  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • D
    dklinkman
    wrote on last edited by dklinkman
    #349
    Just got my Sensebender GW and soldered it up. Adapted the serial sketch to Ethernet and it almost worked. Found some posts on this topic that helped me locate and fix my config error. Now all is well. Thanks! --edit-- added photo
    -d
    • D
      dklinkman
      #350
      @dklinkman said in 💬 Sensebender Gateway:
      Sensebender
      And I got a Sensebender Micro soldered up and running also!! Just temp and humid so far. Too cool
      --edit-- picture
      • SoloamS
        SoloamS
        Soloam
          Is it possible to use the sensebender board as MQTT gateway? Not Ethernet?
          • SoloamS
            SoloamS
            Soloam
            Yes it is! I use I'm using it as a MQTT gateway for some time
            • C
              C
              Christian Schulte genannt Trux
              First: Great work! My GW is working very well!
              I wanted to know for what I can use the SD-Card.
              My idea is to fetch the logs in the serial and write them to the SD-Card.
              But I don't know where. Is there a point in the mySensors core where I can fetch all logs?
              • R
                R
                rolandow
                Forgive me if this isn't the right place to ask; but as a beginner, where do I start? How can I order this thing, or any other stuff from OpenHardware.io ? I see so many design files, I'm not sure what to do with them. Soldering the thing I can probably manage, but is there a guide available how to order the PCB, and maybe the parts as well?
                alexsh1A 1 Reply Last reply
                • R rolandow
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @rolandow said in 💬 Sensebender Gateway:
                  Sesnebender GW can be ordered from Itead:
                  https://www.itead.cc/mysensors-gateway.html
                  Other openhardware.io projects maybe ordered either (1) directly from a link; pcb only (2) you can download eagle files and upload them to pcb manufactures like oshpark.com (3) you can purchase the final product. So a generic answer to your question is it depends :)
                  I do not think there is a guide here, but if you go to oshpark.com there is a guide how to order a pcb. Parts (BOM) can be ordered from Aliexpress, eBay or more reputable supplies like digi-key or mouser
                  • G
                    G
                    Gerator
                    Hi!
                    I'm trying to use sensebender GW as ethernet gateway. I loaded the stock W5100 sketch compiled with samd 1.6.21 defs but it didn't worked. I have been trying out different things and realized that it works with 1.6.12 defs. Now it's working but I'm stuck with an old version. Anyone with the same problem? Maybe I'm missing something?
                    Also I found out ethernet library in 1.0.5 defs is outdated. I have been trying to use stock one (v2.0) without success. Anyone has tried?
                    • pepsonP
                      pepsonP
                      pepson
                      hi
                      when i try compile sketch only with change radio to rfm69hw i have this:
                      Arduino:1.8.9 (Windows 10), Płytka:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
                      SensebenderGatewaySerial:95:26: error: 'LED_BLUE' was not declared in this scope
                      static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
                      SensebenderGatewaySerial:95:36: error: 'LED_RED' was not declared in this scope
                      SensebenderGatewaySerial:95:45: error: 'LED_GREEN' was not declared in this scope
                      SensebenderGatewaySerial:95:56: error: 'LED_YELLOW' was not declared in this scope
                      SensebenderGatewaySerial:95:68: error: 'LED_ORANGE' was not declared in this scope
                      C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'void preHwInit()':
                      SensebenderGatewaySerial:116:10: error: 'MY_SWC1' was not declared in this scope
                      pinMode(MY_SWC1, INPUT_PULLUP);
                      SensebenderGatewaySerial:117:10: error: 'MY_SWC2' was not declared in this scope
                      pinMode(MY_SWC2, INPUT_PULLUP);
                      SensebenderGatewaySerial:130:17: error: 'LED_BLUE' was not declared in this scope
                      digitalWrite(LED_BLUE, led_state);
                      SensebenderGatewaySerial:145:16: error: 'LED_GREEN' was not declared in this scope
                      digitalWrite(LED_GREEN, HIGH);
                      SensebenderGatewaySerial:149:16: error: 'LED_YELLOW' was not declared in this scope
                      digitalWrite(LED_YELLOW, HIGH);
                      SensebenderGatewaySerial:154:16: error: 'LED_ORANGE' was not declared in this scope
                      digitalWrite(LED_ORANGE, HIGH);
                      SensebenderGatewaySerial:167:17: error: 'LED_RED' was not declared in this scope
                      digitalWrite(LED_RED, HIGH);
                      C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testSDCard()':
                      SensebenderGatewaySerial:219:33: error: 'MY_SDCARD_CS' was not declared in this scope
                      if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
                      C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testEEProm()':
                      SensebenderGatewaySerial:249:2: error: 'SerialUSB' was not declared in this scope
                      SerialUSB.print(" -> EEPROM ");
                      C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testAnalog()':
                      SensebenderGatewaySerial:267:30: error: 'MY_BAT_DETECT' was not declared in this scope
                      int bat_detect = analogRead(MY_BAT_DETECT);
                      exit status 1
                      What is error ? please help me
                      magpernM 1 Reply Last reply
                      • pepsonP
                        pepsonP
                        pepson
                        I also can not install board in Arduino IDE 1.8.9
                        • pepsonP
                          pepsonP
                          pepson
                          please help
                          https://forum.mysensors.org/topic/10548/solved-sensbender-gateway-gives-a-lot-of-hu/2
                          • pepsonP pepson
                            hi
                            exit status 1
                            magpernM
                            magpernM
                            magpern
                            wrote on last edited by magpern
                            #361
                            @pepson said in 💬 Sensebender Gateway:
                            hi
                            You cannot use the SensebenderGatewaySerial sketch on an Atmega2560. The SensbenderGatewaySerial sketch is for the SAMD board called Sensebender Gateway.
                            If you have the real Sensebender Gateway you should use this one
                            pepsonP 1 Reply Last reply
                            • magpernM magpern
                              hi
                              pepsonP
                              pepsonP
                              pepson
                              @magpern
                              But get this board to Arduino IDE?
                              • pepsonP pepson
                                @magpern
                                magpernM
                                magpernM
                                magpern
                                @magpern
                                Boards / Boards manager...
                                search for sensebender
                                You might have to
                                File / Preferences / Additional Board manager URLs
                                add
                                https://raw.githubusercontent.com/mysensors/ArduinoBoards/master/package_mysensors.org_index.json
                                • pepsonP
                                  pepsonP
                                  pepson
                                  Hi
                                  I compiled and write to gateway this programmm. Then i connected it to my RPI with Hassio (Home Assistant). In logs on home assistant still show me info: Gateway /dev/serial/by-id/usb-MySensors.org_Sensebender_GW_6A153443514D355934202020FF10182D-if00 not ready after 15.0 secs so continuing with setup
                                  but after run Home Assistant gateway works ok. I send info mto developer Home Assistant ans she not see any bugs....
                                  How i can resolved this problem ?
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    wrote on last edited by pepson
                                    #365
                                    And please help me how i can compile it as gateway Ethernet with module W5100.
                                    Only add to sketch:
                                    #define MY_GATEWAY_W5100
                                    // Enable to UDP
                                    //#define MY_USE_UDP
                                    //#define MY_IP_ADDRESS 192,168,3,160 // wpisz adres ip bramki
                                    #define MY_PORT 5003 //wpisz numer portu bramki
                                    // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
                                    #define MY_MAC_ADDRESS 0xDC, 0xAE, 0xB2, 0x3F, 0xFF, 0xDC
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      When try compilation with this W5100 i get error:
                                      Opcje projektu zmienione, przeładuj całość
                                      In file included from C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MySensors.h:208:0,
                                                   from C:\Users\Piotrek\Desktop\SensebenderGatewayETHERNET\SensebenderGatewayETHERNET.ino:111:
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:74:1: error: 'EthernetServer' does not name a type
                                      EthernetServer _ethernetServer(_ethernetGatewayPort);
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:89:8: error: 'EthernetClient' does not name a type
                                      static EthernetClient client = EthernetClient();
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportInit()':
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:149:7: error: 'Ethernet' was not declared in this scope
                                      if (!Ethernet.begin(_ethernetGatewayMAC)) {
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:149:7: note: suggested alternative: '_ethernetMsg'
                                         _ethernetMsg
                                      In file included from C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MySensors.h:49:0,
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:156:16: error: 'Ethernet' was not declared in this scope
                                                  Ethernet.localIP()[0],
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MyConfig.h:1815:48: note: in definition of macro 'DEBUG_OUTPUT'
                                      #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##VA_ARGS) //!< debug
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:155:2: note: in expansion of macro 'GATEWAY_DEBUG'
                                      GATEWAY_DEBUG(PSTR("GWT:TIN:IP=%" PRIu8 ".%" PRIu8 ".%" PRIu8 ".%" PRIu8 "\n"),
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:156:16: note: suggested alternative: '_ethernetMsg'
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:189:2: error: '_ethernetServer' was not declared in this scope
                                      _ethernetServer.begin();
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:189:2: note: suggested alternative: '_ethernetMsg'
                                      _ethernetMsg
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportSend(MyMessage&)':
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:246:11: error: '_ethernetServer' was not declared in this scope
                                      nbytes = _ethernetServer.write(_ethernetMsg);
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:246:11: note: suggested alternative: '_ethernetMsg'
                                             _ethernetMsg
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool _readFromClient()':
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:289:9: error: 'client' was not declared in this scope
                                      while (client.connected() && client.available()) {
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:289:9: note: suggested alternative: 'Print'
                                           Print
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportAvailable()':
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:409:2: error: 'EthernetClient' was not declared in this scope
                                      EthernetClient newclient = _ethernetServer.available();
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:411:6: error: 'newclient' was not declared in this scope
                                      if (newclient) {
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:412:7: error: 'client' was not declared in this scope
                                      if (client != newclient) {
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:412:7: note: suggested alternative: 'Print'
                                         Print
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:422:6: error: 'client' was not declared in this scope
                                      if (client) {
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:422:6: note: suggested alternative: 'Print'
                                      if (client) {
                                        Print
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'void gatewayTransportRenewIP()':
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:463:6: error: 'Ethernet' was not declared in this scope
                                      if (Ethernet.maintain() & ~(0x06)) {
                                      C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:463:6: note: suggested alternative: '_ethernetMsg'
                                        _ethernetMsg
                                      exit status 1
                                      Błąd kompilacji dla płytki Sensebender Gateway.
                                      What is a problem ?
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        please help me....
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          Hi
                                          Can anybody help me how compile sketch to this gateway to work as Ethernet Gateway...
                                          When i try compile i get the error:
                                          https://pastebin.com/BSQGsCgi
                                          and my sketch looks like:
                                          https://pastebin.com/R3vG076i
                                          tekkaT 1 Reply Last reply
