  3. Saving three bytes of memory with this crazy loop structure..
18 Posts 5 Posters 4.0k Views 4 Watching
  • alowhumA alowhum
    Wow, what a response! Amazing stuff!
    thanks @mfalkvidd for the explanation.
    @Yveaux that millis() / 1000 is very elegant. That's a very interesting direction.
    For now though, looking at some of the creations.. I think I'll stick with my modulo system for readability :-D Very cool though.
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    @Yveaux @mfalkvidd Now it gets ugly - and we are not talking ASM yet... :stuck_out_tongue_winking_eye:
    ISR (WDT_vect) {
      WDTCSR = _BV(WDCE) | _BV(WDE);
      WDTCSR = _BV(WDIF) | _BV(WDIE) | 6; // 1s
      EEARL = 1;
      WDT_vect();
        if(EEARL) {
          EEARL = 0;
          // ... code that runs every second...
    Flash: 502 bytes
    Ram: 9 bytes
    • alowhumA
      alowhumA
      alowhum
      @tekka Whoa :-) Can you elaborate what your code voodoo does a little bit?
      For a balance of readability, I was pondering how to make this:
      • Divide millis() / 1000
      • round that down
      • get the last bit of that rounded down variable
      • if that last bit is different that before, a second has passed.
      YveauxY tekkaT 2 Replies Last reply
      • alowhumA alowhum
        • round that down
        @alowhum that's exactly what my first code snippet does (apart from testing the lowest bit, but you don't need that. Change in seconds is sufficient)
        • alowhumA
          alowhumA
          alowhum
          @Yveaux I know, I really like it. But I was thinking about shaving of another byte somehow :-)
          • alowhumA alowhum
            • round that down
            tekkaT
            tekkaT
            tekka
            @alowhum Instead of a timer, the watchdog interrupt is used to set a flag on a (in this sketch) not-used eeprom addressing register (EEARL)...certainly not a generic approach, but functional :smiley:
            • tekkaT tekka
              @tekka so it wouldn't work in a MySensors sketch? That's cheating ;-)
              tekkaT 1 Reply Last reply
                tekkaT
                tekkaT
                tekka
                @mfalkvidd Strictly speaking, only @Yveaux's solution would work without modifications to the MySensors core :) But the challenge was weakly defined, so no cheating in that sense :sweat_smile:
                mfalkviddM YveauxY 2 Replies Last reply
                • tekkaT tekka
                  @tekka would it? I verified that my solution worked on a serial gateway. But maybe there was some aspect that I didn't test, that would fail.
                  • tekkaT tekka
                    @tekka I couldn't agree more ;-)
                    IMHO readability is the differentiator here.
                      @alowhum trading one (or more) resource(s) for another is what optimizing is about. So if you need ram, this is reasonable. And no, using modulus will not affect the performance of most applications.
                      What I would worry about is the maintainability / readability of the code. What happens if you need to modify the code 2 years from now, will you remember how it works? What is the risk of introducing new bugs or strange side-effects? Is that risk worth saving the ram? If it is, then you use it. I don't see it being anything more complicated than that.
                      AffordableTechA
                      AffordableTechA
                      AffordableTech
                      Hi @mfalkvidd,
                      Problem is, when your code can't compile because you are one (or several) bytes short of ram, nothing else matters.
                      As to readability, I assume you know about that rarely used compiler feature called 'comments'? I hear they use zero Arduino RAM and even less ROM memory. :flushed:.
                      Ok, I'm just being cheeky, so don't flame me, it just seemed a good opportunity for a reminder to everybody. Point being we are all guilty of not using enough comments in our code.
                      You said you are worried about readability and maintainability - it's just like code backups, it's a problem only because we only worry about them 'after' a drive crash, or in the case of comments, two years later when we are trying to remember what the hell this weird code does.. THE REALITY: If we are really worried, we would add liberal comments and do regular backups - otherwise I say we're not really 'that' worried.
                      Cheers,
                      Paul
