  3. Comminucation without controller
12 Posts 2 Posters 4.2k Views 1 Watching
  • C Offline
    C Offline
    C.r.a.z.y.
    Sometimes i forgot to plug usb serial and my sensors, relays stoped after 2-3 times what they do normaly. Is there any way if these nodes stop working than reboot itself? Or any idea to keep working?
    C 1 Reply Last reply
    • C C.r.a.z.y.
      C Offline
      C Offline
      C.r.a.z.y.
      How can i get "fail" to a String from serial monitor?
      send: 51-51-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:0
      • hekH Offline
        hekH Offline
        You get a fail if no hw-ack is received from the recipient.
          C Offline
          C Offline
          C.r.a.z.y.
          @hek Thank you but my goal is to keep it working when there is no controller. My light will not be on or off if there is no controller so i want to add a some code like this;
          re = String(message.sensor);
          if (re.indexOf("fail") >=0)
          asm volatile (" jmp 0"); //reboot
          hekH 1 Reply Last reply
          • C C.r.a.z.y.
            hekH Offline
            hekH Offline
            @C.r.a.z.y.
            Sorry, I don't understand what your setup looks like or what your´re trying to archive.
              @C.r.a.z.y.
              C Offline
              C Offline
              C.r.a.z.y.
              @hek I am using Relay with Button sketch. When there is no controller-no hw-ack, my lights work 2-3 more times and i got "fail" then i can't change the lights state manually.
              When i see "fail" i have to restart the nano.
              • hekH Offline
                hekH Offline
                The hw ack is handled by the library/radio itself. Controller is not involved.
                So, what is your button sketch communicating with?
                • C Offline
                  C Offline
                  C.r.a.z.y.
                  This Sketch works 1 on and 1 off when there is no controller;
                  repeater started, id 0
                  send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
                  send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
                  send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=5,st=fail:Relay
                  send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
                  send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                  **send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:0
                  "#include <MySensor.h>
                  "#include <SPI.h>
                  "#include <Bounce2.h>
                  "#define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                  "#define NUMBER_OF_RELAYS 1 // Total number of attached relays
                  "#define RELAY_ON 1 // GPIO value to write to turn on attached relay
                  "#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
                  "#define CHILD_ID 1
                  "#define TRIGGER_PIN 7 // Arduino pin tied to trigger pin on the ultrasonic sensor.
                  unsigned long SLEEP_TIME = 700; // Sleep time between reads (in milliseconds)
                  //int hey =50;
                  int dist;
                  int kac;
                  int value;
                  int oldValue=0;
                  bool state;
                  Bounce debouncer = Bounce();
                  Bounce debouncer2 = Bounce();
                  gw.sendSketchInfo("Relay", "1.0");
                  gw.present(sensor, S_LIGHT);
                  pinMode(pin, OUTPUT);
                  state = gw.loadState(CHILD_ID);
                  digitalWrite(pin, state?RELAY_ON:RELAY_OFF);
                  debouncer.attach(TRIGGER_PIN);
                  debouncer2.attach(RELAY_1);
                  debouncer.interval(5); debouncer2.interval(5);
                  debouncer.update();
                  dist = debouncer.read();
                  debouncer2.update();
                  kac = debouncer2.read();
                  if (dist == 0)
                      if(kac==0  ) //MANUAL ON-OFF
                       digitalWrite(RELAY_1, HIGH );  // gw.send(msg.set(1));
                       delay(1000); //  gw.sleep(SLEEP_TIME);
                      else  //MANUAL ON-OFF
                        digitalWrite(RELAY_1, LOW );   // gw.send(msg.set(0));
                         delay(1000);//  gw.sleep(SLEEP_TIME);
                   //NORMAL PROCESS FOR MYSENSORS.h
                    if (dist != oldValue && dist==0) {
                     gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                     oldValue = dist;
                  if (message.type==V_LIGHT) {
                  // digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                  • hekH Offline
                    hekH Offline
                    Wierd. even if the node loses it's parent it should retry finding a new each time you press the "button" and send a new state.
                    • hekH Offline
                      hekH Offline
                      There has been a few edge-case bugfixes done recently on github/master.
                      Could you just download latest and try the again to check if it has been fixed already?
                      • hekH Offline
                        hekH Offline
                        You cannot use id=0 for a repeater node.
                        Id 0 is reserved for gateway.
                        • C Offline
                          C Offline
                          C.r.a.z.y.
                          New master file didn't make difference. When i see "fail" i can't change the state with original RelayWithButtonActuator sketch.
                          Ok id is not "0" now.
                          11.9k
                          113.3k
