DHT11 Example Code on Arduino
Hey guys!
I could really need some help here, for some reason I am not able to get my sensor node to work.What I have:
An Arduino Nano (Also tested with Uno), an NRF24 and a DHT11 sensor.
Also I have a working OpenHAB install on a RPi and a NodeMCU with another NRF24.The Pi is running mosquitto and the NodeMCU is acting as a gateway; I am able to connect to my broker via MQTT.fx and can see messages coming in from the gateway.
The critical part is the sensor node; I am using the example code (I downloaded the extra examples with the known-working libraries) "DhtTemperatureAndHumiditySensor.ino"; my DHT11 is connected to pin 3.
When I use a short test-sketch to just read the sensor and print it to the serial console it's working fine, so I am sure the sensors is working fine.The output on the serial console is:
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.3.0 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0 25 TSM:INIT 26 TSF:WUR:MS=0 33 TSM:INIT:TSP OK 35 TSM:FPAR 37 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2046 !TSM:FPAR:NO REPLY 2049 TSM:FPAR 2051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 4059 !TSM:FPAR:NO REPLY 4061 TSM:FPAR 4063 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 6071 !TSM:FPAR:NO REPLY 6073 TSM:FPAR 6075 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 8083 !TSM:FPAR:FAIL 8084 TSM:FAIL:CNT=1 8086 TSM:FAIL:DIS 8088 TSF:TDI:TSL 18091 TSM:FAIL:RE-INIT 18093 TSM:INIT 18100 TSM:INIT:TSP OK 18102 TSM:FPAR 18104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 20112 !TSM:FPAR:NO REPLY 20114 TSM:FPAR 20116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 22124 !TSM:FPAR:NO REPLY 22126 TSM:FPAR 22128 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 24136 !TSM:FPAR:NO REPLY 24138 TSM:FPAR 24140 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 26148 !TSM:FPAR:FAIL 26149 TSM:FAIL:CNT=2 26151 TSM:FAIL:DIS 26153 TSF:TDI:TSL 36157 TSM:FAIL:RE-INIT 36159 TSM:INIT 36166 TSM:INIT:TSP OK 36168 TSM:FPAR 36170 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 38178 !TSM:FPAR:NO REPLY 38180 TSM:FPAR 38182 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 40192 !TSM:FPAR:NO REPLY 40194 TSM:FPAR 40196 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 42204 !TSM:FPAR:NO REPLY 42206 TSM:FPAR 42208 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 44216 !TSM:FPAR:FAIL 44217 TSM:FAIL:CNT=3 44219 TSM:FAIL:DIS 44221 TSF:TDI:TSL 54224 TSM:FAIL:RE-INIT 54226 TSM:INIT 54234 TSM:INIT:TSP OK 54236 TSM:FPAR 54238 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 56246 !TSM:FPAR:NO REPLY 56248 TSM:FPAR 56250 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 58258 !TSM:FPAR:NO REPLY 58260 TSM:FPAR 58262 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 60270 !TSM:FPAR:NO REPLY 60272 TSM:FPAR 60274 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 62282 !TSM:FPAR:FAIL 62283 TSM:FAIL:CNT=4 62285 TSM:FAIL:DIS 62287 TSF:TDI:TSL 72290 TSM:FAIL:RE-INIT 72292 TSM:INIT 72299 TSM:INIT:TSP OK 72301 TSM:FPAR 72303 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 74311 !TSM:FPAR:NO REPLY 74313 TSM:FPAR 74315 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 76323 !TSM:FPAR:NO REPLY 76325 TSM:FPAR 76327 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 78336 !TSM:FPAR:NO REPLY 78338 TSM:FPAR 78340 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 80348 !TSM:FPAR:FAIL 80349 TSM:FAIL:CNT=5 80351 TSM:FAIL:DIS 80353 TSF:TDI:TSL 90356 TSM:FAIL:RE-INIT 90358 TSM:INIT 90365 TSM:INIT:TSP OK 90368 TSM:FPAR 90370 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 92378 !TSM:FPAR:NO REPLY 92380 TSM:FPAR 92382 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 94390 !TSM:FPAR:NO REPLY 94392 TSM:FPAR 94394 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 96402 !TSM:FPAR:NO REPLY 96404 TSM:FPAR 96406 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 98414 !TSM:FPAR:FAIL 98415 TSM:FAIL:CNT=6 98417 TSM:FAIL:DIS 98419 TSF:TDI:TSL 108422 TSM:FAIL:RE-INIT 108424 TSM:INIT 108431 TSM:INIT:TSP OK 108433 TSM:FPAR 108436 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 110443 !TSM:FPAR:NO REPLY 110445 TSM:FPAR 110448 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 112455 !TSM:FPAR:NO REPLY 112457 TSM:FPAR 112460 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 114467 !TSM:FPAR:NO REPLY 114469 TSM:FPAR 114472 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 116480 !TSM:FPAR:FAIL 116482 TSM:FAIL:CNT=7 116484 TSM:FAIL:DIS 116486 TSF:TDI:TSL 176488 TSM:FAIL:RE-INIT 176490 TSM:INIT 176497 TSM:INIT:TSP OK 176499 TSM:FPAR 176502 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 178509 !TSM:FPAR:NO REPLY 178511 TSM:FPAR 178514 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 180523 !TSM:FPAR:NO REPLY 180525 TSM:FPAR 180528 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 182535 !TSM:FPAR:NO REPLY 182537 TSM:FPAR 182540 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 184547 !TSM:FPAR:FAIL 184549 TSM:FAIL:CNT=7 184551 TSM:FAIL:DIS 184553 TSF:TDI:TSL 244555 TSM:FAIL:RE-INIT 244557 TSM:INIT 244564 TSM:INIT:TSP OK 244567 TSM:FPAR 244570 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 246577 !TSM:FPAR:NO REPLY 246579 TSM:FPAR 246582 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 248589 !TSM:FPAR:NO REPLY 248591 TSM:FPAR 248594 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 250601 !TSM:FPAR:NO REPLY 250603 TSM:FPAR 250606 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 252613 !TSM:FPAR:FAIL 252615 TSM:FAIL:CNT=7 252617 TSM:FAIL:DIS 252619 TSF:TDI:TSL 312621 TSM:FAIL:RE-INIT 312623 TSM:INIT 312630 TSM:INIT:TSP OK 312632 TSM:FPAR 312635 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 314642 !TSM:FPAR:NO REPLY 314644 TSM:FPAR 314647 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 316654 !TSM:FPAR:NO REPLY 316656 TSM:FPAR 316659 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 318666 !TSM:FPAR:NO REPLY 318668 TSM:FPAR 318671 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 320679 !TSM:FPAR:FAIL 320681 TSM:FAIL:CNT=7 320684 TSM:FAIL:DIS 320686 TSF:TDI:TSL 380688 TSM:FAIL:RE-INIT 380690 TSM:INIT 380697 TSM:INIT:TSP OK 380699 TSM:FPAR 380702 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 382709 !TSM:FPAR:NO REPLY 382711 TSM:FPAR 382714 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 384722 !TSM:FPAR:NO REPLY 384724 TSM:FPAR 384728 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 386735 !TSM:FPAR:NO REPLY 386737 TSM:FPAR 386740 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 388747 !TSM:FPAR:FAIL 388749 TSM:FAIL:CNT=7 388751 TSM:FAIL:DIS 388753 TSF:TDI:TSL 448755 TSM:FAIL:RE-INIT 448757 TSM:INIT 448764 TSM:INIT:TSP OK 448766 TSM:FPAR 448770 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 450777 !TSM:FPAR:NO REPLY 450779 TSM:FPAR 450782 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 452789 !TSM:FPAR:NO REPLY 452791 TSM:FPAR 452794 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 454801 !TSM:FPAR:NO REPLY 454803 TSM:FPAR 454806 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 456813 !TSM:FPAR:FAIL 456815 TSM:FAIL:CNT=7 456817 TSM:FAIL:DIS 456819 TSF:TDI:TSL 516822 TSM:FAIL:RE-INIT 516824 TSM:INIT 516831 TSM:INIT:TSP OK 516833 TSM:FPAR 516836 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 518843 !TSM:FPAR:NO REPLY 518845 TSM:FPAR 518848 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 520855 !TSM:FPAR:NO REPLY 520857 TSM:FPAR 520860 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 522867 !TSM:FPAR:NO REPLY 522869 TSM:FPAR 522872 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 524879 !TSM:FPAR:FAIL 524881 TSM:FAIL:CNT=7 524883 TSM:FAIL:DIS 524886 TSF:TDI:TSL 584888 TSM:FAIL:RE-INIT 584890 TSM:INIT 584897 TSM:INIT:TSP OK 584899 TSM:FPAR 584902 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 586909 !TSM:FPAR:NO REPLY 586911 TSM:FPAR 586914 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 588921 !TSM:FPAR:NO REPLY 588923 TSM:FPAR 588926 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 590934 !TSM:FPAR:NO REPLY 590936 TSM:FPAR 590939 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 592946 !TSM:FPAR:FAIL 592948 TSM:FAIL:CNT=7 592950 TSM:FAIL:DIS 592952 TSF:TDI:TSL 652954 TSM:FAIL:RE-INIT 652956 TSM:INIT 652963 TSM:INIT:TSP OK 652965 TSM:FPAR 652968 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 654976 !TSM:FPAR:NO REPLY 654978 TSM:FPAR 654981 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 656988 !TSM:FPAR:NO REPLY 656990 TSM:FPAR 656993 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 659000 !TSM:FPAR:NO REPLY 659002 TSM:FPAR 659005 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 661012 !TSM:FPAR:FAIL 661014 TSM:FAIL:CNT=7 661016 TSM:FAIL:DIS 661018 TSF:TDI:TSL 721020 TSM:FAIL:RE-INIT 721022 TSM:INIT 721030 TSM:INIT:TSP OK 721032 TSM:FPAR 721035 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 723042 !TSM:FPAR:NO REPLY 723044 TSM:FPAR 723047 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 725054 !TSM:FPAR:NO REPLY 725056 TSM:FPAR 725059 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 727066 !TSM:FPAR:NO REPLY 727068 TSM:FPAR 727071 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 729078 !TSM:FPAR:FAIL 729080 TSM:FAIL:CNT=7 729082 TSM:FAIL:DIS 729084 TSF:TDI:TSL 789086 TSM:FAIL:RE-INIT 789088 TSM:INIT 789095 TSM:INIT:TSP OK 789097 TSM:FPAR 789100 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 791107 !TSM:FPAR:NO REPLY 791109 TSM:FPAR 791112 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 793119 !TSM:FPAR:NO REPLY 793121 TSM:FPAR 793124 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 795132 !TSM:FPAR:NO REPLY 795134 TSM:FPAR 795138 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 797145 !TSM:FPAR:FAIL 797147 TSM:FAIL:CNT=7 797149 TSM:FAIL:DIS 797151 TSF:TDI:TSL 857153 TSM:FAIL:RE-INIT 857155 TSM:INIT 857162 TSM:INIT:TSP OK 857164 TSM:FPAR 857167 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 859175 !TSM:FPAR:NO REPLY 859177 TSM:FPAR 859181 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 861188 !TSM:FPAR:NO REPLY 861190 TSM:FPAR 861193 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 863200 !TSM:FPAR:NO REPLY 863202 TSM:FPAR 863205 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 865212 !TSM:FPAR:FAIL 865214 TSM:FAIL:CNT=7 865216 TSM:FAIL:DIS 865218 TSF:TDI:TSL 925220 TSM:FAIL:RE-INIT 925222 TSM:INIT 925230 TSM:INIT:TSP OK 925232 TSM:FPAR 925235 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 927242 !TSM:FPAR:NO REPLY 927244 TSM:FPAR 927247 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 929254 !TSM:FPAR:NO REPLY 929256 TSM:FPAR 929259 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 931266 !TSM:FPAR:NO REPLY 931268 TSM:FPAR 931271 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 933278 !TSM:FPAR:FAIL 933280 TSM:FAIL:CNT=7 933282 TSM:FAIL:DIS 933284 TSF:TDI:TSL 993286 TSM:FAIL:RE-INIT 993288 TSM:INIT 993295 TSM:INIT:TSP OK 993297 TSM:FPAR 993300 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 995307 !TSM:FPAR:NO REPLY 995309 TSM:FPAR 995312 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 997319 !TSM:FPAR:NO REPLY 997321 TSM:FPAR 997324 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 999331 !TSM:FPAR:NO REPLY 999333 TSM:FPAR 999336 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1001344 !TSM:FPAR:FAIL 1001346 TSM:FAIL:CNT=7 1001348 TSM:FAIL:DIS 1001350 TSF:TDI:TSL 1061353 TSM:FAIL:RE-INIT 1061355 TSM:INIT 1061362 TSM:INIT:TSP OK 1061364 TSM:FPAR 1061367 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1063375 !TSM:FPAR:NO REPLY 1063377 TSM:FPAR 1063380 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1065389 !TSM:FPAR:NO REPLY 1065391 TSM:FPAR 1065394 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1067402 !TSM:FPAR:NO REPLY 1067404 TSM:FPAR 1067407 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1069415 !TSM:FPAR:FAIL 1069417 TSM:FAIL:CNT=7 1069419 TSM:FAIL:DIS 1069421 TSF:TDI:TSL 1129424 TSM:FAIL:RE-INIT 1129426 TSM:INIT 1129434 TSM:INIT:TSP OK 1129436 TSM:FPAR 1129439 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1131447 !TSM:FPAR:NO REPLY 1131449 TSM:FPAR 1131452 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1133460 !TSM:FPAR:NO REPLY 1133462 TSM:FPAR 1133465 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1135473 !TSM:FPAR:NO REPLY 1135475 TSM:FPAR 1135478 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1137486 !TSM:FPAR:FAIL 1137488 TSM:FAIL:CNT=7 1137490 TSM:FAIL:DIS 1137492 TSF:TDI:TSL 1197496 TSM:FAIL:RE-INIT 1197498 TSM:INIT 1197505 TSM:INIT:TSP OK 1197507 TSM:FPAR 1197510 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1199518 !TSM:FPAR:NO REPLY 1199520 TSM:FPAR 1199523 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1201532 !TSM:FPAR:NO REPLY 1201534 TSM:FPAR 1201538 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1203546 !TSM:FPAR:NO REPLY 1203548 TSM:FPAR 1203551 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1205559 !TSM:FPAR:FAIL 1205561 TSM:FAIL:CNT=7 1205563 TSM:FAIL:DIS 1205565 TSF:TDI:TSL 1265568 TSM:FAIL:RE-INIT 1265570 TSM:INIT 1265577 TSM:INIT:TSP OK 1265580 TSM:FPAR 1265583 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1267591 !TSM:FPAR:NO REPLY 1267593 TSM:FPAR 1267596 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1269604 !TSM:FPAR:NO REPLY 1269606 TSM:FPAR 1269609 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1271617 !TSM:FPAR:NO REPLY 1271619 TSM:FPAR 1271622 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1273630 !TSM:FPAR:FAIL 1273632 TSM:FAIL:CNT=7 1273634 TSM:FAIL:DIS 1273636 TSF:TDI:TSL 1333639 TSM:FAIL:RE-INIT 1333641 TSM:INIT 1333648 TSM:INIT:TSP OK 1333650 TSM:FPAR 1333653 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1335661 !TSM:FPAR:NO REPLY 1335663 TSM:FPAR 1335666 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1337674 !TSM:FPAR:NO REPLY 1337676 TSM:FPAR 1337679 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1339688 !TSM:FPAR:NO REPLY 1339691 TSM:FPAR 1339694 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1341702 !TSM:FPAR:FAIL 1341704 TSM:FAIL:CNT=7 1341706 TSM:FAIL:DIS 1341708 TSF:TDI:TSL 1401711 TSM:FAIL:RE-INIT 1401713 TSM:INIT 1401720 TSM:INIT:TSP OK 1401722 TSM:FPAR 1401725 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1403734 !TSM:FPAR:NO REPLY 1403736 TSM:FPAR 1403739 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1405747 !TSM:FPAR:NO REPLY 1405749 TSM:FPAR 1405752 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1407760 !TSM:FPAR:NO REPLY 1407762 TSM:FPAR 1407765 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1409773 !TSM:FPAR:FAIL 1409775 TSM:FAIL:CNT=7 1409777 TSM:FAIL:DIS 1409779 TSF:TDI:TSL 1469782 TSM:FAIL:RE-INIT 1469784 TSM:INIT 1469791 TSM:INIT:TSP OK 1469793 TSM:FPAR 1469796 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1471804 !TSM:FPAR:NO REPLY 1471806 TSM:FPAR 1471809 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1473817 !TSM:FPAR:NO REPLY 1473819 TSM:FPAR 1473822 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1475830 !TSM:FPAR:NO REPLY 1475832 TSM:FPAR 1475835 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1477844 !TSM:FPAR:FAIL 1477847 TSM:FAIL:CNT=7 1477849 TSM:FAIL:DIS 1477851 TSF:TDI:TSL 1537854 TSM:FAIL:RE-INIT 1537856 TSM:INIT 1537863 TSM:INIT:TSP OK 1537865 TSM:FPAR 1537868 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1539876 !TSM:FPAR:NO REPLY 1539878 TSM:FPAR 1539881 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1541890 !TSM:FPAR:NO REPLY 1541892 TSM:FPAR 1541895 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1543903 !TSM:FPAR:NO REPLY 1543905 TSM:FPAR 1543908 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1545916 !TSM:FPAR:FAIL 1545918 TSM:FAIL:CNT=7 1545920 TSM:FAIL:DIS 1545922 TSF:TDI:TSL 1605925 TSM:FAIL:RE-INIT 1605927 TSM:INIT 1605935 TSM:INIT:TSP OK 1605937 TSM:FPAR 1605940 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1607948 !TSM:FPAR:NO REPLY 1607950 TSM:FPAR 1607953 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1609961 !TSM:FPAR:NO REPLY 1609963 TSM:FPAR 1609966 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1611974 !TSM:FPAR:NO REPLY 1611976 TSM:FPAR 1611979 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1613987 !TSM:FPAR:FAIL 1613989 TSM:FAIL:CNT=7 1613991 TSM:FAIL:DIS 1613993 TSF:TDI:TSL 1673997 TSM:FAIL:RE-INIT 1673999 TSM:INIT 1674006 TSM:INIT:TSP OK 1674008 TSM:FPAR 1674011 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1676019 !TSM:FPAR:NO REPLY 1676021 TSM:FPAR 1676024 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1678033 !TSM:FPAR:NO REPLY 1678035 TSM:FPAR 1678039 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1680047 !TSM:FPAR:NO REPLY 1680049 TSM:FPAR 1680052 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1682060 !TSM:FPAR:FAIL 1682062 TSM:FAIL:CNT=7 1682064 TSM:FAIL:DIS 1682066 TSF:TDI:TSL 1742069 TSM:FAIL:RE-INIT 1742071 TSM:INIT 1742078 TSM:INIT:TSP OK 1742081 TSM:FPAR 1742084 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1744092 !TSM:FPAR:NO REPLY 1744094 TSM:FPAR 1744097 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1746105 !TSM:FPAR:NO REPLY 1746107 TSM:FPAR 1746110 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1748118 !TSM:FPAR:NO REPLY 1748120 TSM:FPAR 1748123 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1750131 !TSM:FPAR:FAIL 1750133 TSM:FAIL:CNT=7 1750135 TSM:FAIL:DIS 1750137 TSF:TDI:TSL 1810140 TSM:FAIL:RE-INIT 1810142 TSM:INIT 1810149 TSM:INIT:TSP OK 1810151 TSM:FPAR 1810154 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1812162 !TSM:FPAR:NO REPLY 1812164 TSM:FPAR 1812167 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1814175 !TSM:FPAR:NO REPLY 1814177 TSM:FPAR 1814180 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1816189 !TSM:FPAR:NO REPLY 1816192 TSM:FPAR 1816195 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1818203 !TSM:FPAR:FAIL 1818205 TSM:FAIL:CNT=7 1818207 TSM:FAIL:DIS 1818209 TSF:TDI:TSL 1878212 TSM:FAIL:RE-INIT 1878214 TSM:INIT 1878221 TSM:INIT:TSP OK 1878223 TSM:FPARMQTT.fx shows messages without content every ~5 Minutes going to "Gateway1-out/255/188/3/0/3", where the 188 seems to change at random.
Also, as far as I understand the debug-mode of the sketch should be enabled (since #define MY_DEBUG is set in the beginning), however I'm not seeing any of the printed lines which should print the temperature and the humidity.
I'm probably dumb here since I'm getting into this stuff since yesterday morning, so I would really appreciate someone helping me. I read something about having to define a sensor ID, but as far as I can tell it's already defined.
My full code is literally the same as here: https://www.mysensors.org/build/humidity
/** * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* * * REVISION HISTORY * Version 1.0: Henrik EKblad * Version 1.1 - 2016-07-20: Converted to MySensors v2.0 and added various improvements - Torben Woltjen (mozzbozz) * * DESCRIPTION * This sketch provides an example of how to implement a humidity/temperature * sensor using a DHT11/DHT-22. * * For more information, please visit: * http://www.mysensors.org/build/humidity * */ // Enable debug prints #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 //#define MY_RS485 #include <SPI.h> #include <MySensors.h> #include <DHT.h> // Set this to the pin you connected the DHT's data pin to #define DHT_DATA_PIN 3 // Set this offset if the sensor has a permanent small offset to the real temperatures. // In Celsius degrees (as measured by the device) #define SENSOR_TEMP_OFFSET 0 // Sleep time between sensor updates (in milliseconds) // Must be >1000ms for DHT22 and >2000ms for DHT11 static const uint64_t UPDATE_INTERVAL = 60000; // Force sending an update of the temperature after n sensor reads, so a controller showing the // timestamp of the last update doesn't show something like 3 hours in the unlikely case, that // the value didn't change since; // i.e. the sensor would force sending an update every UPDATE_INTERVAL*FORCE_UPDATE_N_READS [ms] static const uint8_t FORCE_UPDATE_N_READS = 10; #define CHILD_ID_HUM 0 #define CHILD_ID_TEMP 1 float lastTemp; float lastHum; uint8_t nNoUpdatesTemp; uint8_t nNoUpdatesHum; bool metric = true; MyMessage msgHum(CHILD_ID_HUM, V_HUM); MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); DHT dht; void presentation() { // Send the sketch version information to the gateway sendSketchInfo("TemperatureAndHumidity", "1.1"); // Register all sensors to gw (they will be created as child devices) present(CHILD_ID_HUM, S_HUM); present(CHILD_ID_TEMP, S_TEMP); metric = getControllerConfig().isMetric; } void setup() { dht.setup(DHT_DATA_PIN); // set data pin of DHT sensor if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) { Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!"); } // Sleep for the time of the minimum sampling period to give the sensor time to power up // (otherwise, timeout errors might occure for the first reading) sleep(dht.getMinimumSamplingPeriod()); } void loop() { // Force reading sensor, so it works also after sleep() dht.readSensor(true); // Get temperature from DHT library float temperature = dht.getTemperature(); if (isnan(temperature)) { Serial.println("Failed reading temperature from DHT!"); } else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS) { // Only send temperature if it changed since the last measurement or if we didn't send an update for n times lastTemp = temperature; // apply the offset before converting to something different than Celsius degrees temperature += SENSOR_TEMP_OFFSET; if (!metric) { temperature = dht.toFahrenheit(temperature); } // Reset no updates counter nNoUpdatesTemp = 0; send(msgTemp.set(temperature, 1)); #ifdef MY_DEBUG Serial.print("T: "); Serial.println(temperature); #endif } else { // Increase no update counter if the temperature stayed the same nNoUpdatesTemp++; } // Get humidity from DHT library float humidity = dht.getHumidity(); if (isnan(humidity)) { Serial.println("Failed reading humidity from DHT"); } else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) { // Only send humidity if it changed since the last measurement or if we didn't send an update for n times lastHum = humidity; // Reset no updates counter nNoUpdatesHum = 0; send(msgHum.set(humidity, 1)); #ifdef MY_DEBUG Serial.print("H: "); Serial.println(humidity); #endif } else { // Increase no update counter if the humidity stayed the same nNoUpdatesHum++; } // Sleep for a while to save energy sleep(UPDATE_INTERVAL); }Thank you in advance.
Hey guys!
@zerosquared welcome to the MySensors forum! The reason you don't see any debug messages about temperature is that the node is stuck trying to find a parent, and therefore never runs presentation() and loop().
The debug log from the gateway would be useful too se why the node never sees a reply to the gind parent request.
The most common cause is power problem. Which capacitor(s) are you using on the gw and the node? How are they powered? If you haven't already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to quickly troubleshoot them.
@mfalkvidd
Thank you very much for your answer! Below there are two logs from the serial console; I started them simultaneously, so the timestamps should be at least somewhat compareable. For this I did not include #define MY_NODE_ID 1 like @bgunnarb suggested.Gateway:
connected with Flamingos for sale, channel 11 dhcp client start... ip:192.168.178.66,mask:255.255.255.0,gw:192.168.178.1 398 TSM:READY:ID=0,PAR=0,DIS=0 431 MCO:REG:NOT NEEDED STUB: dhcp_stop ip:192.168.178.22,mask:255.255.255.0,gw:192.168.178.1 scandone 957 GWT:TPC:CONNECTING... 984 GWT:TPC:IP=192.168.178.22 1016 MCO:BGN:STP 1033 MCO:BGN:INIT OK,TSP=1 1062 GWT:TPC:IP=192.168.178.22 1094 GWT:RMQ:MQTT RECONNECT 1148 GWT:RMQ:MQTT CONNECTED 1177 GWT:TPS:TOPIC=Gateway1-out/0/255/0/0/18,MSG SENT 1447 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 1509 TSF:MSG:BC 1525 TSF:MSG:FPAR REQ,ID=255 1556 TSF:CKU:OK,FCTRL 1579 TSF:MSG:GWL OK 2212 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 3459 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 3521 TSF:MSG:BC 3538 TSF:MSG:FPAR REQ,ID=255 3568 TSF:CKU:OK,FCTRL 3591 TSF:MSG:GWL OK 4188 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 5471 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 5532 TSF:MSG:BC 5549 TSF:MSG:FPAR REQ,ID=255 5579 TSF:CKU:OK,FCTRL 5603 TSF:MSG:GWL OK 6162 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 7482 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 7544 TSF:MSG:BC 7560 TSF:MSG:FPAR REQ,ID=255 7591 TSF:CKU:OK,FCTRL 7614 TSF:MSG:GWL OK 8138 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 pm open,type:2 0 19506 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 19569 TSF:MSG:BC 19586 TSF:MSG:FPAR REQ,ID=255 19618 TSF:PNG:SEND,TO=0 19643 TSF:CKU:OK 19661 TSF:MSG:GWL OK 19946 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 21517 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 21580 TSF:MSG:BC 21598 TSF:MSG:FPAR REQ,ID=255 21629 TSF:CKU:OK,FCTRL 21653 TSF:MSG:GWL OK 21882 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 23529 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 23591 TSF:MSG:BC 23609 TSF:MSG:FPAR REQ,ID=255 23641 TSF:CKU:OK,FCTRL 23665 TSF:MSG:GWL OK 23858 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 25540 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 25603 TSF:MSG:BC 25621 TSF:MSG:FPAR REQ,ID=255 25652 TSF:CKU:OK,FCTRL 25676 TSF:MSG:GWL OK 25832 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 37565 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 37627 TSF:MSG:BC 37645 TSF:MSG:FPAR REQ,ID=255 37677 TSF:PNG:SEND,TO=0 37702 TSF:CKU:OK 37720 TSF:MSG:GWL OK 38656 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 39576 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 39639 TSF:MSG:BC 39657 TSF:MSG:FPAR REQ,ID=255 39688 TSF:CKU:OK,FCTRL 39712 TSF:MSG:GWL OK 40593 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 41589 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 41651 TSF:MSG:BC 41669 TSF:MSG:FPAR REQ,ID=255 41700 TSF:CKU:OK,FCTRL 41725 TSF:MSG:GWL OK 42570 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 43600 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 43663 TSF:MSG:BC 43680 TSF:MSG:FPAR REQ,ID=255 43712 TSF:CKU:OK,FCTRL 43736 TSF:MSG:GWL OK 44544 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 55624 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 55687 TSF:MSG:BC 55705 TSF:MSG:FPAR REQ,ID=255 55736 TSF:PNG:SEND,TO=0 55762 TSF:CKU:OK 55779 TSF:MSG:GWL OK 56343 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 57636 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 57699 TSF:MSG:BC 57717 TSF:MSG:FPAR REQ,ID=255 57748 TSF:CKU:OK,FCTRL 57772 TSF:MSG:GWL OK 58280 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 59647 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 59710 TSF:MSG:BC 59728 TSF:MSG:FPAR REQ,ID=255 59759 TSF:CKU:OK,FCTRL 59783 TSF:MSG:GWL OK 60254 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 61659 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 61721 TSF:MSG:BC 61739 TSF:MSG:FPAR REQ,ID=255 61771 TSF:CKU:OK,FCTRL 61795 TSF:MSG:GWL OK 62230 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 73682 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 73745 TSF:MSG:BC 73763 TSF:MSG:FPAR REQ,ID=255 73794 TSF:PNG:SEND,TO=0 73819 TSF:CKU:OK 73837 TSF:MSG:GWL OK 74026 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 75694 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 75757 TSF:MSG:BC 75774 TSF:MSG:FPAR REQ,ID=255 75806 TSF:CKU:OK,FCTRL 75830 TSF:MSG:GWL OK 75964 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 77705 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 77768 TSF:MSG:BC 77786 TSF:MSG:FPAR REQ,ID=255 77817 TSF:CKU:OK,FCTRL 77841 TSF:MSG:GWL OK 77938 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 79716 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 79779 TSF:MSG:BC 79797 TSF:MSG:FPAR REQ,ID=255 79828 TSF:CKU:OK,FCTRL 79852 TSF:MSG:GWL OK 79913 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 91741 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 91804 TSF:MSG:BC 91822 TSF:MSG:FPAR REQ,ID=255 91853 TSF:PNG:SEND,TO=0 91878 TSF:CKU:OK 91896 TSF:MSG:GWL OK 92736 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 93754 TSF:MSG:READ,255-255-0,s=221,c=3,t=3,pt=0,l=0,sg=0: 93814 GWT:TPS:TOPIC=Gateway1-out/255/221/3/0/3,MSG SENT 95764 TSF:MSG:READ,255-255-0,s=184,c=3,t=3,pt=0,l=0,sg=0: 95825 GWT:TPS:TOPIC=Gateway1-out/255/184/3/0/3,MSG SENT 97774 TSF:MSG:READ,255-255-0,s=147,c=3,t=3,pt=0,l=0,sg=0: 97835 GWT:TPS:TOPIC=Gateway1-out/255/147/3/0/3,MSG SENT 99785 TSF:MSG:READ,255-255-0,s=110,c=3,t=3,pt=0,l=0,sg=0: 99846 GWT:TPS:TOPIC=Gateway1-out/255/110/3/0/3,MSG SENT 111809 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 111872 TSF:MSG:BC 111891 TSF:MSG:FPAR REQ,ID=255 111924 TSF:PNG:SEND,TO=0 111950 TSF:CKU:OK 111969 TSF:MSG:GWL OK 112404 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 113820 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 113884 TSF:MSG:BC 113903 TSF:MSG:FPAR REQ,ID=255 113935 TSF:CKU:OK,FCTRL 113960 TSF:MSG:GWL OK 114338 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 115831 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 115895 TSF:MSG:BC 115914 TSF:MSG:FPAR REQ,ID=255 115946 TSF:CKU:OK,FCTRL 115971 TSF:MSG:GWL OK 116312 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 117844 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 117907 TSF:MSG:BC 117926 TSF:MSG:FPAR REQ,ID=255 117959 TSF:CKU:OK,FCTRL 117984 TSF:MSG:GWL OK 118290 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 179847 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 179911 TSF:MSG:BC 179930 TSF:MSG:FPAR REQ,ID=255 179963 TSF:PNG:SEND,TO=0 179989 TSF:CKU:OK 180008 TSF:MSG:GWL OK 180898 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 181860 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 181923 TSF:MSG:BC 181942 TSF:MSG:FPAR REQ,ID=255 181975 TSF:CKU:OK,FCTRL 182000 TSF:MSG:GWL OK 182834 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 183872 TSF:MSG:READ,255-255-0,s=9,c=3,t=3,pt=0,l=0,sg=0: 183932 GWT:TPS:TOPIC=Gateway1-out/255/9/3/0/3,MSG SENT 185882 TSF:MSG:READ,255-255-0,s=228,c=3,t=3,pt=0,l=0,sg=0: 185944 GWT:TPS:TOPIC=Gateway1-out/255/228/3/0/3,MSG SENT 187893 TSF:MSG:READ,255-255-0,s=191,c=3,t=3,pt=0,l=0,sg=0: 187955 GWT:TPS:TOPIC=Gateway1-out/255/191/3/0/3,MSG SENT 189903 TSF:MSG:READ,255-255-0,s=154,c=3,t=3,pt=0,l=0,sg=0: 189965 GWT:TPS:TOPIC=Gateway1-out/255/154/3/0/3,MSG SENTNode:
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.3.0 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0 25 TSM:INIT 26 TSF:WUR:MS=0 33 TSM:INIT:TSP OK 35 TSM:FPAR 37 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2046 !TSM:FPAR:NO REPLY 2049 TSM:FPAR 2051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 4059 !TSM:FPAR:NO REPLY 4061 TSM:FPAR 4063 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 6071 !TSM:FPAR:NO REPLY 6073 TSM:FPAR 6075 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 8083 !TSM:FPAR:FAIL 8084 TSM:FAIL:CNT=1 8086 TSM:FAIL:DIS 8088 TSF:TDI:TSL 18091 TSM:FAIL:RE-INIT 18093 TSM:INIT 18100 TSM:INIT:TSP OK 18102 TSM:FPAR 18104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 20112 !TSM:FPAR:NO REPLY 20114 TSM:FPAR 20116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 22124 !TSM:FPAR:NO REPLY 22126 TSM:FPAR 22128 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 24136 !TSM:FPAR:NO REPLY 24138 TSM:FPAR 24140 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 26148 !TSM:FPAR:FAIL 26149 TSM:FAIL:CNT=2 26151 TSM:FAIL:DIS 26153 TSF:TDI:TSL 36157 TSM:FAIL:RE-INIT 36159 TSM:INIT 36166 TSM:INIT:TSP OK 36168 TSM:FPAR 36170 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 38178 !TSM:FPAR:NO REPLY 38180 TSM:FPAR 38182 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 40192 !TSM:FPAR:NO REPLY 40194 TSM:FPAR 40196 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 42204 !TSM:FPAR:NO REPLY 42206 TSM:FPAR 42208 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 44216 !TSM:FPAR:FAIL 44217 TSM:FAIL:CNT=3 44219 TSM:FAIL:DIS 44221 TSF:TDI:TSL 54224 TSM:FAIL:RE-INIT 54226 TSM:INIT 54234 TSM:INIT:TSP OK 54236 TSM:FPAR 54238 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 56246 !TSM:FPAR:NO REPLY 56248 TSM:FPAR 56250 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 58258 !TSM:FPAR:NO REPLY 58260 TSM:FPAR 58262 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 60270 !TSM:FPAR:NO REPLY 60272 TSM:FPAR 60274 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 62282 !TSM:FPAR:FAIL 62283 TSM:FAIL:CNT=4 62285 TSM:FAIL:DIS 62287 TSF:TDI:TSL 72290 TSM:FAIL:RE-INIT 72292 TSM:INIT 72299 TSM:INIT:TSP OK 72301 TSM:FPAR 72303 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 74311 !TSM:FPAR:NO REPLY 74313 TSM:FPAR 74315 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 76323 !TSM:FPAR:NO REPLY 76325 TSM:FPAR 76327 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 78336 !TSM:FPAR:NO REPLY 78338 TSM:FPAR 78340 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 80348 !TSM:FPAR:FAIL 80349 TSM:FAIL:CNT=5 80351 TSM:FAIL:DIS 80353 TSF:TDI:TSL 90356 TSM:FAIL:RE-INIT 90358 TSM:INIT 90365 TSM:INIT:TSP OK 90368 TSM:FPAR 90370 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 91358 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0 91363 TSF:MSG:FPAR OK,ID=0,D=1 92378 TSM:FPAR:OK 92379 TSM:ID 92381 TSM:ID:REQ 92383 TSF:MSG:SEND,255-255-0-0,s=221,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 94391 TSM:ID 94392 TSM:ID:REQ 94395 TSF:MSG:SEND,255-255-0-0,s=184,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 96402 TSM:ID 96403 TSM:ID:REQ 96406 TSF:MSG:SEND,255-255-0-0,s=147,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 98413 TSM:ID 98414 TSM:ID:REQ 98417 TSF:MSG:SEND,255-255-0-0,s=110,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 100424 !TSM:ID:FAIL 100425 TSM:FAIL:CNT=6 100428 TSM:FAIL:DIS 100429 TSF:TDI:TSL 110432 TSM:FAIL:RE-INIT 110434 TSM:INIT 110441 TSM:INIT:TSP OK 110443 TSM:FPAR 110446 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 112453 !TSM:FPAR:NO REPLY 112455 TSM:FPAR 112458 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 114465 !TSM:FPAR:NO REPLY 114467 TSM:FPAR 114470 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 116478 !TSM:FPAR:NO REPLY 116481 TSM:FPAR 116484 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 118491 !TSM:FPAR:FAIL 118493 TSM:FAIL:CNT=7 118495 TSM:FAIL:DIS 118497 TSF:TDI:TSL 178499 TSM:FAIL:RE-INIT 178501 TSM:INIT 178508 TSM:INIT:TSP OK 178510 TSM:FPAR 178513 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 180521 !TSM:FPAR:NO REPLY 180524 TSM:FPAR 180527 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 181482 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0 181487 TSF:MSG:FPAR OK,ID=0,D=1 182534 TSM:FPAR:OK 182535 TSM:ID 182537 TSM:ID:REQ 182540 TSF:MSG:SEND,255-255-0-0,s=9,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 184547 TSM:ID 184548 TSM:ID:REQ 184551 TSF:MSG:SEND,255-255-0-0,s=228,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 186558 TSM:ID 186559 TSM:ID:REQ 186562 TSF:MSG:SEND,255-255-0-0,s=191,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 188569 TSM:ID 188570 TSM:ID:REQ 188573 TSF:MSG:SEND,255-255-0-0,s=154,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 190580 !TSM:ID:FAIL 190581 TSM:FAIL:CNT=7 190584 TSM:FAIL:DIS 190585 TSF:TDI:TSLMy current power-configuration:
On the node I'm using a seperate AM1117 with a 100µF cap just for the RF24 and on the gateway I'm powering the RF24 straight from the 3V3 rail of the NodeMCU, also with a 100µF cap.Tomorrow I'll try hooking up my bench supply for a more stable voltage, but I measured no drops and the RF24 examples worked with this configuration in high power mode, but maybe just because it were much shorter bursts..?
@bgunnarb Thank you also very much for the suggestion; I added the #define to the sketch, right above the defintion of the Child IDs, but I experienced the same results as far as I can tell.
Here are some logs, too (also started at around the same time for comparability):Gateway:
0⸮~?⸮4⸮Ҷ⸮⸮OCAM⸮⸮47 MCO:BGN:INIT GW,CP=RNNGE---,VER=2.3.0 90 TSF:LRT:OK 105 TSM:INIT 118 TSF:WUR:MS=0 142 TSM:INIT:TSP OK 163 TSM:INIT:GW MODE scandone state: 0 -> 2 (b0) state: 2 -> 3 (0) state: 3 -> 5 (10) add 0 aid 3 cnt connected with Flamingos for sale, channel 11 dhcp client start... ip:192.168.178.66,mask:255.255.255.0,gw:192.168.178.1 398 TSM:READY:ID=0,PAR=0,DIS=0 431 MCO:REG:NOT NEEDED STUB: dhcp_stop ip:192.168.178.22,mask:255.255.255.0,gw:192.168.178.1 scandone 958 GWT:TPC:CONNECTING... 985 GWT:TPC:IP=192.168.178.22 1017 MCO:BGN:STP 1034 MCO:BGN:INIT OK,TSP=1 1063 GWT:TPC:IP=192.168.178.22 1095 GWT:RMQ:MQTT RECONNECT 1146 GWT:RMQ:MQTT CONNECTED 1175 GWT:TPS:TOPIC=Gateway1-out/0/255/0/0/18,MSG SENT 1443 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 1505 TSF:MSG:BC 1522 TSF:MSG:FPAR REQ,ID=255 1552 TSF:CKU:OK,FCTRL 1575 TSF:MSG:GWL OK 2204 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 3456 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 3517 TSF:MSG:BC 3534 TSF:MSG:FPAR REQ,ID=255 3564 TSF:CKU:OK,FCTRL 3588 TSF:MSG:GWL OK 4180 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 5467 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 5529 TSF:MSG:BC 5545 TSF:MSG:FPAR REQ,ID=255 5576 TSF:CKU:OK,FCTRL 5599 TSF:MSG:GWL OK 6156 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 7478 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 7540 TSF:MSG:BC 7557 TSF:MSG:FPAR REQ,ID=255 7587 TSF:CKU:OK,FCTRL 7610 TSF:MSG:GWL OK 8130 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 pm open,type:2 0 19502 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 19565 TSF:MSG:BC 19583 TSF:MSG:FPAR REQ,ID=255 19614 TSF:PNG:SEND,TO=0 19639 TSF:CKU:OK 19657 TSF:MSG:GWL OK 19938 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 21514 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 21577 TSF:MSG:BC 21595 TSF:MSG:FPAR REQ,ID=255 21626 TSF:CKU:OK,FCTRL 21650 TSF:MSG:GWL OK 21876 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 23525 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 23588 TSF:MSG:BC 23606 TSF:MSG:FPAR REQ,ID=255 23637 TSF:CKU:OK,FCTRL 23661 TSF:MSG:GWL OK 23850 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 25537 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 25599 TSF:MSG:BC 25617 TSF:MSG:FPAR REQ,ID=255 25649 TSF:CKU:OK,FCTRL 25673 TSF:MSG:GWL OK 25826 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 37561 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 37624 TSF:MSG:BC 37642 TSF:MSG:FPAR REQ,ID=255 37673 TSF:PNG:SEND,TO=0 37699 TSF:CKU:OK 37716 TSF:MSG:GWL OK 38648 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 39573 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 39636 TSF:MSG:BC 39654 TSF:MSG:FPAR REQ,ID=255 39685 TSF:CKU:OK,FCTRL 39709 TSF:MSG:GWL OK 40586 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 41585 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 41648 TSF:MSG:BC 41666 TSF:MSG:FPAR REQ,ID=255 41697 TSF:CKU:OK,FCTRL 41721 TSF:MSG:GWL OK 42563 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 43597 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 43659 TSF:MSG:BC 43677 TSF:MSG:FPAR REQ,ID=255 43709 TSF:CKU:OK,FCTRL 43733 TSF:MSG:GWL OK 44538 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 55621 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 55684 TSF:MSG:BC 55702 TSF:MSG:FPAR REQ,ID=255 55733 TSF:PNG:SEND,TO=0 55759 TSF:CKU:OK 55776 TSF:MSG:GWL OK 56337 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 57633 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 57696 TSF:MSG:BC 57714 TSF:MSG:FPAR REQ,ID=255 57745 TSF:CKU:OK,FCTRL 57769 TSF:MSG:GWL OK 58274 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 59644 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 59707 TSF:MSG:BC 59725 TSF:MSG:FPAR REQ,ID=255 59756 TSF:CKU:OK,FCTRL 59780 TSF:MSG:GWL OK 60249 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 61656 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 61718 TSF:MSG:BC 61736 TSF:MSG:FPAR REQ,ID=255 61768 TSF:CKU:OK,FCTRL 61792 TSF:MSG:GWL OK 62225 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 73680 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 73742 TSF:MSG:BC 73760 TSF:MSG:FPAR REQ,ID=255 73792 TSF:PNG:SEND,TO=0 73817 TSF:CKU:OK 73835 TSF:MSG:GWL OK 74021 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 75691 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 75754 TSF:MSG:BC 75772 TSF:MSG:FPAR REQ,ID=255 75803 TSF:CKU:OK,FCTRL 75827 TSF:MSG:GWL OK 75958 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 77703 TSF:MSG:READ,255-255-0,s=38,c=3,t=3,pt=0,l=0,sg=0: 77763 GWT:TPS:TOPIC=Gateway1-out/255/38/3/0/3,MSG SENT 79714 TSF:MSG:READ,255-255-0,s=2,c=3,t=3,pt=0,l=0,sg=0: 79773 GWT:TPS:TOPIC=Gateway1-out/255/2/3/0/3,MSG SENT 81724 TSF:MSG:READ,255-255-0,s=221,c=3,t=3,pt=0,l=0,sg=0: 81785 GWT:TPS:TOPIC=Gateway1-out/255/221/3/0/3,MSG SENT 83735 TSF:MSG:READ,255-255-0,s=184,c=3,t=3,pt=0,l=0,sg=0: 83795 GWT:TPS:TOPIC=Gateway1-out/255/184/3/0/3,MSG SENTNode:
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.3.0 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0 25 TSM:INIT 26 TSF:WUR:MS=0 33 TSM:INIT:TSP OK 35 TSM:FPAR 37 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2046 !TSM:FPAR:NO REPLY 2049 TSM:FPAR 2051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 4059 !TSM:FPAR:NO REPLY 4061 TSM:FPAR 4063 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 6071 !TSM:FPAR:NO REPLY 6073 TSM:FPAR 6075 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 8083 !TSM:FPAR:FAIL 8084 TSM:FAIL:CNT=1 8086 TSM:FAIL:DIS 8088 TSF:TDI:TSL 18091 TSM:FAIL:RE-INIT 18093 TSM:INIT 18100 TSM:INIT:TSP OK 18102 TSM:FPAR 18104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 20112 !TSM:FPAR:NO REPLY 20114 TSM:FPAR 20116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 22124 !TSM:FPAR:NO REPLY 22126 TSM:FPAR 22128 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 24136 !TSM:FPAR:NO REPLY 24138 TSM:FPAR 24140 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 26148 !TSM:FPAR:FAIL 26149 TSM:FAIL:CNT=2 26151 TSM:FAIL:DIS 26153 TSF:TDI:TSL 36157 TSM:FAIL:RE-INIT 36159 TSM:INIT 36166 TSM:INIT:TSP OK 36168 TSM:FPAR 36170 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 38178 !TSM:FPAR:NO REPLY 38180 TSM:FPAR 38182 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 40192 !TSM:FPAR:NO REPLY 40194 TSM:FPAR 40196 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 42204 !TSM:FPAR:NO REPLY 42206 TSM:FPAR 42208 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 44216 !TSM:FPAR:FAIL 44217 TSM:FAIL:CNT=3 44219 TSM:FAIL:DIS 44221 TSF:TDI:TSL 54224 TSM:FAIL:RE-INIT 54226 TSM:INIT 54234 TSM:INIT:TSP OK 54236 TSM:FPAR 54238 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 56246 !TSM:FPAR:NO REPLY 56248 TSM:FPAR 56250 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 58258 !TSM:FPAR:NO REPLY 58260 TSM:FPAR 58262 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 60270 !TSM:FPAR:NO REPLY 60272 TSM:FPAR 60274 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 62282 !TSM:FPAR:FAIL 62283 TSM:FAIL:CNT=4 62285 TSM:FAIL:DIS 62287 TSF:TDI:TSL 72290 TSM:FAIL:RE-INIT 72292 TSM:INIT 72299 TSM:INIT:TSP OK 72301 TSM:FPAR 72303 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 74311 !TSM:FPAR:NO REPLY 74313 TSM:FPAR 74315 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 74566 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0 74571 TSF:MSG:FPAR OK,ID=0,D=1 76323 TSM:FPAR:OK 76324 TSM:ID 76326 TSM:ID:REQ 76328 TSF:MSG:SEND,255-255-0-0,s=38,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 78337 TSM:ID 78338 TSM:ID:REQ 78341 TSF:MSG:SEND,255-255-0-0,s=2,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 80348 TSM:ID 80349 TSM:ID:REQ 80352 TSF:MSG:SEND,255-255-0-0,s=221,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 82359 TSM:ID 82360 TSM:ID:REQ 82363 TSF:MSG:SEND,255-255-0-0,s=184,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 84370 !TSM:ID:FAIL 84371 TSM:FAIL:CNT=5 84373 TSM:FAIL:DIS 84375 TSF:TDI:TSLI also noticed in MQTT.fx that some (maybe 1 out of 10) messages are not empty but contain "2.3.0".
Thank you so much for your help, really appreciating it.
This part from the gateway log
TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0indicates that the gateway sends a reply to the find parent request, and the reply is acknowledged by the next hop.
This part from the node log!TSM:FPAR:NO REPLYindicates that the dht11 node did not receive a reply to the find parent request.
Do you have any MySensors repeater nodes in your MySensors network?
This part from the dht11 node shows when the node is able to receive the find parent response
74566 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0 74571 TSF:MSG:FPAR OK,ID=0,D=1 76323 TSM:FPAR:OKThis part shows that the dht11node does not receive a node id (due to openhab not having the dynamic id feature as mentioned by bgunnarb)
76324 TSM:ID 76326 TSM:ID:REQ 76328 TSF:MSG:SEND,255-255-0-0,s=38,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 78337 TSM:ID 78338 TSM:ID:REQ 78341 TSF:MSG:SEND,255-255-0-0,s=2,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 80348 TSM:ID 80349 TSM:ID:REQ 80352 TSF:MSG:SEND,255-255-0-0,s=221,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 82359 TSM:ID 82360 TSM:ID:REQ 82363 TSF:MSG:SEND,255-255-0-0,s=184,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 84370 !TSM:ID:FAIL -
76324 TSM:ID 76326 TSM:ID:REQ 76328 TSF:MSG:SEND,255-255-0-0,s=38,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 78337 TSM:ID 78338 TSM:ID:REQ 78341 TSF:MSG:SEND,255-255-0-0,s=2,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 80348 TSM:ID 80349 TSM:ID:REQ 80352 TSF:MSG:SEND,255-255-0-0,s=221,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 82359 TSM:ID 82360 TSM:ID:REQ 82363 TSF:MSG:SEND,255-255-0-0,s=184,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 84370 !TSM:ID:FAIL@mfalkvidd said in DHT11 Example Code on Arduino:
No, in fact I have just two RF24 Modules at all, so my whole setup consists of:
Raspberry Pi -> NodeMCU (Gateway) -> Arduino Nano as node.
When I get back home I'll try again with better power-sources, maybe it will help.
Thanks again for your time. -
Oops! I may have misled you.
The #define MY_NODE_ID 1 has to go into the sketch before you call #include <MySensors.h>as pointed out in the description of the Library API definitions:
"Remember to set configuration defines before including the MySensors.h."
In my sketches I always do all the #define (s) first like below:// Enable debug prints to serial monitor #define MY_DEBUG #define MY_NODE_ID 23 #define BATTERY_SENSE_PIN A0 // Input pin for battery sense #define VMIN 1.0 // (Min input voltage to regulator according to datasheet or guessing. (?) ) #define VMAX 3.22 // (Known or desired voltage of full batteries. If not, set to Vlim.) #define CHILD_ID_HUM 0 #define CHILD_ID_TEMP 1 // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #include <SPI.h> #include <AM2320.h> #include <Wire.h> #include <MySensors.h> // Rest of code goes here... -
In my sketches I always do all the #define (s) first like below:// Enable debug prints to serial monitor #define MY_DEBUG #define MY_NODE_ID 23 #define BATTERY_SENSE_PIN A0 // Input pin for battery sense #define VMIN 1.0 // (Min input voltage to regulator according to datasheet or guessing. (?) ) #define VMAX 3.22 // (Known or desired voltage of full batteries. If not, set to Vlim.) #define CHILD_ID_HUM 0 #define CHILD_ID_TEMP 1 // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #include <SPI.h> #include <AM2320.h> #include <Wire.h> #include <MySensors.h> // Rest of code goes here...@bgunnarb Yes! Thank you so much, this was the problem; it is working now, I can see the messages in MQTT.fx and they contain the temperature and the humidity.
I'm feeling pretty stupid right now, seems like something I should have been able to figure out myself, but you know how this goes sometimes.
A big thank you from germany to both of you. @mfalkvidd @bgunnarb -
