  3. Handling NACKs
Handling NACKs
44 Posts 9 Posters 10.0k Views 13 Watching
  • sundberg84S sundberg84
    @BearWithBeard @karlheinz2000 - this is gold, thank you. I going to be a bit more annoying here :)
    What about doing this to a repeater?
    I have 3 main repeaters in my house. Do you know if it would be possible to catch the NACK / OK coming from all repeated messages? I guess we are talking changing in the core code?
    WOuld be awsome, to collect hourly OK and NACk and send to the controller for these three repeaters. It would indicate issues with both those three main nodes and also the network as a whole.
    BearWithBeardB
    BearWithBeardB
    BearWithBeard
    @sundberg84 Statistics are awesome, I like your thought! :+1:
    But I'm afraid that you are right: There seems to be no easy way to get TX success indicators outside of the sending node. Atleast not without changes to the library.
    You can either ...
    • verify that the parent of the sender received the message (hardware ACK), or
    • verify that the destination (generally the gateway) received the message (software ACK / echo),
    ... but not if any of the parents successfully passed the message on.
    I guess, if you really wanted to, you could use direct node-to-node communication: On your sensor node, send the message to the nearest repeater, handle the message in receive() on the repeater and send it manually to the next repeater, until you reach the gateway. Then you should have full control over monitoring hardware ACK, at the cost of having a completely static network. I don't think that's desirable though...
    • mfalkviddM
      Maybe the indication handler could be used to count transmission failures?
      • electrikE
        electrikE
        electrik
        I'm counting the send() fails and send that at intervals to the gateway as a child sensor.
        This won't work off course for repeaters so I guess @mfalkvidd's idea would do the trick.
        Or alternatively send dummy data, just to check the connection.
        • karlheinz2000K karlheinz2000
          I count in every node, if send() returns false and send the number to controller to get an idea about rf quality.
          I do not retry, because Mysensors already retries, right?
          I use NFR24 and RFM69. Behavior is sometimes strange. No NACKs for weeks and then a really high number of NACKs for a few days. Setup not changed. I have no idea why... Same for indoor and outdoor sensors.
          electrikE
          electrikE
          electrik
          @karlheinz2000 said in Handling NACKs:
          I've had similar effects and could relate this back to the gateway. I'm using an MQTT gateway and if that has Wifi connection issues, it is trying to reconnect to the network in a loop. During these retries it can't handle the NRF communication, if there are more messages than fit in the buffer.
          After solving these Wifi issues (updated the ESP32 core) and using the latest Mysensors release, things work much better.
            sundberg84S
            sundberg84S
            @mfalkvidd - do you have a pointer to where I can start, bear in mind Im a very bad coder so I need somewhere to start following the logic.
              @sundberg84 seems like it isn't very well documented, but https://forum.mysensors.org/topic/7181/what-do-the-error-led-flashes-mean/9?_=1582119986104 has some information.
              increasing a counter for every INDICATION_ERR_TX and another counter for every INDICATION_TX could be sufficient to get a good ratio of how many successful and failed transmissions there are.
              Edit: https://forum.mysensors.org/post/89230 might be better to start from
              • mfalkviddM
                Something like this should work. Not sure if a power meter is the best way to present to controller, fee free to use something better.
                #define MY_RADIO_RF24
                //#define MY_RADIO_NRF5_ESB
                //#define MY_RADIO_RFM95
                #define MY_REPEATER_FEATURE
                #define MY_INDICATION_HANDLER
                static uint32_t txOK = 0;
                static uint32_t txERR = 0;
                #define REPORT_INTERVAL 300000 // Report every 5 minutes
                #define CHILD_ID_TX_OK 1
                #define CHILD_ID_TX_ERR 2
                MyMessage txOKmsg(CHILD_ID_TX_OK, V_KWH);
                MyMessage txERRmsg(CHILD_ID_TX_ERR, V_KWH);
                void indication(indication_t ind)
                  switch (ind)
                    case INDICATION_TX:
                      txOK++;
                    case INDICATION_ERR_TX:
                      txERR++;
                  //Send the sensor node sketch version information to the gateway
                  sendSketchInfo(F("Repeater Node"), F("1.0"));
                  present(CHILD_ID_TX_OK, S_POWER);
                  present(CHILD_ID_TX_ERR, S_POWER);
                  static unsigned long last_send = 0;
                  if (millis() - last_send > REPORT_INTERVAL) {
                    send(txOKmsg.set(txOK));
                    send(txERRmsg.set(txERR));
                    last_send=millis();
                The same could probably be added to any gateway sketch.
                    switch (ind)
                      case INDICATION_TX:
                        txOK++;
                        txERR++;
                      last_send=millis();
                  sundberg84S
                  sundberg84S
                  @mfalkvidd - appreciate you time here, should have taken me hours and hours!
                    @sundberg84 you're welcome. I'm trying to add the feature to one of my gateways now (I don't have any repeaters).
                    skywatchS 1 Reply Last reply
                      skywatchS
                      skywatchS
                      skywatch
                      @mfalkvidd I won't sleep tonight now! - Can't wait to see how it works out in the 'real world' for you....
                      • skywatchS skywatch
                        #24
                        @skywatch so far it is not showing anything interesting. On the other hand, I don't think my GW will transmit anything (no nodes request anything from the controller). This is what it looks like in Domoticz:
                        I'll let it run overnight, will post an update tomorrow.
                        • mfalkviddM
                          #25
                          As expected, there have been no errors recorded. The number of TX OK per hour is constant.
                          Domoticz log file shows that the gateway reports every 5 minutes.
                          Maybe the gateway should look at INDICATION_GW_TX.
                            sundberg84S
                            sundberg84S
                            #26
                            @mfalkvidd - INDICATION_GW_TX sounds like a good plan. This is a great tool I think for the future to evaluate and debug your network. I used S_CUSTOM and a utility meter (hourly) in HA to get the values.
                            Just started up, first values in - will report back when I have more data:
                            No errors so far :)
                            Just so I understand: case INDICATION_ERR_TX: means NACK ?
                              No errors so far :)
                              @sundberg84 I think so.
                              https://github.com/mysensors/MySensors/blob/79d7977cff47555d7bc812036caa6159df9cc8c7/core/MyTransport.cpp#L560 (I've cut out some code for brevity)
                              	const bool result = transportSendWrite(route, message);
                              #if !defined(MY_GATEWAY_FEATURE)
                              	// update counter
                              	if (route == _transportConfig.parentNodeId) {
                              		if (!result) {
                              			setIndication(INDICATION_ERR_TX);
                              			_transportSM.failedUplinkTransmissions++;
                              			_transportSM.failedUplinkTransmissions = 0u;
                              	if(!result) {
                              https://github.com/mysensors/MySensors/blob/79d7977cff47555d7bc812036caa6159df9cc8c7/core/MyTransport.h#L433
                              * @brief Send message to recipient
                              * @param to Recipient of message
                              * @param message
                              * @return true if message sent successfully
                              I guess we could use _transportSM.failedUplinkTransmissions instead of using our own counter.
                              • electrikE
                                electrikE
                                electrik
                                @mfalkvidd said in Handling NACKs:
                                That one is reset when a message is sent successfully, and we want to know the total number of failed msgs right?
                                • electrikE electrik
                                  @electrik I see. Good point.
                                    sundberg84S
                                    sundberg84S
                                    Something strange happened last hour:
                                    But atleast now I know something is up.
                                    skywatchS mfalkviddM 2 Replies Last reply
                                      skywatchS
                                      skywatchS
                                      skywatch
                                      @sundberg84 said in Handling NACKs:
                                      @sundberg84 - OMG, I have sat through whole flims with less suspense than this thread! ......
                                        @sundberg84 that's a very nice visual representation. Could you share how you set that up in HA?
                                          sundberg84S
                                          sundberg84S
                                          @mfalkvidd - its accually Grafana and Influx database. So HA sends values to Influx which are visually presented in Grafana. Im sure you can do this from Domoticz as well... there are some limitations in Influx db so I might change to another database in the future which suits me better.
                                          12.5k
