  3. GUIDE - NRF5 / NRF51 / NRF52 for beginners
102 Posts 26 Posters 50.3k Views 26 Watching
  • N
    N
    ncollins
    At the time, I did not have a BMP or any STM32 capable of being flashed as a programmer.
    I figured the jlink clone might be useful in the future, but I definitely think the BMP / diy programmer is the way I would have gone if I had one sitting around.
      Sancho119
      @ncollins
      @monte
      thx for these advices.
      I think i will try with BMP clone (STM32F103C8T6), cheaper than J-link (i must only wait 1 month to have it, buying it in china...)
      is it possible to erase E73 with BMP in win10 ?
      • berkseoB
        berkseoB
        berkseo
        #37
        https://translate.google.ru/translate?sl=auto&tl=en&u=http%3A%2F%2Fmysensors.ru%2Fforum%2Fviewtopic.php%3Ff%3D5%26t%3D456
        https://www.nordicsemi.com/Software-and-Tools/Development-Tools/nRFgo-Studio/Download#infotabs
          Sancho119
          Some news !
          i buy a Jlink, and success in erase my nrf52832 with nrf prog, using method of berkseo.
          Next i try to upload a basic sketch (blink) :
          #define MY_RADIO_NRF5_ESB
          #include <nrf.h>
          Serial.begin(9600);
          hwPinMode(LED_BUILTIN,OUTPUT_H0H1);
          digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
          delay(1000); // wait for a second
          digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
          I have this :
          Licensed under GNU GPL v2
          For bug reports, read
          debug_level: 2
          adapter speed: 10000 kHz
          Info : No device selected, using first device.
          Info : J-Link ARM-OB STM32 compiled Aug 22 2012 19:52:04
          Info : Hardware version: 7.00
          Info : VTarget = 3.300 V
          Info : clock speed 10000 kHz
          Info : SWD IDCODE 0x2ba01477
          Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
          xPSR: 0x01000000 pc: 0x0000051c msp: 0x20010000
          ** Programming Started **
          auto erase enabled
          Warn : Unknown device (HWID 0x00000139)
          Warn : not enough working area available(requested 32)
          Warn : no working area available, falling back to slow memory writes
          wrote 12288 bytes from file C:\Users\Sancho\AppData\Local\Temp\arduino_build_76789/NRF5_blink_led8.ino.hex in 4.155332s (2.888 KiB/s)
          ** Programming Finished **
          ** Verify Started **
          Warn : not enough working area available(requested 52)
          verified 10812 bytes in 0.165932s (63.632 KiB/s)
          ** Verified OK **
          ** Resetting Target **
          shutdown command invoked
          I think its good, but when i put a led with a resistance on P0.08, nothing :(
          could you help me more ?
          • S Sancho119
            Some news !
            #include <nrf.h>
            Serial.begin(9600);
            I have this :
            debug_level: 2
            auto erase enabled
            ** Verified OK **
            Toyman
            @sancho119 said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
            Some news !
            #include <nrf.h>
            Serial.begin(9600);
            I have this :
            debug_level: 2
            auto erase enabled
            ** Verified OK **
            LED_BUILTIN corresponds to po17
            • P
              P
              p359
              Hi. Are the steps in first post still valid please?
              I'm trying without luck to get first nrf52 programmed. I get a weird error"Error resolving FQBN: missing" in Arduino IDE when I try to verify any basic sketch, even blink. Thanks for any thoughts
              N 1 Reply Last reply
              • P p359
                N
                N
                ncollins
                @p359 Which version of Arduino IDE are you using? I was seeing that with 1.8.10, but I ended up downgrading to 1.8.6 to test and it worked.
                P 1 Reply Last reply
                • N ncollins
                  P
                  P
                  p359
                  @ncollins 1.8.10 also. I'll try then 1.8.6 tonight. Cheers for the idea!
                    MartinC
                    Is it possible to get Serial output in Arduino IDE for nRF52 boards with J-Link OB 7.0? Or do I need a newer programmer? Or maybe I can get it with ST-Link v2/v2.1 somehow?
                    alowhumA 1 Reply Last reply
                    • M MartinC
                      alowhumA
                      alowhumA
                      alowhum
                      @martinc said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                      The answer is actually in the first post.
                        MartinC
                        @alowhum said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                        Thanks, I've seen it before. In my case a programmer is easier solution - I don't know yet how to re-assign TX&RX pins in Arduino on my EByte 52840 module and in specs for that module there is no info about UART connectivity.
                        Maybe you know how can I re-assign TX&RX pins in Arduino? Then I can solder wires to assigned TX&RX pins and connect them to USB-UART. What I've found is in Forth language ...
                        • I
                          I
                          idanronen
                          Does anyone know what settings I need to use for this development board with arduino ide?
                          Ebyte E104-BT5032A-TB
                          https://a.aliexpress.com/_dT5dMb8
                          It has a cp2102 on board which I have the driver for. I've installed the arduino ide nrf52 board, but I can't find a programmer, board, or any other settings which will let me flash it without a Java exception or a timeout. Maybe I need to set the jumpers differently but there's no documentation on that.
                          OTA works fine though.
                          Nca78N 2 Replies Last reply
                          • I idanronen
                            @idanronen this is a UART to BT module, and from what I understand in the documentation the CP2102 is only here to give you access to the serial port of the module, but not to program it ?
                            To program it you will have to use the SWDIO/SWDCLK pins I suppose, and I'm interested to know if it can be reprogrammed because that would make a tiny NRF52832 module for boards that don't require many IOs.
                            I 2 Replies Last reply
                            • Nca78N Nca78
                              I
                              I
                              idanronen
                              @Nca78 I feared that might be the case. my task for today was to dig up my st-link and try that, though I hoped I might have done something wrong and the cp2102 can be used to program and not just debug.
                              That module is pretty cheap and from what I see with the naked eye, you can disconnect the cp2102 with the jumpers so the power consumption might actually be good enough to use as-is.
                              I'll report back to let you know once I've succeeded
                              • A
                                Avamander
                                wrote on last edited by Avamander
                                #49
                                I tried flashing MySensors onto my nRF52840 Adafruit Feather board but it fails, I opened an issue on GH about it https://github.com/mysensors/MySensors/issues/1424, maybe someone here has any ideas how to get it running on those boards?
                                • Nca78N Nca78
                                  I
                                  I
                                  idanronen
                                  wrote on last edited by idanronen
                                  #50
                                  @Nca78 no luck with the st-link v2, though i doubt it is related to the board, but rather my inability. i've tried every option in zadig, installed the st-link driver from their website, and nothing works.
                                  i get this in arduino ide:
                                  debug_level: 0
                                  0x4000
                                  Error: init mode failed (unable to connect to the target)
                                  in procedure 'program'
                                  in procedure 'init' called at file "embedded:startup.tcl", line 473
                                  in procedure 'ocd_bouncer'
                                  ** OpenOCD init failed **
                                  the selected serial port
                                  • N
                                    N
                                    ncollins
                                    With all the NRF52 modules from EBYTE I've tried, the only way I can flash them is over SWDIO, SWCLK, GND, VCC via JLink clone.
                                    And, before flashing is possible, I have to unlock the module by following these directions: https://github.com/micooke/arduino-nRF5-smartwatches/blob/master/nrf52_disable_read_protection.txt
                                    I 1 Reply Last reply
                                    • N ncollins
                                      I
                                      I
                                      idanronen
                                      @ncollins I've been working on turning an stm32f030f4p6 into a blackmagic probe for a few days now. Hit a wall when the compiled firmware came out to 83kb which is over the 64kb on board. Found someone who shrunk it down so it'd fit, and someone claiming it has another 64kb which can be unlocked. I'm just looking for the patience to get back in there, as this whole thing has been a major ordeal
                                      • I
                                        I
                                        idanronen
                                        Im not sure my flashing with the blackmagic even does anything. The console is unclear:
                                        Sketch uses 3556 bytes (0%) of program storage space. Maximum is 409600 bytes.
                                        Remote debugging using \\.\COM11
                                        Target voltage: ABSENT!
                                        Available Targets:
                                        No. Att Driver
                                         1      Nordic nRF52 M3/M4
                                         2      Nordic nRF52 Access Port
                                        Attaching to Remote target
                                        0xfffffffe in ?? ()
                                        Reading symbols from nrf1.ino.elf...done.
                                        Loading section .text, size 0xde4 lma 0x1c000
                                        Loading section .ARM.exidx, size 0x8 lma 0x1cde4
                                        Loading section .data, size 0x78 lma 0x1cdec
                                        Start address 0x1c578, load size 3684
                                        Transfer rate: 33 KB/sec, 614 bytes/write.
                                        Temporary breakpoint 1 at 0x1cb8c: file C:\Users\....\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.6.0\cores\nRF5\main.cpp, line 28.
                                        Starting program: C:\Users\....\AppData\Local\Temp\arduino_build_366086\nrf1.ino.elf
                                        Note: automatically using hardware breakpoints for read-only addresses.
                                        Program received signal SIGSEGV, Segmentation fault.
                                        0x00000000 in ?? ()
                                        Program complete!
                                        and i dont see any serial debug information
                                        • BearWithBeardB
                                          BearWithBeardB
                                          BearWithBeard
                                          wrote on last edited by BearWithBeard
                                          #54
                                          I just got my first NRF5 running. I'll note how I got it working in case any of you guys still have troubles:
                                          Setup
                                          • OS: Windows 10
                                          • Programmer: STM32 Blue Pill with the Black Magic Probe firmware
                                          • NRF5: EByte E73-TBB dev board with a E73-2G4M0S1B (NRF52832)
                                          • Environment: PlatformIO
                                          Instructions
                                          Load the Black Magic Probe firmware with stlink as the probe host onto Blue Pill. You can follow this guide.
                                          Connect your new BMP to the NRF52 module:
                                          BMP NRF52 Serial Port
                                          3V3 3V3
                                          GND GND
                                          A5 SWDCLK GDB Server
                                          B14 SWDIO GBD Server
                                          A2 RXI UART
                                          A3 TXO UART
                                          Note: A2 and A3 are not required for programming. This is how you'd wire up the BMP for "classic" serial debugging. You can use the BMP both for programming and serial communication - no need for a second FTDI module.
                                          Using the GNU Arm Embedded Toolchain, run arm-none-eabi-gdb in a console and enter the following commands to unlock the NRF52:
                                          target extended-remote BMP_GDB_SERVER_PORT
                                          mon swdp_scan
                                          attach N // N = number of "Nordic nRF52 Access Port" if there are several
                                          mon erase_mass
                                          detach
                                          From the two serial ports the BMP provides, you want to use the GDB Server for BMP_GDB_SERVER_PORT above. If Windows only provides generic names for both ("USB Serial Device" or something), the one with the lower number should (usually) be the right choice. If not, try the other one.
                                          Windows users also must prefix the port with \\.\ if the number is double-digit, e.g. \\.\COM13.
                                          Now you can start uploading sketches the usual way. Here's my minimal PlatformIO config:
                                          [env:nrf52_dk]
                                          platform = nordicnrf52
                                          board = nrf52_dk
                                          board_build.variant = generic
                                          framework = arduino
                                          upload_protocol = blackmagic
                                          lib_deps =
                                          	548 ; MySensors
                                          And a minimal test sketch for MySensors:
                                          #include <Arduino.h>
                                          #define LED 17
                                          #define MY_RADIO_RF24
                                          #define MY_NODE_ID 182
                                          #define SKETCH_NAME "NRF52 Test"
                                          #define SKETCH_VERSION "0.1"
                                          #define CHILD_ID 1
                                          MyMessage msg(CHILD_ID, V_VAR1);
                                            present(CHILD_ID, S_CUSTOM);
                                            pinMode(LED, OUTPUT);
                                            static uint8_t num;
                                            send(msg.set(num));
                                            ++num;
                                            digitalWrite(LED, HIGH);
                                            wait(5000);
                                            digitalWrite(LED, LOW);
                                            wait(5000);
                                          Works like a charm so far! Now, if you please excuse me, I have a whole new microprocessor family to explore. Fun times!
                                          nagelcN Ikes 72000I I electrikE 4 Replies Last reply
