  3. Home Assistant
  4. mysprinkler for mysensor and home assistant not working together
18 Posts 8 Posters 5.0k Views 7 Watching
  • Johannes SchoellerJ Johannes Schoeller
    @martinhjelmare said in mysprinkler for mysensor and home assistant not working together:
    You need to send initial values for each device. That's what's missing.
    Also remove the mysensors sensor platform from your configuration yaml. That's not needed.
    thanks martin. i read that, but i have no idea how to send those initial values?
    is this something that i have to implement in the sensor's code?
    https://home-assistant.io/components/mysensors/#presentation says:
    Send at least one initial value per V_TYPE. In version 2.0 of MySensors this has to be done in the loop function.
    is it something like that?
        Serial.println("Sending initial value");
        send(msg.set(state?RELAY_ON:RELAY_OFF));
    if that is the case, i assume it's missing in the irrigation controller's code. correct?
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @johannes-schoeller
    Yes, something like that.
    I'm not familiar with the irrigation controller code. But your log is missing the output about sending values, so I assume it's missing from the sketch.
      Johannes SchoellerJ
      Johannes Schoeller
      thanks that did work. basically it worked the very next day w/o changing anything. it just did send initial values. so problem solved.
      but i have another issue. now that everything is working so far, and i see the switch automatically added in my home assistant dashboard, i can use them and click them. this is seen by the sensor and it acts appropriately.
      but how the irrigation controller is meant to be used is: it ASKS the hub for data. this data is a) time (works!) and b) duration to activate each zone on button press.
      so it has 4 irrigation zones, each of them ca be assigned 2 values, one is how long it's turned on when activated alone, and one how long it's turned on when you run all zones, one after the other.
      but i don't know how to set those values in home assistant so i can send them back to the sensor.
      this is what the sensor looks like in home assistant:
        Johannes SchoellerJ
        Johannes SchoellerJ
        Johannes Schoeller
        wrote on last edited by Johannes Schoeller
        you mean this form configuration.yaml:
        mysensors:
          gateways:
            - device: '/dev/ttyUSB0'
              baud_rate: 38400
              persistence_file: 'home/homeassistant/mysensors.json'
          optimistic: false
          persistence: true
          retain: true
          version: '2.0'
        or this from sensors.yaml:
        - platform: mysensors
            port: "/dev/ttyUSB0"
        EDIT: got is sorted out myself. NOT the configuration part is wrong, but the sensors.yaml part is too much. i removed it, and it works fine. thank you!!
          Johannes SchoellerJ
          Johannes Schoeller
          i investigated further and now i know that the sensor is requesting VAR_1 to VAR_3 and afaik this is not working with home assistant.
          any ideas how to circumvent this? i need to set the value in HA and then the sensor is requesting it. how would this be accomplished in HA?
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @johannes-schoeller
            Currently you can hack it by adding those value types and values to the JSON persistence file, keeping the structure. It's not a real solution, but should work. They will get represented as sensor entities in home assistant. If you want to avoid entity_id clashes the V_VAR1 and V_VAR3 should be placed on different children.
            I have on the roadmap to add an option for inital values in the mysensors home assistant config section.
            MadKezzaM 1 Reply Last reply
            • Darren HerdD
              Darren HerdD
              Darren Herd
              @johannes-schoeller
              hi im currently struggling with the same problem, i dont suppose you found a solution? i tried to do what martinhjelmare said but obviously i did it wrong. any help would be apreciated anyone. at the moment i have the mysprinkler for mysensor showing in home assistant and if i try start one of the relays it just goes to next relay but doesnt start. it shows on the display 0 sec and i cant find how to set how to put in time for the relays as im a noob lol. cheers
              Johannes SchoellerJ 1 Reply Last reply
              • Darren HerdD Darren Herd
                @johannes-schoeller
                Johannes SchoellerJ
                Johannes SchoellerJ
                Johannes Schoeller
                @darren-herd said in mysprinkler for mysensor and home assistant not working together:
                @johannes-schoeller
                i wish i would. i now 3d printed a case for it, got it all working so far, but can't make it announce the sensors in HA. no idea, why it worked before, and what's not working now ...
                B 1 Reply Last reply
                  @johannes-schoeller
                  B
                  B
                  bereska
                  @johannes-schoeller did you find a solution? I am struggling to add a water meter pulse sensor to HA UI. Thank you
                  • D
                    diltech
                    You can fix variable with sending data. In the firmware, you must add this function for place value in this V_VARx
                    So, place this function into your setup firmware.
                    Where in this case
                    This loop repeat for each relay (i) and you can set any value at the end (1) for one minutes and (5) for five minutes.
                    That's all.
                    void goInitiateValveTime() {
                        send(var1valve.setSensor(i).set(1));
                        wait(50);
                        send(var2valve.setSensor(i).set(5));
                      wait(50);
                      lastValve = -1;
                    Refresh Home Assistant just after run one time your script and value appear in your persistence file.
                    Regars,
                    MadKezzaM 2 Replies Last reply
                      @johannes-schoeller
                      MadKezzaM
                      MadKezzaM
                      MadKezza
                      @martinhjelmare did this get added?
                      "add an option for inital values in the mysensors home assistant config section"
                      • D diltech
                        Where in this case
                        That's all.
                            wait(50);
                          wait(50);
                          lastValve = -1;
                        Regars,
                        MadKezzaM
                        MadKezzaM
                        MadKezza
                        @diltech i need help with where to put this in my firmware
                        • D diltech
                          Where in this case
                          That's all.
                              wait(50);
                            wait(50);
                            lastValve = -1;
                          Regars,
                          MadKezzaM
                          MadKezzaM
                          MadKezza
                          @diltech for reference here is my code
                          MySprinkler for MySensors
                          Arduino Multi-Zone Sprinkler Control
                          May 31, 2015
                          *** Version 2.0
                          * LED status indicator
                          PARTS LIST:
                          * Relays (8 channel)
                          * NRF24L01 Radio
                          * Arduino (I used a Pro Mini)
                          * Capacitors (10uf and .1uf)
                          * 3.3v voltage regulator
                          * Resistors (270, 1K & 10K)
                          * Female Dupont Cables
                          * LED
                          * Push button
                          * Shift Register (SN74HC595)
                          * 18 gauge wire (for relay)
                          INSTRUCTIONS:
                            on the serial monitor.
                          // Enable debug prints
                          #define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                          #include <TimeLib.h>
                          #include <LiquidCrystal.h>
                          #define NUMBER_OF_VALVES 2  // Change this to set your valve count up to 16.
                          #define VALVE_TIMES_RELOAD 300000UL  // Change this (in milliseconds) for how often to update all valves data from the controller (Loops at value/number valves)
                                                               // ie: 300000 for 8 valves produces requests 37.5seconds with all valves updated every 5mins
                          #define SKETCH_VERSION "2.2"
                          #define CHILD_ID_SPRINKLER 0
                          #define ACTIVE_LOW // comment out this line if your relays are active high
                          // #define DEBUG_ON   // comment out to supress serial monitor output
                          #ifdef ACTIVE_LOW
                          #define ALL_VALVES_OFF 0xFFFF
                          #define ALL_VALVES_OFF 0U
                          #ifdef DEBUG_ON
                          #define SERIAL_START(x)
                          typedef enum {
                          SprinklerStates;
                          SprinklerStates lastState;
                          byte menuState = 0;
                          unsigned long menuTimer;
                          byte countDownTime = 10;
                          int allZoneTime [NUMBER_OF_VALVES + 1];
                          int valveSoloTime [NUMBER_OF_VALVES + 1];
                          int valveNumber;
                          int lastValve;
                          unsigned long startMillis;
                          const int ledPin = 5;
                          const int waterButtonPin = 3;
                          bool buttonPushed = false;
                          bool showTime = true;
                          bool clockUpdating = false;
                          bool recentUpdate = true;
                          int allVars[] = {V_VAR1, V_VAR2, V_VAR3};
                          const char *dayOfWeek[] = {
                          String valveNickName[17] = {
                          time_t lastTimeRun = 0;
                          //Setup Shift Register...
                          const int latchPin = 8;
                          const int clockPin = 4;
                          const int dataPin  = 7;
                          const int outputEnablePin = 6;
                          LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                          bool receivedInitialValue = false;
                          bool inSetup = true;
                            pinMode(latchPin, OUTPUT);
                            pinMode(clockPin, OUTPUT);
                            pinMode(dataPin, OUTPUT);
                            pinMode(ledPin, OUTPUT);
                            pinMode(outputEnablePin, OUTPUT);
                            digitalWrite (outputEnablePin, LOW);
                            attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
                            digitalWrite (ledPin, HIGH);
                            updateRelays(ALL_VALVES_OFF);
                            //delay(5000);
                            lcd.clear();
                            lcd.backlight();
                            lcd.createChar(0, clock);
                            lcd.createChar(1, raindrop);
                            delay(500);
                            if (loadState(0) == 0xFF) // EEPROM flag
                              for (int i = 0; i < 4 ; i++)
                                lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                            digitalWrite (ledPin, LOW);
                            DEBUG_PRINTLN(F("Ready..."));
                            lcd.setCursor(0, 0);
                            lcd.setCursor(15, 0);
                            lcd.write(byte(0));
                            lcd.setCursor(0, 1);
                            int clockCounter = 0;
                              requestTime();
                              wait(1000);
                              lcd.print(".");
                              clockCounter++;
                              if (clockCounter > 16)
                                lcd.clear();
                                wait(2000);
                            for (byte i = 1; i <= NUMBER_OF_VALVES; i++)
                              lcd.clear();
                              goGetValveTimes();
                            lcd.clear();
                            inSetup = false;
                              present(i, S_LIGHT);
                            updateClock();
                            updateDisplay();
                            goGetValveTimes();
                            if (buttonPushed)
                              menuTimer = millis();
                                state = ZONE_SELECT_MENU;
                                menuState = 0;
                                menuState++;
                                  menuState = 0;
                              slowToggleLED ();
                              if (state != lastState)
                                  wait(50);
                                  send(msg1valve.setSensor(i).set(false), false);
                                lcd.clear();
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                                wait(2000);
                                lastValve = -1;
                              if (lastValve != valveNumber)
                                    send(msg1valve.setSensor(i).set(true), false);
                                  wait(50);
                              lastValve = valveNumber;
                              fastToggleLed();
                                valveNumber = 1;
                                startMillis = millis();
                                valveNumber++;
                                  state = CYCLE_COMPLETE;
                                  lastValve = -1;
                                  lastTimeRun = now();
                                    wait(50);
                                  DEBUG_PRINT(F("State = "));
                                  DEBUG_PRINTLN(state);
                              fastToggleLed();
                                  wait(50);
                                DEBUG_PRINT(F("Zone: "));
                                DEBUG_PRINTLN(valveNumber);
                                fastToggleLed();
                              displayMenu();
                              lastState = state;
                          void displayMenu(void)
                            static int lastSecond;
                              lcd.clear();
                              lcd.print(F("Starting"));
                              lcd.print(F("."));
                              Serial.print(".");
                            lastSecond = thisSecond;
                              if (menuState == 0)
                                valveNumber = 1;
                                state = RUN_ALL_ZONES;
                                valveNumber = menuState;
                                state = RUN_SINGLE_ZONE;
                            lastMenuState = menuState;
                          void updateRelays(int value)
                            digitalWrite(latchPin, LOW);
                            digitalWrite(latchPin, HIGH);
                              buttonPushed = true;
                          void fastToggleLed()
                              fastLedTimer = millis ();
                          void slowToggleLED ()
                              slowLedTimer = millis ();
                            bool zoneTimeUpdate = false;
                            if (message.isAck())
                              if (message.sensor == i)
                                if (message.type == V_LIGHT)
                                  if (switchState == 0)
                                    if (i == 0)
                                      valveNumber = 1;
                                      valveNumber = i;
                                      DEBUG_PRINTLN(i);
                                  int variable1 = 5; // atoi(message.data);// RUN_ALL_ZONES time <-- this is what was added " 5; //" as the controller won't talk to the node for VAR_V -->
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(F(" = "));
                                  DEBUG_PRINTLN(variable1);
                                    allZoneTime[i] = variable1;
                                    zoneTimeUpdate = true;
                                  receivedInitialValue = true;
                                  int variable2 = 5; // atoi(message.data);// RUN_SINGLE_ZONE time <-- this is whats changed " 5; //" as the controller won't talk to the node for VAR_V -->
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(variable2);
                                    valveSoloTime[i] = variable2;
                                  if (newMessage.length() == 0)
                                    DEBUG_PRINTLN(i);
                                  if (newMessage.length() > 16)
                                    newMessage.substring(0, 16);
                                  valveNickName[i] = "";
                                  DEBUG_PRINT(F("Recieved variable3 valve: "));
                                  DEBUG_PRINT(i);
                            if (zoneTimeUpdate)
                                if (i != 0)
                                  DEBUG_PRINT(F("Zone "));
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(allZoneTime[i]);
                                  DEBUG_PRINT(F(" name: "));
                              recentUpdate = false;
                          void updateDisplay()
                            static bool displayToggle = false;
                              switch (state) {
                                case STAND_BY_ALL_OFF:
                                  fastClear();
                                  if (displayToggle)
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.print(hourFormat12());
                                    lcd.print(minute());
                                    lcd.print(month());
                                    lcd.print(day());
                                    lcd.print(F("/"));
                                    lcd.print(year() % 100);
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.setCursor(11, 1);
                                    lcd.print(day(lastTimeRun));
                                case RUN_SINGLE_ZONE:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print(F(" Zone:"));
                                    lcd.print(valveNumber);
                                    lcd.print(F(" Active"));
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                case RUN_ALL_ZONES:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print(F(" Active "));
                                    lcd.print("min");
                                    lcd.print("sec  ");
                                case CYCLE_COMPLETE:
                                  if (displayToggle)
                                    int totalTimeRan = 0;
                                    lcd.print(totalTimeRan);
                                    lcd.print(" Minutes   ");
                                default:
                                  // what of ZONE_SELECT_MENU?
                              lastUpdateTime = millis();
                            lastDisplayState = state;
                            int lastSecond = second();
                            int lastMinute = minute();
                            int lastHour = hour();
                            setTime(newTime);
                              DEBUG_PRINT(hourFormat12());
                              DEBUG_PRINT(minute());
                              DEBUG_PRINT(month());
                              DEBUG_PRINT(F("/"));
                              DEBUG_PRINT(day());
                              DEBUG_PRINTLN(year());
                              showTime = false;
                          void fastClear()
                          void updateClock()
                              lcd.write(byte(0));
                              clockUpdating = true;
                              requestTime();
                              lastVeraGetTime = millis();
                            if (loadState(0) != 0xFF)
                              saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                            for (int i = 1; i < 5; i++)
                              saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                          void goGetValveTimes()
                            static byte valveIndex = 1;
                            if (inSetup || millis() - valveUpdateTime >= VALVE_TIMES_RELOAD / NUMBER_OF_VALVES) // update each valve once every 5 mins (distributes the traffic)
                              if (inSetup) {
                                lcd.print(F(" Updating  "));
                                lcd.print(valveIndex);
                              bool flashIcon = false;
                              DEBUG_PRINT(valveIndex);
                              DEBUG_PRINTLN(F(" Data..."));
                              for (int a = 0; a < (sizeof(allVars)/sizeof(int)); a++) {
                                byte timeout = 10;
                                while (!receivedInitialValue && timeout > 0)
                                  flashIcon = !flashIcon;
                                  request(valveIndex, allVars[a]);
                                  wait(50);
                                  timeout--;
                              valveUpdateTime = millis();
                              valveIndex++;
                              if (valveIndex > NUMBER_OF_VALVES)
                                valveIndex = 1;
                          • MadKezzaM
                            MadKezzaM
                            MadKezza
                            has anyone got any ideas? has anyone read this?
                            • MadKezzaM MadKezza
                              @MadKezza this topic has been viewed 3k times.
                              • sundberg84S
                                sundberg84S
                                I have added a sollution to V_VAR problem in both my rain and power pulse meter (check these threads). As said above, Homeassistant will not give an answer to these requests if there are no value in the mysensors json file. Either add this in the hardware code or as I did, request a couple of times to make sure you get the value if there is one. Count these requests and set a upper limit, like five or ten reuqest. Once your each this limit, send the value 0 to HA and this will be updated in the json file and start from there.
                                12.5k
