π¬ EFEKTA Temp&Hum sensor(ver. nRF52 )+E-Ink display
@jeti said in π¬ EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
One question: the high temperature is a result of testing? So with a long enough sleep time the temp will be accurate?
Don't quite understand the question. The chip is not heated. No matter how much the device sleeps, the temperature sensor also sleeps. A digital temperature and humidity sensor is used.
@berkseo on the second restart the temperature shows 46Β°C that's why in wondered of this is caused by testing. As during "normal" using this should not be an issue
@jeti
On video, now I understand)). Used software for the Atmega328 , so was error. This chip is very fast. I fix it. -
Once the code is available I would order 10x PCB's.
Also, do you have a link to the nRF52832 module? (a 840 version would be also very nice :-))ok, I just odered the 5 PCB Sets.
Beside the link to the nRF52832 Module, please provide also the link to the e-Paper Module. -
Really nice design..
Could you please post the schematics / board files as well, as this is a openhardware site.
Also if you upload the gerber files directly (not in a zip / rar file), then the openhardware.io site is able to render 3D views of the boards etc.
Beside the link to the nRF52832 Module, please provide also the link to the e-Paper Module.@heinzv said in π¬ EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
Beside the link to the nRF52832 Module, please provide also the link to the e-Paper Module.Code in the work. BOM added.
@tbowmo
Thank you for rating. I will lay out the scheme in the near future, it needs to be drawn :). 3D-model does not work, it turns out a piece of cheese. I work at Diptrace( https://diptrace.com ), but this problem is not only mine - https://forum.mysensors.org/topic/9528/temperature-and-humidity-sensor-ver-atmega328-e-ink-display/30 -
@jeti
So far I'm satisfied, there is one point with updating the screen. I do not really want to do a full update in the program, but probably have to. Partial update gives the effect of visible lines from the previous symbol. Look at the photo, but it is a problem of code and beauty :)
@jeti
The work of the program was changed. Now the screen update is better. Looks more beautiful :)
@berkseo cool thanks for your update, really impressive which detail you are aiming to achieve!
I'm planning to get some as soon as possible :-) already gathering the parts. Any chance you upload the PCB?@jeti said in π¬ EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
I'm planning to get some as soon as possible already gathering the parts. Any chance you upload the PCB?PCB files have already been added, they are in the archives.
@berkseo I have ordered already the 10x PCB's and also most of the BOM. I'm also going to order one full mounted PCB (if still available).
Can you do me a favour: I need one decimal digit for the temp (not required for hum) but certainly for the temp!
Here is a hint/proposal: You can make the decimal digit smaller. I attach one sample from a Xiaomi device (unfortunatly has no wireless and not sure if/how it can be hacked and wireless added).
Here is a hint/proposal: You can make the decimal digit smaller. I attach one sample from a Xiaomi device (unfortunatly has no wireless and not sure if/how it can be hacked and wireless added).Do you want me to change the SOFTWARE a bit? Well, I do not think this is a problem. Question ... Maybe you like some kind of special font? I donβt know which one to use. I can also add technical sensors that can set device parameters through the controller of an intelligent home. An example of such sensors, see the video of my new prototype sensor. ... Now there is only one device left, but I plan to make a little more by the end of next week (I hope :)). Since I started posting my projects on openhardware, I realized that I donβt like to solder for sale, itβs not interesting :)
Note, the device consists of two printed circuit boards, the order system on openhardware does not allow you to add two printed circuit boards for one device, just formed a second revision. For self-order download archives.
@berkseo Yes, I'd like to change the SW so that the temp shows also one decimal like 21,6 C
For the decimal a smaller font likes quite nice such as shown in the picture of the sensor from Xiaomi.
I don't have a specical font in mind but rather recommend to take proportional font rather than a mono-space font whcih is rather used for debugger output but not for a productive end user display. The space between the digits is typically smaller/less using a proportional font and looks more elegant than using mono-font.I know, that the 10 PCB's are 5 + 5 (5 sets).
I can imagine, that selling soldered PCB's is not a very interesting business and is boring and time consuming for just little amount of money. I was buying one just as reference and will solder the other 5 sets by myself. I know how much effort that is.
With your input, this post could be even better π
