  3. nRF5 action!
nRF5 action!
  • alowhumA alowhum
    I created a BMP, both from a cheap ST-Link and an STM32, and it didn't help me break open those eByte NRF52 units.
    mr_redM
    mr_redM
    mr_red
    @alowhum where did you get stuck? Whats your process?
    ileneken3I 1 Reply Last reply
    • monteM monte
      @smilvert I think I solved issues I mentioned. But I don't have final code yet as I am waiting for parts to arrive for my board. But I think there is no problem using WT51822 board except that you'll have to manually set PORT interrupt and also set pin SENSE register which is cannot be done with arduino function pinMode().
      So I guess you can order PCBs if you want, I'm going to post final sketch with explanations at the end of the month.
      W
      W
      waspie
      @monte do you have final code now ? :)
      • mr_redM mr_red
        ileneken3I
        ileneken3I
        ileneken3
        @mr_red
        I got to the point where the stm32loader.py runs and outputs:
        Bootloader version 22
        Chip id: 0x410 (STM32 Medium-density)
        Write 256 bytes at 0x8000000
        Write 256 bytes at 0x8000100
        [..snip..]
        Write 256 bytes at 0x8001900
        Write 256 bytes at 0x8001A00
        Read 256 bytes at 0x8000000
        Read 256 bytes at 0x8000100
        [..snip..]
        Read 256 bytes at 0x8001900
        Read 256 bytes at 0x8001A00
        Verification OK
        After that, you're supposed to plug in to the USB directly. I get " USB device not recognized". Zadig doesn't help. It lists it as:
        "Unknown USB Device (Device Descriptor Request Failed)"
        Any ideas?
        • ileneken3I ileneken3
          @mr_red
          [..snip..]
          [..snip..]
          Verification OK
          Any ideas?
          Toyman
          @ileneken3 have you returned the jumpers back?
          • T Toyman
            ileneken3I
            ileneken3I
            ileneken3
            @toyman
            Unfortunately, yes, I have returned the jumpers to their original settings, and have even tried all 4 combinations.
            I also changed computers, changed OS's, changed cables.
            The board LOOKS like it was well manufactured, but I suppose a bad board is a possibility. Other than that, I can't figure out what could be wrong.
            • d00616D d00616
              sebiS
              sebiS
              sebi
              @d00616 said in nRF5 action!:
              I am having the same issue trying to write on a E73 module with read/write protections. I don't have a JLink, but a ST Link-V2 and OpenOCD.
              Do you know how to remove the protections on the E73 with such tools? Thanks.
              • N
                N
                novicit
                @sebi,
                A couple weeks ago I began exploring deploying E73 modules and had to remove protections. I was successful and now have a working E73 ethernet gateway. Only had ST Link-V2, so I used a "blue pill" I had in inventory to load it with Black Magic Probe. This cleared the protections.
                The instructions I followed to load the BMP are step-by-step at https://github.com/TamojitSaha/STM32f103_Black-Magic-Probe
                The instructions followed to clear protections with BMP also are step-by-step and worked perfect. They are at https://github.com/AndruPol/nrf52832-recover
                In item #4, the program arm-none-eabi-gdb.exe seems to be part of the Arduino tool chain as I found it just by doing a search in file explorer and it was already on my win10 machine. Also, in item #4, (gdb) is the prompt that the program arm-none-eabi-gdb.exe gives. In the first line, change the '/dev/ttyACM0' to your com port. Use 'quit' to exit the program. Also, use 'mon help' to see options.
                There are apparently a number of ways to 'recover' the E73, but this worked easily for me, and was step-by-step.
                • N
                  N
                  ncollins
                  @NeverDie Hoping you can help me with an WTNRF51822-S4AT problem where my stop recognizing interrupt events 2ish days after the last interrupt.
                  The buttons sleep for 24 hours, then wake up and send battery level. Even though the interrupt stops triggering, they still send battery level.
                  Possible some kind of timer is expiring?
                  Any help is appreciated.
                  // General settings
                  #define SKETCH_NAME "ThinButton"
                  #define SENSOR_NAME SKETCH_NAME
                  #define SKETCH_VERSION "1.4"
                  #define MY_NODE_ID 37
                  #define MY_BAUD_RATE 115200
                  #define IS_NRF51
                  #define PIR_DETECTION_PIN 3
                  #define SHORT_WAIT 50
                  #define DEBOUNCE_MS 1000
                  volatile bool motion_change=false;
                  #define MY_RADIO_NRF5_ESB
                  #define SLEEP_MS 1000 * 60 * 60 * 24
                  #define   CHILD_ID_VOLT 1
                  MyMessage msgBattery(CHILD_ID_VOLT, V_VOLTAGE);
                  #define CHILD_ID_BTN 2
                  #define BTN_PIN PIR_DETECTION_PIN
                  MyMessage msgBtn(CHILD_ID_BTN, V_TRIPPED);
                    #ifndef IS_NRF51
                  void turnOffRadio() {
                    NRF_RADIO->TASKS_DISABLE=1;
                  void turnOffUarte0() {
                    #ifndef IS_NRF51
                      NRF_UARTE0->TASKS_STOPRX = 1;
                      NRF_UARTE0->TASKS_STOPTX = 1;
                    #ifdef IS_NRF51
                      NRF_UART0->TASKS_STOPRX = 1;
                      NRF_UART0->TASKS_STOPTX = 1;
                      NRF_UART0->TASKS_SUSPEND = 1;
                  void turnOffAdc() {
                    #ifndef IS_NRF51
                        NRF_SAADC->TASKS_STOP=1;
                  void mySleepPrepare() {  //turn-off energy drains prior to sleep
                    turnOffHighFrequencyClock();
                    turnOffRadio();
                    turnOffUarte0();
                  void activateLpComp() {
                    NRF_LPCOMP->PSEL=4; // monitor AIN0 (i.e. pin P0.02 on nRF52832 PIR Motion Sensor v607).
                    while (!(NRF_LPCOMP->PSEL==4)) {} //wait until confirmed
                    NRF_LPCOMP->ANADETECT=0;  //detect CROSS events on PIR detection pin
                    while (NRF_LPCOMP->ANADETECT!=0) {} //wait until confirmed
                    NRF_LPCOMP->INTENSET=B1000;  //Enable interrupt for CROSS event
                    while (!(((NRF_LPCOMP->INTENSET)&B1000)==B1000)) {} //wait until confirmed
                    NVIC_EnableIRQ(LPCOMP_IRQn);
                      while (((NRF_LPCOMP->INTENCLR)&B0100)==B0100) {} //wait until confirmed
                    while (((NRF_LPCOMP->INTENSET)&B1000)!=B0100) {} //wait until confirmed
                  // setup
                    hwInit();
                    hwPinMode(PIR_DETECTION_PIN,INPUT);
                    disableNfc();  //remove unnecessary energy drains
                    turnOffAdc();  //remove unnecessary energy drains
                    activateLpComp();
                  void mySleep(uint32_t ms) {
                     mySleepPrepare();  //Take steps to reduce drains on battery current prior to sleeping
                     sleep(ms);
                  // presentation
                    present(CHILD_ID_VOLT, S_MULTIMETER, SENSOR_NAME);
                    wait(SHORT_WAIT);
                    present(CHILD_ID_BTN, S_MOTION, SENSOR_NAME);
                    wait(SHORT_WAIT);
                  unsigned long lastTripped = millis();
                  // loop
                    mySleep(SLEEP_MS);
                    if(motion_change){
                      unsigned long ms = millis();
                      long timeDiff = ms - lastTripped;
                      if(timeDiff < 0 || timeDiff > 1000){
                        send(msgBtn.set((uint8_t) 1));
                      NRF_LPCOMP->EVENTS_CROSS=0;
                      send(msgBattery.set(getInternalVoltage(),3));
                  float getInternalVoltage(){
                    return ((float)hwCPUVoltage())/1000.0;
                  #if __CORTEX_M == 0x04
                          event = 0;        \
                          (void)event
                  // This must be in one line
                  extern "C" { void LPCOMP_IRQHandler(void) {motion_change=true; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_CROSS); NRF_LPCOMP->EVENTS_CROSS=0; MY_HW_RTC->CC[0]=(MY_HW_RTC->COUNTER+2);}}
                  NeverDieN W 2 Replies Last reply
                  • N ncollins
                    // General settings
                    #define IS_NRF51
                      #ifndef IS_NRF51
                      #ifndef IS_NRF51
                      #ifdef IS_NRF51
                    void turnOffAdc() {
                      #ifndef IS_NRF51
                      turnOffRadio();
                      turnOffUarte0();
                    // setup
                      hwInit();
                      activateLpComp();
                       sleep(ms);
                    // presentation
                      wait(SHORT_WAIT);
                      wait(SHORT_WAIT);
                    // loop
                      mySleep(SLEEP_MS);
                      if(motion_change){
                            event = 0;        \
                            (void)event
                    #1778
                    @ncollins
                    It has been a while. I may be switching to PIC: https://forum.mysensors.org/topic/10666/anyone-ever-look-into-ezbl-aka-easy-booloader-on-a-pic
                    The impression I get is that you just write the new hex file into flash, flip a switch in software, and bang, you switchover to the new firmware without skipping a beat. No need to even reboot.
                    I think anything with the best general solution for OTA updates is a better path than doing OTA firmware bootloader one-offs for each MCU. From what I've gathered, it seems PIC may be the only one with the generalized bootloader support that I'm looking for. I haven't tried PIC before, but I'll be receiving a PIC board on Tuesday to test out this new theory. I'm gravitating toward LoRa anyway, so for that I can't leverage anything from NRF5x anyway. LoRa is the closest thing to bulletproof wireless communications that I've found so far. It just works, with fantastic range and coverage while still fitting within FCC requirements.
                    PICs tend to consume less energy than both atmega's and nRF5x's while sleeping, so there may be some positive trade-offs to be had there as well.
                    I'll miss the tight integration possible with an nRF5x. Maybe someday there will be PICs with integrated LoRa radios? MicroChip makes both separately, so it could conceivably happen. They've already done it with SAM: https://pic-microcontroller.com/microchip-new-ultra-low-power-lora-sip/
                    N 1 Reply Last reply
                      @ncollins
                      N
                      N
                      ncollins
                      @neverdie Interesting, thanks for the info
                      • N ncollins
                        // General settings
                        #define IS_NRF51
                          #ifndef IS_NRF51
                          #ifndef IS_NRF51
                          #ifdef IS_NRF51
                        void turnOffAdc() {
                          #ifndef IS_NRF51
                          turnOffRadio();
                          turnOffUarte0();
                        // setup
                          hwInit();
                          activateLpComp();
                           sleep(ms);
                        // presentation
                          wait(SHORT_WAIT);
                          wait(SHORT_WAIT);
                        // loop
                          mySleep(SLEEP_MS);
                          if(motion_change){
                                event = 0;        \
                                (void)event
                        W
                        W
                        waspie
                        @ncollins I had the same problem and sort of "solved" it by having it reboot every 3 hours (or maybe it was 6).
                        I don't know how to use the nrf5x stuff anywhere near well enough to actually fix it but it seems to work.
                        • W waspie
                          N
                          N
                          ncollins
                          @waspie I was actually about to go down that route. Would you mind posting a code snippet for how you're triggering the reboot?
                          W 1 Reply Last reply
                          • N ncollins
                            W
                            W
                            waspie
                            wrote on last edited by waspie
                            #1782
                            @ncollins
                            throw this somewhere in your code:
                            void reboot() {
                              wdt_disable();
                              wdt_enable(WDTO_15MS);
                              while (1) {}
                            and then calling the reboot (in the entire loop):
                              if (motion_change) {
                                motionDetected=!motionDetected;
                                if (motionDetected) {
                                  send(msg.set("1"));  // motion detected
                                else {
                                  digitalWrite(LED_BUILTIN,LOW);  //turn-off LED to signify motion no longer detected
                                  send(msg.set("0"));  // send all-clear to prepare for future detections
                              else { //must be a scheduled wake-up.  Time to report voltage as a heartbeat.
                                batteryVoltage=((float)hwCPUVoltage())/1000.0;  //take voltage measurement after transmission to hopefully measure lowest voltage that occurs.
                                send(msg_S_MULTIMETER_V_VOLTAGE.set(batteryVoltage,3));  //send battery voltage with 3 decimal places
                                time = millis();
                                if (time > 14400000 ) {
                                  reboot();
                              mySleep(1200000);  //sleep for 20 minutes
                            N 2 Replies Last reply
                            • W waspie
                              @ncollins
                              void reboot() {
                                wdt_disable();
                                while (1) {}
                                  else {
                                  time = millis();
                                    reboot();
                              N
                              N
                              ncollins
                              @waspie appreciate it, thank you
                              • Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                @NeverDie Interesting. What have pulled you from nrf52 towards PICs?
                                Can you post a link on the board you ordered, (or one like that)? Thanks.
                                • Sergio RiusS Sergio Rius
                                  #1785
                                  @sergio-rius I'm still deciding. What's holding me back from plunging into pic is that. it appears, the pics won't be able to leverage the arduino libraries. For that reason, I think I'm probably better off staying arduino compatible. In the end, it may be less effort to simply write my own OTA firmware update bootloader.
                                    @NeverDie I love the Feather boards. Currently working with the RFM69 feather. Build in battery connector/charger is very nice to have.
                                    Have you found a cheaper source than Amazon for buying them?
                                    siamola
                                    where it's just every pin of the SAMD21 mapped to a post, and it's only just the SAMD21 chip on the board. Then I can experiment on breadboard and figure out what I want and what works before finally reducing it to a subsequent PCB.
                                    • Sergio RiusS
                                      Sergio RiusS
                                      Sergio Rius
                                      Any charitative soul can help me prepare a black magic probe? I'm following the guides but at some point I can't continue.
                                      For example, following this one: https://hackaday.io/project/28180-bluetooth-gamepad-phone-case/log/71316-stm32-black-magic-probe-flashing
                                      I do:
                                      $ mkdir mbp && cd mbp
                                      $ wget https://raw.githubusercontent.com/jsnyder/stm32loader/master/stm32loader.py
                                      $ chmod 774 stm32loader.py
                                      $ sudo apt install python-pip
                                      $ pip install pyserial # There I remove '--assume-yes' as this is a wrong parameter
                                      # Then here starts the funk
                                      $ sudo apt install arm-none-eabi-gdb  # The package does not exist.
                                      # I found online that it may be already incorporated and my worth a try, so I continue.
                                      # So I change the boot0 jumper to 1, that it not said in the guide, connect the two boards and plug it into the computer.
                                      $ dmesg | grep tty
                                      # Nothing.
                                      $ sudo dmesg | tail
                                      [10680.891711] usb 1-12: Product: STM32 STLink
                                      [10680.891714] usb 1-12: Manufacturer: STMicroelectronics
                                      [10680.891716] usb 1-12: SerialNumber: PÿqRpQP2$g
                                      [11990.202434] usb 1-12: USB disconnect, device number 7
                                      [11998.926846] usb 1-12: new full-speed USB device number 8 using xhci_hcd
                                      [11999.076060] usb 1-12: New USB device found, idVendor=0483, idProduct=3748, bcdDevice= 1.00
                                      [11999.076066] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                      [11999.076069] usb 1-12: Product: STM32 STLink
                                      [11999.076072] usb 1-12: Manufacturer: STMicroelectronics
                                      [11999.076074] usb 1-12: SerialNumber: PÿqRpQP2$g
                                      # But no usb port. So I add udev rule.
                                      $ ls -l /dev/stl*
                                      lrwxrwxrwx 1 root root 15 oct 15 14:32 /dev/stlinkv2_12 -> bus/usb/001/008
                                      $ sudo ./stm32loader.py -p /dev/stlinkv2_12
                                        File "./stm32loader.py", line 427, in <module>
                                          cmd.open(conf['port'], conf['baud'])
                                        File "./stm32loader.py", line 71, in open
                                          timeout=5               # set a timeout value, None for waiting forever
                                        File "/home/sergio/.local/lib/python2.7/site-packages/serial/serialutil.py", line 240, in __init__
                                          self.open()
                                        File "/home/sergio/.local/lib/python2.7/site-packages/serial/serialposix.py", line 272, in open
                                          self._reconfigure_port(force_update=True)
                                        File "/home/sergio/.local/lib/python2.7/site-packages/serial/serialposix.py", line 326, in _reconfigure_port
                                          raise SerialException("Could not configure port: {}".format(msg))
                                      serial.serialutil.SerialException: Could not configure port: (25, 'Inappropriate ioctl for device')
                                      $ sudo apt install gdb-multiarch
                                      # Same effect.
                                      And here I am. Does anyone knows what kind of magic is required to put inside this little thing? :smirk:
                                      monteM 1 Reply Last reply
                                        #1788
                                        @Sergio-Rius
                                        I can't help you with blackmagic probe unfortunately.
                                        Just personal opinion, I prefer Segger probe.
                                        For example, Segger EDU mini is cheap. for the price don't bother with clones..
                                        • very affordable
                                        • compatible with a lot of IDEs, and when you use it with Segger IDE then you get best integration
                                        • segger provides lot of tools for debugging for free
                                        • easy updates and drivers install
                                        The only cons to a jlink probe could be no additional uart, but I don't need uart for debug&prints (segger ozone and rtt tools), and nor uploading sketch.
                                        Or a nrf5dk board is a nice alternative too, a little bit more expensive than EDU Mini but you get jlink+devboard+ later you could hook a power profiler kit on it ;)
                                        Still a jlink mini at hand is quite useful.
                                        Like I said just personal, I'm sure BMP is nice too, I guess you'll get it working before you can get a jlink :)
                                          I do:
                                          $ dmesg | grep tty
                                          # Nothing.
                                          $ sudo dmesg | tail
                                          $ ls -l /dev/stl*
                                              self.open()
                                          # Same effect.
                                          monteM
                                          monteM
                                          monte
                                          @sergio-rius I too have struggled to flash st-link clone with bmp firmware, but eventually I managed to do it. Unfortunately I don't remember what exactly I did, but I remember that I came to a solution when decided to try another st-link as a destination. If I remember correctly, there are different stm32 chips on these boards and some of them have insufficient amount of flash memory for bmp firmware.
                                          arm-none-eabi-gdb package is not available in ubuntu's repositories starting from 18.04. You can either download toolchain from eclipse's github archive or try to install older package as described here.
                                          Also, I used info from this blogs when flashed my st-link:
                                          http://blog.linuxbits.io/2016/02/15/cheap-chinese-st-link-v-2-programmer-converted-to-black-magic-probe-debugger/
                                          http://nuft.github.io/arm/2015/08/24/blackmagic-stlink.html
                                          As for buying stuff, don't forget you can buy ready to use BMP from their creators too ;)
