  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 331.3k Views 52 Watching
  • mikeeM mikee
    Hi guys, I’m trying 2 days to compile this sketch for Domoticz. Still getting errors ones from library then from code...
    Can someone share with me his working code for Domoticz in 2.0 version? Thanks a lot
    dbemowskD
    dbemowskD
    @mikee It helps for us to know what errors you are getting.
    • mikeeM
      mikeeM
      mikee
      Hi @dbemowsk , Thanks for your reply. I had to reinstall Arduino IDE and all Libraries from my PC. I was fighting with „'POSITIVE' was not declared in this scope“ error, and installed over 6 Libraries for LCD. I got finally working the sketch for Vera from Mysensors/build, at least .
      Unfortunately I’m not able to modify Sketch witch are guys using with Domoticz in this Topic.
      Is there a way to get missing variables into Irrigation controller from domoticz or at least to set them manually in sketch? For me is enough one watering time for all valves.
      dbemowskD 1 Reply Last reply
      • mikeeM mikee
        dbemowskD
        dbemowskD
        @mikee This was actually one of the reasons I switched from Domoticz to a Vera controller a couple years ago. The main issue at the time had to do with the use of V_VAR1 - V_VAR3 which is used to configure the valve names and the valve times. I wanted to have the ability to change the valve times.
        For your situation though, you can modify your Zone names in the code by changing this bit:
        String valveNickName[17] = {
        Depending on the number of zones you have, just change the names in quotes for Zone 1, Zone 2, etc... up to the number of valves that you have.
        I have been told recently though that Domoticz now supports V_VAR(x), but I am not sure how to use it just yet.
        E 1 Reply Last reply
        • A
          annujbhatia
          Hi, my module works with 8 relays but when i try to expand to 16 relays i have an issue. The 2nd register heats up and the pro mini keep restarting / re-initializing. I think i have the wrong connections for the 2nd register. Can anyone help / share what the wiring for the 2nd register should be?
          • A annujbhatia
            zboblamontZ
            zboblamontZ
            zboblamont
            #366
            @mfalkvidd Is this #3 of same question?
            • zboblamontZ zboblamont
              @zboblamont yes indeed.. If anyone can help @annujbhatia, please post in https://forum.mysensors.org/topic/9434/problem-with-2nd-register-heating instead of here, to keep all information in the same place.
              • johnecyJ johnecy
                I have the irrigation controller all setup and working. I have one problem though as soon as I power it up with 5 volts for the pro mini sometimes one sometimes all the relays come on. If I am not home the water runs all day is there a programing change or a wire change I need to make to stop this. I was using the old wire diagram without the pull up on pin 13 of the 74hc I changed to the new version and added the lines off code but it still does not help.
                pndgt0P
                pndgt0P
                pndgt0
                Hi @johnecy, know it has been a long time from your post, but I have implemented the script recently and am having the same issue that you mentined. please, how do you solve it?
                @johnecy said in Irrigation Controller (up to 16 valves with Shift Registers):
                • dbemowskD dbemowsk
                  E
                  E
                  edweather
                  I have build the irrigation controler this weekend and just found out that there are some issues using this with domoticz.
                  Is there someone willing to share his customized code to get these zone and time variables working ?
                  Thanks in advance,
                  Edwin
                  • E edweather
                    Thanks in advance,
                    Edwin
                    dbemowskD
                    dbemowskD
                    @edweather I had a lot of this working in Domoticz years ago. I have since switched to Vera, but here is a link to an old post I had on the subject.
                    https://forum.mysensors.org/topic/153/irrigation-controller-up-to-16-valves-with-shift-registers/216
                      E
                      E
                      edweather
                      @dbemowsk Thank you!
