  2. Announcements
  3. 💬 FOTA (Wireless Programming)
wirelessupdateover the airsensebenderfotafirmware over the airwireless programming
130 Posts 46 Posters 81.9k Views 44 Watching
  • acbA
    acbA
    acb
    Quick question: Should FOTA work with personalized nodes/gateway?
    If the answer should be yes, then I appear to have a problem…
    As soon as I enable signing and signature requesting, the node will no longer respond to any internal or stream commands (e.g. Request Presentation, Reboot, Firmware, etc.) made via @tekka’s MYSController app. I haven’t tried anything else yet.
    The node still happily sends signed sensor data to the gateway and they ping-pong with heartbeats, etc.
    And as soon as I disable signing and signature requesting, the node will respond to all those same commands, quite happily rebooting, updating the firmware, etc.
    So, am I doing something wrong?
    (MYSController Version: 1.0.0beta, b3316. MySensors Library v2.3.1)
    acbA 1 Reply Last reply
    • S sindrome73
      @guillermo-schimmel Thanks for the reply.
      Very useful, but can you tell me more accurately what software to use to recompile after making the change ????
      Maybe some links to the software to download ..... thanks again for the availability
      sindrome73
      @sindrome73 Hi Good evening, and I'm sorry for the delay in the reply.
      As you have never done a Bootloader, if you are kind enough to do it, I thank you.
      The channel I'm using is the "Channel 84" for now I'm using only the 16MHZ Bootloade, but if you want, the others are fine too.
      In addition you can give me some starting point to be able to fill in too ??
      Thanks for your availability, greetings
      G 1 Reply Last reply
      • S sindrome73
        G
        G
        Guillermo Schimmel
        wrote on last edited by Guillermo Schimmel
        #116
        @sindrome73 here you have bootloaders for all the channels.
        https://github.com/guillebot/MYSensors-Bootloaders
        They are unchanged from default elsewhere. Only RF CHANNEL.
          sindrome73
          Hello!! And thank you again ......
          A really good job, it's something that was definitely missing ......
          I would suggest to the directors to expand the guide on OTA you better explain the steps to change channels and make a link to your great job !!
          Now if I understand this and the Bootloader that I have to load on my Arduino Pro-Mini, in practice insert in the path of the IDE of Arduino when I make the updates use that channel
          As soon as I can I try them and I'll let you know, in a lot of thanks again ......
          • acbA acb
            acbA
            acbA
            acb
            @acb
            So, I’m answering my own question a little here after digging into the gateway/node logs and code - and so I'm replying to my own post.
            Yes, it should and it does. FOTA (and any other internal commands) works with personalization (signed commands) using the MYSController.
            What doesn’t appear to work is if you’re using smartSleep and asking the MYSController app to trigger sending your internal command upon receiving from the node - in this case, simply a heartbeat from smartSleep.
            Does that make sense?
            So, if I don’t sleep the node, I can issue reboots and other internal commands that are signed, no problem.
            As soon as I switch to using smartSleep(DURATION) instead of wait(DURATION) and ask the MYSController app to trigger sending, for example, an internal reboot command “Upon RX”, then the reboot command never makes it to the node before it goes back to sleep. So the gateway tries to send the queued command, but the node has already gone back to sleep, and so it gets ignored.
            I’ve tried varying the smartSleep duration as well as the MY_SMART_SLEEP_WAIT_DURATION_MS define.
            I haven’t tried varying the MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS define, but it didn’t immediately appear that this was a transport connection issue.
            It looks like the gateway/node do all their NONCE request/response just fine, but it could be something to do with how all that gets queued and ordered.
            Doesn’t look like it has anything to do with ATC at all, since I’ve tried enabling/disabling on both node and gateway.
            Also doesn’t look like it has anything to do with the new driver, since I’ve tried both the old and the new and get the same behaviour.
            The only difference appears to be the way smartSleep interacts with signed messages.
            I’ll keep digging, but if anyone has any ideas what I might be doing wrong here, I’d appreciate any help or advice.
            • G Guillermo Schimmel
              G
              G
              Guillermo Schimmel
              @guillermo-schimmel It was bothering me that I was using a 16MHz compiled bootloader for 8MHz Arduino Pro Mini.
              So I recompiled the bootloader for all the channels and 1MHz, 8MHz and 16MHz.
              I don't know yet if it makes a difference but it seems right.
                mmanzanelli
                Hi, Can i burn mysbooloder on arduino mega2560?? its to use as a node. i have a node full functional that manage 24 signals, sensors and actuators. Now i want to make it FOTA node Thanks
                  mmanzanelli
                  hi, can i use mysbootloder with arduino mega2560? The mega is used as a node that manage 24 sensors / actuators, i use this by the number of pins needed. thnks
                  • M mmanzanelli
                    manutremo
                    @mmanzanelli I don't think you can, the Mega has a different memory structure not supported by the present bootloaders.
                    • badmannenB
                      badmannenB
                      badmannen
                      I have a quick question. so I don´t screw things up more than necessary, What bootloader should I use on a barebone 328p? ... I was just going to burn the "mini pro" that ´@Guillermo Schimmel so kindly uploaded on GitHub. but then I realised ..that might be wrong ..
                      Can anyone guide me about what to burn in, I am making a bunch of" 2AA Slim-nodes"
                      Also I ahve 3 old ones, I actually don´t remember but If I understood things correct, the Channel have to be the same on all nodes on the network I assume , and by default it is set to Channel 76, unless manually changed in the "old" code before this FOTA-generation?
                      I think I read too much info so my mind is slightly confused now =) so I hope it was clear enough
                      rPi 3 - UNO R3 - Mini - Nano - custom
                      • badmannenB badmannen
                        G
                        G
                        Guillermo Schimmel
                        @badmannen 76 is the default. I uploaded different versions for all the channel numbers.
                        Have in mind that they all have to match (gateway and all the nodes).
                        If they don't match they aren't going to see each other.
                        badmannenB 2 Replies Last reply
                          badmannenB
                          badmannenB
                          badmannen
                          @guillermo-schimmel
                          Ok so If I push this one "MYSBootloader.ch76.8000000L.RF24_PA_LOW.hex" into the FLASH on my barebone 328P via AVRDudess
                          It should , in theory at least , do the trick ?
                          And then After I can upload any sketch on top of it, in the Arduino IDE, with just choosing "Programmer-----> USBasp"
                          which is what I use to connect to the 328P
                            @guillermo-schimmel
                            G
                            G
                            Guillermo Schimmel
                            @badmannen
                            1st: In order to upload soft using a cable, you don't need to modify the bootloader. Any bootloader will work.
                            if and only if you want to experiment with FOTA (uploading firmware via wireless), then:
                            2nd: if you want to use FOTA and you choose MYSBOOTLOADER, then please check the fuses and lock bits, I dont remember them all. But it seems ok, have a try and let us know!
                              badmannenB
                              badmannenB
                              badmannen
                              @guillermo-schimmel OR Am I making things more complicated than I need? ... maybe it is easier just to copy your hexfile into -->
                              "ARDUINO_PATH" > hardware > arduino > avr > bootloaders
                              and then burn it in the Arduino IDE ?
                                G
                                G
                                Guillermo Schimmel
                                @badmannen are you sure that your arduino doesn't have a bootloader? why are you trying to modify it?
                                If it doesn't have a bootloader, or if you want to play with FOTA, then what you are doing it's ok, that is the way I did it.
                                badmannenB 1 Reply Last reply
                                • badmannenB
                                  badmannenB
                                  badmannen
                                  @guillermo-schimmel
                                  Ok Perfect! , I will give it a go and see what happens . thanks a lot .. I just needed a little confidence boost to get going =)
                                  Yes I wanted to Try to Use FOTA, just to check it out , at least it´s enabled if I push this bootloader in from the start
                                    badmannenB
                                    badmannenB
                                    badmannen
                                    wrote on last edited by badmannen
                                    #130
                                    @guillermo-schimmel Thanks a lot ! I got it all up and running node a couple of nodes. But now I confused myself . I got an Arduino Nano as a node that also acts as a repeater, what bootloader can I push into that one? I assume anycahnnel and 16MHz should do the trick since it got that crystal attached.
                                    And also one thing that is not really clear in my head, I set the "Fuses&Lock bits" with the AVRDudess for my 328P barebone. But do I really need that? . If I load the bootloader in ARduini IDE for example I specify all those settings in the "board.txt" file. Or is that just to tell the IDE what settings is on the chip ?
                                    If I clear these two things up I think I got everything sorted now =)
