  3. Handling NACKs
Handling NACKs
44 Posts 9 Posters 9.7k Views 13 Watching
  • mfalkviddM
    #25
    As expected, there have been no errors recorded. The number of TX OK per hour is constant.
    Domoticz log file shows that the gateway reports every 5 minutes.
    Maybe the gateway should look at INDICATION_GW_TX.
      sundberg84S
      sundberg84S
      #26
      @mfalkvidd - INDICATION_GW_TX sounds like a good plan. This is a great tool I think for the future to evaluate and debug your network. I used S_CUSTOM and a utility meter (hourly) in HA to get the values.
      Just started up, first values in - will report back when I have more data:
      No errors so far :)
      Just so I understand: case INDICATION_ERR_TX: means NACK ?
      • sundberg84S sundberg84
        No errors so far :)
        @sundberg84 I think so.
        https://github.com/mysensors/MySensors/blob/79d7977cff47555d7bc812036caa6159df9cc8c7/core/MyTransport.cpp#L560 (I've cut out some code for brevity)
        	const bool result = transportSendWrite(route, message);
        #if !defined(MY_GATEWAY_FEATURE)
        	// update counter
        	if (route == _transportConfig.parentNodeId) {
        		if (!result) {
        			setIndication(INDICATION_ERR_TX);
        			_transportSM.failedUplinkTransmissions++;
        			_transportSM.failedUplinkTransmissions = 0u;
        	if(!result) {
        https://github.com/mysensors/MySensors/blob/79d7977cff47555d7bc812036caa6159df9cc8c7/core/MyTransport.h#L433
        * @brief Send message to recipient
        * @param to Recipient of message
        * @param message
        * @return true if message sent successfully
        I guess we could use _transportSM.failedUplinkTransmissions instead of using our own counter.
        • electrikE
          electrikE
          electrik
          @mfalkvidd said in Handling NACKs:
          That one is reset when a message is sent successfully, and we want to know the total number of failed msgs right?
          • electrikE electrik
            @electrik I see. Good point.
              sundberg84S
              sundberg84S
              Something strange happened last hour:
              But atleast now I know something is up.
              skywatchS mfalkviddM 2 Replies Last reply
                skywatchS
                skywatchS
                skywatch
                @sundberg84 said in Handling NACKs:
                @sundberg84 - OMG, I have sat through whole flims with less suspense than this thread! ......
                  @sundberg84 that's a very nice visual representation. Could you share how you set that up in HA?
                    sundberg84S
                    sundberg84S
                    @mfalkvidd - its accually Grafana and Influx database. So HA sends values to Influx which are visually presented in Grafana. Im sure you can do this from Domoticz as well... there are some limitations in Influx db so I might change to another database in the future which suits me better.
                      @sundberg84 sorry for going off topic, but what limitations have you experienced?
                      I've been thinking about using something better than Domoticz for a long time. Maybe Grafana is the way to go.
                      BearWithBeardB sundberg84S 2 Replies Last reply
                        BearWithBeardB
                        BearWithBeardB
                        BearWithBeard
                        wrote on last edited by BearWithBeard
                        #35
                        @mfalkvidd Domoticz is a full-blown home automation system, isn't it? Grafana is just a monitoring dashboard that pulls data from a time-series database (like InfluxDB) and generates fancy graphs. It can't automate and control things or send commands other than alarms (eg. if a value exceeds a threshold, or no new data came in since x minutes, send an email).
                        One of InfluxDBs limitations is that you can't use (or only some basic) math operations on db queries, which may limit what you can graph in Grafana. Also, changing data types of existing fields in measurements is also not possible, which is annoying, because Grafana treats values differently based on their data type. @sundberg84 can probably name more limitations. I'd love to switch to Carbon / Graphite for data collection and storage... if only it wouldn't take time to read up, setup and migrate all the data. :tired_face:
                        By the way - great idea to use the indication handler to log radio reliability! :+1: Definitely going to implement this on my gateways repeaters when I find the time.
                          sundberg84S
                          sundberg84S
                          #36
                          @mfalkvidd - @BearWithBeard said it. The limitations are mostly math related. For example, you cant show a graph with current and last years values (timeshift) on the same graph due to that limitation in InfluxDB. I want to compare power usage this day to same day last year - not possible. Im looking to change to Graphite as well instead of Influx.
                          Moving from Domoticz to HA was a great move for me, but not as i thought. Im using HA more or less just as an umbrella. I would say im using only the OS Hass.IO and not using Home Assistant that much. Whats good in Home Assistant is that its quite easy to integrate different protocolls like MySensors or whatever you use. But after that I dont use Home Assistant but the great possibilities to have add-ons on Hass.IO. I use Node Red for all my automations (Extremly easy compared to code!), Influx + Grafana for visual, motionEyeOs for camera secutiry and more... all you have to do is install the addon from the "store" and you are more or less ready to go. These addons im sure you can install with domoticz as well if you like the integrations with the different protocolls there.
                          i think we have handeled the NACK questions so no worries for me if we go off topic, but if you rather like send me a dm.
                          • sundberg84S
                            sundberg84S
                            I just love this idea. Implemented the code on my second now, one to go.
                              @sundberg84 very nice. I'm happy we were able to implement it with so little effort. What does your graph look like now?
                              Mine is very boring, as I suspected. Don't have any outgoing traffic from my GW. Will have to add it to my nodes to get any useful data.
                                sundberg84S
                                sundberg84S
                                #39
                                @mfalkvidd i didnt fins time yet to implement more. But very good for two repeaters.
                                E 1 Reply Last reply
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  Very cool stuff.
                                  @mfalkvidd Would it be possible to create the functionality, but to measure the successrate of outgoing messages from the gateway node?
                                  For example, I'l love to be able to see how often the controller/gateway tries to toggle a distant node, but fails.
                                  • alowhumA alowhum
                                    Very cool stuff.
                                    @alowhum unless I misunderstand your suggestion, that's exactly what I have already done.
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      Ah, now I see. Thanks!
                                        E
                                        E
                                        evb
                                        @sundberg84 If I get it correct you implemented in your repeater sketch the use of the MySensors indication handler?
                                        void indication(indication_t ind)
                                          switch (ind)
                                            case INDICATION_TX:
                                              txOK++;
                                              txERR++;
                                        txOk and txErr are always incremented in the sketch and send to the gateway.
                                        Yet I see in your graphs a hourly count? Graphs from Grafana?
                                        Can you explain how you did this?
                                        • sundberg84S
                                          sundberg84S
                                          @evb - yes, that is correct, here is a complete sketch with a GW (Nrf24 - ethernet)
                                          #define MY_GATEWAY_W5100
                                          // radio on the same spi bus.
                                          #define MY_SOFTSPI
                                          #ifndef MY_RF24_CE_PIN
                                          #define MY_RF24_CE_PIN 5
                                          #ifndef MY_RF24_CS_PIN
                                          #define MY_RF24_CS_PIN 6
                                          #define MY_IP_ADDRESS 192,168,1,8   // If this is disabled, DHCP is used to retrieve address
                                          #define MY_PORT 5003
                                          #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0x01, 0x08 //AF-A0-F2-15-3B-1C
                                          // Set blinking period
                                          // Enable inclusion mode
                                          #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                                          #define MY_DEFAULT_RX_LED_PIN  9  // Receive led pin
                                          #define MY_DEFAULT_TX_LED_PIN  8  // the PCB, on board LED
                                          #define MY_INDICATION_HANDLER
                                          static uint32_t txOK = 0;
                                          static uint32_t txERR = 0;
                                          #define REPORT_INTERVAL 300000 // Report every 5 minutes
                                          #define CHILD_ID_TX_OK 0
                                          #define CHILD_ID_TX_ERR 1
                                          #if defined(MY_USE_UDP)
                                          #include <EthernetUdp.h>
                                          #include <Ethernet.h>
                                          MyMessage txOKmsg(CHILD_ID_TX_OK, V_CUSTOM);
                                          MyMessage txERRmsg(CHILD_ID_TX_ERR, V_CUSTOM);
                                            switch (ind)
                                              case INDICATION_TX:
                                                txOK++;
                                                txERR++;
                                            //Send the sensor node sketch version information to the gateway
                                            sendSketchInfo("Gateway #1", "1.0");
                                            present(CHILD_ID_TX_OK, S_CUSTOM);
                                            present(CHILD_ID_TX_ERR, S_CUSTOM);
                                            static unsigned long last_send = 0;
                                            if (millis() - last_send > REPORT_INTERVAL) {
                                              send(txOKmsg.set(txOK));
                                              send(txERRmsg.set(txERR));
                                              last_send = millis();
                                          In Home Assistant you need to create a sensor that breaks down the incrementing number to each intervall you want.
                                          I use a utility_meter.
                                          utility_meter:
                                          hourly_ok_gw:
                                              source: sensor.gateway_1_0_0
                                              cycle: hourly
                                            hourly_err_gw:
                                              source: sensor.gateway_1_0_1
                                              cycle: hourly
                                          This sensors will be sent to Grafana each hour just like any other sensor and you can create a graph there:
