  3. Comminucation without controller
12 Posts 2 Posters 4.7k Views 1 Watching
    You get a fail if no hw-ack is received from the recipient.
    C 1 Reply Last reply
      C
      C
      C.r.a.z.y.
      @hek Thank you but my goal is to keep it working when there is no controller. My light will not be on or off if there is no controller so i want to add a some code like this;
      re = String(message.sensor);
      if (re.indexOf("fail") >=0)
      asm volatile (" jmp 0"); //reboot
      hekH 1 Reply Last reply
      • C C.r.a.z.y.
        @C.r.a.z.y.
        Sorry, I don't understand what your setup looks like or what your´re trying to archive.
          @C.r.a.z.y.
          C
          C
          C.r.a.z.y.
          @hek I am using Relay with Button sketch. When there is no controller-no hw-ack, my lights work 2-3 more times and i got "fail" then i can't change the lights state manually.
          When i see "fail" i have to restart the nano.
            The hw ack is handled by the library/radio itself. Controller is not involved.
            So, what is your button sketch communicating with?
            • C
              C
              C.r.a.z.y.
              This Sketch works 1 on and 1 off when there is no controller;
              repeater started, id 0
              send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
              send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
              send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=5,st=fail:Relay
              send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
              send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
              **send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:0
              "#include <MySensor.h>
              "#include <SPI.h>
              "#include <Bounce2.h>
              "#define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
              "#define NUMBER_OF_RELAYS 1 // Total number of attached relays
              "#define RELAY_ON 1 // GPIO value to write to turn on attached relay
              "#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
              "#define CHILD_ID 1
              "#define TRIGGER_PIN 7 // Arduino pin tied to trigger pin on the ultrasonic sensor.
              unsigned long SLEEP_TIME = 700; // Sleep time between reads (in milliseconds)
              //int hey =50;
              int dist;
              int kac;
              int value;
              int oldValue=0;
              bool state;
              Bounce debouncer = Bounce();
              Bounce debouncer2 = Bounce();
              gw.sendSketchInfo("Relay", "1.0");
              gw.present(sensor, S_LIGHT);
              pinMode(pin, OUTPUT);
              state = gw.loadState(CHILD_ID);
              digitalWrite(pin, state?RELAY_ON:RELAY_OFF);
              debouncer.attach(TRIGGER_PIN);
              debouncer2.attach(RELAY_1);
              debouncer.interval(5); debouncer2.interval(5);
              debouncer.update();
              dist = debouncer.read();
              debouncer2.update();
              kac = debouncer2.read();
              if (dist == 0)
                  if(kac==0  ) //MANUAL ON-OFF
                   digitalWrite(RELAY_1, HIGH );  // gw.send(msg.set(1));
                   delay(1000); //  gw.sleep(SLEEP_TIME);
                  else  //MANUAL ON-OFF
                    digitalWrite(RELAY_1, LOW );   // gw.send(msg.set(0));
                     delay(1000);//  gw.sleep(SLEEP_TIME);
               //NORMAL PROCESS FOR MYSENSORS.h
                if (dist != oldValue && dist==0) {
                 gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                 oldValue = dist;
              if (message.type==V_LIGHT) {
              // digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                Wierd. even if the node loses it's parent it should retry finding a new each time you press the "button" and send a new state.
                  There has been a few edge-case bugfixes done recently on github/master.
                  Could you just download latest and try the again to check if it has been fixed already?
                    You cannot use id=0 for a repeater node.
                    Id 0 is reserved for gateway.
                    • C
                      C
                      C.r.a.z.y.
                      New master file didn't make difference. When i see "fail" i can't change the state with original RelayWithButtonActuator sketch.
                      Ok id is not "0" now.
