  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • C
    C
    Christian Schulte genannt Trux
    First: Great work! My GW is working very well!
    I wanted to know for what I can use the SD-Card.
    My idea is to fetch the logs in the serial and write them to the SD-Card.
    But I don't know where. Is there a point in the mySensors core where I can fetch all logs?
    • R
      R
      rolandow
      Forgive me if this isn't the right place to ask; but as a beginner, where do I start? How can I order this thing, or any other stuff from OpenHardware.io ? I see so many design files, I'm not sure what to do with them. Soldering the thing I can probably manage, but is there a guide available how to order the PCB, and maybe the parts as well?
      alexsh1A 1 Reply Last reply
      • R rolandow
        alexsh1A
        alexsh1A
        alexsh1
        @rolandow said in 💬 Sensebender Gateway:
        Sesnebender GW can be ordered from Itead:
        https://www.itead.cc/mysensors-gateway.html
        Other openhardware.io projects maybe ordered either (1) directly from a link; pcb only (2) you can download eagle files and upload them to pcb manufactures like oshpark.com (3) you can purchase the final product. So a generic answer to your question is it depends :)
        I do not think there is a guide here, but if you go to oshpark.com there is a guide how to order a pcb. Parts (BOM) can be ordered from Aliexpress, eBay or more reputable supplies like digi-key or mouser
        • G
          G
          Gerator
          Hi!
          I'm trying to use sensebender GW as ethernet gateway. I loaded the stock W5100 sketch compiled with samd 1.6.21 defs but it didn't worked. I have been trying out different things and realized that it works with 1.6.12 defs. Now it's working but I'm stuck with an old version. Anyone with the same problem? Maybe I'm missing something?
          Also I found out ethernet library in 1.0.5 defs is outdated. I have been trying to use stock one (v2.0) without success. Anyone has tried?
          • pepsonP
            pepsonP
            pepson
            hi
            when i try compile sketch only with change radio to rfm69hw i have this:
            Arduino:1.8.9 (Windows 10), Płytka:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
            SensebenderGatewaySerial:95:26: error: 'LED_BLUE' was not declared in this scope
            static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
            SensebenderGatewaySerial:95:36: error: 'LED_RED' was not declared in this scope
            SensebenderGatewaySerial:95:45: error: 'LED_GREEN' was not declared in this scope
            SensebenderGatewaySerial:95:56: error: 'LED_YELLOW' was not declared in this scope
            SensebenderGatewaySerial:95:68: error: 'LED_ORANGE' was not declared in this scope
            C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'void preHwInit()':
            SensebenderGatewaySerial:116:10: error: 'MY_SWC1' was not declared in this scope
            pinMode(MY_SWC1, INPUT_PULLUP);
            SensebenderGatewaySerial:117:10: error: 'MY_SWC2' was not declared in this scope
            pinMode(MY_SWC2, INPUT_PULLUP);
            SensebenderGatewaySerial:130:17: error: 'LED_BLUE' was not declared in this scope
            digitalWrite(LED_BLUE, led_state);
            SensebenderGatewaySerial:145:16: error: 'LED_GREEN' was not declared in this scope
            digitalWrite(LED_GREEN, HIGH);
            SensebenderGatewaySerial:149:16: error: 'LED_YELLOW' was not declared in this scope
            digitalWrite(LED_YELLOW, HIGH);
            SensebenderGatewaySerial:154:16: error: 'LED_ORANGE' was not declared in this scope
            digitalWrite(LED_ORANGE, HIGH);
            SensebenderGatewaySerial:167:17: error: 'LED_RED' was not declared in this scope
            digitalWrite(LED_RED, HIGH);
            C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testSDCard()':
            SensebenderGatewaySerial:219:33: error: 'MY_SDCARD_CS' was not declared in this scope
            if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
            C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testEEProm()':
            SensebenderGatewaySerial:249:2: error: 'SerialUSB' was not declared in this scope
            SerialUSB.print(" -> EEPROM ");
            C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testAnalog()':
            SensebenderGatewaySerial:267:30: error: 'MY_BAT_DETECT' was not declared in this scope
            int bat_detect = analogRead(MY_BAT_DETECT);
            exit status 1
            What is error ? please help me
            magpernM 1 Reply Last reply
            • pepsonP
              pepsonP
              pepson
              I also can not install board in Arduino IDE 1.8.9
              • pepsonP
                pepsonP
                pepson
                please help
                https://forum.mysensors.org/topic/10548/solved-sensbender-gateway-gives-a-lot-of-hu/2
                • pepsonP pepson
                  hi
                  exit status 1
                  magpernM
                  magpernM
                  magpern
                  wrote on last edited by magpern
                  #361
                  @pepson said in 💬 Sensebender Gateway:
                  hi
                  You cannot use the SensebenderGatewaySerial sketch on an Atmega2560. The SensbenderGatewaySerial sketch is for the SAMD board called Sensebender Gateway.
                  If you have the real Sensebender Gateway you should use this one
                  pepsonP 1 Reply Last reply
                  • magpernM magpern
                    hi
                    pepsonP
                    pepsonP
                    pepson
                    @magpern
                    But get this board to Arduino IDE?
                    • pepsonP pepson
                      @magpern
                      magpernM
                      magpernM
                      magpern
                      @magpern
                      Boards / Boards manager...
                      search for sensebender
                      You might have to
                      File / Preferences / Additional Board manager URLs
                      add
                      https://raw.githubusercontent.com/mysensors/ArduinoBoards/master/package_mysensors.org_index.json
                      • pepsonP
                        pepsonP
                        pepson
                        Hi
                        I compiled and write to gateway this programmm. Then i connected it to my RPI with Hassio (Home Assistant). In logs on home assistant still show me info: Gateway /dev/serial/by-id/usb-MySensors.org_Sensebender_GW_6A153443514D355934202020FF10182D-if00 not ready after 15.0 secs so continuing with setup
                        but after run Home Assistant gateway works ok. I send info mto developer Home Assistant ans she not see any bugs....
                        How i can resolved this problem ?
                        • pepsonP
                          pepsonP
                          pepson
                          wrote on last edited by pepson
                          #365
                          And please help me how i can compile it as gateway Ethernet with module W5100.
                          Only add to sketch:
                          #define MY_GATEWAY_W5100
                          // Enable to UDP
                          //#define MY_USE_UDP
                          //#define MY_IP_ADDRESS 192,168,3,160 // wpisz adres ip bramki
                          #define MY_PORT 5003 //wpisz numer portu bramki
                          // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
                          #define MY_MAC_ADDRESS 0xDC, 0xAE, 0xB2, 0x3F, 0xFF, 0xDC
                          • pepsonP
                            pepsonP
                            pepson
                            When try compilation with this W5100 i get error:
                            Opcje projektu zmienione, przeładuj całość
                            In file included from C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MySensors.h:208:0,
                                         from C:\Users\Piotrek\Desktop\SensebenderGatewayETHERNET\SensebenderGatewayETHERNET.ino:111:
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:74:1: error: 'EthernetServer' does not name a type
                            EthernetServer _ethernetServer(_ethernetGatewayPort);
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:89:8: error: 'EthernetClient' does not name a type
                            static EthernetClient client = EthernetClient();
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportInit()':
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:149:7: error: 'Ethernet' was not declared in this scope
                            if (!Ethernet.begin(_ethernetGatewayMAC)) {
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:149:7: note: suggested alternative: '_ethernetMsg'
                               _ethernetMsg
                            In file included from C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MySensors.h:49:0,
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:156:16: error: 'Ethernet' was not declared in this scope
                                        Ethernet.localIP()[0],
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MyConfig.h:1815:48: note: in definition of macro 'DEBUG_OUTPUT'
                            #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##VA_ARGS) //!< debug
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:155:2: note: in expansion of macro 'GATEWAY_DEBUG'
                            GATEWAY_DEBUG(PSTR("GWT:TIN:IP=%" PRIu8 ".%" PRIu8 ".%" PRIu8 ".%" PRIu8 "\n"),
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:156:16: note: suggested alternative: '_ethernetMsg'
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:189:2: error: '_ethernetServer' was not declared in this scope
                            _ethernetServer.begin();
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:189:2: note: suggested alternative: '_ethernetMsg'
                            _ethernetMsg
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportSend(MyMessage&)':
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:246:11: error: '_ethernetServer' was not declared in this scope
                            nbytes = _ethernetServer.write(_ethernetMsg);
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:246:11: note: suggested alternative: '_ethernetMsg'
                                   _ethernetMsg
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool _readFromClient()':
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:289:9: error: 'client' was not declared in this scope
                            while (client.connected() && client.available()) {
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:289:9: note: suggested alternative: 'Print'
                                 Print
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportAvailable()':
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:409:2: error: 'EthernetClient' was not declared in this scope
                            EthernetClient newclient = _ethernetServer.available();
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:411:6: error: 'newclient' was not declared in this scope
                            if (newclient) {
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:412:7: error: 'client' was not declared in this scope
                            if (client != newclient) {
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:412:7: note: suggested alternative: 'Print'
                               Print
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:422:6: error: 'client' was not declared in this scope
                            if (client) {
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:422:6: note: suggested alternative: 'Print'
                            if (client) {
                              Print
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'void gatewayTransportRenewIP()':
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:463:6: error: 'Ethernet' was not declared in this scope
                            if (Ethernet.maintain() & ~(0x06)) {
                            C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:463:6: note: suggested alternative: '_ethernetMsg'
                              _ethernetMsg
                            exit status 1
                            Błąd kompilacji dla płytki Sensebender Gateway.
                            What is a problem ?
                            • pepsonP
                              pepsonP
                              pepson
                              please help me....
                              • pepsonP
                                pepsonP
                                pepson
                                Hi
                                Can anybody help me how compile sketch to this gateway to work as Ethernet Gateway...
                                When i try compile i get the error:
                                https://pastebin.com/BSQGsCgi
                                and my sketch looks like:
                                https://pastebin.com/R3vG076i
                                tekkaT 1 Reply Last reply
                                • pepsonP pepson
                                  Hi
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @pepson Did you add
                                  #include <Ethernet.h>
                                  • tekkaT tekka
                                    @pepson Did you add
                                    pepsonP
                                    pepsonP
                                    pepson
                                    @tekka
                                    No.... thanks i fixed it....:)
                                    • A
                                      Andreas Kräuchi
                                      I just got my Sensebender Gateway and loaded the Sensebender Gateway Serial sketch. When I use the MYSController I get those wired infos...
                                      Currently there is no other Snesor runing just the Sensebender Gateway with an RF24. Why does it see a new child and what are all thos "hu;hu;hu" errors?
                                      • A
                                        Andreas Kräuchi
                                        Ok solved it by adding:
                                        #undef PRId8
                                        #undef PRIi8
                                        #undef PRIo8
                                        #undef PRIu8
                                        #undef PRIx8
                                        #undef PRIX8
                                        #undef PRIdLEAST8
                                        #undef PRIiLEAST8
                                        #undef PRIoLEAST8
                                        #undef PRIuLEAST8
                                        #undef PRIxLEAST8
                                        #undef PRIXLEAST8
                                        #undef PRIdFAST8
                                        #undef PRIiFAST8
                                        #undef PRIoFAST8
                                        #undef PRIuFAST8
                                        #undef PRIxFAST8
                                        #undef PRIXFAST8
                                        #define PRId8    "d"
                                        #define PRIi8   "i"
                                        #define PRIo8   "o"
                                        #define PRIu8   "u"
                                        #define PRIx8   "x"
                                        #define PRIX8   "X"
                                        #define PRIdLEAST8  "d"
                                        #define PRIiLEAST8  "i"
                                        #define PRIoLEAST8  "o"
                                        #define PRIuLEAST8  "u"
                                        #define PRIxLEAST8  "x"
                                        #define PRIXLEAST8  "X"
                                        #define PRIdFAST8 "d"
                                        #define PRIiFAST8 "i"
                                        #define PRIoFAST8 "o"
                                        #define PRIuFAST8 "u"
                                        #define PRIxFAST8 "x"
                                        #define PRIXFAST8 "X"
                                        • A
                                          andy5211d
                                          I have a similar issue with Sensebender Ethernet MQTT Gateway and MYSController. Can only connect to the gateway by serial from MYSController. The set-up is working correctly as best I can tell, and has several different MySensors in use. Has been working for a number of years. Only just discovered the MYSController software.
                                          So the Controller only shows data in the MYSController Debug tab. Nothing in any of the others. NOTE in the screen grab below the Controller at 192.168.1.96 is not connected, there is no difference when it is other than the Gateway error (!GWT:RMQ:FAIL) is not shown. Anyone with any ides for me to pursue? Thanks.
