  3. Everything nRF52840
Everything nRF52840
323 Posts 28 Posters 177.3k Views 33 Watching
  • U Uhrheber
    One interesting thing I stumbled upon:
    https://github.com/insane-adding-machines/unicore-mx
    UniCore-MX | Universal Core for ARM Cortex-M0/0+/3/4/7/X
    Supports nRF51/52
    NeverDieN
    NeverDieN
    #141
    @uhrheber said in Everything nRF52840:
    Supports nRF51/52
    I looked at the link, but I can't figure out what problem it's solving. What's the headline on that?
    • RedferneR Redferne
      @heinzv
      1. It does use the S140 v6.1.0 Softdevice, however I have only "ported"/test the most basic SDK 15.2 BLE feature of @sandeepmistry BLEPheriphal BLEPeripheral. The example shows as BLEService and Read/Writeable BLECharCharacteristic used to toggling the onboard LED. I was hoping we could get more developers involved and "port" the missing pieces, if there's interrest. My main focus was just to get something Arduino-like running using PlatformIO build system on the cheap (~$10) NRF52840 dongle.
      2. I have tested Black Magic Probe (Bluepill) and JLink Mini on the PCA10059 with great success. It also possible to use the nrfutil to create a dfu.zip. The Nordic Open DFU Bootloader (which is pre-flashed on PCA10059) allows easy programming without soldering, just plug-in USB.
      First get and install the nrfutil from here
      1. Linux environment example, first build the PCA10059 example project:
      pio run -e ble
      1. Generate a dfu.zip including the softdevice:
      nrfutil pkg generate --hw-version 52 --debug-mode --sd-req 0x00 --sd-id 0xAE --application .pioenvs/ble/userfirmware.hex --softdevice ~/.platformio/packages/framework-arduinonordicnrf5/cores/nRF5/SDK/components/softdevice/s140/hex/s140_nrf52_6.1.0_softdevice.hex dfu.zip
      1. Plugin the PCA10059 dongle in a USB port. Make sure that the Bootloader is executing by checking the RED led, should be "breathing". Else press the reset button. Now flash the new firmware, here the dongle was enumerated as ACM3.
      nrfutil dfu usb-serial --package dfu.zip --port /dev/ttyACM3
      ... and Bob's your uncle :smile_cat:
      H
      H
      heinzv
      @redferne I was trying to get your platform and board extention as wellas the BLE library added to platformio, but got stuck afetr many many hours and many attempts (too much to add all the problems in one post). I'm using platformio with Windows 10 (I guess you use it with Linux/Ubuntu and also with a couple of command line tools)
      I was trying to install this two:
      https://github.com/Redferne/arduino-nRF5
      Redferne/arduino-BLEPeripheral
      I was trying to build a couple of simple examples and also the
      C:\users\internet.platformio\lib\BLEPeripheral\src\BLEBondStore.cpp:11:12: fatal error: nrf_soc.h: No such file or directory
      and
      C:\users\internet.platformio\lib\BLEPeripheral\src/BLEPeripheral.h:136:5: error: 'nRF52840' does not name a type; did you mean 'NRF52840'?
      and all other following errors are probably the result of the above ones.
      Any hints?
      Another question: How to define/declare the usage of the S140 softdevice in the project?
      Using the PlatformIO IDE, not the command line.
      RedferneR 1 Reply Last reply
      • NeverDieN
        NeverDieN
        As pointed out by @reinhold, here's a handy tool for programming your nRF52840 dongle, and possibly other nRF52 projects too:
        https://www.tindie.com/products/ElectronutLabs/pogoprog-model-c-pogo-pin-programmer-swd-2-pack/
        I think I'd like it better if it could somehow latch itself to the board, though, so that I could also get debugging information hands free without having to continually press the tool up against the board.
        • H heinzv
          and
          Any hints?
          RedferneR
          RedferneR
          Redferne
          @heinzv I'm sorry if I was unclear. I have only updated and tested one example which is the PCA10059 It should build without errors, but you might need to specify build type as "ble" or "dongle" as per the readme.
          To enable the NRF52840 support use these flags:
          -DNRF52 -DNRF52840 -DNRF52840_XXAA
          and if building with the BLE Peripheral library and Softdevice S140 add:
          -DNRF52 -DNRF52840 -DNRF52840_XXAA -DNRF52_S140
          • NeverDieN
            NeverDieN
            I have basic radio code now working in micropython: https://github.com/rabbithat/micropython_nRF52840/blob/master/README.md
            So, I'm inching closer toward being able to do OTA code updates. :smiley:
            • alowhumA
              alowhumA
              alowhum
              @neverdie Does this also mean we're slightly closer to a MySensors implementation in MicroPython?
              NeverDieN 1 Reply Last reply
              • alowhumA alowhum
                NeverDieN
                NeverDieN
                @alowhum said in Everything nRF52840:
                Theoretically. ;)
                • NeverDieN
                  NeverDieN
                  #148
                  By the way, I have it now to where you can send long strings (up to 255 characters if so desired) in a single packet from one node to another using micropython: https://github.com/rabbithat/Micropython_nRF52840_send
                  So, it's starting to get useful. I expect OTA code updates should be within range fairly soon. Since it's all written in micropython, I'll be able OTA update even the radio code as well, which is slick. :sunglasses:
                  • alowhumA
                    alowhumA
                    alowhum
                    Very cool!
                    • NeverDieN
                      NeverDieN
                      #150
                      I have my first pass on nRF52840 OTA updates working with micropython. So, proof of concept works. :smile: I feel I should improve the code a bit before posting it though. I should probably add a hash function like MD5 or SHA256 to make sure the transmitted update is valid before making it go live.
                      monteM O 2 Replies Last reply
                      • NeverDieN NeverDie
                        monteM
                        monteM
                        monte
                        @neverdie YAY for transport-agnostic mysensors-python-edition!
                          O
                          O
                          Omemanti
                          @neverdie would this also be usable for the nrf52832? (Not asking for an ETA here :))
                          • WormholeW
                            WormholeW
                            Wormhole
                            I've recently purchased a couple of the nrf52840 dongles and was searching web for ways to flash them and came across this post. I am a complete NOOB with this stuff, so I've found the information here really useful, so thanks to all who have contributed.
                            During my searches, I can across this; HOME SMART MESH (https://www.homesmartmesh.com/). It seems very similar to what MySensors is doing, but geared towards nrf5 hardware. Was wondering if you had seem this before, or had any thoughts on the project re: pros and cons?
                            H 1 Reply Last reply
                            • WormholeW Wormhole
                              H
                              H
                              heinzv
                              wrote on last edited by heinzv
                              #154
                              @wormhole I took a quick look at this HomeSmartMesh project and it's certainly interesting.
                              However, the MySensors project is more mature, has a large community, supports more MCU's and sensors and many HW projects are using/supporting it. It also supports nRF51 and nRF52 MCU's already to a certain extent (I guess using the internal nRF24 radio protocol and external RF chips like RFM69/95).
                              Beside that, it supports also a couple of home automations suite like FEHM, OpenHAB etc.
                              I'm currently on OpenHAB 2.3 using the MySensors Gateway for OpenHAB.
                              I think it would be rather a good idea, that we get the new nRF52840 features and RF protocols supported by MySensors (such as the BLE 5.0 with the long range feature).
                              We had already the discussions on IEEE 802.15.4 / Thread / Zigbee which are also great for home automation. The question was also, if we can/should include it in MySensors or are these competing technology stacks to MySensors.
                              I personally like the MySensors project, because it project a good development infrastructure with a lot of supported/preconfigures sensors which makes it quite easy to creates sensor nodes..
                              Now we are exploring how to best integrate and use the nRF52840 boards. NeverDie seem to be quite ahead of us and exploring also micropython option (not sure how far that fits into the MySensors concept :-)
                              • NeverDieN
                                NeverDieN
                                #155
                                I now have working OTA update code for micropython programs on the nRF52840. I posted it on github: https://github.com/rabbithat/NRF52840_MicroPython_OTA_Updates
                                :sunglasses:
                                  :sunglasses:
                                  H
                                  H
                                  heinzv
                                  @neverdie You are a hero :-) Now the question is of course what comes next? Do you see any chance to get some of the findings implemented into the MySensors project? or will it be a completly new nRF52840 thread/story? Like using ZigBee or BLE 5.0 long range (remember the discussion we had with @scalz if it makes sense to use MySensors aor use a full standard stack like ZigBee or BLE 5.0).
                                  What are your thoughts and plans? Best option to build sensor nodes/actors with nRF52840?
                                  • H heinzv
                                    NeverDieN
                                    NeverDieN
                                    #157
                                    @heinzv said in Everything nRF52840:
                                    Well, as the saying goes, Rome wasn't built in day. I think there's no doubt that MySensors could be built using MicroPython, but right now there is no Rome and there's barely even a camp site. It's all just green fields and a few scattered tents. Also, I am just one person, and this is still early days. My near-term plan is to improve the OTA code to make it faster and more efficient. Right now, perhaps ironically, maybe the only reason to prefer Micropython over C is the existence of this OTA code. If someone writes an OTA bootloader for the nRF52840 in C, maybe that reason goes away. I might have done that instead, but this seemed a shorter path to getting an OTA.
                                    In the end, programming the nRF52840 is, at this stage, almost like writing micro code. In other words, it almost doesn't matter which language you pick (provided it has an OTA updater), because the focus ends up being the same: fiddling with the registers and programming the PPI in order to get the highest efficiency.
                                      H
                                      H
                                      heinzv
                                      #158
                                      @neverdie sure, I did not epect Rome to be built in one day by one person :-) I was just curiuos in which direction you're heading.
                                      If the OTA feature is one of the key features, I was thinking of using a couple of information provided by Nordic such as as details on the OTA/flashing process of the nRF52 as well as the OTA DFU bootloader example provided as part of the 15.2 SDK.
                                      OTA/Flash process
                                      https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk52.v0.9.0%2Fbledfu_architecture.html
                                      http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.tools%2Fdita%2Ftools%2FnRF_Connect%2FnRF_Connect_DFU.html
                                      OTA/Flash sources in C/C++
                                      Just a few thoughts (I have to investiage) if we could use the sequence from the bootloader examples and they used libs for receiving data/code and initialized the flash process using the provided libraries
                                      nRF5_SDK_15.2.0\components\libraries\bootloader
                                      here I see in the dfu sub-dir the required function to observer, receiver and flash code
                                      There a multiple examples how the code is transfered: via USB/serial, BLE/Zigbee, ANT ... and I guess we could use also the nRF24 protocol. Also encryption functions are available in the samples (secure dfu bootloader).
                                      We need to derive, what nee to be done on the sender side to start to set the target to dfu mode and initiate the code transfer. Maybe that is also a tricky task.
                                      Do you see that this approach can work and could be added to own C/C++ sketches and thus also added the MySensors project (of coure we need to include and use the required nRF52 libs for dfu)?
                                      • NeverDieN
                                        NeverDieN
                                        I don't doubt that it can be done. The amount of effort? It could be a little or a lot. I just don't know.
                                        • NeverDieN
                                          NeverDieN
                                          #160
                                          By the way, I now have the micropython code in a state where it is more easily demoed: https://github.com/rabbithat/NRF52840_MicroPython_OTA_Updates
                                          Rather than continuing to post here about it, I'll just make future updates there. So, if anyone here is interested in it, you may want to check the github repository from time to time. :spock-hand:
