  3. MQTT Gateway "hangs" when reconnecting
6 Posts 4 Posters 2.1k Views 1 Watching
  • F
    F
    Fredrik Carlsson
    Hello
    I have experienced with both Node-RED and OpenHAB that when i restart this controllers the gateway stalls and i must manually reset it.
    It is not every time it happens though.
    I have tried to search the forum without success. Has anyone else experienced this?
      marceloaqno
      Code Contributor
      Which gateway type you are using? MQTTGateway? Do you have any log from serial?
      • F
        F
        Fredrik Carlsson
        Yes it's the mqtt gateway. I will try tonight with a to take a debug log. I just have to find a long enough ethernet cable
        • F
          F
          Fredrik Carlsson
          Well.,
          I have tried now for one hour to reproduce the problem without success. I have now a laptop running where the gateway is but have to take this down soon. I will try again another time
            Most probably a powering issue. Try switching to some other power source and add decouple capacitor.
              mainali
              I am facing similar issue, gateway not reachable after a power outage. Have to manually reset the arduino. Please help
