  2. Announcements
1.1k Posts 173 Posters 1.5m Views 131 Watching
    @alowhum to my knowledge, activating SPI has always been required, unless the user has already activated SPI by some other means.
    Do you have a suggestion on how to make it more prominent that what it is now? Preferably without contributing too much to the pileup of notices that scare users - everything is super-important to at least 1 person.
    alowhumA
    alowhumA
    alowhum
    #1018
    @mfalkvidd I don't know, perhaps mention it as something that has to be done upfront instead of something that might need to be done if there is an error?
    I'm not having any luck actually getting the radio to work. I now noticed this warning during compilation:
    g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_MQTT_CLIENT_ID=\"mygateway1\" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mysensors-in\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mysensors-out\" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
    drivers/Linux/GPIO.cpp: In constructor ‘GPIOClass::GPIOClass()’:
    drivers/Linux/GPIO.cpp:53:18: warning: ‘%s’ directive writing up to 255 bytes into a region of size 48 [-Wformat-overflow=]
        sprintf(file, "/sys/class/gpio/%s/base", de->d_name);
    drivers/Linux/GPIO.cpp:53:11: note: ‘sprintf’ output between 22 and 277 bytes into a destination of size 64
    drivers/Linux/GPIO.cpp:62:18: warning: ‘%s’ directive writing up to 255 bytes into a region of size 48 [-Wformat-overflow=]
        sprintf(file, "/sys/class/gpio/%s/ngpio", de->d_name);
    drivers/Linux/GPIO.cpp:62:11: note: ‘sprintf’ output between 23 and 278 bytes into a destination of size 64
    • alowhumA
      alowhumA
      alowhum
      #1019
      Could this be an issue?
      ./configure without any additional parameters gives:
      The rest looks fine:
        [OK] /sys/class/gpio/export found.
      [SECTION] Gateway configuration.
        [OK] Type: ethernet.
        [OK] Transport: rf24.
        [OK] Signing: Disabled.
        [OK] Encryption: Disabled.
        [OK] CPPFLAGS: -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV
        [OK] Init system detected: systemd.
        [OK] Saved.
        [OK] Finished.
      Same thing happens with the dev version
      • mfalkviddM
        #1020
        Yes, if the configure script cannot detect which hardware to use, compilation failure could very well be the result.
          swedchef
          Hi All
          I'm just venturing into this world of building my own sensors - but perhaps i am a tad late? Two months since last update.. Typically me - showing up to the party when everybody else has left.
          My main issue is, i am running the Raspberry Pi 4 - and when trying to build (i've tried both the development and master builds) i get from 4 (master build) to A BUNCH (development) of errors. First of all, the autodetect of SoC does not work for me either (just like @alowhum, and with the same warnings), and when using --help the actual SoC is not listed either, so should i just assume it does not work for Raspberry Pi 4?
          Is there any chance the 4 will be supported soon?
          Just a note - i can actually complete the configure and then make - but unfortunately i just get a TSP error when trying to fire up the radio.
          Hope i can get this working as it was the main reason for upgrading my RaspberryPi version 1 to a version 4 :man-facepalming:
          Thanks in advance for any and all help!
          • S swedchef
            Hi All
            Thanks for sharing your experience @swedchef
            From the problems reported by users (you included), it seems like the rpi4 is quite different fom the earlier rpis. To add support, the following ingredients are needed in one person
            • person needs to have sufficient knowledge and skills to figure out how to support the rpi4
            • person needs to have sufficient time to do the work
            • person needs to have a rpi4
            • person needs to be sufficiently interested/motivated to do the work
            It seems like, so far, we haven't found this person (or this person hasn't found us).
            phildeferP 1 Reply Last reply
              phildeferP
              phildeferP
              phildefer
              Re: 💬 Building a Raspberry Pi Gateway
              Hi all,
              i compile with success the gateway in Raspberry PI 4 (with some code modification)
              this is not perfect.. but it works.
              if someone wants to try, i upload the gateway compiled with this options :
              --my-transport=rf24 --my-gateway=ethernet --my-port=5003
              https://gofile.io/?c=fRxeF7
              AnticimexA mfalkviddM 2 Replies Last reply
              • phildeferP phildefer
                Hi all,
                AnticimexA
                AnticimexA
                Anticimex
                @phildefer could you please share what you changed? The security concerned might not be comfortable running a binary with unspecified changes that manages their home automation setup. Especially not a project supposed to be open source.
                  Hi all,
                  @phildefer would you mind sharing the code modifications that were needed?
                    phildeferP
                    phildeferP
                    phildefer
                    @mfalkvidd @Anticimex : yes i sharing the code perhaps this week end. I need to find time to make a PR to GITHUB
                    As I said, my code may not be as clean as you'd like, but it works.
                    • P
                      P
                      patrikr76
                      wrote on last edited by patrikr76
                      #1027
                      Hey all,
                      I got the same problem as @swedchef and saw the warnings @alowhum mentioned.
                      Simply upping the buffer that is declared in GPIO.cpp solved the warnings and made it compile without issue but the radio still won't work.
                      Maybe it has to do with the soc not being detected, as mentioned, and that the pin positions on the new soc are different from previous ones.
                      @phildefer, weekend has come and gone buddy. Patience is a virtue some do not have. :)
                      Edit: So looking a little more through the files today i see that configure looks for the soc type in /proc/cpuinfo and funnily my raspi 4 reports a BCM2835
                      • P patrikr76
                        Hey all,
                        @patrikr76 I beleive @phildefer pushed the code 4 days ago. See https://github.com/mysensors/MySensors/pull/1353
                        Something has seriously mangled whitespace in the modified code, but apart from that it looks good to me, but I am not that familiar with the rpi code and I have not tested it myself.
                        P K 2 Replies Last reply
                          P
                          P
                          patrikr76
                          #1029
                          @mfalkvidd said in 💬 Building a Raspberry Pi Gateway:
                          You are correct.
                          @phildefer, thank you.
                          There were a couple of minor warnings about indentations and the buffer size i mentioned earlier fixed by upping the declared buffer in GPIO.cpp. Not sure if that is a good fix or not, the warning goes away though.
                          A few other warnings looks like this:
                          In member function ‘char* MyMessage::getString(char*) const’,
                              inlined from ‘bool transportSendWrite(uint8_t, MyMessage&)’ at ./core/MyTransport.cpp:987:2,
                              inlined from ‘bool transportRouteMessage(MyMessage&)’ at ./core/MyTransport.cpp:560:40,
                              inlined from ‘void stUplinkTransition()’ at ./core/MyTransport.cpp:252:29:
                          ./core/MyMessage.cpp:284:17: warning: ‘char* strncpy(char*, const char*, size_t)’ output may be truncated copying between 0 and 25 bytes from a string of length 25 [-Wstringop-truncation]
                              (void)strncpy(buffer, this->data, this->getLength());
                          Not sure how to fix those.
                          Edit: Forgot to mention, it seems to be working though.
                          • franz-unixF
                            franz-unixF
                            franz-unix
                            Thanks guys for the effort to port MySensors for the Pi 4.
                            I'm very interested, but my coding skills are not sufficient to help in the development. Maybe I can do some debug when my Pi4 will arrive
                            MySensors for the Pi4 is a must-have!😊
                              K
                              K
                              kiesel
                              @mfalkvidd @phildefer
                              I can confirm that the code compiles and runs on my rasbperry pi 4 model b. I am using a rfm69 radio and that seems to be working too. I couldn't test it yet though since I haven't wired any rfm69 nodes up yet.
                              franz-unixF 1 Reply Last reply
                              • K kiesel
                                franz-unixF
                                franz-unixF
                                franz-unix
                                @kiesel Good news!😉
                                I will test both (nrf24 and rfm69) when my Pi 4 arrive.
                                • franz-unixF
                                  franz-unixF
                                  franz-unix
                                  Ok my Pi 4 is arrived. I have 2 gateway, one RFM69 and one NRF24 connected respectively to spi0 and spi1. Details here.
                                  With a Raspberry Pi 3 all works fine (compilation and execution) with both Rasbian Stretch and with Raspbian Buster.
                                  With a Raspberry Pi 4 and the same version of Rasbian Buster the situation is a bit different:
                                  • The RFM69 gateway on the SPI0 compiles and can be executed without problems. In this days I don't have an RFM69 radio module, so I don't know if it works, but the daemon start in a regular way.
                                  • The NRF24 gateway compile, but after few seconds of execution the daemon stops with the following error.
                                  Oct 26 13:59:47 ERROR Could not open /sys/class/gpio/gpio12/direction
                                  Considering that the same configuration works for a Pi 3, it is possible that the error is caused by the autodetect of SoC issue mentioned above?
                                  The details of my /boot/config.txt file are here
                                  • franz-unixF
                                    franz-unixF
                                    franz-unix
                                    Update:
                                    • tested the RFM69 gateway with a radio module attached -> Not working
                                    • tried to compile and execute the NRF24 gateway on the first spi bus (--spi-spidev-device=/dev/spidev0.0) -> same error as above
                                    I have checked my Makefile and configure files and they don't contain the modification proposed by @phildefer . Is this normal? I'm using the development branch.
                                    • franz-unixF
                                      franz-unixF
                                      franz-unix
                                      Tested with this commit of @phildefer, now both gateways compiles and starts but for both I got this error.
                                      Oct 27 20:50:41 DEBUG !TSM:INIT:TSP FAIL
                                      • franz-unixF
                                        franz-unixF
                                        franz-unix
                                        Hi, if someone needs more info (debug, log, etc...) I'm here.
                                        I can perform tests on Rpi 3 and Rpi 4 (Raspbian Buster) with NRF24 and RFM69 radio modules and then report the results. Not so much but maybe this can help the development.
                                        • jerseyguy1996J
                                          jerseyguy1996J
                                          jerseyguy1996
                                          wrote on last edited by jerseyguy1996
                                          #1037
                                          I'm doing a brand new install of Openhab2 and the mysensors gateway on a new Raspberry Pi 4 after having run Openhab(1) and the mysensors gateway successfully on a Raspberry Pi 3 for years. I used the development branch of the mysensorsgateway as discussed here: https://github.com/mysensors/MySensors/pull/1364
                                          I wrote down my step by step procedure here in case it helps someone else. I'm starting out with the pre-built Openhabian image found here: https://www.openhab.org/docs/installation/openhabian.html
                                          Install the PiGatewaySerial using these instructions:
                                          1. First get to your Downloads directory
                                          cd
                                          cd Downloads
                                          1. Clone the MySensors repository into your Downloads directory and then go into that folder
                                          git clone https://github.com/mysensors/MySensors.git --branch development
                                          cd MySensors
                                          1. Set configuration options (you can use “./configure —help” to see your options)
                                            a. In this case we are choosing to use the serial gateway with a pseudo terminal and a symbolic link to that pseudoterminal called ttyUSB20 in /dev. We then set the group to tty.
                                          ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20 --my-serial-groupname=tty
                                          Edit: If building this on a 64bit operating system you will need to edit the configure file before running make. Do the following:
                                          cp configure configure_bk
                                          nano configure
                                          Find this function
                                          function gcc_cpu_flags {
                                              local soc=$1
                                              case $soc in
                                          and find your CPU. In my case it is the BCM2711 (I've only done this on this one CPU so your mileage may vary) and I changed this:
                                           BCM2711)
                                                  flags="-march=armv8-a+crc -mtune=cortex-a72 -mfpu=neon-fp-armv8 -mfloat-abi=hard"
                                          to this:
                                          BCM2711)
                                                  flags="-march=armv8-a+crc -mtune=cortex-a72"
                                          Then proceed to step 4 below.
                                          1. Run make and make install
                                          make
                                          sudo make install
                                          1. We can set it to launch on boot up by running
                                          1. To launch it manually right now run (skip this step to run and see output for confirmation that it works)
                                          1. Executable in located:
                                          cd /usr/local/bin
                                          1. need root to run it:
                                          sudo mysgw
                                          That's pretty much it. I was happily greeted with:
                                          Dec 29 16:01:50 INFO Starting gateway...
                                          Dec 29 16:01:50 INFO Protocol version - 2.4.0-alpha
                                          Dec 29 16:01:50 DEBUG Serial port /dev/ttyUSB20 (115200 baud) created
                                          Dec 29 16:01:50 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
                                          Dec 29 16:01:50 DEBUG TSF:LRT:OK
                                          Dec 29 16:01:50 DEBUG TSM:INIT
                                          Dec 29 16:01:50 DEBUG TSF:WUR:MS=0
                                          Dec 29 16:01:50 DEBUG TSM:INIT:TSP OK
                                          Dec 29 16:01:50 DEBUG TSM:INIT:GW MODE
                                          Dec 29 16:01:50 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                          Dec 29 16:01:50 DEBUG MCO:REG:NOT NEEDED
                                          Dec 29 16:01:50 DEBUG MCO:BGN:STP
                                          Dec 29 16:01:50 DEBUG MCO:BGN:INIT OK,TSP=1
                                          Dec 29 16:01:50 DEBUG TSM:READY:NWD REQ
                                          Dec 29 16:01:50 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                          Dec 29 16:01:50 DEBUG TSF:MSG:READ,4-4-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                                          Dec 29 16:01:50 DEBUG TSF:MSG:READ,0-4-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                                          Dec 29 16:01:50 DEBUG TSF:MSG:BC
                                          Dec 29 16:01:52 DEBUG TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                                          Dec 29 16:01:52 DEBUG TSF:MSG:READ,4-4-0,s=2,c=1,t=2,pt=2,l=2,sg=0:0
                                          Dec 29 16:01:52 DEBUG TSF:MSG:READ,4-4-0,s=3,c=1,t=2,pt=2,l=2,sg=0:1
                                          Dec 29 16:01:52 DEBUG TSF:MSG:READ,4-4-0,s=4,c=1,t=2,pt=2,l=2,sg=0:1
                                          ^CDec 29 16:02:35 NOTICE Received SIGINT
