  3. Home Assistant
  4. mysprinkler for mysensor and home assistant not working together
18 Posts 8 Posters 4.9k Views 7 Watching
  • Johannes SchoellerJ
    Johannes SchoellerJ
    Johannes Schoeller
    wrote on last edited by Johannes Schoeller
    first of all i must admit that i'm quite a noob. so please forgive if my questions seem stupid.
    i built the irrigation system board, and it seems to work electronically. i also built a serial gateway with the same 3.3v arduino pro mini that i used for the irrigation controller.
    the serial gateway is connected to the usb (with a serial - rs232 converter which also powers the arduino and the nrf2401 with 3.3v). i added the gateway to configuration.yaml
    mysensors:
      gateways:
        - device: '/dev/ttyUSB0'
          baud_rate: 38400
          persistence_file: 'home/homeassistant/mysensors.json'
      optimistic: false
      persistence: true
      retain: true
      version: '2.0'
    the sensor.yaml has this added:
      - platform: mysensors
        port: "/dev/ttyUSB0"
    the serial debug of the irrigation controller looks like that:
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSF:SID:OK,ID=2
    16 TSM:FPAR
    86 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    946 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    952 TSF:MSG:FPAR OK,ID=0,D=1
    2095 TSM:FPAR:OK
    2095 TSM:ID
    2097 TSM:ID:OK
    2099 TSM:UPL
    2107 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2162 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2168 TSF:MSG:PONG RECV,HP=1
    2170 TSM:UPL:OK
    2172 TSM:READY:ID=2,PAR=0,DIS=1
    2179 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2240 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2250 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2265 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2400 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2410 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:MySprinkler
    2426 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.2
    2437 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2447 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2490 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2535 TSF:MSG:SEND,2-2-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2584 TSF:MSG:SEND,2-2-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2590 MCO:REG:REQ
    2609 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2756 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2762 MCO:PIM:NODE REG=1
    2764 MCO:BGN:STP
    Initialising...
    Turning All Valves Off...
    Checking EEPROM for stored date:
    Retreiving last run time from EEPROM...
    Sensor Presentation Complete
    Ready...
    3389 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    Requesting time from Gateway:
    3467 TSF:MSG:READ,0-0-2,s=255,c=3,t=1,pt=0,l=10,sg=0:1515859257
    Time value received and updated...
    Clock updated....
    Sensor's time currently set to: 04:00pm
    1/13/2018
    Saturday
    Calling for Valve 1 Data...
    4403 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    4462 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    4526 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    4587 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:```
    there seems to be some communication between the hub and the sensor which is ok. but i don't see any mysensor sensors in home assistant and i don't understand what the log errors below mean, or how to get rid of them.
    Jan 13 14:01:13 hassbian hass[2451]: 2018-01-13 14:01:13 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=11,sg=0:MySprinkler#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [homeassistant.components.mysensors] Node update: node 2 child 255#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [homeassistant.components.mysensors] Not a child update for node 2#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] Handle queue with call <bound method SerialGateway.logic of SerialGateway>(('2;255;3;0;11;MySprinkler\n',), {}) took 0.200 seconds#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=3,sg=0:2.2#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,2-2-0,s=0,c=0,t=3,pt=0,l=0,sg=0:#0
    Jan 13 14:01:14 hassbian hass[2451]: #033[33m2018-01-13 14:01:14 WARNING (Thread-13) [mysensors] child_id 0 already exists in children of node 2, cannot add child#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:#0
    Jan 13 14:01:14 hassbian hass[2451]: #033[33m2018-01-13 14:01:14 WARNING (Thread-13) [mysensors] child_id 1 already exists in children of node 2, cannot add child#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,2-2-0,s=2,c=0,t=3,pt=0,l=0,sg=0:#0
    Jan 13 14:01:14 hassbian hass[2451]: #033[33m2018-01-13 14:01:14 WARNING (Thread-13) [mysensors] child_id 2 already exists in children of node 2, cannot add child#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,2-2-0,s=3,c=0,t=3,pt=0,l=0,sg=0:#0
    Jan 13 14:01:14 hassbian hass[2451]: #033[33m2018-01-13 14:01:14 WARNING (Thread-13) [mysensors] child_id 3 already exists in children of node 2, cannot add child#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,2-2-0,s=4,c=0,t=3,pt=0,l=0,sg=0:#0
    Jan 13 14:01:14 hassbian hass[2451]: #033[33m2018-01-13 14:01:14 WARNING (Thread-13) [mysensors] child_id 4 already exists in children of node 2, cannot add child#0
    Jan 13 14:01:14 hassbian hass[2451]: 2018-01-13 14:01:14 DEBUG (Thread-13) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2#0```
    this is my
    /home/homeassistant/mysensors.json
    {"2": {"sketch_version": "2.2", "battery_level": 0, "protocol_version": "2.1.1", "sketch_name": "MySprinkler", "children": {"0": {"id": 0, "description": "", "type": 3, "values": {}}, "1": {"id": 1, "description": "", "type": 3, "values": {}}, "2": {"id": 2, "description": "", "type": 3, "values": {}}, "3": {"id": 3, "description": "", "type": 3, "values": {}}, "4": {"id": 4, "description": "", "type": 3, "values": {}}}, "sensor_id": 2, "type": 17}}
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      You need to send initial values for each device. That's what's missing.
      Also remove the mysensors sensor platform from your configuration yaml. That's not needed.
      Johannes SchoellerJ 2 Replies Last reply
        Johannes SchoellerJ
        Johannes SchoellerJ
        Johannes Schoeller
        @martinhjelmare said in mysprinkler for mysensor and home assistant not working together:
        thanks martin. i read that, but i have no idea how to send those initial values?
        is this something that i have to implement in the sensor's code?
        https://home-assistant.io/components/mysensors/#presentation says:
        Send at least one initial value per V_TYPE. In version 2.0 of MySensors this has to be done in the loop function.
        is it something like that?
            Serial.println("Sending initial value");
            send(msg.set(state?RELAY_ON:RELAY_OFF));
        if that is the case, i assume it's missing in the irrigation controller's code. correct?
        • Johannes SchoellerJ Johannes Schoeller
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @johannes-schoeller
          Yes, something like that.
          I'm not familiar with the irrigation controller code. But your log is missing the output about sending values, so I assume it's missing from the sketch.
            Johannes SchoellerJ
            Johannes Schoeller
            thanks that did work. basically it worked the very next day w/o changing anything. it just did send initial values. so problem solved.
            but i have another issue. now that everything is working so far, and i see the switch automatically added in my home assistant dashboard, i can use them and click them. this is seen by the sensor and it acts appropriately.
            but how the irrigation controller is meant to be used is: it ASKS the hub for data. this data is a) time (works!) and b) duration to activate each zone on button press.
            so it has 4 irrigation zones, each of them ca be assigned 2 values, one is how long it's turned on when activated alone, and one how long it's turned on when you run all zones, one after the other.
            but i don't know how to set those values in home assistant so i can send them back to the sensor.
            this is what the sensor looks like in home assistant:
              Johannes SchoellerJ
              Johannes SchoellerJ
              Johannes Schoeller
              you mean this form configuration.yaml:
              mysensors:
                gateways:
                    baud_rate: 38400
                optimistic: false
                persistence: true
                retain: true
                version: '2.0'
              or this from sensors.yaml:
              EDIT: got is sorted out myself. NOT the configuration part is wrong, but the sensors.yaml part is too much. i removed it, and it works fine. thank you!!
                Johannes SchoellerJ
                Johannes Schoeller
                i investigated further and now i know that the sensor is requesting VAR_1 to VAR_3 and afaik this is not working with home assistant.
                any ideas how to circumvent this? i need to set the value in HA and then the sensor is requesting it. how would this be accomplished in HA?
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @johannes-schoeller
                  Currently you can hack it by adding those value types and values to the JSON persistence file, keeping the structure. It's not a real solution, but should work. They will get represented as sensor entities in home assistant. If you want to avoid entity_id clashes the V_VAR1 and V_VAR3 should be placed on different children.
                  I have on the roadmap to add an option for inital values in the mysensors home assistant config section.
                  MadKezzaM 1 Reply Last reply
                  • Darren HerdD
                    Darren HerdD
                    Darren Herd
                    @johannes-schoeller
                    hi im currently struggling with the same problem, i dont suppose you found a solution? i tried to do what martinhjelmare said but obviously i did it wrong. any help would be apreciated anyone. at the moment i have the mysprinkler for mysensor showing in home assistant and if i try start one of the relays it just goes to next relay but doesnt start. it shows on the display 0 sec and i cant find how to set how to put in time for the relays as im a noob lol. cheers
                    Johannes SchoellerJ 1 Reply Last reply
                    • Darren HerdD Darren Herd
                      @johannes-schoeller
                      Johannes SchoellerJ
                      Johannes SchoellerJ
                      Johannes Schoeller
                      @darren-herd said in mysprinkler for mysensor and home assistant not working together:
                      @johannes-schoeller
                      i wish i would. i now 3d printed a case for it, got it all working so far, but can't make it announce the sensors in HA. no idea, why it worked before, and what's not working now ...
                      B 1 Reply Last reply
                        @johannes-schoeller
                        B
                        B
                        bereska
                        @johannes-schoeller did you find a solution? I am struggling to add a water meter pulse sensor to HA UI. Thank you
                        • D
                          diltech
                          You can fix variable with sending data. In the firmware, you must add this function for place value in this V_VARx
                          So, place this function into your setup firmware.
                          Where in this case
                          This loop repeat for each relay (i) and you can set any value at the end (1) for one minutes and (5) for five minutes.
                          That's all.
                          void goInitiateValveTime() {
                              send(var1valve.setSensor(i).set(1));
                              wait(50);
                              send(var2valve.setSensor(i).set(5));
                            wait(50);
                            lastValve = -1;
                          Refresh Home Assistant just after run one time your script and value appear in your persistence file.
                          Regars,
                          MadKezzaM 2 Replies Last reply
                            @johannes-schoeller
                            MadKezzaM
                            MadKezzaM
                            MadKezza
                            @martinhjelmare did this get added?
                            "add an option for inital values in the mysensors home assistant config section"
                            • D diltech
                              Where in this case
                              That's all.
                                  wait(50);
                                wait(50);
                                lastValve = -1;
                              Regars,
                              MadKezzaM
                              MadKezzaM
                              MadKezza
                              @diltech i need help with where to put this in my firmware
                              • D diltech
                                Where in this case
                                That's all.
                                    wait(50);
                                  wait(50);
                                  lastValve = -1;
                                Regars,
                                MadKezzaM
                                MadKezzaM
                                MadKezza
                                @diltech for reference here is my code
                                MySprinkler for MySensors
                                Arduino Multi-Zone Sprinkler Control
                                May 31, 2015
                                *** Version 2.0
                                * LED status indicator
                                PARTS LIST:
                                * Relays (8 channel)
                                * NRF24L01 Radio
                                * Arduino (I used a Pro Mini)
                                * Capacitors (10uf and .1uf)
                                * 3.3v voltage regulator
                                * Resistors (270, 1K & 10K)
                                * Female Dupont Cables
                                * LED
                                * Push button
                                * Shift Register (SN74HC595)
                                * 18 gauge wire (for relay)
                                INSTRUCTIONS:
                                  on the serial monitor.
                                // Enable debug prints
                                #define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                                #include <TimeLib.h>
                                #include <LiquidCrystal.h>
                                #define NUMBER_OF_VALVES 2  // Change this to set your valve count up to 16.
                                #define VALVE_TIMES_RELOAD 300000UL  // Change this (in milliseconds) for how often to update all valves data from the controller (Loops at value/number valves)
        // ie: 300000 for 8 valves produces requests 37.5seconds with all valves updated every 5mins
                                #define SKETCH_VERSION "2.2"
                                #define CHILD_ID_SPRINKLER 0
                                #define ACTIVE_LOW // comment out this line if your relays are active high
                                // #define DEBUG_ON   // comment out to supress serial monitor output
                                #ifdef ACTIVE_LOW
                                #define ALL_VALVES_OFF 0xFFFF
                                #define ALL_VALVES_OFF 0U
                                #ifdef DEBUG_ON
                                #define SERIAL_START(x)
                                typedef enum {
                                SprinklerStates;
                                SprinklerStates lastState;
                                byte menuState = 0;
                                unsigned long menuTimer;
                                byte countDownTime = 10;
                                int allZoneTime [NUMBER_OF_VALVES + 1];
                                int valveSoloTime [NUMBER_OF_VALVES + 1];
                                int valveNumber;
                                int lastValve;
                                unsigned long startMillis;
                                const int ledPin = 5;
                                const int waterButtonPin = 3;
                                bool buttonPushed = false;
                                bool showTime = true;
                                bool clockUpdating = false;
                                bool recentUpdate = true;
                                int allVars[] = {V_VAR1, V_VAR2, V_VAR3};
                                const char *dayOfWeek[] = {
                                String valveNickName[17] = {
                                time_t lastTimeRun = 0;
                                //Setup Shift Register...
                                const int latchPin = 8;
                                const int clockPin = 4;
                                const int dataPin  = 7;
                                const int outputEnablePin = 6;
                                LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                                bool receivedInitialValue = false;
                                bool inSetup = true;
                                  pinMode(latchPin, OUTPUT);
                                  pinMode(clockPin, OUTPUT);
                                  pinMode(dataPin, OUTPUT);
                                  pinMode(ledPin, OUTPUT);
                                  pinMode(outputEnablePin, OUTPUT);
                                  digitalWrite (outputEnablePin, LOW);
                                  attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
                                  digitalWrite (ledPin, HIGH);
                                  updateRelays(ALL_VALVES_OFF);
                                  //delay(5000);
                                  lcd.clear();
                                  lcd.backlight();
                                  lcd.createChar(0, clock);
                                  lcd.createChar(1, raindrop);
                                  delay(500);
                                  if (loadState(0) == 0xFF) // EEPROM flag
                                    for (int i = 0; i < 4 ; i++)
                                      lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                                  digitalWrite (ledPin, LOW);
                                  DEBUG_PRINTLN(F("Ready..."));
                                  lcd.setCursor(0, 0);
                                  lcd.setCursor(15, 0);
                                  lcd.write(byte(0));
                                  lcd.setCursor(0, 1);
                                  int clockCounter = 0;
                                    requestTime();
                                    wait(1000);
                                    lcd.print(".");
                                    clockCounter++;
                                    if (clockCounter > 16)
                                      lcd.clear();
                                      wait(2000);
                                  for (byte i = 1; i <= NUMBER_OF_VALVES; i++)
                                    lcd.clear();
                                    goGetValveTimes();
                                  lcd.clear();
                                  inSetup = false;
                                    present(i, S_LIGHT);
                                  updateClock();
                                  updateDisplay();
                                  goGetValveTimes();
                                  if (buttonPushed)
                                    menuTimer = millis();
                                      state = ZONE_SELECT_MENU;
                                      menuState = 0;
                                      menuState++;
                                        menuState = 0;
                                    slowToggleLED ();
                                    if (state != lastState)
                                        wait(50);
                                        send(msg1valve.setSensor(i).set(false), false);
                                      lcd.clear();
                                      lcd.setCursor(0,0);
                                      lcd.setCursor(0,1);
                                      wait(2000);
                                      lastValve = -1;
                                    if (lastValve != valveNumber)
                                          send(msg1valve.setSensor(i).set(true), false);
                                        wait(50);
                                    lastValve = valveNumber;
                                    fastToggleLed();
                                      valveNumber = 1;
                                      startMillis = millis();
                                      valveNumber++;
                                        state = CYCLE_COMPLETE;
                                        lastValve = -1;
                                        lastTimeRun = now();
                                          wait(50);
                                        DEBUG_PRINT(F("State = "));
                                        DEBUG_PRINTLN(state);
                                    fastToggleLed();
                                        wait(50);
                                      DEBUG_PRINT(F("Zone: "));
                                      DEBUG_PRINTLN(valveNumber);
                                      fastToggleLed();
                                    displayMenu();
                                    lastState = state;
                                void displayMenu(void)
                                  static int lastSecond;
                                    lcd.clear();
                                    lcd.print(F("Starting"));
                                    lcd.print(F("."));
                                    Serial.print(".");
                                  lastSecond = thisSecond;
                                    if (menuState == 0)
                                      valveNumber = 1;
                                      state = RUN_ALL_ZONES;
                                      valveNumber = menuState;
                                      state = RUN_SINGLE_ZONE;
                                  lastMenuState = menuState;
                                void updateRelays(int value)
                                  digitalWrite(latchPin, LOW);
                                  digitalWrite(latchPin, HIGH);
                                    buttonPushed = true;
                                void fastToggleLed()
                                    fastLedTimer = millis ();
                                void slowToggleLED ()
                                    slowLedTimer = millis ();
                                  bool zoneTimeUpdate = false;
                                  if (message.isAck())
                                    if (message.sensor == i)
                                      if (message.type == V_LIGHT)
                                        if (switchState == 0)
                                          if (i == 0)
                                            valveNumber = 1;
                                            valveNumber = i;
                                            DEBUG_PRINTLN(i);
                                        int variable1 = 5; // atoi(message.data);// RUN_ALL_ZONES time <-- this is what was added " 5; //" as the controller won't talk to the node for VAR_V -->
                                        DEBUG_PRINT(i);
                                        DEBUG_PRINT(F(" = "));
                                        DEBUG_PRINTLN(variable1);
                                          allZoneTime[i] = variable1;
                                          zoneTimeUpdate = true;
                                        receivedInitialValue = true;
                                        int variable2 = 5; // atoi(message.data);// RUN_SINGLE_ZONE time <-- this is whats changed " 5; //" as the controller won't talk to the node for VAR_V -->
                                        DEBUG_PRINT(i);
                                        DEBUG_PRINTLN(variable2);
                                          valveSoloTime[i] = variable2;
                                        if (newMessage.length() == 0)
                                          DEBUG_PRINTLN(i);
                                        if (newMessage.length() > 16)
                                          newMessage.substring(0, 16);
                                        valveNickName[i] = "";
                                        DEBUG_PRINT(F("Recieved variable3 valve: "));
                                        DEBUG_PRINT(i);
                                  if (zoneTimeUpdate)
                                      if (i != 0)
                                        DEBUG_PRINT(F("Zone "));
                                        DEBUG_PRINT(i);
                                        DEBUG_PRINT(allZoneTime[i]);
                                        DEBUG_PRINT(F(" name: "));
                                    recentUpdate = false;
                                void updateDisplay()
                                  static bool displayToggle = false;
                                    switch (state) {
                                      case STAND_BY_ALL_OFF:
                                        fastClear();
                                        if (displayToggle)
                                          if (clockUpdating)
                                            lcd.write(byte(0));
                                          lcd.print(hourFormat12());
                                          lcd.print(minute());
                                          lcd.print(month());
                                          lcd.print(day());
                                          lcd.print(F("/"));
                                          lcd.print(year() % 100);
                                          if (clockUpdating)
                                            lcd.write(byte(0));
                                          lcd.setCursor(11, 1);
                                          lcd.print(day(lastTimeRun));
                                      case RUN_SINGLE_ZONE:
                                        fastClear();
                                        if (displayToggle)
                                          lcd.print(F(" Zone:"));
                                          lcd.print(valveNumber);
                                          lcd.print(F(" Active"));
                                            lcd.print("min");
                                            lcd.print("sec  ");
                                      case RUN_ALL_ZONES:
                                        fastClear();
                                        if (displayToggle)
                                          lcd.print(F(" Active "));
                                          lcd.print("min");
                                          lcd.print("sec  ");
                                      case CYCLE_COMPLETE:
                                        if (displayToggle)
                                          int totalTimeRan = 0;
                                          lcd.print(totalTimeRan);
                                          lcd.print(" Minutes   ");
                                      default:
                                        // what of ZONE_SELECT_MENU?
                                    lastUpdateTime = millis();
                                  lastDisplayState = state;
                                  int lastSecond = second();
                                  int lastMinute = minute();
                                  int lastHour = hour();
                                  setTime(newTime);
                                    DEBUG_PRINT(hourFormat12());
                                    DEBUG_PRINT(minute());
                                    DEBUG_PRINT(month());
                                    DEBUG_PRINT(F("/"));
                                    DEBUG_PRINT(day());
                                    DEBUG_PRINTLN(year());
                                    showTime = false;
                                void fastClear()
                                void updateClock()
                                    lcd.write(byte(0));
                                    clockUpdating = true;
                                    requestTime();
                                    lastVeraGetTime = millis();
                                  if (loadState(0) != 0xFF)
                                    saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                                  for (int i = 1; i < 5; i++)
                                    saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                                void goGetValveTimes()
                                  static byte valveIndex = 1;
                                  if (inSetup || millis() - valveUpdateTime >= VALVE_TIMES_RELOAD / NUMBER_OF_VALVES) // update each valve once every 5 mins (distributes the traffic)
                                    if (inSetup) {
                                      lcd.print(F(" Updating  "));
                                      lcd.print(valveIndex);
                                    bool flashIcon = false;
                                    DEBUG_PRINT(valveIndex);
                                    DEBUG_PRINTLN(F(" Data..."));
                                    for (int a = 0; a < (sizeof(allVars)/sizeof(int)); a++) {
                                      byte timeout = 10;
                                      while (!receivedInitialValue && timeout > 0)
                                        flashIcon = !flashIcon;
                                        request(valveIndex, allVars[a]);
                                        wait(50);
                                        timeout--;
                                    valveUpdateTime = millis();
                                    valveIndex++;
                                    if (valveIndex > NUMBER_OF_VALVES)
                                      valveIndex = 1;
                                • MadKezzaM
                                  MadKezzaM
                                  MadKezza
                                  has anyone got any ideas? has anyone read this?
                                  • MadKezzaM MadKezza
                                    @MadKezza this topic has been viewed 3k times.
                                    • sundberg84S
                                      sundberg84S
                                      I have added a sollution to V_VAR problem in both my rain and power pulse meter (check these threads). As said above, Homeassistant will not give an answer to these requests if there are no value in the mysensors json file. Either add this in the hardware code or as I did, request a couple of times to make sure you get the value if there is one. Count these requests and set a upper limit, like five or ten reuqest. Once your each this limit, send the value 0 to HA and this will be updated in the json file and start from there.
