  3. Home Assistant
  4. Presenting to HA over ethernet
2 Posts 2 Posters 1.2k Views 2 Watching
  • T
    tdecurtins
    Just reading into Mysensors and my main question is on presenting to the controller. Would I just be able to set the IP address of the HA controller on the gateway and then it will automatically show show up in HA? I understand I would at least need to add Mysensors into the config on the HA controller. But if the sensors could just show up after that, that would be amazing!
    • T tdecurtins
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @tdecurtins
      https://www.home-assistant.io/components/mysensors/#presentation
      Home assistant only supports ethernet gateways that act as servers. So home assistant will connect as the client, ie we only configure the gateway address in home assistant, not the other way around.
