Serial Monitor: Reversed question marks when on battery
I am creating my first sensor using a easypcb. It has two reed switches, one on D3 and the other on D8 (via an IRS).
When I power the sensor from an USB port the output in the serial monitor looks fine, but when I power it via battery (2 AA rechargables, 2.6v in total) the output contains reversed question marks:
12:45:04.443 -> __ __ ____ 12:45:04.443 -> | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ 12:45:04.443 -> | |\/| | | | \__⸮ \ / _ \ `_ \/ __|/ _ \| `__/ __| 12:45:04.443 -> | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ 12:45:04.443 -> |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ 12:45:04.476 -> |___/ 2.3.2 12:45:04.476 -> 12:45:04.476 -> 16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,RE⸮=255,VER=2.3.2 12:45:04.476 -> 28 T⸮M:INIT 12:45:04.476 -> 28 TSF:WUR:MS=0 12:45:04.476 -> 32 TSM:INIT:TSP OK 12:45:04.476 -> 34 TS⸮:INI⸮:ST⸮TID=1 12:45:04.476 -> 36 TSF:SID:OK,ID=1 12:45:04.476 -> 38 TSM:FPAR 12:45:04.476 -> 43 ?TSF:MSG:SEND,1-1-255-255,s=255,⸮=3,t=7,pt=0,l=0,⸮g=0,⸮t=0,st=OK: 12:45:06.499 -> 2052 !TSM:FPAR:NO REPLYThis has been soldered to the PCB:
- Arduino Pro Mini 3v
RFM69HW
Antenna
//Battery Measurement
1M Ohm
470k Ohm
1uF Capacitor
//Booster
Step up Booster(to 3v)
1uF Capacitor
Does that mean the booster is broken? Or did I use the wrong capacitor size? The easypcb says 0.1uF but I only had 1uF capacitors and I hoped it would work.
RFM69HW
Antenna
1M Ohm
470k Ohm
1uF Capacitor
//Booster
1uF Capacitor
Well, it seems the problem might have been that the booster capacitor was touching the booster.
Only problem left is a lot of NACKs, but I will create a different topic for that.
/edit: There are less reversed question marks now, but there are still some.
@kiesel said in Serial Monitor: Reversed question marks when on battery:
There should be no illegal characters at all. Looks like there's still a comm issue.
@Yveaux thanks, what could be the reason for them? And by xomms you mean Serial, not the rfm69, right?
