  3. Mozilla WebThings Gateway
  4. MQTT Support
MQTT Support
Scheduled Pinned Locked Moved Mozilla WebThings Gateway
14 Posts 4 Posters 3.0k Views 3 Watching
  • alowhumA alowhum
    I've tried to add the required code. But as I'm not an MQTT user, I'm not sure I've implemented it properly.
    You mentioned:
    It should be asking for the mqtt server address, credentials and topic prefix?
    • The IP address can be filled in at the same spot where you fill it in for the ethernet gateway.
    • Are credentials required?
    • Topic prefix seems to be hardcoded to the mysensors ones? Right now I have:
                    MQTTC = MQTT(ip_address, 1883, 60)
                    MQTTC.start()
                    #self.GATEWAY = mysensors.AsyncMQTTGateway(ip_address, event_callback=self.mysensors_message,
                    #    persistence=True, persistence_file=self.persistence_file_path,
                    #    protocol_version='2.2')
                    self.GATEWAY = mysensors.AsyncMQTTGateway(MQTTC.publish, MQTTC.subscribe, in_prefix='mygateway1-out',
                        out_prefix='mygateway1-in', retain=True, event_callback=event,
    @alowhum on a MySensors mqtt gateway, username, password and topic prefix can be configured by defines. Since they are configurable on a MySensors gateway, I think it would make sense to also support configuration of these parameters in Webthings gateway.
    • alowhumA
      alowhumA
      alowhum
      I've added support for username and password (in theory). It should be available in the next version.
      • alowhumA
        alowhumA
        alowhum
        I've been trying to test it. I got to the point where in theory it's connected to Mosquitto. But I don't have any MySensors MQTT devices, so nothing is happening after that.
        Could someone help me craft a test message? Something like:
        mosquitto_pub -h localhost -t mygateway1-out -m "4;255;3;0;6;0"
        • alowhumA alowhum
          @alowhum I don't use mqtt either, but https://www.mysensors.org/build/mqtt_gateway#setup-and-test-gateway has instructions for how to send a test message. Can you use that?
          • bjacobseB
            bjacobseB
            bjacobse
            I don't use Webthings, but MQTT shall work similar, on my RPI I have Domoticz and Mosquitto broker running, check in a prompt:
            Is the broker running? ps -ef |grep mosq
            you can also check the logfile: sudo tail /var/log/mosquitto/mosquitto.log
            Then if above is ok, then your test message shall appear in the logfile, then Mosquitto is working. Then next check Mosquitto WebThings connection. I would assume a logfile must be present in WebThings that shows if a sensor is providing something
            bjacobseB 1 Reply Last reply
            • bjacobseB bjacobse
              bjacobseB
              bjacobseB
              bjacobse
              @bjacobse
              did you setup Node-RED?
              Maybe this can help you: https://diyprojects.io/mqtt-mosquitto-communicating-connected-objects-iot/#.XTBAKiZJFCU
              • R
                R
                Ryanmt
                I don't have webthings setup anymore but am happy to spin it up in a docker container and test for you. Just let me know what the steps are to install the test version and i'll give it a go.
                • alowhumA
                  alowhumA
                  alowhum
                  @Ryanmt thanks, that would be great.
                  I've tried to do some testing. Things look promising.
                  The Paho MQTT client seems to connect to a lot of topics:
                  Started MQTT client
                  subscribing to topicmygateway1-out/+/+/0/+/+
                  subscribing to topicmygateway1-out/+/+/3/+/+
                  subscribing to topicmygateway1-out/7/1/1/+/+
                  subscribing to topicmygateway1-out/7/1/2/+/+
                  subscribing to topicmygateway1-out/7/10/1/+/+
                  subscribing to topicmygateway1-out/7/10/2/+/+
                  subscribing to topicmygateway1-out/7/11/1/+/+
                  subscribing to topicmygateway1-out/7/11/2/+/+
                  etc.
                  Then, this:
                  mosquitto_pub -t 'mygateway1-out/7/1/2/0/47' -m '0,test'
                  gives:
                  Not a valid message: not a valid value for dictionary value @ data['payload']
                  So there is a communication path. I'm just not recreating the correct message.
                  • alowhumA
                    alowhumA
                    alowhum
                    Does this look correct?
                    in_prefix='mygateway1-out', out_prefix='mygateway1-in'
                    Shouldn't that be reversed?
                    • alowhumA
                      alowhumA
                      alowhum
                      I saw the same pattern in the original example code at PyMySensors, so I'm assuming it's ok.
                      I've uploaded version 0.1.2 of the MySensors add-on, Mozilla should accept it in a work day or two.
