  3. Serial Monitor: Reversed question marks when on battery
5 Posts 2 Posters 553 Views 2 Watching
  • K
    K
    kiesel
    wrote on last edited by kiesel
    I am creating my first sensor using a easypcb. It has two reed switches, one on D3 and the other on D8 (via an IRS).
    When I power the sensor from an USB port the output in the serial monitor looks fine, but when I power it via battery (2 AA rechargables, 2.6v in total) the output contains reversed question marks:
    12:45:04.443 ->  __  __       ____
    12:45:04.443 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
    12:45:04.443 -> | |\/| | | | \__⸮ \ / _ \ `_ \/ __|/ _ \| `__/ __|
    12:45:04.443 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
    12:45:04.443 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
    12:45:04.476 ->         |___/                      2.3.2
    12:45:04.476 ->
    12:45:04.476 -> 16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,RE⸮=255,VER=2.3.2
    12:45:04.476 -> 28 T⸮M:INIT
    12:45:04.476 -> 28 TSF:WUR:MS=0
    12:45:04.476 -> 32 TSM:INIT:TSP OK
    12:45:04.476 -> 34 TS⸮:INI⸮:ST⸮TID=1
    12:45:04.476 -> 36 TSF:SID:OK,ID=1
    12:45:04.476 -> 38 TSM:FPAR
    12:45:04.476 -> 43 ?TSF:MSG:SEND,1-1-255-255,s=255,⸮=3,t=7,pt=0,l=0,⸮g=0,⸮t=0,st=OK:
    12:45:06.499 -> 2052 !TSM:FPAR:NO REPLY
    This has been soldered to the PCB:
    • Arduino Pro Mini 3v
      RFM69HW
      Antenna
      //Battery Measurement
      1M Ohm
      470k Ohm
      1uF Capacitor
      //Booster
      Step up Booster(to 3v)
      1uF Capacitor
    Does that mean the booster is broken? Or did I use the wrong capacitor size? The easypcb says 0.1uF but I only had 1uF capacitors and I hoped it would work.
    K 1 Reply Last reply
    • K kiesel
      12:45:04.476 ->
        RFM69HW
        Antenna
        1M Ohm
        470k Ohm
        1uF Capacitor
        //Booster
        1uF Capacitor
      K
      K
      kiesel
      Well, it seems the problem might have been that the booster capacitor was touching the booster.
      Only problem left is a lot of NACKs, but I will create a different topic for that.
      /edit: There are less reversed question marks now, but there are still some.
      • K kiesel
        @kiesel said in Serial Monitor: Reversed question marks when on battery:
        There should be no illegal characters at all. Looks like there's still a comm issue.
        • YveauxY Yveaux
          K
          K
          kiesel
          @Yveaux thanks, what could be the reason for them? And by xomms you mean Serial, not the rfm69, right?
          • K kiesel
            Baud rate could be slightly off, or crappy connections,or ....
            Correct
