  3. GUIDE - NRF5 / NRF51 / NRF52 for beginners
102 Posts 26 Posters 50.2k Views 26 Watching
    Sancho119
    I'm trying to begin with nrf52832.
    I have follow advice, with soldering 4 wires. I use STlink v2, downloading soft before use it.
    When i try to erase the nrf52832, with sketch "mass_erase" in exemple, i have the following error :
    Arduino : 1.8.7 (Windows 10), Carte : "MyBoardNRF5 nRF52832, None, Crystal Oscillator, Don't enable"
    C:\Users\Sancho\AppData\Local\Arduino15\packages\sandeepmistry\tools\openocd\0.10.0-dev.nrf5/bin/openocd.exe -d2 -f interface/stlink-v2.cfg -c transport select hla_swd; set WORKAREASIZE 0x4000; -f target/nrf52.cfg -c init; halt; nrf51 mass_erase; program {{{build.core.path}/SDK/components/softdevice/none/hex/none_nrf52_{softdeviceversion}_softdevice.hex}} verify reset; shutdown;
    Licensed under GNU GPL v2
    For bug reports, read
    debug_level: 2
    0x4000
    adapter speed: 10000 kHz
    Info : clock speed 4000 kHz
    Info : STLINK v2 JTAG v29 API v2 SWIM v7 VID 0x0483 PID 0x3748
    Info : using stlink api v2
    Info : Target voltage: 3.280426
    Error: init mode failed (unable to connect to the target)
    in procedure 'init'
    in procedure 'ocd_bouncer'
    Erreur lors de la gravure de la séquence d'initialisation.
    I try to upload an empty sketch (MyBoardNRF5), and have this message :
    Le croquis utilise 10508 octets (2%) de l'espace de stockage de programmes. Le maximum est de 524288 octets.
    C:\Users\Sancho\AppData\Local\Arduino15\packages\sandeepmistry\tools\openocd\0.10.0-dev.nrf5/bin/openocd.exe -d2 -f interface/stlink-v2.cfg -c transport select hla_swd; set WORKAREASIZE 0x4000; -f target/nrf52.cfg -c program {{C:\Users\Sancho\AppData\Local\Temp\arduino_build_74329/MyBoardNRF5.ino.hex}} verify reset; shutdown;
    debug_level: 2
    0x4000
    Une erreur est survenue lors du transfert du croquis
    in procedure 'program'
    in procedure 'init' called at file "embedded:startup.tcl", line 473
    ** OpenOCD init failed **
    shutdown command invoked
    Can you help me please ?
    monteM 1 Reply Last reply
    • S Sancho119
      debug_level: 2
      0x4000
      in procedure 'init'
      debug_level: 2
      0x4000
      monteM
      monteM
      monte
      wrote on last edited by monte
      #31
      @sancho119 what exact model of a board do you have? Did you try to switch SWDIO and SWCLK, maybe they are messed up? Or lose connection? To erase softdevice you can simply chose Tools>Softdevice>"None" and then press "Burn bootloader" button.
        Sancho119
        Hello
        it's a E73 2G4M04S1B from EBYTE
        When i switch SWDIO and SWCLK, i can see the led of STLink V2 changing from red to blue, but when i try to uplod empty sketch (MyBoardNRF5), i have this error :
        C:\Users\Sancho\AppData\Local\Arduino15\packages\sandeepmistry\tools\openocd\0.10.0-dev.nrf5/bin/openocd.exe -d2 -f interface/stlink-v2.cfg -c transport select hla_swd; set WORKAREASIZE 0x4000; -f target/nrf52.cfg -c program {{C:\Users\Sancho\AppData\Local\Temp\arduino_build_432557/MyBoardNRF5.ino.hex}} verify reset; shutdown;
        debug_level: 2
        0x4000
        Info : Target voltage: 3.283200
        in procedure 'reset' called at file "embedded:startup.tcl", line 478
        embedded:startup.tcl:454: Error: ** Unable to reset target **
        in procedure 'program_error' called at file "embedded:startup.tcl", line 479
        le port série sélectionné at file "embedded:startup.tcl", line 454
        n'existe pas ou votre Arduino n'est pas connectée
        N 1 Reply Last reply
        • S Sancho119
          Hello
          debug_level: 2
          0x4000
          N
          N
          ncollins
          @sancho119 No matter what I tried, I could not unlock the E73 with the STLink.
          I had to buy a jlink clone, download a bunch of segger debugging tools, use the segger tools to override the lock flag. After that I could flash the bootloader.
          https://github.com/micooke/arduino-nRF5-smartwatches/blob/master/nrf52_disable_read_protection.txt
          #To share my experience with the nRF52832.
          #I was unable to disable the read protection / flash lock with a BMP or ST-Link V2, but i was successful with a J-Link.
          #When nRF52832 chip is read protected / locked, the first step is to try:
          nrfjprog –recover -f nrf52
          #This performs the same task as:
          Jlink -if swd -device nrf52
          J-Link>SWDSelect
          J-Link>SWDWriteDP 1, 0x50000000
          J-Link>SWDWriteDP 2, 0x01000000
          J-Link>SWDWriteAP 1, 0x00000001
          #Wait until AP 2 is 0, and the operation is complete
          J-Link>SWDReadAP 2
          #If two successive reads from AP 3 produce 0, then 1 then protection is disabled
          J-Link>SWDReadAP 3
          J-Link>SWDReadAP 3
          #Tested with JLink v6.20b
          • N ncollins
            J-Link>SWDSelect
            J-Link>SWDReadAP 2
            J-Link>SWDReadAP 3
            J-Link>SWDReadAP 3
            monteM
            monteM
            monte
            @ncollins have you tried this: https://github.com/AndruPol/nrf52832-recover ?
            • N
              N
              ncollins
              At the time, I did not have a BMP or any STM32 capable of being flashed as a programmer.
              I figured the jlink clone might be useful in the future, but I definitely think the BMP / diy programmer is the way I would have gone if I had one sitting around.
                Sancho119
                @ncollins
                @monte
                thx for these advices.
                I think i will try with BMP clone (STM32F103C8T6), cheaper than J-link (i must only wait 1 month to have it, buying it in china...)
                is it possible to erase E73 with BMP in win10 ?
                • berkseoB
                  berkseoB
                  berkseo
                  #37
                  https://translate.google.ru/translate?sl=auto&tl=en&u=http%3A%2F%2Fmysensors.ru%2Fforum%2Fviewtopic.php%3Ff%3D5%26t%3D456
                  https://www.nordicsemi.com/Software-and-Tools/Development-Tools/nRFgo-Studio/Download#infotabs
                    Sancho119
                    Some news !
                    i buy a Jlink, and success in erase my nrf52832 with nrf prog, using method of berkseo.
                    Next i try to upload a basic sketch (blink) :
                    #define MY_RADIO_NRF5_ESB
                    #include <nrf.h>
                    Serial.begin(9600);
                    hwPinMode(LED_BUILTIN,OUTPUT_H0H1);
                    digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
                    delay(1000); // wait for a second
                    digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
                    I have this :
                    debug_level: 2
                    Info : No device selected, using first device.
                    Info : J-Link ARM-OB STM32 compiled Aug 22 2012 19:52:04
                    Info : Hardware version: 7.00
                    Info : VTarget = 3.300 V
                    Info : clock speed 10000 kHz
                    Info : SWD IDCODE 0x2ba01477
                    Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
                    xPSR: 0x01000000 pc: 0x0000051c msp: 0x20010000
                    ** Programming Started **
                    auto erase enabled
                    Warn : Unknown device (HWID 0x00000139)
                    Warn : not enough working area available(requested 32)
                    Warn : no working area available, falling back to slow memory writes
                    wrote 12288 bytes from file C:\Users\Sancho\AppData\Local\Temp\arduino_build_76789/NRF5_blink_led8.ino.hex in 4.155332s (2.888 KiB/s)
                    ** Programming Finished **
                    ** Verify Started **
                    Warn : not enough working area available(requested 52)
                    verified 10812 bytes in 0.165932s (63.632 KiB/s)
                    ** Verified OK **
                    ** Resetting Target **
                    I think its good, but when i put a led with a resistance on P0.08, nothing :(
                    could you help me more ?
                    • S Sancho119
                      Some news !
                      #include <nrf.h>
                      Serial.begin(9600);
                      I have this :
                      debug_level: 2
                      auto erase enabled
                      ** Verified OK **
                      Toyman
                      @sancho119 said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                      Some news !
                      #include <nrf.h>
                      Serial.begin(9600);
                      I have this :
                      debug_level: 2
                      auto erase enabled
                      ** Verified OK **
                      LED_BUILTIN corresponds to po17
                      • P
                        P
                        p359
                        Hi. Are the steps in first post still valid please?
                        I'm trying without luck to get first nrf52 programmed. I get a weird error"Error resolving FQBN: missing" in Arduino IDE when I try to verify any basic sketch, even blink. Thanks for any thoughts
                        • P p359
                          N
                          N
                          ncollins
                          @p359 Which version of Arduino IDE are you using? I was seeing that with 1.8.10, but I ended up downgrading to 1.8.6 to test and it worked.
                          P 1 Reply Last reply
                          • N ncollins
                            P
                            P
                            p359
                            @ncollins 1.8.10 also. I'll try then 1.8.6 tonight. Cheers for the idea!
                              MartinC
                              Is it possible to get Serial output in Arduino IDE for nRF52 boards with J-Link OB 7.0? Or do I need a newer programmer? Or maybe I can get it with ST-Link v2/v2.1 somehow?
                              alowhumA 1 Reply Last reply
                              • M MartinC
                                alowhumA
                                alowhumA
                                alowhum
                                @martinc said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                                The answer is actually in the first post.
                                  MartinC
                                  @alowhum said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                                  Thanks, I've seen it before. In my case a programmer is easier solution - I don't know yet how to re-assign TX&RX pins in Arduino on my EByte 52840 module and in specs for that module there is no info about UART connectivity.
                                  Maybe you know how can I re-assign TX&RX pins in Arduino? Then I can solder wires to assigned TX&RX pins and connect them to USB-UART. What I've found is in Forth language ...
                                  • I
                                    I
                                    idanronen
                                    Does anyone know what settings I need to use for this development board with arduino ide?
                                    Ebyte E104-BT5032A-TB
                                    https://a.aliexpress.com/_dT5dMb8
                                    It has a cp2102 on board which I have the driver for. I've installed the arduino ide nrf52 board, but I can't find a programmer, board, or any other settings which will let me flash it without a Java exception or a timeout. Maybe I need to set the jumpers differently but there's no documentation on that.
                                    OTA works fine though.
                                    Nca78N 2 Replies Last reply
                                    • I idanronen
                                      @idanronen this is a UART to BT module, and from what I understand in the documentation the CP2102 is only here to give you access to the serial port of the module, but not to program it ?
                                      To program it you will have to use the SWDIO/SWDCLK pins I suppose, and I'm interested to know if it can be reprogrammed because that would make a tiny NRF52832 module for boards that don't require many IOs.
                                      I 2 Replies Last reply
                                      • Nca78N Nca78
                                        I
                                        I
                                        idanronen
                                        @Nca78 I feared that might be the case. my task for today was to dig up my st-link and try that, though I hoped I might have done something wrong and the cp2102 can be used to program and not just debug.
                                        That module is pretty cheap and from what I see with the naked eye, you can disconnect the cp2102 with the jumpers so the power consumption might actually be good enough to use as-is.
                                        I'll report back to let you know once I've succeeded
                                        • A
                                          Avamander
                                          wrote on last edited by Avamander
                                          #49
                                          I tried flashing MySensors onto my nRF52840 Adafruit Feather board but it fails, I opened an issue on GH about it https://github.com/mysensors/MySensors/issues/1424, maybe someone here has any ideas how to get it running on those boards?
