  3. Sketch for Lightning Sensor
58 Posts 14 Posters 41.7k Views 11 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    #48
    I have adopted the MOD-1016 module (https://www.embeddedadventures.com/datasheets/MOD-1016_hw_v8_doc_v4.pdf) for MySensors if anyone is interested:
    Copyright (c) 2016, Embedded Adventures
    All rights reserved.
    Contact us at source [at] embeddedadventures.com
    Redistribution and use in source and binary forms, with or without
    modification, are permitted provided that the following conditions are met:
    - Redistributions of source code must retain the above copyright notice,
      this list of conditions and the following disclaimer.
    - Redistributions in binary form must reproduce the above copyright
      notice, this list of conditions and the following disclaimer in the
      documentation and/or other materials provided with the distribution.
    - Neither the name of Embedded Adventures nor the names of its contributors
      may be used to endorse or promote products derived from this software
      without specific prior written permission.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
    AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
    IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
    ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
    LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
    CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
    SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
    INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
    CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
    ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
    THE POSSIBILITY OF SUCH DAMAGE.
    #define MY_NODE_ID 15
    #include <AS3935.h> // AS3935 MOD-1016 by Embedded Adventures
    volatile bool detected = false;
     //-----------------IMPORTANT--------------------
     //---------------CHANGE SETTINGS HERE-----------
    #define IRQ_pin 2
    #define AS3935_TUNE_CAPS     6 // <-- SET THIS VALUE TO THE NUMBER LISTED ON YOUR BOARD
    #define AS3935_INDOORS       1 // AS3935_INDOORS=1 indoors, AS3935_INDOORS=0 outdoors
    #define AS3935_NOISE_FLOOR   6
    #define AS3935_ENABLE_DISTURBERS 1 // 0 or 1
    #define CHILD_ID_DISTANCE 1
    #define CHILD_ID_INTENSITY 2
    MyMessage msgDist(CHILD_ID_DISTANCE, V_DISTANCE);
    MyMessage msgInt(CHILD_ID_INTENSITY, V_VAR1);
      while (!Serial) {}
      Serial.println("MOD-1016 (AS3935) Lightning Sensor");
      Serial.println("beginning boot procedure....");
      Wire.begin();
      mod1016.init(IRQ_pin);
      //Tune Caps, Set AFE, Set Noise Floor
      //autoTuneCaps(IRQ_pin);
      mod1016.setTuneCaps(AS3935_TUNE_CAPS);
    delay(2);
    #if AS3935_INDOORS == 1
      mod1016.setIndoors();
      mod1016.setOutdoors();
    delay(2);
    mod1016.setNoiseFloor(AS3935_NOISE_FLOOR);
    delay(2);
    #if AS3935_ENABLE_DISTURBERS == 1
      mod1016.enableDisturbers();
      mod1016.disableDisturbers();
    //mod1016.calibrateRCO();
    delay(2);
      Serial.println("TUNE\tIN/OUT\tNOISEFLOOR");
      Serial.print(mod1016.getTuneCaps(), HEX);
      Serial.print("\t");
      Serial.print(mod1016.getAFE(), BIN);
      Serial.print("\t");
      Serial.println(mod1016.getNoiseFloor(), HEX);
      Serial.print("\n");
      pinMode(IRQ_pin, INPUT);
      attachInterrupt(digitalPinToInterrupt(IRQ_pin), alert, RISING);
      Serial.println("after interrupt");
        // delay execution to allow chip to stabilize.
      delay(1000);
    void presentation()  {
      sendSketchInfo("Lightning Sensor MOD-1016", "1.0");
      present(CHILD_ID_DISTANCE, S_DISTANCE);
      present(CHILD_ID_INTENSITY, S_CUSTOM);
      if (detected) {
        translateIRQ(mod1016.getIRQ());
        detected = false;
    void alert() {
      detected = true;
    void translateIRQ(uns8 irq) {
      switch(irq) {
          case 1:
            Serial.println("Noise detected");
          case 4:
            Serial.println("Disturber detected");
          case 8:
            Serial.println("Lightning detected!");
            printandsendToGW();
    void printandsendToGW() {
      int distance = mod1016.calculateDistance();
      unsigned int lightning_intensity = mod1016.getIntensity();
      if (distance == -1)
        Serial.println("Lightning out of range");
      else if (distance == 1)
        Serial.println("Distance not in table");
      else if (distance == 0)
        Serial.println("Lightning overhead");
      else {
        Serial.print("Lightning ~");
        Serial.print(distance);
        Serial.println("km away\n");
        Serial.print("Lightning Intensity: ");
        Serial.println(lightning_intensity);
        send(msgDist.set(distance));
        send(msgInt.set(lightning_intensity));
    You have to change the sketch according to your module settings
    skywatchS 1 Reply Last reply
    • skywatchS
      skywatchS
      skywatch
      #49
      I ordered one form embedded adventures on 27/7 - Now it is 3/9 and still nothing.
      Waiting to hear from them....
      That's the whole truth.
      alexsh1A 1 Reply Last reply
      • skywatchS skywatch
        alexsh1A
        alexsh1A
        alexsh1
        @skywatch give them a call or send a e-mail. Maybe your order was lost in post. Happens.
        My order arrived in 2 days from Embedded Adventures
        • skywatchS
          skywatchS
          skywatch
          OK - finally got board, seems the problem was in the warehouse. I got email to say it had been sent and it never did. At least I can try it out soon and see how it compares to the current lightning sensors I use.
          • alexsh1A alexsh1
            #define IRQ_pin 2
              while (!Serial) {}
              Wire.begin();
            delay(2);
            delay(2);
            delay(2);
            delay(2);
              Serial.print("\t");
              Serial.print("\t");
              Serial.print("\n");
              delay(1000);
              if (detected) {
                detected = false;
            void alert() {
              detected = true;
              switch(irq) {
                  case 1:
                  case 4:
                  case 8:
                    printandsendToGW();
              if (distance == -1)
              else {
            skywatchS
            skywatchS
            skywatch
            @alexsh1
            Is your example using I2C or SPI? I can't make it out.
            I'd guess I2C, but want to make sure first.....
            Thank you
              #53
              @skywatch said in Sketch for Lightning Sensor:
              Please do let us know how it compares and which one you like the best.
                skywatchS
                skywatchS
                skywatch
                @neverdie Last night was the first lightning to test it out - 3 storm cells went through with hail and lightning, but nothing from the sensor :(
                So today I have rewired it, made some changes to the program and if we get lightning tonight I might have some news :)
                Nca78N 1 Reply Last reply
                  I have the same problem. Insane storms, and nothing from the sensor, the bast I had were events identified as noise. I've had storms around and sensor doesn't detect anything, very disappointing.
                  I've tried to disconnect my laptop from main so it's not grounded (seem it can be a problem) but I still had nothing.
                  • Nca78N Nca78
                    skywatchS
                    skywatchS
                    skywatch
                    #56
                    @nca78 As you might expect there was no lightning last night to test it. :(
                    It's taken 2 years to get this far as storms are not frequent around here.
                    My sensor is from Embedded Adventures, is that the same one you are using?
                    I run it from 5V, it is set for 'indoors' and is placed on a window sil. I can see 'noise' if I place a laptop near to it. If I enable 'disturbers' I see them flooding in. The noise floor is set to 3 and I get no triggers at that level. Previously the noise floor was at 6.
                    So for the moment I am a little frustrated/disappointed with this 'sensor'. But I have to wait for the next storm, which should be tonight or tomorrow :)
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @skywatch I have the same sensor for months working like a charm. Sadly I had to disable it as I had one node and several sensors interfering with each other.
                      I will have to have the lightning sensor on a separate node
                      • alexsh1A alexsh1
                        BTW, I am not sure the sensor is similar to what you guys have.
                        K
                        K
                        kijagas663
                        Embedded Adventures is a fake website anymore. They don't send the mod-1016 sensor.
                        The website still gets payment for products but there is no shipment.
                        embedded adventures is fraudulent.
