  3. Vera
  4. Upgrading Plugin and Libraries
22 Posts 4 Posters 11.2k Views 1 Watching
    Just upload/overwrite the Vera files. No need to remove anything.
    Keep Arduino library in sync with Vera files (download them at the same time).
    • ferpandoF
      ferpandoF
      ferpando
      I guess you have to reprogram all arduinos with the new code right?
      hekH 1 Reply Last reply
      • ferpandoF ferpando
        @ferpando
        Between versions where over-the-air protocol has changed, yes. But we try to only change this between major version updates.
          @ferpando
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @hek
          so, what is the 'latest' library version? Is it 1.2?
            Latest public version is 1.3b3 (xxxxxx)
            There should also be a hash value after version. We auto-update this hash value each time a library file is modified to keep track of the exact version used when someone needs support etc.
            https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/Version.h
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              so forgive me if I am being thick, but I updated the latest from the links here and here. I installed them and I still have Lib Version 1.2+?
              wrong places?
                wrong places?
                @BulldogLowell
                Those links should work fine.
                Double check the path where the Arduino libraries should be copied. Follow the guide how to locate library path on the page you linked.
                  @BulldogLowell
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @hek
                  I did that, got it in my Arduino folder, restarted the IDE, updated a device and it still shows old Lib Version.
                  I also downloaded and updated the latest Vera files.
                  So, must I recompile and upload the Gateway to show the updated version number in the the gateway and all the nodes?
                    Yes, update both gateway and nodes. If you just updated one of the nodes (and not gateway) communication might be broken thus new version for node is not showing up.
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      hmmm... I updated the gateway, with the files I just downloaded and no luck.
                      ferpandoF 1 Reply Last reply
                        ferpandoF
                        ferpandoF
                        ferpando
                        @BulldogLowell
                        Take a look at mine
                          @BulldogLowell
                          Take a look at mine
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @ferpando said:
                          @BulldogLowell
                          Take a look at mine
                          I cannot understand what is happening here
                            Check the Version.h file of your downloaded library files and assure it contains the newer version before building/uploading the sketch.
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              Now I'm more perplexed.
                              I am going to try to recompile and upload the Gateway, again.
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                • B
                                  B
                                  bluman
                                  I've just built a new Ubuntu 1404 64 bit environment and installed the Arduino IDE 1.05 as per the instructions on Arduino Playground here.
                                  I downloaded the Arduino libraries from the MySensors website and followed the guide unzipping into the sketchbook directory (/home/<myuser>/sketchbook) as detailed here.
                                  After restarting the IDE I am presented with the attached error stating that there is a problem with the Arduino libraries, bad library name.
                                  Has anyone else come across this error before?
                                  Bluman
                                  I tried moving the Arduino-master folder in to the libraries folderArduino_IDE_Lib_error.png
                                    Move the content of library folder inside "Arduino-master" into libraries.
                                    • B
                                      B
                                      bluman
                                      Thanks Henk that worked.
                                      • B
                                        B
                                        bluman
                                        OK, I've just uploaded the new plugin files to Vera and restarted, all appears to be working. The new format is now shown in the devices view.
                                        I've hit a snag when trying to compile the serial gateway sketch where it's complaining about the avr/program.h file is missing.
                                        avr/progmem.h: No such file or directory
                                        I noticed the lib directory under Arduino-Master/AVR so I attempted to copy (merge and replace) this into the sketckbook/libraries folder. Unfortunately I'm getting two additional errors relating to the RF24 and SPI libraries.
                                        In file included from /home/hp2540p/sketchbook/libraries/RF24/RF24.h:788:0,
                                        from SerialGateway.ino:26:
                                        /home/hp2540p/sketchbook/libraries/RF24/RF24.c:27:21: fatal error: spi/spi.h: No such file or directory
                                        #include <spi/spi.h>
                                        I'm not in a good place and need to understand the difference with these different library locations.
                                        If others have felt my pain, how did you resolve this issue? HELP!
                                        bluman
                                        • B
                                          B
                                          bluman
                                          OK, I started from scratch by removing all library folders under the sketchbook directory and copying over from the Arduino-master/libraries folder.
                                          Now I just see the avr/progmem.h file missing error.
                                          SerialGateway.ino:31:25: fatal error: avr/progmem.h: No such file or directory
                                          compilation terminated.
                                          I noticed it is referenced to the avr directory relative to the base sketchbook directory so I searched through the entire Arduino-master folder structure and do not see this file.
                                          Does this need to be downloaded separately from Github or have I missed a step somewhere?
                                          I'm using Unbuntu 1404 with Arduino IDE 1.05+dfsg2-2.
                                          bluman
