  3. nRF5 action!
nRF5 action!
  • O Omemanti
    A quick Google pointed me to https://github.com/AndruPol/nrf52832-recover/blob/master/README.md
    I do have a STM32F103C8T6 laying around. But ATM no time to play with it.
    Maybe that's the €3 solution for unlocking.
    Toyman
    @omemanti said in [nRF5 action!]Maybe that's the €3 solution for unlocking.
    BMP is enough to unlock. BluePill costs ca. €2 and it's easily convertable to BMP
    • mr_redM
      mr_redM
      mr_red
      @Omemanti Good find about the BMP to recover the Ebyte module. Can you point me to an aliexpress link? "stm32" "bluepill" are not the magic chinese keywords..
      • mr_redM mr_red
        @mr_red https://medium.com/@paramaggarwal/converting-an-stm32f103-board-to-a-black-magic-probe-c013cf2cc38c has keywords and a direct link to Ali
        • alowhumA
          alowhumA
          alowhum
          I created a BMP, both from a cheap ST-Link and an STM32, and it didn't help me break open those eByte NRF52 units.
          mr_redM 1 Reply Last reply
          • alowhumA alowhum
            mr_redM
            mr_redM
            mr_red
            @alowhum where did you get stuck? Whats your process?
            ileneken3I 1 Reply Last reply
            • monteM monte
              @smilvert I think I solved issues I mentioned. But I don't have final code yet as I am waiting for parts to arrive for my board. But I think there is no problem using WT51822 board except that you'll have to manually set PORT interrupt and also set pin SENSE register which is cannot be done with arduino function pinMode().
              So I guess you can order PCBs if you want, I'm going to post final sketch with explanations at the end of the month.
              W
              W
              waspie
              @monte do you have final code now ? :)
              • mr_redM mr_red
                ileneken3I
                ileneken3I
                ileneken3
                @mr_red
                I got to the point where the stm32loader.py runs and outputs:
                Bootloader version 22
                Chip id: 0x410 (STM32 Medium-density)
                Write 256 bytes at 0x8000000
                Write 256 bytes at 0x8000100
                [..snip..]
                Write 256 bytes at 0x8001900
                Write 256 bytes at 0x8001A00
                Read 256 bytes at 0x8000000
                Read 256 bytes at 0x8000100
                [..snip..]
                Read 256 bytes at 0x8001900
                Read 256 bytes at 0x8001A00
                Verification OK
                After that, you're supposed to plug in to the USB directly. I get " USB device not recognized". Zadig doesn't help. It lists it as:
                "Unknown USB Device (Device Descriptor Request Failed)"
                Any ideas?
                • ileneken3I ileneken3
                  @mr_red
                  [..snip..]
                  [..snip..]
                  Verification OK
                  Any ideas?
                  Toyman
                  @ileneken3 have you returned the jumpers back?
                  • T Toyman
                    ileneken3I
                    ileneken3I
                    ileneken3
                    @toyman
                    Unfortunately, yes, I have returned the jumpers to their original settings, and have even tried all 4 combinations.
                    I also changed computers, changed OS's, changed cables.
                    The board LOOKS like it was well manufactured, but I suppose a bad board is a possibility. Other than that, I can't figure out what could be wrong.
                    • d00616D d00616
                      sebiS
                      sebiS
                      sebi
                      @d00616 said in nRF5 action!:
                      I am having the same issue trying to write on a E73 module with read/write protections. I don't have a JLink, but a ST Link-V2 and OpenOCD.
                      Do you know how to remove the protections on the E73 with such tools? Thanks.
                      • N
                        N
                        novicit
                        @sebi,
                        A couple weeks ago I began exploring deploying E73 modules and had to remove protections. I was successful and now have a working E73 ethernet gateway. Only had ST Link-V2, so I used a "blue pill" I had in inventory to load it with Black Magic Probe. This cleared the protections.
                        The instructions I followed to load the BMP are step-by-step at https://github.com/TamojitSaha/STM32f103_Black-Magic-Probe
                        The instructions followed to clear protections with BMP also are step-by-step and worked perfect. They are at https://github.com/AndruPol/nrf52832-recover
                        In item #4, the program arm-none-eabi-gdb.exe seems to be part of the Arduino tool chain as I found it just by doing a search in file explorer and it was already on my win10 machine. Also, in item #4, (gdb) is the prompt that the program arm-none-eabi-gdb.exe gives. In the first line, change the '/dev/ttyACM0' to your com port. Use 'quit' to exit the program. Also, use 'mon help' to see options.
                        There are apparently a number of ways to 'recover' the E73, but this worked easily for me, and was step-by-step.
                        • N
                          N
                          ncollins
                          @NeverDie Hoping you can help me with an WTNRF51822-S4AT problem where my stop recognizing interrupt events 2ish days after the last interrupt.
                          The buttons sleep for 24 hours, then wake up and send battery level. Even though the interrupt stops triggering, they still send battery level.
                          Possible some kind of timer is expiring?
                          Any help is appreciated.
                          // General settings
                          #define SKETCH_NAME "ThinButton"
                          #define SENSOR_NAME SKETCH_NAME
                          #define SKETCH_VERSION "1.4"
                          #define MY_NODE_ID 37
                          #define MY_BAUD_RATE 115200
                          #define IS_NRF51
                          #define PIR_DETECTION_PIN 3
                          #define SHORT_WAIT 50
                          #define DEBOUNCE_MS 1000
                          volatile bool motion_change=false;
                          #define MY_RADIO_NRF5_ESB
                          #define SLEEP_MS 1000 * 60 * 60 * 24
                          #define   CHILD_ID_VOLT 1
                          MyMessage msgBattery(CHILD_ID_VOLT, V_VOLTAGE);
                          #define CHILD_ID_BTN 2
                          #define BTN_PIN PIR_DETECTION_PIN
                          MyMessage msgBtn(CHILD_ID_BTN, V_TRIPPED);
                            #ifndef IS_NRF51
                          void turnOffRadio() {
                            NRF_RADIO->TASKS_DISABLE=1;
                          void turnOffUarte0() {
                            #ifndef IS_NRF51
                              NRF_UARTE0->TASKS_STOPRX = 1;
                              NRF_UARTE0->TASKS_STOPTX = 1;
                            #ifdef IS_NRF51
                              NRF_UART0->TASKS_STOPRX = 1;
                              NRF_UART0->TASKS_STOPTX = 1;
                              NRF_UART0->TASKS_SUSPEND = 1;
                          void turnOffAdc() {
                            #ifndef IS_NRF51
                                NRF_SAADC->TASKS_STOP=1;
                          void mySleepPrepare() {  //turn-off energy drains prior to sleep
                            turnOffHighFrequencyClock();
                            turnOffRadio();
                            turnOffUarte0();
                          void activateLpComp() {
                            NRF_LPCOMP->PSEL=4; // monitor AIN0 (i.e. pin P0.02 on nRF52832 PIR Motion Sensor v607).
                            while (!(NRF_LPCOMP->PSEL==4)) {} //wait until confirmed
                            NRF_LPCOMP->ANADETECT=0;  //detect CROSS events on PIR detection pin
                            while (NRF_LPCOMP->ANADETECT!=0) {} //wait until confirmed
                            NRF_LPCOMP->INTENSET=B1000;  //Enable interrupt for CROSS event
                            while (!(((NRF_LPCOMP->INTENSET)&B1000)==B1000)) {} //wait until confirmed
                            NVIC_EnableIRQ(LPCOMP_IRQn);
                              while (((NRF_LPCOMP->INTENCLR)&B0100)==B0100) {} //wait until confirmed
                            while (((NRF_LPCOMP->INTENSET)&B1000)!=B0100) {} //wait until confirmed
                          // setup
                            hwInit();
                            hwPinMode(PIR_DETECTION_PIN,INPUT);
                            disableNfc();  //remove unnecessary energy drains
                            turnOffAdc();  //remove unnecessary energy drains
                            activateLpComp();
                          void mySleep(uint32_t ms) {
                             mySleepPrepare();  //Take steps to reduce drains on battery current prior to sleeping
                             sleep(ms);
                          // presentation
                            present(CHILD_ID_VOLT, S_MULTIMETER, SENSOR_NAME);
                            wait(SHORT_WAIT);
                            present(CHILD_ID_BTN, S_MOTION, SENSOR_NAME);
                            wait(SHORT_WAIT);
                          unsigned long lastTripped = millis();
                          // loop
                            mySleep(SLEEP_MS);
                            if(motion_change){
                              unsigned long ms = millis();
                              long timeDiff = ms - lastTripped;
                              if(timeDiff < 0 || timeDiff > 1000){
                                send(msgBtn.set((uint8_t) 1));
                              NRF_LPCOMP->EVENTS_CROSS=0;
                              send(msgBattery.set(getInternalVoltage(),3));
                          float getInternalVoltage(){
                            return ((float)hwCPUVoltage())/1000.0;
                          #if __CORTEX_M == 0x04
                                  event = 0;        \
                                  (void)event
                          // This must be in one line
                          extern "C" { void LPCOMP_IRQHandler(void) {motion_change=true; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_CROSS); NRF_LPCOMP->EVENTS_CROSS=0; MY_HW_RTC->CC[0]=(MY_HW_RTC->COUNTER+2);}}
                          NeverDieN W 2 Replies Last reply
                          • N ncollins
                            // General settings
                            #define IS_NRF51
                              #ifndef IS_NRF51
                              #ifndef IS_NRF51
                              #ifdef IS_NRF51
                            void turnOffAdc() {
                              #ifndef IS_NRF51
                              turnOffRadio();
                              turnOffUarte0();
                            // setup
                              hwInit();
                              activateLpComp();
                               sleep(ms);
                            // presentation
                              wait(SHORT_WAIT);
                              wait(SHORT_WAIT);
                            // loop
                              mySleep(SLEEP_MS);
                              if(motion_change){
                                    event = 0;        \
                                    (void)event
                            #1778
                            @ncollins
                            It has been a while. I may be switching to PIC: https://forum.mysensors.org/topic/10666/anyone-ever-look-into-ezbl-aka-easy-booloader-on-a-pic
                            The impression I get is that you just write the new hex file into flash, flip a switch in software, and bang, you switchover to the new firmware without skipping a beat. No need to even reboot.
                            I think anything with the best general solution for OTA updates is a better path than doing OTA firmware bootloader one-offs for each MCU. From what I've gathered, it seems PIC may be the only one with the generalized bootloader support that I'm looking for. I haven't tried PIC before, but I'll be receiving a PIC board on Tuesday to test out this new theory. I'm gravitating toward LoRa anyway, so for that I can't leverage anything from NRF5x anyway. LoRa is the closest thing to bulletproof wireless communications that I've found so far. It just works, with fantastic range and coverage while still fitting within FCC requirements.
                            PICs tend to consume less energy than both atmega's and nRF5x's while sleeping, so there may be some positive trade-offs to be had there as well.
                            I'll miss the tight integration possible with an nRF5x. Maybe someday there will be PICs with integrated LoRa radios? MicroChip makes both separately, so it could conceivably happen. They've already done it with SAM: https://pic-microcontroller.com/microchip-new-ultra-low-power-lora-sip/
                            N 1 Reply Last reply
                              @ncollins
                              N
                              N
                              ncollins
                              @neverdie Interesting, thanks for the info
                              • N ncollins
                                // General settings
                                #define IS_NRF51
                                  #ifndef IS_NRF51
                                  #ifndef IS_NRF51
                                  #ifdef IS_NRF51
                                void turnOffAdc() {
                                  #ifndef IS_NRF51
                                  turnOffRadio();
                                  turnOffUarte0();
                                // setup
                                  hwInit();
                                  activateLpComp();
                                   sleep(ms);
                                // presentation
                                  wait(SHORT_WAIT);
                                  wait(SHORT_WAIT);
                                // loop
                                  mySleep(SLEEP_MS);
                                  if(motion_change){
                                        event = 0;        \
                                        (void)event
                                W
                                W
                                waspie
                                @ncollins I had the same problem and sort of "solved" it by having it reboot every 3 hours (or maybe it was 6).
                                I don't know how to use the nrf5x stuff anywhere near well enough to actually fix it but it seems to work.
                                • W waspie
                                  N
                                  N
                                  ncollins
                                  @waspie I was actually about to go down that route. Would you mind posting a code snippet for how you're triggering the reboot?
                                  W 1 Reply Last reply
                                  • N ncollins
                                    W
                                    W
                                    waspie
                                    wrote on last edited by waspie
                                    #1782
                                    @ncollins
                                    throw this somewhere in your code:
                                    void reboot() {
                                      wdt_disable();
                                      wdt_enable(WDTO_15MS);
                                      while (1) {}
                                    and then calling the reboot (in the entire loop):
                                      if (motion_change) {
                                        motionDetected=!motionDetected;
                                        if (motionDetected) {
                                          send(msg.set("1"));  // motion detected
                                        else {
                                          digitalWrite(LED_BUILTIN,LOW);  //turn-off LED to signify motion no longer detected
                                          send(msg.set("0"));  // send all-clear to prepare for future detections
                                      else { //must be a scheduled wake-up.  Time to report voltage as a heartbeat.
                                        batteryVoltage=((float)hwCPUVoltage())/1000.0;  //take voltage measurement after transmission to hopefully measure lowest voltage that occurs.
                                        send(msg_S_MULTIMETER_V_VOLTAGE.set(batteryVoltage,3));  //send battery voltage with 3 decimal places
                                        time = millis();
                                        if (time > 14400000 ) {
                                          reboot();
                                      mySleep(1200000);  //sleep for 20 minutes
                                    N 2 Replies Last reply
                                    • W waspie
                                      @ncollins
                                      void reboot() {
                                        wdt_disable();
                                        while (1) {}
                                          else {
                                          time = millis();
                                            reboot();
                                      N
                                      N
                                      ncollins
                                      @waspie appreciate it, thank you
                                      • Sergio RiusS
                                        Sergio RiusS
                                        Sergio Rius
                                        @NeverDie Interesting. What have pulled you from nrf52 towards PICs?
                                        Can you post a link on the board you ordered, (or one like that)? Thanks.
                                        • Sergio RiusS Sergio Rius
                                          #1785
                                          @sergio-rius I'm still deciding. What's holding me back from plunging into pic is that. it appears, the pics won't be able to leverage the arduino libraries. For that reason, I think I'm probably better off staying arduino compatible. In the end, it may be less effort to simply write my own OTA firmware update bootloader.
