  2. Announcements
  3. πŸ’¬ Building a Raspberry Pi Gateway
    Thanks for sharing your experience @swedchef
    From the problems reported by users (you included), it seems like the rpi4 is quite different fom the earlier rpis. To add support, the following ingredients are needed in one person
    • person needs to have sufficient knowledge and skills to figure out how to support the rpi4
    • person needs to have sufficient time to do the work
    • person needs to have a rpi4
    • person needs to be sufficiently interested/motivated to do the work
    It seems like, so far, we haven't found this person (or this person hasn't found us).
    phildeferP
    phildeferP
    phildefer
    Re: πŸ’¬ Building a Raspberry Pi Gateway
    Hi all,
    i compile with success the gateway in Raspberry PI 4 (with some code modification)
    this is not perfect.. but it works.
    if someone wants to try, i upload the gateway compiled with this options :
    --my-transport=rf24 --my-gateway=ethernet --my-port=5003
    https://gofile.io/?c=fRxeF7
    AnticimexA mfalkviddM 2 Replies Last reply
    • phildeferP phildefer
      Hi all,
      AnticimexA
      AnticimexA
      Anticimex
      @phildefer could you please share what you changed? The security concerned might not be comfortable running a binary with unspecified changes that manages their home automation setup. Especially not a project supposed to be open source.
        Hi all,
        @phildefer would you mind sharing the code modifications that were needed?
        phildeferP 1 Reply Last reply
          phildeferP
          phildeferP
          phildefer
          @mfalkvidd @Anticimex : yes i sharing the code perhaps this week end. I need to find time to make a PR to GITHUB
          As I said, my code may not be as clean as you'd like, but it works.
          • P
            P
            patrikr76
            wrote on last edited by patrikr76
            #1027
            Hey all,
            I got the same problem as @swedchef and saw the warnings @alowhum mentioned.
            Simply upping the buffer that is declared in GPIO.cpp solved the warnings and made it compile without issue but the radio still won't work.
            Maybe it has to do with the soc not being detected, as mentioned, and that the pin positions on the new soc are different from previous ones.
            @phildefer, weekend has come and gone buddy. Patience is a virtue some do not have. :)
            Edit: So looking a little more through the files today i see that configure looks for the soc type in /proc/cpuinfo and funnily my raspi 4 reports a BCM2835
            • P patrikr76
              Hey all,
              @patrikr76 I beleive @phildefer pushed the code 4 days ago. See https://github.com/mysensors/MySensors/pull/1353
              Something has seriously mangled whitespace in the modified code, but apart from that it looks good to me, but I am not that familiar with the rpi code and I have not tested it myself.
              P K 2 Replies Last reply
                P
                P
                patrikr76
                #1029
                @mfalkvidd said in πŸ’¬ Building a Raspberry Pi Gateway:
                You are correct.
                @phildefer, thank you.
                There were a couple of minor warnings about indentations and the buffer size i mentioned earlier fixed by upping the declared buffer in GPIO.cpp. Not sure if that is a good fix or not, the warning goes away though.
                A few other warnings looks like this:
                In member function β€˜char* MyMessage::getString(char*) const’,
                    inlined from β€˜bool transportSendWrite(uint8_t, MyMessage&)’ at ./core/MyTransport.cpp:987:2,
                    inlined from β€˜bool transportRouteMessage(MyMessage&)’ at ./core/MyTransport.cpp:560:40,
                    inlined from β€˜void stUplinkTransition()’ at ./core/MyTransport.cpp:252:29:
                ./core/MyMessage.cpp:284:17: warning: β€˜char* strncpy(char*, const char*, size_t)’ output may be truncated copying between 0 and 25 bytes from a string of length 25 [-Wstringop-truncation]
                    (void)strncpy(buffer, this->data, this->getLength());
                Not sure how to fix those.
                Edit: Forgot to mention, it seems to be working though.
                • franz-unixF
                  franz-unixF
                  franz-unix
                  Thanks guys for the effort to port MySensors for the Pi 4.
                  I'm very interested, but my coding skills are not sufficient to help in the development. Maybe I can do some debug when my Pi4 will arrive
                  MySensors for the Pi4 is a must-have!😊
                    K
                    K
                    kiesel
                    @mfalkvidd @phildefer
                    I can confirm that the code compiles and runs on my rasbperry pi 4 model b. I am using a rfm69 radio and that seems to be working too. I couldn't test it yet though since I haven't wired any rfm69 nodes up yet.
                    franz-unixF 1 Reply Last reply
                    • K kiesel
                      franz-unixF
                      franz-unixF
                      franz-unix
                      @kiesel Good news!πŸ˜‰
                      I will test both (nrf24 and rfm69) when my Pi 4 arrive.
                      • franz-unixF
                        franz-unixF
                        franz-unix
                        Ok my Pi 4 is arrived. I have 2 gateway, one RFM69 and one NRF24 connected respectively to spi0 and spi1. Details here.
                        With a Raspberry Pi 3 all works fine (compilation and execution) with both Rasbian Stretch and with Raspbian Buster.
                        With a Raspberry Pi 4 and the same version of Rasbian Buster the situation is a bit different:
                        • The RFM69 gateway on the SPI0 compiles and can be executed without problems. In this days I don't have an RFM69 radio module, so I don't know if it works, but the daemon start in a regular way.
                        • The NRF24 gateway compile, but after few seconds of execution the daemon stops with the following error.
                        Oct 26 13:59:47 ERROR Could not open /sys/class/gpio/gpio12/direction
                        Considering that the same configuration works for a Pi 3, it is possible that the error is caused by the autodetect of SoC issue mentioned above?
                        The details of my /boot/config.txt file are here
                        • franz-unixF
                          franz-unixF
                          franz-unix
                          Update:
                          • tested the RFM69 gateway with a radio module attached -> Not working
                          • tried to compile and execute the NRF24 gateway on the first spi bus (--spi-spidev-device=/dev/spidev0.0) -> same error as above
                          I have checked my Makefile and configure files and they don't contain the modification proposed by @phildefer . Is this normal? I'm using the development branch.
                          • franz-unixF
                            franz-unixF
                            franz-unix
                            Tested with this commit of @phildefer, now both gateways compiles and starts but for both I got this error.
                            Oct 27 20:50:41 DEBUG !TSM:INIT:TSP FAIL
                            • franz-unixF
                              franz-unixF
                              franz-unix
                              Hi, if someone needs more info (debug, log, etc...) I'm here.
                              I can perform tests on Rpi 3 and Rpi 4 (Raspbian Buster) with NRF24 and RFM69 radio modules and then report the results. Not so much but maybe this can help the development.
                              • jerseyguy1996J
                                jerseyguy1996J
                                jerseyguy1996
                                wrote on last edited by jerseyguy1996
                                #1037
                                I'm doing a brand new install of Openhab2 and the mysensors gateway on a new Raspberry Pi 4 after having run Openhab(1) and the mysensors gateway successfully on a Raspberry Pi 3 for years. I used the development branch of the mysensorsgateway as discussed here: https://github.com/mysensors/MySensors/pull/1364
                                I wrote down my step by step procedure here in case it helps someone else. I'm starting out with the pre-built Openhabian image found here: https://www.openhab.org/docs/installation/openhabian.html
                                Install the PiGatewaySerial using these instructions:
                                1. First get to your Downloads directory
                                cd
                                cd Downloads
                                1. Clone the MySensors repository into your Downloads directory and then go into that folder
                                git clone https://github.com/mysensors/MySensors.git --branch development
                                cd MySensors
                                1. Set configuration options (you can use β€œ./configure β€”help” to see your options)
                                  a. In this case we are choosing to use the serial gateway with a pseudo terminal and a symbolic link to that pseudoterminal called ttyUSB20 in /dev. We then set the group to tty.
                                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20 --my-serial-groupname=tty
                                Edit: If building this on a 64bit operating system you will need to edit the configure file before running make. Do the following:
                                cp configure configure_bk
                                nano configure
                                Find this function
                                function gcc_cpu_flags {
                                    local soc=$1
                                    case $soc in
                                and find your CPU. In my case it is the BCM2711 (I've only done this on this one CPU so your mileage may vary) and I changed this:
                                 BCM2711)
                                        flags="-march=armv8-a+crc -mtune=cortex-a72 -mfpu=neon-fp-armv8 -mfloat-abi=hard"
                                to this:
                                BCM2711)
                                        flags="-march=armv8-a+crc -mtune=cortex-a72"
                                Then proceed to step 4 below.
                                1. Run make and make install
                                make
                                sudo make install
                                1. We can set it to launch on boot up by running
                                1. To launch it manually right now run (skip this step to run and see output for confirmation that it works)
                                1. Executable in located:
                                cd /usr/local/bin
                                1. need root to run it:
                                sudo mysgw
                                That's pretty much it. I was happily greeted with:
                                Dec 29 16:01:50 INFO Starting gateway...
                                Dec 29 16:01:50 INFO Protocol version - 2.4.0-alpha
                                Dec 29 16:01:50 DEBUG Serial port /dev/ttyUSB20 (115200 baud) created
                                Dec 29 16:01:50 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
                                Dec 29 16:01:50 DEBUG TSF:LRT:OK
                                Dec 29 16:01:50 DEBUG TSM:INIT
                                Dec 29 16:01:50 DEBUG TSF:WUR:MS=0
                                Dec 29 16:01:50 DEBUG TSM:INIT:TSP OK
                                Dec 29 16:01:50 DEBUG TSM:INIT:GW MODE
                                Dec 29 16:01:50 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                Dec 29 16:01:50 DEBUG MCO:REG:NOT NEEDED
                                Dec 29 16:01:50 DEBUG MCO:BGN:STP
                                Dec 29 16:01:50 DEBUG MCO:BGN:INIT OK,TSP=1
                                Dec 29 16:01:50 DEBUG TSM:READY:NWD REQ
                                Dec 29 16:01:50 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                Dec 29 16:01:50 DEBUG TSF:MSG:READ,4-4-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                                Dec 29 16:01:50 DEBUG TSF:MSG:READ,0-4-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                                Dec 29 16:01:50 DEBUG TSF:MSG:BC
                                Dec 29 16:01:52 DEBUG TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                                Dec 29 16:01:52 DEBUG TSF:MSG:READ,4-4-0,s=2,c=1,t=2,pt=2,l=2,sg=0:0
                                Dec 29 16:01:52 DEBUG TSF:MSG:READ,4-4-0,s=3,c=1,t=2,pt=2,l=2,sg=0:1
                                Dec 29 16:01:52 DEBUG TSF:MSG:READ,4-4-0,s=4,c=1,t=2,pt=2,l=2,sg=0:1
                                ^CDec 29 16:02:35 NOTICE Received SIGINT
                                • K
                                  K
                                  kiesel
                                  Be advised that there seems to be an issue with rfm69HW on the raspberry pi:
                                  When using the radio directly on the pi (not as a serial gateway) the range drops significantly:
                                  https://github.com/mysensors/MySensors/issues/1367
                                  Apparently this wasn't an issue with mysensors 2.2, so using that is an option if you can compile it for you raspberry pi.
                                  • SebexS
                                    SebexS
                                    Sebex
                                    I'm getting a bad file descriptor error, any advice? Seems only 1 instance to be running.
                                    pi@raspberrypi:~ $ sudo mysgw
                                    Mar 19 20:14:04 INFO  Starting gateway...
                                    Mar 19 20:14:04 INFO  Protocol version - 2.3.2
                                    Mar 19 20:14:04 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=255,VER=2.3.2
                                    Mar 19 20:14:04 DEBUG TSF:LRT:OK
                                    Mar 19 20:14:04 DEBUG TSM:INIT
                                    Mar 19 20:14:04 DEBUG TSF:WUR:MS=0
                                    Mar 19 20:14:04 DEBUG TSM:INIT:TSP OK
                                    Mar 19 20:14:04 DEBUG TSM:INIT:GW MODE
                                    Mar 19 20:14:04 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                    Mar 19 20:14:04 DEBUG MCO:REG:NOT NEEDED
                                    Mar 19 20:14:04 ERROR bind: Address already in use
                                    Mar 19 20:14:04 ERROR Failed to bind!
                                    Mar 19 20:14:04 DEBUG MCO:BGN:STP
                                    Mar 19 20:14:04 DEBUG MCO:BGN:INIT OK,TSP=1
                                    Mar 19 20:14:04 ERROR accept: Bad file descriptor
                                    Mar 19 20:14:04 DEBUG TSM:READY:NWD REQ
                                    Mar 19 20:14:04 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                    • SebexS Sebex
                                      @Sebex don't run multiple instances that try to listen to the same tcp port.
                                      SebexS 1 Reply Last reply
                                        SebexS
                                        SebexS
                                        Sebex
                                        @mfalkvidd thanks, I was wrongly under the impression that sudo mysgw would show the logs but it creates a second instance. Thanks for helping :smile:!
                                        • OldSurferDudeO
                                          OldSurferDudeO
                                          OldSurferDude
                                          I have an Arduino Mesh network (see https://tmrh20.github.io/RF24Mesh/) (master and 4 nodes)
                                          networkChannel 120, networkDataRate RF24_1MBPS, nodes 0-4
                                          Now I want to have my master be an RPi because it can talk to the real world.
                                          It looks like I have the RPi wired up and software loaded (per https://www.mysensors.org/build/raspberry). Now I need to know how to talk to my Arduino's.
                                          Now how do I talk to my Arduino's?
                                          o- general description of what you are trying to do
                                          Raspberry Pi controller with serial gateway with nrf24l01+ to connect to Arduino's
                                          o- the exact configure command you used
                                          cd MySensors
                                          ./configure --my-transport=rf24 --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyMySensorsGateway
                                          make
                                          sudo ./bin/mysgw
                                          [reboot RPi]
                                          cd MySensors
                                          sudo make install
                                          ls -als /dev/ttyMySensorsGateway [yeilds: 0 lrwxrwxrwx 1 root root 10 Apr 9 19:22 /dev/ttyMySensorsGateway -> /dev/pts/1]
                                          o- the output from the test
                                          Apr 09 18:47:32 INFO Config file /etc/mysensors.conf does not exist, creating new file.
                                          Apr 09 18:47:32 INFO Starting gateway...
                                          Apr 09 18:47:32 INFO Protocol version - 2.3.2
                                          Apr 09 18:47:32 DEBUG Serial port /dev/ttyMySensorsGateway (115200 baud) created
                                          Apr 09 18:47:32 INFO EEPROM file /etc/mysensors.eeprom does not exist, creating new file.
                                          Apr 09 18:47:32 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=255,VER=2.3.2
                                          Apr 09 18:47:32 DEBUG TSF:LRT:OK
                                          Apr 09 18:47:32 DEBUG TSM:INIT
                                          Apr 09 18:47:32 DEBUG TSF:WUR:MS=0
                                          Apr 09 18:47:32 DEBUG TSM:INIT:TSP OK
                                          Apr 09 18:47:32 DEBUG TSM:INIT:GW MODE
                                          Apr 09 18:47:32 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                          Apr 09 18:47:32 DEBUG MCO:REG:NOT NEEDED
                                          Apr 09 18:47:32 DEBUG MCO:BGN:STP
                                          Apr 09 18:47:32 DEBUG MCO:BGN:INIT OK,TSP=1
                                          Apr 09 18:47:32 DEBUG TSM:READY:NWD REQ
                                          Apr 09 18:47:32 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                          [did not return to command prompt]
                                          o- the settings you used in your controller
                                          n/a
                                          With your input, this post could be even better πŸ’—
