  3. OpenHAB
  4. openHab binding 2.4.0 Variable Problem ( 2.4.0.201806211605)
2 Posts 1 Posters 2.7k Views 3 Watching
  • I
    I
    itbeyond
    @TimO I posted something in the thread https://forum.mysensors.org/topic/9346/getting-mysensors-mqtt-gateway-working-on-openhab-2-2-stable/40 but just did another full round of testing to be sure so adding a new thread to get the conversation started. I have just set a test node that sits on my desk and have added the var1 item to an already well working test node - it is a switch and was not using any vars etc. So I editted the node code and added a loop request for var1 every 30 seconds.
    Here is the code for this node
     * Version 1.0 - Henrik Ekblad
    #define MY_RF24_CHANNEL 82
    #define MY_RF24_IRQ_PIN 2
    #define MY_RX_MESSAGE_BUFFER_FEATURE
    #define MY_NODE_ID 27  // Set this to fix your Radio ID or use Auto
    //#define MY_REPEATER_FEATURE
    #define MY_TRANSPORT_SANITY_CHECK
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    #define RELAY_UNKNOWN 2
    int CurrentState[] = {RELAY_UNKNOWN, RELAY_UNKNOWN, RELAY_UNKNOWN, RELAY_UNKNOWN};
    int SetState[] = {RELAY_OFF, RELAY_OFF, RELAY_OFF, RELAY_OFF};
    unsigned long requestVar1Last = millis();
    unsigned long requestVar1Time = 30000;
    MyMessage relayMsg(0, V_STATUS);
    void before() {
      wdt_enable(WDTO_2S);
        pinMode(pin, OUTPUT);
        SetState[sensor] = RELAY_OFF;
        request(sensor, V_STATUS);
        delay(50);
        request(sensor, V_VAR1);
      sendSketchInfo("Power Socket (7)", "4.1");
      for (int sensor=1; sensor<=NUMBER_OF_RELAYS; sensor++) {
        present(sensor, S_BINARY);
      wdt_reset();
          if (CurrentState[sensor] != SetState[sensor] && SetState[sensor] != RELAY_UNKNOWN) {
            digitalWrite(pin, SetState[sensor]?RELAY_ON:RELAY_OFF);
            CurrentState[sensor] = SetState[sensor];
            resend(relayMsg.setSensor(sensor).set(CurrentState[sensor]), 5);
      if (requestVar1Last + requestVar1Time < millis()) {
         request(1, V_VAR1);
    void resend(MyMessage &msg, int repeats)
      int repeat = 1;
      int repeatdelay = 0;
      boolean sendOK = false;
      while ((sendOK == false) and (repeat < repeats)) {
        if (send(msg)) {
          sendOK = true;
        } else {
          sendOK = false;
          Serial.print("Send Failed: ");
          Serial.println(repeat);
          repeatdelay += 50;
        } repeat++; wait(repeatdelay);
      int sensor = message.sensor;
      if (message.type==V_STATUS) {
        // Change relay state
        SetState[sensor] = message.getBool();
        // Write some debug info
        Serial.print(F("Incoming change for sensor:"));
        Serial.print(message.sensor);
        Serial.print(F(", New status: "));
      if (message.type == V_VAR1) {
        int variable1 = atoi(message.data);// RUN_ALL_ZONES time
        Serial.print(F("Recieved variable1: "));
        Serial.println(variable1);
    I added the item to openHab ad follows:
    Switch   Desktop_Debug_Light "Desktop Debug Light" <light> (gDevices,gRoom_Office) [ "iss:type:DevSwitch", "iss:room:Entry" ]  {channel="mysensors:light:gateway:Desktop_Debug_Light:status"}
    Number  Desktop_Debug_Var1 "Desktop Debug Light- Var1 [%d]" <selfruntime>  (gDevices,gRoom_Office)   {channel="mysensors:light:gateway:Desktop_Debug_Light:var1"}
    I used Paper UI and set the variable to 10 - this pushed the update to the node correctly. I then rebooted openHab which using persistance restores the variable 1 value back to 10 however when the node requests var1 from the controller after the reboot it receives 0. I have found this to be the same if I do an postUpdate. The var1 container on openHab has the 10 value in it I have confirmed this with a Rest API commnd the GET the item.
    Here is the logs from the openHab log:tail and also the node I have added comments where the reboot happened and you will see the results:
    2018-08-28 08:23:22.581 [.ItemChannelLinkAddedEvent] - Link 'Desktop_Debug_Var1-mysensors:light:gateway:Desktop_Debug_Light:var1' has been added.
    2018-08-28 08:24:08.812 [ome.event.ItemCommandEvent] - Item 'Desktop_Debug_Var1' received command 10
    2018-08-28 08:24:08.829 [vent.ItemStateChangedEvent] - Desktop_Debug_Var1 changed from NULL to 10
    REBOOTED THE OPENHAB SERVER
    2018-08-28 08:27:40.145 [temChannelLinkRemovedEvent] - Link 'Desktop_Debug_Var1 => mysensors:light:gateway:Desktop_Debug_Light:var1' has been removed.
    2018-08-28 08:28:57.469 [.ItemChannelLinkAddedEvent] - Link 'Desktop_Debug_Var1-mysensors:light:gateway:Desktop_Debug_Light:var1' has been added.
    2018-08-28 08:29:08.389 [vent.ItemStateChangedEvent] - Desktop_Debug_Var1 changed from NULL to 10.0
    2280 TSF:MSG:SEND,27-27-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    2286 MCO:BGN:INIT OK,TSP=1
    2290 TSF:MSG:SEND,27-27-0-0,s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
    2317 TSF:MSG:READ,0-0-27,s=1,c=1,t=2,pt=0,l=1,sg=0:1
    Incoming change for sensor:1, New status: 1
    2521 TSF:MSG:READ,0-0-27,s=1,c=1,t=24,pt=0,l=2,sg=0:10
    Recieved variable1: 10
    30002 TSF:MSG:SEND,27-27-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    30026 TSF:MSG:READ,0-0-27,s=1,c=1,t=24,pt=0,l=2,sg=0:10
    ***** REBOOT OF OPENHAB SERVER *******
    60010 TSF:MSG:SEND,27-27-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    90018 TSF:MSG:SEND,27-27-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    120026 TSF:MSG:SEND,27-27-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    150038 TSF:MSG:SEND,27-27-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    ***** OPENHAB UP AGAIN ********
    150090 TSF:MSG:READ,0-0-27,s=1,c=1,t=24,pt=0,l=1,sg=0:0
    Recieved variable1: 0
    180046 TSF:MSG:SEND,27-27-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    180071 TSF:MSG:READ,0-0-27,s=1,c=1,t=24,pt=0,l=1,sg=0:0
    210054 TSF:MSG:SEND,27-27-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    210073 TSF:MSG:READ,0-0-27,s=1,c=1,t=24,pt=0,l=1,sg=0:0
    You can see the PaperUI update at 2018-08-28 08:24:08.829 which corresponds with the 30026 TSF:MSG:READ,0-0-27,s=1,c=1,t=24,pt=0,l=2,sg=0:10. I then rebooted and the server restored the value of 10 but the node continues to receive 0 and does so for ever - it never gets the value 10.
    Here is the output of the item using the REST API which is taken well after the reboot and after many request(1,V_VAR1)'s is still reporting 0.
    http://openhabianpi:8080/rest/items/Desktop_Debug_Var1
      "link": "http://openhabianpi:8080/rest/items/Desktop_Debug_Var1",
      "state": "10.0",
      "stateDescription": {
        "pattern": "%d",
        "readOnly": false,
        "options": []
      "editable": false,
      "type": "Number",
      "name": "Desktop_Debug_Var1",
      "label": "Desktop Debug Light- Var1",
      "category": "selfruntime",
      "tags": [],
      "groupNames": [
        "gDevices",
        "gRoom_Office"
    http://openhabianpi:8080/rest/items/Desktop_Debug_Var1/state
    10.0
    As mentioned the variable received at the node never updates also if we use a postUpdate in openHab it will continue to receive 0 until we issue a sendCommand at which time it will update until the next postUpdate or server reboot.
    I 1 Reply Last reply
    • I itbeyond
      void before() {
          delay(50);
        wdt_reset();
           request(1, V_VAR1);
        int repeat = 1;
          if (send(msg)) {
            sendOK = true;
          } else {
            sendOK = false;
            repeatdelay += 50;
        "state": "10.0",
          "pattern": "%d",
          "readOnly": false,
          "options": []
        "editable": false,
        "type": "Number",
        "tags": [],
        "groupNames": [
          "gDevices",
          "gRoom_Office"
      10.0
      I
      I
      itbeyond
      @itbeyond said in openHab binding 2.4.0 Variable Problem ( 2.4.0.201806211605):
      Bug reported to Github issues at: https://github.com/tobof/openhab2-addons/issues/126
