESB
                  //#define MY_RADIO_RFM95
                  #define MY_RF24_PA_LEVEL RF24_PA_LOW                    // Low power radio setting works better with cheap Chinese radios.
                  #define NUMBEROFSENSORS 6                               // How many sensors are connected?
                  #define DRYNESSTHRESHOLD 45                             // minimum moisture level that is still ok. A lower value will trigger LED/irrigation.
                  #define SLEEPTIME 60                                    // sleep time between the sending of data (in SECONDS). Maximum is 254 seconds. Change "byte" to "int" further down in the code if you want more time between sending updates.
                  unsigned long lastTimeChecked = 0;                      // used by the measurement timer.
                  MyMessage msg(0, V_LEVEL);                              // used to send data to the gateway
                  void before()
                    for (byte i = 3; i < NUMBEROFSENSORS + 3; i++){             // Set the LED (or irrigation vales) to their initial position. Because Mysensors uses pin 2, we use pin 3 till 8 as output.
                      pinMode(i, OUTPUT);
                      digitalWrite(i, LOW);
                    // send the sketch version information to the gateway and Controller
                    sendSketchInfo(F("Plant Sensorium"), F("1.0"));
                    // present the sensors
                    for (byte i=0; i<NUMBEROFSENSORS ; i++) {
                      present(i, S_MOISTURE); // the last i gives the controller a name, in this case the number of the sensor.
                    delay(1000);
                    Serial.println(F("Hello world. Warming up the sensors (15 seconds).")); // to avoid weird measurements
                    delay(15000);
                    static byte measurementCounter = 0;                     // Counts the measurements. Internally the node measures once per second.
                    if (millis() - lastTimeChecked > 1000) {
                      lastTimeChecked = millis();
                      Serial.println(F("__________"));
                      for (int i=0; i<NUMBEROFSENSORS; i++) {               // loop over all the sensors.
                        byte shiftedDigitalPin = i + 3;
                        int16_t moistureLevel = (1023-analogRead(i))/10.23;
                        Serial.print(i);
                        Serial.print(F(" mosture level: "));
                        Serial.println(moistureLevel);
                        if(digitalRead(shiftedDigitalPin) == HIGH){                         // outputs the LED/irrigation status via serial. This code can be removed.
                          Serial.print(F("- currently watering until "));
                          Serial.println(DRYNESSTHRESHOLD + 10);
                        if (moistureLevel < DRYNESSTHRESHOLD){              // if the plant doesn' have enough water, turn on the LED/water.
                          Serial.print(F("- moisture level is below "));
                          Serial.println(DRYNESSTHRESHOLD);
                          digitalWrite(shiftedDigitalPin, HIGH);
                        }else if (moistureLevel >= DRYNESSTHRESHOLD + 10){   // turn of the water/led if the plant is wet enough.
                          digitalWrite(shiftedDigitalPin, LOW);
                        if(measurementCounter < NUMBEROFSENSORS){           // During the first 6 seconds the script will send updated data.
                          if(measurementCounter == i){                      // it sends sensor 0 at second 0. Sensor 1 at second 1, etc. This keeps the radio happy.
                            Serial.println(F("- sending data."));
                            send(msg.setSensor(i).set(moistureLevel));
                        if(measurementCounter > SLEEPTIME){ // If enough time has passed, the counter is reset, and new data is sent.
                        }else{
                          measurementCounter++;
                  • TmasterT Offline
                    TmasterT Offline
                    Tmaster
                    Erik .if you dont have a gateway or mysensors implemented in your house yet,you should do someting simple.that schetch its crazy for a new start person.
                    Some relays that fire by time its enouf. Wifi part that you want provably its realy Wi-Fi,not mysensors conection that its an wireless protocol,(not wifi). We are deep in summer,its not time to make a new irrigation controller from 0 and tryit😋
                    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                    • E Offline
                      E Offline
                      erik
                      @Anticimex well the article spawned my interest but not sure at all about assumptions or similar. I kind of just tried to find relevant parts on AliExpress based on the article and started building. I have bought a nrf24 card to connect. How can I modify the code then to just skip the signing and wifi connectivity for now, just to see if this works?
                      @alowhum nice. How do you define which sensors are connected where? Do I need more code than that? Other libraries (doesn't seem so?).
                      @Tmaster not sure what you are saying here, are the wifi sensors not using Wifi?
                      I bought this module: https://www.aliexpress.com/item/nrf24l0-PA-VER2-0-small-size-of-the-module-high-power-wireless-module-long-distance/32458371131.html and attach it through the socket adapter (which turns 3.3V to 5V) https://www.aliexpress.com/item/1pcs-New-Socket-Adapter-plate-Board-for-8Pin-NRF24L01-Wireless-Transceive-module-51/32656317260.html . The Wifi antenna itself I grabbed from an old router I had laying around. Then attached the module according to the article; VCC to a ”5V” block and pin GND to ”5V GND”. The others were connected: CE to 9, CSN to 10, MOSI to 11, MISO to 12 and SCK to 13.
                      Anyway, that is the Wifi module and of course I am interested in getting that to work as well (perhaps with my raspberry pi?), but the immediate goal is to get it to work at all.
                      Appreciate the help people :)
                      • E erik
                        A Offline
                        A Offline
                        Anticimex
                        @erik to disable signing in the sketch, I already gave you the answer above.
                        • E Offline
                          E Offline
                          erik
                          @Anticimex just tried this, doesn't seem to work.
                          What is the easiest way to debug this? How can I verify that all the components work?
                          12.1k
