  3. 💬 Safe relay node
💬 Safe relay node
atmega328ds18s20bta206safemysensorsssdrelaymoc3063-macs712nrf24l01smartnrp05-a-05dap9930gm1
17 Posts 6 Posters 5.8k Views 6 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/565/Safe-relay-node
      What's the TL;DR on this?
      • monteM
        monteM
        monte
        How do you power your board?
        • berkseoB
          berkseoB
          berkseo
          It is powered by an external power source which also has to be installed in an electrical Cabinet (5v, 5A).
          • berkseoB
            berkseoB
            berkseo
            ---> What's the TL;DR on this?
            In the given screenshot of the scheme there are no such names.
            • jeremushkaJ
              jeremushkaJ
              jeremushka
              very nice project :) for the power supply, is it a flyback power supply? did you design by yourself the Transformer?
              berkseoB 1 Reply Last reply
              • jeremushkaJ jeremushka
                berkseoB
                berkseoB
                berkseo
                @jeremushka said in 💬 Safe relay node:
                very nice project for the power supply, is it a flyback power supply? did you design by yourself the Transformer?
                The transformer works on lnk306, applied circuit without galvanic isolation, induction coil was replaced by transformer for high stability of output power.
                • jeremushkaJ
                  jeremushkaJ
                  jeremushka
                  Will it be possible to purchase this very good device you made?
                    berkseoB
                    berkseoB
                    berkseo
                    @jeremushka
                    Yes, soon. No time to add information to this device's page and add an item to ebay
                    • jeremushkaJ
                      jeremushkaJ
                      jeremushka
                      Is it possible for you to share your main code to have a try on a prototype ?
                        berkseoB
                        berkseoB
                        berkseo
                        @jeremushka Later, but soon, after the device is ready. I'm revising the concept now. Now I decide whether to switch to nRF5...
                        • R
                          R
                          Raj Kiran
                          Hi
                          can you confirm where u buy Plastic enclosure 1DIN(DIN rail) as well whats its size ? any schema file to share ?
                          • jeremushkaJ
                            jeremushkaJ
                            jeremushka
                            Have you moved to nrf5 for this concept or finally decided to keep the current design which is working well :) ?
                              berkseoB
                              berkseoB
                              berkseo
                              Have you moved to nrf5 for this concept or finally decided to keep the current design which is working well ?
                              In the process on nrf52840, but most likely it will be a zigbee(although nothing prevents to make its software under Mysensors that's already available in the Arduino IDE for 52840). The problem with the Mysensors is to support slow and weak chips, the backward compatibility problem does not allow moving forward.
                              • jeremushkaJ
                                jeremushkaJ
                                jeremushka
                                So, i understand your point. You didn't continue on this project. However, is it possible for you to share what you have done please?
                                • jeremushkaJ
                                  jeremushkaJ
                                  jeremushka
                                  Hello, have you move forward with NRF5 on this project? I think it is a really good idea to embed in a DIN box. All automation system can be installed in the electrical board. More clean and safe installation and can be easily controlled on the board in case of issue of the hardware instead to unmount all the nodes that we can usually install behind, wall plug or switch.
                                  • jeremushkaJ
                                    jeremushkaJ
                                    jeremushka
                                    Hello Berk, Is it possible for you to share your schematic for this project please? especially the power part?
