  3. Saving three bytes of memory with this crazy loop structure..
18 Posts 5 Posters 4.0k Views 4 Watching
  • alowhumA
    alowhumA
    alowhum
    In order to use encryption on Arduino Nano's I'm trying to save as much memory as possible. It's a real learning experience.
    In order to create a non-blocking 'once per second' clock without using a (4 byte) long variable I created the monster below. It uses a modulo function to measure seconds instead, as well as a single boolean (1 byte) to make sure the loop runs only once per second.
    (#define LOOPDURATION = 1000)
      static boolean loopDone = false;                        // used to make sure the 'once every millisecond' things only run once every millisecond (or 2.. on very rare occasions the millis() function skips a millisecond.);
      // Main loop to time actions.
      if( (millis() % LOOPDURATION) < 4 && loopDone == false ) {
        loopDone = true;
        // once-per-second stuff here.
      // This resets the loopDone variable after the loop has run.
      if( (millis() % LOOPDURATION) > LOOPDURATION - 4 && loopDone == true ) {
        loopDone = false;
    I'd be curious what you think about this method.
    • It uses more space in the flash memory
    • Does using modulo use a lot of processing power?
    mfalkviddM YveauxY 2 Replies Last reply
    • alowhumA alowhum
          loopDone = true;
          loopDone = false;
      @alowhum trading one (or more) resource(s) for another is what optimizing is about. So if you need ram, this is reasonable. And no, using modulus will not affect the performance of most applications.
      What I would worry about is the maintainability / readability of the code. What happens if you need to modify the code 2 years from now, will you remember how it works? What is the risk of introducing new bugs or strange side-effects? Is that risk worth saving the ram? If it is, then you use it. I don't see it being anything more complicated than that.
      AffordableTechA 1 Reply Last reply
      • alowhumA alowhum
            loopDone = true;
            loopDone = false;
        YveauxY
        YveauxY
        @alowhum I guess that if your loop runs slower than once every 4ms you might miss the 1 second deadline.
        How about this?
            static uint8_t first = 1;
            static uint8_t secsPrev;
            uint8_t secs = millis() / 1000;
            if (first or (secs != secsPrev))
                // ... code that runs every second...
                secsPrev = secs;
            first = 0;
        For AVR:
        Flash: 602 bytes vs 634
        Ram: 12 bytes vs 10 (you beat me there ;-) )
        Or even, when timing doesn't need to be too accurate (2.4% slower):
            uint8_t secs = millis() >> 10;
                secsPrev = secs;
            first = 0;
        For AVR:
        Flash: 526 bytes vs 634
        Ram: 12 bytes vs 10
        Can we go even lower? :muscle:
        • YveauxY Yveaux
          How about this?
                  secsPrev = secs;
              first = 0;
          For AVR:
                  secsPrev = secs;
              first = 0;
          For AVR:
          Ram: 12 bytes vs 10
          @yveaux you could probably use the MSB of secsPrev for the "first" boolean and save a byte of ram?
          YveauxY 1 Reply Last reply
            YveauxY
            YveauxY
            @mfalkvidd
                static int8_t secsPrev = -1;
                const int8_t secs = int8_t(millis() / 1000) & 0x7F;
                if ((secsPrev < 0) or (secs != secsPrev))
                    secsPrev = secs;
            For AVR:
            Flash: 595 bytes vs 634
            Ram: 11 bytes vs 10 (almost there ;-) )
            Wheeeeeeeeeee!
              An alternative is to move the counter to another hardware resource (a timer, for instance):
                cli();
                TCCR1A = 0;// set entire TCCR1A register to 0
                TCCR1B = 0;// same for TCCR1B
                TCNT1  = 0;//initialize counter value to 0
                // set compare match register for 1hz increments 15624 for 16MHz, 7812 for 8MHz
                OCR1A = 7812;// = (16*10^6) / (1*1024) - 1 (must be <65536)
                // turn on CTC mode
                TCCR1B |= (1 << WGM12);
                // Set CS10 and CS12 bits for 1024 prescaler
                TCCR1B |= (1 << CS12) | (1 << CS10);
                // enable timer compare interrupt
                TIMSK1 |= (1 << OCIE1A);
                sei();
              volatile uint8_t shouldRun = 1;
              ISR(TIMER1_COMPA_vect) {
                shouldRun = 1;
                // put your main code here, to run repeatedly:
                if (shouldRun) {
                  shouldRun = false;
              Flash 570 bytes
              Ram: 11 bytes
              This solution uses 1 byte less (or is it 3 bytes, since it also uses 2 pointers less?) on the stack as well, which might make a difference. But it reserves timer1, which might or might not be OK depending on your application.
                  cli();
                  // turn on CTC mode
                  sei();
                  shouldRun = 1;
                  if (shouldRun) {
                    shouldRun = false;
                Flash 570 bytes
                Ram: 11 bytes
                YveauxY
                YveauxY
                @mfalkvidd Nice one!
                To quote @mfalkvidd : "What I would worry about is the maintainability / readability of the code" ;-)
                • alowhumA
                  alowhumA
                  alowhum
                  Wow, what a response! Amazing stuff!
                  thanks @mfalkvidd for the explanation.
                  @Yveaux that millis() / 1000 is very elegant. That's a very interesting direction.
                  For now though, looking at some of the creations.. I think I'll stick with my modulo system for readability :-D Very cool though.
                  tekkaT 1 Reply Last reply
                  • alowhumA alowhum
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    @Yveaux @mfalkvidd Now it gets ugly - and we are not talking ASM yet... :stuck_out_tongue_winking_eye:
                    ISR (WDT_vect) {
                      WDTCSR = _BV(WDCE) | _BV(WDE);
                      WDTCSR = _BV(WDIF) | _BV(WDIE) | 6; // 1s
                      EEARL = 1;
                      WDT_vect();
                        if(EEARL) {
                          EEARL = 0;
                    Flash: 502 bytes
                    Ram: 9 bytes
                    • alowhumA
                      alowhumA
                      alowhum
                      @tekka Whoa :-) Can you elaborate what your code voodoo does a little bit?
                      For a balance of readability, I was pondering how to make this:
                      • Divide millis() / 1000
                      • round that down
                      • get the last bit of that rounded down variable
                      • if that last bit is different that before, a second has passed.
                      YveauxY tekkaT 2 Replies Last reply
                      • alowhumA alowhum
                        • round that down
                        YveauxY
                        YveauxY
                        @alowhum that's exactly what my first code snippet does (apart from testing the lowest bit, but you don't need that. Change in seconds is sufficient)
                        • alowhumA
                          alowhumA
                          alowhum
                          @Yveaux I know, I really like it. But I was thinking about shaving of another byte somehow :-)
                          • alowhumA alowhum
                            • round that down
                            tekkaT
                            tekkaT
                            tekka
                            @alowhum Instead of a timer, the watchdog interrupt is used to set a flag on a (in this sketch) not-used eeprom addressing register (EEARL)...certainly not a generic approach, but functional :smiley:
                            • tekkaT tekka
                              @tekka so it wouldn't work in a MySensors sketch? That's cheating ;-)
                                tekkaT
                                tekkaT
                                tekka
                                @mfalkvidd Strictly speaking, only @Yveaux's solution would work without modifications to the MySensors core :) But the challenge was weakly defined, so no cheating in that sense :sweat_smile:
                                • tekkaT tekka
                                  @tekka would it? I verified that my solution worked on a serial gateway. But maybe there was some aspect that I didn't test, that would fail.
                                  • tekkaT tekka
                                    YveauxY
                                    YveauxY
                                    @tekka I couldn't agree more ;-)
                                    IMHO readability is the differentiator here.
                                      AffordableTechA
                                      AffordableTechA
                                      AffordableTech
                                      Hi @mfalkvidd,
                                      Problem is, when your code can't compile because you are one (or several) bytes short of ram, nothing else matters.
                                      As to readability, I assume you know about that rarely used compiler feature called 'comments'? I hear they use zero Arduino RAM and even less ROM memory. :flushed:.
                                      Ok, I'm just being cheeky, so don't flame me, it just seemed a good opportunity for a reminder to everybody. Point being we are all guilty of not using enough comments in our code.
                                      You said you are worried about readability and maintainability - it's just like code backups, it's a problem only because we only worry about them 'after' a drive crash, or in the case of comments, two years later when we are trying to remember what the hell this weird code does.. THE REALITY: If we are really worried, we would add liberal comments and do regular backups - otherwise I say we're not really 'that' worried.
                                      Cheers,
                                      Paul
