  3. 💬 Safe relay node
💬 Safe relay node
atmega328ds18s20bta206safemysensorsssdrelaymoc3063-macs712nrf24l01smartnrp05-a-05dap9930gm1
17 Posts 6 Posters 5.9k Views 6 Watching
  • berkseoB
    berkseoB
    berkseo
    It is powered by an external power source which also has to be installed in an electrical Cabinet (5v, 5A).
    • berkseoB
      berkseoB
      berkseo
      ---> What's the TL;DR on this?
      In the given screenshot of the scheme there are no such names.
      • jeremushkaJ
        jeremushkaJ
        jeremushka
        very nice project :) for the power supply, is it a flyback power supply? did you design by yourself the Transformer?
        berkseoB 1 Reply Last reply
        • jeremushkaJ jeremushka
          berkseoB
          berkseoB
          berkseo
          @jeremushka said in 💬 Safe relay node:
          very nice project for the power supply, is it a flyback power supply? did you design by yourself the Transformer?
          The transformer works on lnk306, applied circuit without galvanic isolation, induction coil was replaced by transformer for high stability of output power.
          • jeremushkaJ
            jeremushkaJ
            jeremushka
            Will it be possible to purchase this very good device you made?
              berkseoB
              berkseoB
              berkseo
              @jeremushka
              Yes, soon. No time to add information to this device's page and add an item to ebay
              • jeremushkaJ
                jeremushkaJ
                jeremushka
                Is it possible for you to share your main code to have a try on a prototype ?
                  berkseoB
                  berkseoB
                  berkseo
                  @jeremushka Later, but soon, after the device is ready. I'm revising the concept now. Now I decide whether to switch to nRF5...
                  • R
                    R
                    Raj Kiran
                    Hi
                    can you confirm where u buy Plastic enclosure 1DIN(DIN rail) as well whats its size ? any schema file to share ?
                    • jeremushkaJ
                      jeremushkaJ
                      jeremushka
                      Have you moved to nrf5 for this concept or finally decided to keep the current design which is working well :) ?
                        berkseoB
                        berkseoB
                        berkseo
                        Have you moved to nrf5 for this concept or finally decided to keep the current design which is working well ?
                        In the process on nrf52840, but most likely it will be a zigbee(although nothing prevents to make its software under Mysensors that's already available in the Arduino IDE for 52840). The problem with the Mysensors is to support slow and weak chips, the backward compatibility problem does not allow moving forward.
                        • jeremushkaJ
                          jeremushkaJ
                          jeremushka
                          So, i understand your point. You didn't continue on this project. However, is it possible for you to share what you have done please?
                          • jeremushkaJ
                            jeremushkaJ
                            jeremushka
                            Hello, have you move forward with NRF5 on this project? I think it is a really good idea to embed in a DIN box. All automation system can be installed in the electrical board. More clean and safe installation and can be easily controlled on the board in case of issue of the hardware instead to unmount all the nodes that we can usually install behind, wall plug or switch.
                            • jeremushkaJ
                              jeremushkaJ
                              jeremushka
                              Hello Berk, Is it possible for you to share your schematic for this project please? especially the power part?
