  3. Sensor advice
Sensor advice
11 Posts 6 Posters 1.6k Views 6 Watching
  • N Offline
    N Offline
    NoClue
    I am curious what company or individual would be a good contact to talk to about an idea I have using sensors (I think sensors is what I need to use, but won't know till I talk to someone)? I have no clue about sensors and what they are capable of doing, so just throwing this out here. Thank you.
    skywatchS HJ_SKH 2 Replies Last reply
    • N NoClue
      skywatchS Offline
      skywatchS Offline
      skywatch
      @noclue You could start right here, but we can't help much without knowing what you want to sense etc.
      • N Offline
        N Offline
        NoClue
        Thank you Skywatch. I am wanting something that would alert me (either through a "beep" noise or a light (or both)) when point B is directly below point A. The distance between the 2 points is about 8-12 inches. Point A would be considered the fulcrum and point B would be the moving part. Thank you.
        skywatchS 1 Reply Last reply
        • N NoClue
          skywatchS Offline
          skywatchS Offline
          skywatch
          @noclue Well theres still not a to go on, but you could use a rotational encoder on the moving part and read that. I guess the distance is too much for magnetic sensors to work (unless you could attach something to the fixed or moving part to bring them closer).
          Alternatively you might consider a light beam (or laser beam) hitting a reflective stick on to the moving part and sensing the light bounced back from it.
          But for all I know this is in a hot oven or even underwater. So maybe you can think of something from the above.
          N zboblamontZ 2 Replies Last reply
          • skywatchS skywatch
            N Offline
            N Offline
            NoClue
            @skywatch Thank you. I know I'm not too specific, sorry. Are you able to send me a Direct Message so I can give you more detailed information? Thanks.
              zboblamontZ Offline
              zboblamontZ Offline
              zboblamont
              @skywatch Laser?
              • zboblamontZ zboblamont
                @skywatch Laser?
                skywatchS Offline
                skywatchS Offline
                skywatch
                @zboblamont Yup - One of the little 'laser pointer' type 5V laser modules hitting a 'stick-on' reflector on the moving part with the sensor placed to get the reflection as it moves in an arc.
                • N NoClue
                  HJ_SKH Offline
                  HJ_SKH Offline
                  HJ_SK
                  @noclue Put your concrete idea here, what do you want to control?
                  N 1 Reply Last reply
                  • HJ_SKH HJ_SK
                    N Offline
                    N Offline
                    NoClue
                    @hj_sk I want to control my idea. I have put my ideas out there before, only to be stolen.
                    B 1 Reply Last reply
                    • T Offline
                      T Offline
                      tbowmo
                      This forum is about sharing ideas, and open source software / hardware.
                      So that is the reason people ask you to put your questions out in the open here. So all can collaborate, and enjoy the teamspirit ;)
                      • N NoClue
                        B Offline
                        B Offline
                        bjacobse
                        @noclue said in Sensor advice:
                        either do as Tbowmo suggests, or if you are afraid that we will all steal your idea, I can recommend to contact a electronic development company, that will sign a non-disclosure contract, a company could be this one (I'm not affiliated with the specific company)
                        https://www.prevas.com/
                        12.1k
